How I can send a temperature measurement from coordinator to the end device and that It is printed on the LCD enddevice, what is the code for this?
Shipping Temperature: coordinating end device
Hi David,
the easiest way to do this is to load the "Genericapp" sample from of Zstack. Please check out for the same. A string called "hello world" is transmitted there instead of your temperature values, and you should modify a little so that you can transmit them and display them on LED.
By the way, you havent mentioned, on what target you are working on.
Vidya.
