will timac protocol stack work with accelerometer sensor
Other Parts Discussed in Thread: TIMAC, CC2530, CC2538
hi,
i want to access accelerometer sensor data using TIMAC and transmit .the frequency range of accelerometer  sensor  is 0.15hz to 1000hz.
will TIMAC work with accelerometer sensor with the above given range of frequencies.
i have seen that the TIMAC comes with code for temperature sensor access.
is it feasible to access accelerometer sensor data also.if yes how.what are the required settings?
plz suggest .
thank you.
  • Hi Pratap
    Yes, it should be possible to interface an accelerometer with CC2530 or CC2538, etc running TIMAC, collect the motion information and send it over the air.
    What accelerometer device are you using, what is the part number so that I can look for the datasheet? Which will help to help you.
  • hi Suyash,
    Thank you for clearing my doubt.
    I am using accelerometer sensor,ICP,SEISMIC,Model NO: 393B12,
    It is having frequency range of 0.15Hz to 1000Hz..
    Actually i have successfully interfaced the above mentioned sensor with TIMA,and i am able to transfer the sensor data,but when i pass a sine wave using function generator instead of sensor data,i am not able to reproduce the sine wave at the receiver side.i am using the same settings as for sensor.
    i am attaching the accelerometer sensor datasheet5621.393B12.pdf
    and also the code which i am trying
      Filename:       msa.c
      Revised:        $Date: 2013-02-25 14:58:47 -0800 (Mon, 25 Feb 2013) $
      Revision:       $Revision: 33292 $
      Description:    This file contains the sample application that can be use to test
                      the functionality of the MAC, HAL and low level.
      Copyright 2006-2013 Texas Instruments Incorporated. All rights reserved.
      IMPORTANT: Your use of this Software is limited to those specific rights
      granted under the terms of a software license agreement between the user
      who downloaded the software, his/her employer (which must be your employer)
      and Texas Instruments Incorporated (the "License").  You may not use this
      Software unless you agree to abide by the terms of the License. The License
      limits your use, and you acknowledge, that the Software may not be modified,
      copied or distributed unless embedded on a Texas Instruments microcontroller
      or used solely and exclusively in conjunction with a Texas Instruments radio
      frequency transceiver, which is integrated into your product.  Other than for
      the foregoing purpose, you may not use, reproduce, copy, prepare derivative
      works of, modify, distribute, perform, display or sell this Software and/or
      its documentation for any purpose.
      YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
      PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
      INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
      NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
      TEXAS INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT,
      NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
      LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
      INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
      OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
      OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
      (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
      Should you have any questions regarding your right to use this Software,
      contact Texas Instruments Incorporated at www.TI.com.
        Description:
                                    KEY UP (or S1)
                                  - Non Beacon
                                  - First board in the network will be setup as the coordinator
                                  - Any board after the first one will be setup as the device
