slotted csma/ca backoff period boundary
Other Parts Discussed in Thread: TIMAC
how to set/update csma/ca backoff period boundary in TI MAC code for slotted csma/ca
  • Please look at "TIMAC x.x.x\Documents\API\802.15.4 MAC API.pdf" section "5.2.5 Get and Set Attributes". You should use the MAC_MIN_BE and MAC_MAX_BE attributes to control the backoff period, which will be a random value between:
    [0 – (2^Be)-1]*320uS
    Where Be = MinBe for the first backoff and increasing by 1 up to MaxBe for each consecutive backoff.
    Regards, TC.
  • my question is how to check whether slotted csma/ca is properly working or not ????
  • Yes this is working in beacon enabled networks. You will need to modify the MSA (MAC Sample App). This is described in Section "4.6 Start the device as a beacon network Pan Coordinator" and  Section "4.9 Start the device as a beacon network End Device with direct messaging support" of "Mac Sample Application - Software Design.pdf". Section "8.3 Beacon-enabled network Scan and Sync" of 802.15.4 MAC API.pdf may also be useful.
    Regards, TC.
