Z-Tool 2.0 Script Load fail
Hi there,
I tried to load a script from the Z-tool script window and I got below error:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.MissingMethodException: Method not found: 'System.String System.Windows.Forms.OpenFileDialog.get_SafeFileName()'.
at TI.ZTool.FormScript.menuItemLoad_Click(Object sender, EventArgs e)
at System.Windows.Forms.MenuItem.OnClick(EventArgs e)
at System.Windows.Forms.MenuItem.MenuItemData.Execute()
at System.Windows.Forms.Command.Invoke()
at System.Windows.Forms.Command.DispatchID(Int32 id)
at System.Windows.Forms.Control.WmCommand(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///E:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Z-Tool
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Texas%20Instruments/ZStack-CC2530-2.5.1a/Tools/Z-Tool/Z-Tool%202.0.exe
CodeBase: file:///E:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///E:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///E:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
CodeBase: file:///E:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///E:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
TI.ZPortLib
Assembly Version: 0.0.3.0
Win32 Version: 0.0.3.0
CodeBase: file:///C:/Texas%20Instruments/ZStack-CC2530-2.5.1a/Tools/Z-Tool/TI.ZPortLib.DLL
TI.ZPI
Assembly Version: 1.0.1.0
Win32 Version:
CodeBase: file:///C:/Texas%20Instruments/ZStack-CC2530-2.5.1a/Tools/Z-Tool/TI.ZPI.DLL
TI.ZCmdMatchings
Win32 Version:
CodeBase: file:///C:/Texas%20Instruments/ZStack-CC2530-2.5.1a/Tools/Z-Tool/TI.ZCmdMatchings.DLL
TI.ZScript
Assembly Version: 1.0.4336.15295
Win32 Version: 1.0.4336.15295
CodeBase: file:///C:/Texas%20Instruments/ZStack-CC2530-2.5.1a/Tools/Z-Tool/TI.ZScript.DLL
TI.CommonLib
CodeBase: file:///C:/Texas%20Instruments/ZStack-CC2530-2.5.1a/Tools/Z-Tool/TI.CommonLib.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Any help is welcome.
  • Okay, found the problem by myself.
    I have MS .net 1.1, 2.0 and 4.0 installed for some reason.
    I uninstalled all of them, and then installed the .net 4.0, but Z-Tool can not even start.
    Then I installed the .net 2.0Sp2. After that, everything goes well.
  • Hi, in my case  z-tool works well but when I try to execute SAMPLE jscript shows several errors
    Error: Declaration expected.
    File: C:\Texas Instruments\ZStack-1.4.3-1.2.0\Tools\Z-Tool\Sample.js
    Line: 1
    Source: import System;
    Line: 1
    Source: import TI.ZPI1;
    *** COMPILE TIME ERROR **
    SOMEONE know the origin of these ERRORS?