              KEY LEFT               |      KEY RIGHT(or S2)
                                 ----+----- - Start transmitting
                                    KEY DOWN
     *                                           Includes
    /* Hal Driver includes */
    #include "hal_types.h"
    #include "hal_key.h"
    #include "hal_timer.h"
    #include "hal_drivers.h"
    #include "hal_led.h"
    #include "hal_adc.h"
    #include "hal_lcd.h"
    #include<stdio.h>
    #include<string.h>
    /* OS includes */
    #include "OSAL.h"
    #include "OSAL_Tasks.h"
    #include "OSAL_PwrMgr.h"
    /* Application Includes */
    #include "OnBoard.h"
    /* For Random numbers */
    #include "mac_radio_defs.h"
    /* MAC Application Interface */
    #include "mac_api.h"
    #include "mac_main.h"
    #ifdef FEATURE_MAC_SECURITY
    #include "mac_spec.h"
    /* MAC Sceurity */
    #include "mac_security_pib.h"
    #include "mac_security.h"
    #endif /* FEATURE_MAC_SECURITY */
    /* Application */
    #include "msa.h"
     *                                           Constant
    #define MSA_DEV_SHORT_ADDR        0x0000        /* Device initial short address - This will change after association */
    #define MSA_HEADER_LENGTH         4             /* Header includes DataLength + DeviceShortAddr + Sequence */
    #define MSA_ECHO_LENGTH           8          /* Echo packet */
    #define MSA_MAC_MAX_RESULTS       5             /* Maximun number of scan result that will be accepted */
    #define MSA_MAX_DEVICE_NUM        50            /* Maximun number of devices can associate with the coordinator */
    #if defined (HAL_BOARD_CC2420DB)
      #define MSA_HAL_ADC_CHANNEL     HAL_ADC_CHANNEL_0             /* AVR - Channel 0 and Resolution 10 */
      #define MSA_HAL_ADC_RESOLUTION  HAL_ADC_RESOLUTION_10
    #elif defined (HAL_BOARD_DZ1611) || defined (HAL_BOARD_DZ1612) || defined (HAL_BOARD_DRFG4618) || defined (HAL_BOARD_F2618)
      #define MSA_HAL_ADC_CHANNEL     HAL_ADC_CHANNEL_0             /* DZ1611 and DZ1612 - Channel 0 and Resolution 12 */
      #define MSA_HAL_ADC_RESOLUTION  HAL_ADC_RESOLUTION_12
    #else
      #define MSA_HAL_ADC_CHANNEL     HAL_ADC_CHANNEL_7             /* CC2430 EB & DB - Channel 7 and Resolution 14 */
      #define MSA_HAL_ADC_RESOLUTION  HAL_ADC_RESOLUTION_14
    #endif
    #define MSA_EBR_PERMITJOINING    TRUE
    #define MSA_EBR_LINKQUALITY      1
    #define MSA_EBR_PERCENTFILTER    0xFF
    /* Size table for MAC structures */
    const CODE uint8 msa_cbackSizeTable [] =
      0,                                   /* unused */
      sizeof(macMlmeAssociateInd_t),       /* MAC_MLME_ASSOCIATE_IND */
      sizeof(macMlmeAssociateCnf_t),       /* MAC_MLME_ASSOCIATE_CNF */
      sizeof(macMlmeDisassociateInd_t),    /* MAC_MLME_DISASSOCIATE_IND */
      sizeof(macMlmeDisassociateCnf_t),    /* MAC_MLME_DISASSOCIATE_CNF */
      sizeof(macMlmeBeaconNotifyInd_t),    /* MAC_MLME_BEACON_NOTIFY_IND */
      sizeof(macMlmeOrphanInd_t),          /* MAC_MLME_ORPHAN_IND */
      sizeof(macMlmeScanCnf_t),            /* MAC_MLME_SCAN_CNF */
      sizeof(macMlmeStartCnf_t),           /* MAC_MLME_START_CNF */
      sizeof(macMlmeSyncLossInd_t),        /* MAC_MLME_SYNC_LOSS_IND */
      sizeof(macMlmePollCnf_t),            /* MAC_MLME_POLL_CNF */
      sizeof(macMlmeCommStatusInd_t),      /* MAC_MLME_COMM_STATUS_IND */
      sizeof(macMcpsDataCnf_t),            /* MAC_MCPS_DATA_CNF */
      sizeof(macMcpsDataInd_t),            /* MAC_MCPS_DATA_IND */
      sizeof(macMcpsPurgeCnf_t),           /* MAC_MCPS_PURGE_CNF */
      sizeof(macEventHdr_t),               /* MAC_PWR_ON_CNF */
      sizeof(macMlmePollInd_t)             /* MAC_MLME_POLL_IND */
     *                                        Local Variables
    char sensbuffer[100];
    static int8 SavedADC12MEM1;           //To store ADC outputs
    int8 store;
    int8 x_new,res,res1;
    float values,rcvd;
