How to shutdown coordinator/router?
Other Parts Discussed in Thread: CC2530, Z-STACK
How to shutdown coordinator/router? How to do it?
I need to turn off the only ZigBee part in router or coordinator.  Other tasks must continue to work. Also, after a few hours I need again turn on ZigBee part in CC2530.
    What is the purpose of such a brute move?
    You need the coordinator/router to halt from participating in routing tasks of particular ZigBee network,
    or is it just for allocating all the CPU time to your task/application only?
  • "What is the purpose of such a brute move?"
    ZigBee transceiver consumes a lot of energy.
    "You need the coordinator/router to halt from participating in routing tasks of particular ZigBee network,
    or is it just for allocating all the CPU time to your task/application only?"
    ???? Z-Stack is working with OSAL (very very bad cooperative OS).  CPU time always enough.
    So in other words you want a battery powered coordinator/router?
    I think it is possible to compile router/cooridnator with ZED options. I remember someone
    already asked about this option in the forum before. If I find this discussion, I'll post a link to it.
    The other major issue is to know when, or on what event, to wake up this sleeping beauty
    with regard to other ZRs/ZEDs in the ZigBee network and let it to participate in routing tasks
    again.
  • Hi Andrey,
    I'm getting back to you with a link. This is the most informative thread I have found,
    let me know if it helps you.
  • I think I found a solution
    Shutdown ZigBee task
    nwk_setStateIdle( TRUE );
    // turn MAC receiver off
    unsigned char rxOnIdle = false;
    ZMacSetReq( ZMacRxOnIdle, &rxOnIdle );
    Turn on ZigBee task
    rxOnIdle = true;
    // set NWK task to run
    nwk_setStateIdle( FALSE );
    It's strange that there is no such function.
     At night, I do not need a ZigBee network. But the devices should work.
