Dear TI,
As we know for addscene command and enhancedAddScene command we use the below structure
uint16 groupID; // The group ID for which this scene applies
uint8 ID; // Scene ID
uint16 transTime; // Time to take to transition to this scene
uint16 transTime100ms; // Together with transTime, this allows transition time to be specified in 1/10s
uint8 name[ZCL_GEN_SCENE_NAME_LEN]; // Scene name
uint8 extLen; // Length of extension fields
uint8 extField[ZCL_GEN_SCENE_EXT_LEN]; // Extension fields
There is a difference between the AddScene and EnhancedAddScene.
In the AddScene, the extLen will be
// The length of the extension field(s) is 17:
// 2 + 1 + 1 for On/Off cluster (onOff attibute)
// 2 + 1 + 1 for Level Control cluster (currentLevel attribute)
// 2 + 1 + 6 for Color Control cluster (CurrentHue/CurrentSaturation/currentX/currentY
In the EnhancedAddScene, the extLen will be
// The length of the extension field(s) is 23:
// 2 + 1 + 12 for Color Control cluster (CurrentHue/CurrentSaturation/currentX/currentY/EnhancedCurrentHue/colorLoopActive/colorLoopDirection/colorLoopTime attributes)
Once we send the AddScene Command (after assigning Groupid ,sceneid,hue value ,saturation value ,current x and current y value) and press scene recall command in the remote. we wont be able to see the change in the sample light color.
when we step thru the sample light code. we find that the
static void zllSampleLight_SceneRecallCB( zclSceneReq_t *pReq )
else if ( clusterID == ZCL_CLUSTER_ID_LIGHTING_COLOR_CONTROL )
if ( len == 12 )// Update currentX and currentY attributes with the recalled values
#ifdef ZCL_COLOR_CTRL
uint8 newCurrentHue, newCurrentSaturation;
uint16 newCurrentX, newCurrentY, newEnhancedCurrentHue;
zclCCColorLoopSet_t newColorLoopSetCmd = {0};
newCurrentHue = *pExt++;
newCurrentSaturation = *pExt++;
newCurrentX = BUILD_UINT16( pExt[0], pExt[1] );
pExt += 2;
newCurrentY = BUILD_UINT16( pExt[0], pExt[1] );
pExt += 2;
The above code only works for enhancedAddScene. It wont work for AddScene.
we need to check for len == 6 to cover the AddScene scenario
if( len == 6)//--laksh bug fix TI for add_scene extension field.
uint16 newCurrentX, newCurrentY;
pExt += 2;
pExt += 2;
if ( zclColor_ColorMode == COLOR_MODE_CURRENT_HUE_SATURATION )
zclCCMoveToHueAndSaturation_t cmd;
cmd.hue = newCurrentHue;
cmd.saturation = newCurrentSaturation;
cmd.transitionTime = 0; //0 for now, need to use transition time
zclColor_MoveToHueAndSaturationCB( &cmd );
//restore x,y attributes values
zclColor_CurrentX = newCurrentX;
zclColor_CurrentY = newCurrentY;
else
zclCCMoveToColor_t colorCmd;
colorCmd.colorX = newCurrentX;
colorCmd.colorY = newCurrentY;
colorCmd.transitionTime = 0; //0 for now, need to use transition time
zclColor_MoveToColorCB( &colorCmd ); //restore hue,sat attributes values
zclColor_CurrentHue = newCurrentHue;
zclColor_CurrentSaturation = newCurrentSaturation;
#endif
else if ( len == 12 )// Update currentX and currentY attributes with the recalled values
pExt += 2;
}//static void zllSampleLight_SceneRecallCB( zclSceneReq_t *pReq )
Even this fix is applicable only for Addscene with 2 + 1 + 6 for Color Control cluster (CurrentHue/CurrentSaturation/currentX/currentY.
but according to the spec . we may get
2 + 1 + 1 for Color Control cluster (CurrentHue)
2 + 1 + 2 for Color Control cluster (CurrentHue/CurrentSaturation)
2 + 1 + 4 for Color Control cluster (CurrentHue/CurrentSaturation/currentX/)
Need to cover all the scenario's in recallscene something like
switch(len)
case 1: //CurrentHue
break;
case 2: //CurrentHue/CurrentSaturation
break;
case 4:// CurrentHue/CurrentSaturation/currentX
break;
case 6://CurrentHue/CurrentSaturation/currentX/currentY
break;
case 8:
break;
case 10:
break
case 12://CurrentHue/CurrentSaturation/currentX/currentY/colorLoopActive/colorLoopDirection/colorLoopTime attributes
break;
From the cluster library spec "
Extension field sets = {{ClusterID 1, length 1, {extension field set 1}}, {ClusterID 2, length 2, {extension field set 2}}, ... }. The attributes included in the extension field set for each cluster are defined in the specification for that cluster in this document (the ZigBee Cluster Library). The field set consists of values for these attributes concatenated together, in the order given in the cluster specification, with no attribute identifiers or data type indicators. For forward compatibility, reception of this command shall allow for the possible future addition of other attributes to the trailing ends of the lists given in the cluster specifications (by ignoring them). Similarly, it shall allow for one or more attributes to be omitted from the trailing ends of these lists (see 3.7.2.4.6.2).
Please correct me if i am wrong. kindly confirm the fix.
Thanks and Regards
Lakshman,PMP,PMI-RMP