    float factor=0.000714285714;
      Extended address of the device, for coordinator, it will be msa_ExtAddr1
      For any device, it will be msa_ExtAddr2 with the last 2 bytes from a ADC read
    sAddrExt_t    msa_ExtAddr;
    sAddrExt_t    msa_ExtAddr1 = {0x11, 0x22, 0x33, 0x44, 0x55, 0x66, 0x77, 0x88};
    sAddrExt_t    msa_ExtAddr2 = {0xA0, 0xB0, 0xC0, 0xD0, 0xE0, 0xF0, 0x00, 0x00};
    /* Coordinator and Device information */
    uint16        msa_PanId = MSA_PAN_ID;
    uint16        msa_CoordShortAddr = MSA_COORD_SHORT_ADDR;
    uint16        msa_DevShortAddr   = MSA_DEV_SHORT_ADDR;
      List of short addresses that the coordinator will use
      to assign to each the device that associates to it
    uint16        msa_DevShortAddrList[] = {0x0001, 0x0002, 0x0003, 0x0004, 0x0005,
                                            0x0006, 0x0007, 0x0008, 0x0009, 0x000A,
                                            0x000B, 0x000C, 0x000D, 0x000E, 0x000F,
                                            0x0010, 0x0011, 0x0012, 0x0013, 0x0014,
                                            0x0015, 0x0016, 0x0017, 0x0018, 0x0019,
                                            0x001A, 0x001B, 0x001C, 0x001D, 0x001E,
                                            0x001F, 0x0020, 0x0021, 0x0022, 0x0023,
                                            0x0024, 0x0025, 0x0026, 0x0027, 0x0028,
                                            0x0029, 0x002A, 0x002B, 0x002C, 0x002D,
                                            0x002E, 0x002F, 0x0030, 0x0031, 0x0032};
    /* Current number of devices associated to the coordinator */
    uint8         msa_NumOfDevices = 0;
      /* Current number of devices (including coordinator) communicating to this device */
      uint8       msa_NumOfSecuredDevices = 0;
    /* Predefined packet that will be sent out by the coordinator */
    uint8        msa_Data1[MSA_PACKET_LENGTH];
    /* Predefined packet that will be sent back to the coordinator by the device */
    uint8         msa_Data2[MSA_ECHO_LENGTH];
    /* TRUE and FALSE value */
    bool          msa_MACTrue = TRUE;
    bool          msa_MACFalse = FALSE;
    /* Beacon payload, this is used to determine if the device is not zigbee device */
    uint8         msa_BeaconPayload[] = {0x22, 0x33, 0x44};
    uint8         msa_BeaconPayloadLen = 3;
    /* Contains pan descriptor results from scan */
    macPanDesc_t  msa_PanDesc[MSA_MAC_MAX_RESULTS];
    /* flags used in the application */
    bool          msa_IsCoordinator  = FALSE;   /* True if the device is started as a Pan Coordinate */
    bool          msa_IsStarted      = FALSE;   /* True if the device started, either as Pan Coordinator or device */
    bool          msa_IsSampleBeacon = FALSE;   /* True if the beacon payload match with the predefined */
    bool          msa_IsDirectMsg    = FALSE;   /* True if the messages will be sent as direct messages */
    uint8         msa_State = MSA_IDLE_STATE;   /* Either IDLE state or SEND state */
    /* Structure that used for association request */
    macMlmeAssociateReq_t msa_AssociateReq;
    /* Structure that used for association response */
    macMlmeAssociateRsp_t msa_AssociateRsp;
    /* Structure that contains information about the device that associates with the coordinator */
    typedef struct
      uint16 devShortAddr;
      uint8  isDirectMsg;
    }msa_DeviceInfo_t;
    /* Array contains the information of the devices */
    static msa_DeviceInfo_t msa_DeviceRecord[MSA_MAX_DEVICE_NUM];
    uint8 msa_SuperFrameOrder;
    uint8 msa_BeaconOrder;
    /* Task ID */
    uint8 MSA_TaskId;
     *                                  MAC security related constants
    #define MSA_KEY_TABLE_ENTRIES         1
    #define MSA_KEY_ID_LOOKUP_ENTRIES     1
    #define MSA_KEY_DEVICE_TABLE_ENTRIES  8
    #define MSA_KEY_USAGE_TABLE_ENTRIES   1
    #define MSA_DEVICE_TABLE_ENTRIES      0 /* can grow up to MAX_DEVICE_TABLE_ENTRIES */
    #define MSA_SECURITY_LEVEL_ENTRIES    1
    #define MSA_MAC_SEC_LEVEL             MAC_SEC_LEVEL_ENC_MIC_32
    #define MSA_MAC_KEY_ID_MODE           MAC_KEY_ID_MODE_1
    #define MSA_MAC_KEY_SOURCE            {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}
    #define MSA_MAC_DEFAULT_KEY_SOURCE    {0x33, 0x33, 0x33, 0x33, 0x33, 0x33, 0x33, 0x33}
    #define MSA_MAC_KEY_INDEX             3  /* cannot be zero for implicit key identifier */
    /* Default MSA Security Parameters for outgoing frames */
    bool  macSecurity       = TRUE;
    uint8 msa_securityLevel = MSA_MAC_SEC_LEVEL;
    uint8 msa_keyIdMode     = MSA_MAC_KEY_ID_MODE;
    uint8 msa_keySource[]   = MSA_MAC_KEY_SOURCE;
    uint8 msa_keyIndex      = MSA_MAC_KEY_INDEX;
     *                                 Security PIBs for outgoing frames
    const keyIdLookupDescriptor_t msa_keyIdLookupList[] =
        {0x33, 0x33, 0x33, 0x33, 0x33, 0x33, 0x33, 0x33, 0x03}, 0x01 /* index 3, 9 octets */
    /* Key device list can be modified at run time
    keyDeviceDescriptor_t msa_keyDeviceList[] =
      {0x00, false, false},
    const keyUsageDescriptor_t msa_keyUsageList[] =
      {MAC_FRAME_TYPE_DATA, MAC_DATA_REQ_FRAME}
    const keyDescriptor_t msa_keyTable[] =
        (keyIdLookupDescriptor_t *)msa_keyIdLookupList, MSA_KEY_ID_LOOKUP_ENTRIES,
        (keyDeviceDescriptor_t *)msa_keyDeviceList, MSA_KEY_DEVICE_TABLE_ENTRIES,
        (keyUsageDescriptor_t *)msa_keyUsageList, MSA_KEY_USAGE_TABLE_ENTRIES,
        {0x12, 0x34, 0x56, 0x78, 0x9a, 0xbc, 0xde, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}
    const uint8 msa_keyDefaultSource[] = MSA_MAC_DEFAULT_KEY_SOURCE;
     *                                 Security PIBs for incoming frames
    /* Device table can be modified at run time. */
    deviceDescriptor_t msa_deviceTable[] =
      {0, 0xFFFF, 0, 0, FALSE},
    const securityLevelDescriptor_t msa_securityLevelTable[] =
      {MAC_FRAME_TYPE_DATA, MAC_DATA_REQ_FRAME, MAC_SEC_LEVEL_NONE, FALSE}
    #else /* FEATURE_MAC_SECURITY */
    uint8 msa_securityLevel = MAC_SEC_LEVEL_NONE;
    uint8 msa_keyIdMode     = MAC_KEY_ID_MODE_NONE;
    uint8 msa_keySource[]   = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
    uint8 msa_keyIndex      = 0;
     *                                     Local Function Prototypes
    /* Setup routines */
    void MSA_CoordinatorStartup(void);
    void MSA_DeviceStartup(void);
    /* MAC related routines */
    void MSA_AssociateReq(void);
    void MSA_AssociateRsp(macCbackEvent_t* pMsg);
    void MSA_McpsDataReq(uint8* data, uint8 dataLength, bool directMsg, uint16 dstShortAddr);
    void MSA_McpsPollReq(void);
    void MSA_ScanReq(uint8 scanType, uint8 scanDuration);
    void MSA_SyncReq(void);
    /* Support */
    bool MSA_BeaconPayLoadCheck(uint8* pSdu);
    bool MSA_DataCheck(uint8* data, uint8 dataLength);
     * @fn          MSA_SecurityInit
     * @brief       Initialize the security part of the application
     * @param       none
     * @return      none
    static void MSA_SecurityInit(void)
      uint8   keyTableEntries      = MSA_KEY_TABLE_ENTRIES;
      uint8   autoRequestSecLevel  = MAC_SEC_LEVEL_NONE;
      uint8   securityLevelEntries = MSA_SECURITY_LEVEL_ENTRIES;
      /* Write key table PIBs */
      MAC_MlmeSetSecurityReq(MAC_KEY_TABLE, (void *)msa_keyTable);
      MAC_MlmeSetSecurityReq(MAC_KEY_TABLE_ENTRIES, &keyTableEntries );
      /* Write default key source to PIB */
      MAC_MlmeSetSecurityReq(MAC_DEFAULT_KEY_SOURCE, (void *)msa_keyDefaultSource);
      /* Write security level table to PIB */
      MAC_MlmeSetSecurityReq(MAC_SECURITY_LEVEL_TABLE, (void *)msa_securityLevelTable);
      MAC_MlmeSetSecurityReq(MAC_SECURITY_LEVEL_TABLE_ENTRIES, &securityLevelEntries);
      /* TBD: MAC_AUTO_REQUEST is true on by default
       * need to set auto request security PIBs.
       * dieable auto request security for now
      MAC_MlmeSetSecurityReq(MAC_AUTO_REQUEST_SECURITY_LEVEL, &autoRequestSecLevel);
      /* Turn on MAC security */
      MAC_MlmeSetReq(MAC_SECURITY_ENABLED, &macSecurity);
     * @fn          MSA_SecuredDeviceTableUpdate
     * @brief       Update secured device table and key device descriptor handle
     * @param       panID - Secured network PAN ID
     * @param       shortAddr - Other device's short address
     * @param       extAddr - Other device's extended address
     * @param       pNumOfSecuredDevices - pointer to number of secured devices
     * @return      none
    static void MSA_SecuredDeviceTableUpdate(uint16 panID,
                                             uint16 shortAddr,
                                             sAddrExt_t extAddr,
                                             uint8 *pNumOfSecuredDevices)
      /* Update key device list */
      msa_keyDeviceList[*pNumOfSecuredDevices].deviceDescriptorHandle = *pNumOfSecuredDevices;
      /* Update device table */
      msa_deviceTable[*pNumOfSecuredDevices].panID = panID;
      msa_deviceTable[*pNumOfSecuredDevices].shortAddress = shortAddr;
      sAddrExtCpy(msa_deviceTable[*pNumOfSecuredDevices].extAddress, extAddr);
      MAC_MlmeSetSecurityReq(MAC_DEVICE_TABLE, msa_deviceTable);
      /* Increase the number of secured devices */
      (*pNumOfSecuredDevices)++;
      MAC_MlmeSetSecurityReq(MAC_DEVICE_TABLE_ENTRIES, pNumOfSecuredDevices);
    #pragma vector=TIMER1_A0_VECTOR
    __interrupt void TIMER1_A0_ISR(void)
      ADC12CTL0 |= ADC12ENC;                        // Enable conversions
      ADC12CTL0 |= ADC12SC;                         // Start conversion
    #pragma vector=ADC12_VECTOR
    __interrupt void ADC12_ISR(void)
     // ADC12CTL0 &= ~ADC12ENC;                       // Disable ADC12 conversions
     // REFCTL0 &= ~REFON;                            // Disable reference (if enabled)
      msa_Data1[4] = ADC12MEM1;                   // Store the sampled data
      __bic_SR_register_on_exit(LPM0_bits);
    void accelerometerInit(void)
        P7SEL |= BIT5;                                // Pin 7.6 and 7.7 are inputs from the accelerometer to the ADC => they are configured as inputs to the ADC
      P7DIR &= ~BIT5;
     // UCSCTL8 |= MODOSCREQEN;                       // ADC is clocked by the ACLK in the UCS module
      ADC12CTL0 &= ~ADC12ENC;                       // Disable conversion
      ADC12CTL0 = ADC12ON + ADC12SHT0_5 + ADC12MSC;  // Turn on ADC, Sample once every 1024 cycles, Multisample conversion
      ADC12CTL1 = ADC12CSTARTADD_1 + ADC12SHP + ADC12CONSEQ_1 + ADC12SSEL_3+ADC12DIV1;
      ADC12CTL2 = ADC12RES_0;                       // Resolution=12 bits, 13 clock cycle conversion time
      ADC12MCTL1 = ADC12INCH_13;                    //select channel 13(pin 7.5)
      ADC12IE = 0x00;
        __delay_cycles(200000);                     // Allowing reference voltage to stabilize
    void accelerometerReadWithOffset(int16 x)
          x = SavedADC12MEM1;
        msa_Data1[4] = HI_UINT16(x );
        msa_Data1[5] = LO_UINT16(x );
    void adcStartRead(void)
         ADC12IFG = 0x00;
        ADC12IE = BIT1;
        ADC12CTL0 |= ADC12ENC | ADC12SC;
        // Enable conversion and Start conversion
    void result(int8 collect)
      char str1[100];
       // HalLcdclearscreen();
          sprintf(str1,"  %d ",collect);
         //HalLcdWriteString("Receiving-C",1);
       //  HalLcdWriteString("sensor data:",2);
          HalLcdWriteString(str1,4);
     * @fn          MSA_Init
     * @brief       Initialize the application
     * @param       taskId - taskId of the task after it was added in the OSAL task queue
     * @return      none
    void MSA_Init(uint8 taskId)
      uint8 i;
      /* Initialize the task id */
      MSA_TaskId = taskId;
      /* initialize MAC features */
      MAC_InitDevice();
      MAC_InitCoord();
      /* Initialize MAC beacon */
      MAC_InitBeaconDevice();
      MAC_InitBeaconCoord();
      /* Reset the MAC */
      MAC_MlmeResetReq(TRUE);
      /* Initialize the security part of the application */
      MSA_SecurityInit();
      /* Initialize the data packet */
     /* for (i=MSA_HEADER_LENGTH; i<MSA_PACKET_LENGTH; i++)
        msa_Data1[i] = i-MSA_HEADER_LENGTH;
       accelerometerInit();
      /* Initialize the echo packet */
      for (i=0; i<MSA_ECHO_LENGTH; i++)
        msa_Data2[i] = 0xEE;
      msa_BeaconOrder = MSA_MAC_BEACON_ORDER;
      msa_SuperFrameOrder = MSA_MAC_SUPERFRAME_ORDER;
     * @fn          MSA_ProcessEvent
     * @brief       This routine handles events
     * @param       taskId - ID of the application task when it registered with the OSAL
     *              events - Events for this task
     * @return      16bit - Unprocessed events
    uint16 MSA_ProcessEvent(uint8 taskId, uint16 events)
      uint8* pMsg;
      macCbackEvent_t* pData;
      char str[100];
     //  char str1[100];
        //  TA1CCTL0 = CCIE;                           // CCR0 interrupt enabled
         // TA1CCR0 = 2047;
         // TA1CTL = TASSEL__ACLK  + MC__UP + TACLR;   // SMCLK, up mode, clear TAR
      uint16       panID;
      uint16       panCoordShort;
      sAddrExt_t   panCoordExtAddr;
      static uint8 index;
     static uint8 sequence;
           adcStartRead();
         // msa_Data1[4] = SavedADC12MEM1;
           // msa_Data1[4] = HI_UINT16(SavedADC12MEM1 );
           // msa_Data1[5] = LO_UINT16(SavedADC12MEM1 );
           // res1=BUILD_UINT16((msa_Data1[5]), (msa_Data1[4]));
      //accelerometerReadWithOffset(x_new);      // ADC output (digital data)
      if (events & SYS_EVENT_MSG)
        while ((pMsg = osal_msg_receive(MSA_TaskId)) != NULL)
          switch ( *pMsg )
            case MAC_MLME_ASSOCIATE_IND:
              MSA_AssociateRsp((macCbackEvent_t*)pMsg);
              break;
            case MAC_MLME_ASSOCIATE_CNF:
              /* Retrieve the message */
              pData = (macCbackEvent_t *) pMsg;
              if ((!msa_IsStarted) && (pData->associateCnf.hdr.status == MAC_SUCCESS))
                msa_IsStarted = TRUE;
                /* Retrieve MAC_SHORT_ADDRESS */
                msa_DevShortAddr = pData->associateCnf.assocShortAddress;
                /* Setup MAC_SHORT_ADDRESS - obtained from Association */
                MAC_MlmeSetReq(MAC_SHORT_ADDRESS, &msa_DevShortAddr);
                /* Add the coordinator to device table and key device table for security */
                MAC_MlmeGetReq(MAC_PAN_ID, &panID);
                MAC_MlmeGetSecurityReq(MAC_PAN_COORD_SHORT_ADDRESS, &panCoordShort);
                MAC_MlmeGetSecurityReq(MAC_PAN_COORD_EXTENDED_ADDRESS, &panCoordExtAddr);
                MSA_SecuredDeviceTableUpdate(panID, panCoordShort,
                                             panCoordExtAddr, &msa_NumOfSecuredDevices);
                HalLedBlink(HAL_LED_4, 0, 90, 1000);
                /* Poll for data if it's not setup for direct messaging */
                if (!msa_IsDirectMsg)
                  osal_start_timerEx(MSA_TaskId, MSA_POLL_EVENT, MSA_WAIT_PERIOD);
              break;
            case MAC_MLME_COMM_STATUS_IND:
              break;
            case MAC_MLME_BEACON_NOTIFY_IND:
              /* Check for correct beacon payload */
              if (!msa_IsStarted)
                msa_IsSampleBeacon = MSA_BeaconPayLoadCheck(pData->beaconNotifyInd.pSdu);
                /* If it's the correct beacon payload, retrieve the data for association req */
                if (msa_IsSampleBeacon)
                  msa_AssociateReq.logicalChannel = MSA_MAC_CHANNEL;
                  msa_AssociateReq.coordAddress.addrMode = SADDR_MODE_SHORT;
                  msa_AssociateReq.coordAddress.addr.shortAddr = pData->beaconNotifyInd.pPanDesc->coordAddress.addr.shortAddr;
                  msa_AssociateReq.coordPanId = pData->beaconNotifyInd.pPanDesc->coordPanId;
                  if (msa_IsDirectMsg)
                    msa_AssociateReq.capabilityInformation = MAC_CAPABLE_ALLOC_ADDR | MAC_CAPABLE_RX_ON_IDLE;
                  else
                    msa_AssociateReq.capabilityInformation = MAC_CAPABLE_ALLOC_ADDR;
                  msa_AssociateReq.sec.securityLevel = MAC_SEC_LEVEL_NONE;
                  /* Retrieve beacon order and superframe order from the beacon */
                  msa_BeaconOrder = MAC_SFS_BEACON_ORDER(pData->beaconNotifyInd.pPanDesc->superframeSpec);
                  msa_SuperFrameOrder = MAC_SFS_SUPERFRAME_ORDER(pData->beaconNotifyInd.pPanDesc->superframeSpec);
              break;
            case MAC_MLME_START_CNF:
              /* Set some indicator for the Coordinator */
              if ((!msa_IsStarted) && (pData->startCnf.hdr.status == MAC_SUCCESS))
                msa_IsCoordinator = TRUE;
                HalLedSet (HAL_LED_4, HAL_LED_MODE_ON);
              break;
            case MAC_MLME_SCAN_CNF:
              /* Check if there is any Coordinator out there */
              /* If there is no other on the channel or no other with sampleBeacon start as coordinator */
              if (((pData->scanCnf.resultListSize == 0) && (pData->scanCnf.hdr.status == MAC_NO_BEACON)) || (!msa_IsSampleBeacon))
                MSA_CoordinatorStartup();
              else if ((msa_IsSampleBeacon) && pData->scanCnf.hdr.status == MAC_SUCCESS)
                /* Start the devive up as beacon enabled or not */
                MSA_DeviceStartup();
                /* Call Associate Req */
                MSA_AssociateReq();
              break;
            case MAC_MCPS_DATA_CNF:
              /* If last transmission completed, ready to send the next one */
              if ((pData->dataCnf.hdr.status == MAC_SUCCESS) ||
                  (pData->dataCnf.hdr.status == MAC_CHANNEL_ACCESS_FAILURE) ||
                  (pData->dataCnf.hdr.status == MAC_NO_ACK))
                osal_start_timerEx(MSA_TaskId, MSA_SEND_EVENT, MSA_WAIT_PERIOD);
              mac_msg_deallocate((uint8**)&pData->dataCnf.pDataReq);
              break;
            case MAC_MCPS_DATA_IND:
              pData = (macCbackEvent_t*)pMsg;
             // res=BUILD_UINT16((pData->dataInd.msdu.p[5]), (pData->dataInd.msdu.p[4]));
              if (MSA_DataCheck ( pData->dataInd.msdu.p, pData->dataInd.msdu.len ))
               HalLedSet (HAL_LED_1, HAL_LED_MODE_TOGGLE);   // receiving ledblink
                /* Only send the echo back if the received */
                if (!msa_IsCoordinator)
                  if (MSA_ECHO_LENGTH >= 4)
                    /* Return the first 4 bytes and the last byte of the received packet */
                    msa_Data2[0] = pData->dataInd.msdu.p[0];
                    msa_Data2[1] = pData->dataInd.msdu.p[1];
                    msa_Data2[2] = pData->dataInd.msdu.p[2];
                    msa_Data2[3] = pData->dataInd.msdu.p[3];
                  MSA_McpsDataReq(msa_Data2,
                                  MSA_ECHO_LENGTH,
                                  TRUE,
                                  msa_CoordShortAddr );
                 store=pData->dataInd.msdu.p[4];
                result(store);
        //sprintf(str1,"  %d ",pData->dataInd.msdu.p[4]);
         //HalLcdWriteString(str1,4);
                   P5SEL |= BIT6 + BIT7;                      // P5.6,7 = USCI_A1 TXD/RXD
          UCA1CTL1 |= UCSWRST;                       // **Put state machine in reset**
          UCA1CTL1 |= UCSSEL__SMCLK;
          UCA1BR0 = 9;                              //
          UCA1BR1 = 0;                              //
          UCA1MCTL = UCBRS_1;
          UCA1CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
     int k=0;
     sprintf(sensbuffer,"%d", pData->dataInd.msdu.p[4]);
     while(sensbuffer[k])
     while(!(UCA1IFG&UCTXIFG));
     UCA1TXBUF = sensbuffer[k++];
                else{
                store=(pData->dataInd.msdu.p[4]);
               result(store);
                // sprintf(str1,"  %d ",res);
         // HalLcdWriteString(str1,4);
          UCA1BR0 = 9;                              //
          UCA1BR1 = 0;                              //
          UCA1MCTL = UCBRS_1;
     int k=0;
              break;
          /* Deallocate */
          mac_msg_deallocate((uint8 **)&pMsg);
        return events ^ SYS_EVENT_MSG;
      /* This event handles polling for in-direct message device */
      if (events & MSA_POLL_EVENT)
        MSA_McpsPollReq();
        return events ^ MSA_POLL_EVENT;
      /* This event will blink a LED then send out a DataReq and continue to do so every WAIT_PERIOD */
      if (events & MSA_SEND_EVENT)
        /* Do it again */
       if (msa_State == MSA_SEND_STATE)
          /* Start sending */
         if(msa_IsCoordinator)
            if(MSA_PACKET_LENGTH >= MSA_HEADER_LENGTH)
              /* Coordinator sending to devices. Use the associated list of device to send out msg */
              msa_Data1[0] = MSA_PACKET_LENGTH;
              msa_Data1[1] = HI_UINT16(msa_DeviceRecord[index].devShortAddr);
              msa_Data1[2] = LO_UINT16(msa_DeviceRecord[index].devShortAddr);
              msa_Data1[3] = sequence;              //x_new;                 //
            MSA_McpsDataReq(msa_Data1,
                            MSA_PACKET_LENGTH,
                            msa_DeviceRecord[index].isDirectMsg,
                            msa_DeviceRecord[index].devShortAddr );
            /* Reset the index if it reaches the current number of associated devices */
            if (++index == msa_NumOfDevices)
              index = 0;
            __bis_SR_register(LPM0_bits+GIE);             // Enter LPM0, enable interrupts
           sprintf(str,"   %d ",msa_Data1[4]);
         // HalLcdWriteString("Sending-C",1);
          HalLcdWriteString(str,4);
          UCA1BR0 = 26;                              //
          UCA1BR1 = 0;                              //
          UCA1MCTL = UCBRS_0;
     int k=0;
     sprintf(sensbuffer,"%d", msa_Data1[4]);
          else
         // while(!msa_IsCoordinator)
              /* Device sending to coordinator */
              msa_Data1[1] = HI_UINT16(msa_CoordShortAddr);
              msa_Data1[2] = LO_UINT16(msa_CoordShortAddr);
                            MSA_PACKET_LENGTH,
                            TRUE,
          sprintf(str,"   %d ", msa_Data1[4]);
         // HalLcdWriteString("Sending-ED",1);
          UCA1BR0 = 26;                              //
          UCA1BR1 = 0;                              //
          UCA1MCTL = UCBRS_0;
     int k=0;
          if (sequence++ == 0xFF)
            sequence = 0;
         HalLedSet (HAL_LED_1, HAL_LED_MODE_BLINK);  //sending ledblink
        return events ^ MSA_SEND_EVENT;
      return 0;
     * @fn          MAC_CbackEvent
     * @brief       This callback function sends MAC events to the application.
     *              The application must implement this function.  A typical
     *              implementation of this function would allocate an OSAL message,
     *              copy the event parameters to the message, and send the message
     *              to the application's OSAL event handler.  This function may be
     *              executed from task or interrupt context and therefore must
     *              be reentrant.
     * @param       pData - Pointer to parameters structure.
     * @return      None.
    void MAC_CbackEvent(macCbackEvent_t *pData)
      macCbackEvent_t *pMsg = NULL;
      uint8 len = msa_cbackSizeTable[pData->hdr.event];
      switch (pData->hdr.event)
          len += sizeof(macPanDesc_t) + pData->beaconNotifyInd.sduLength +
                 MAC_PEND_FIELDS_LEN(pData->beaconNotifyInd.pendAddrSpec);
          if ((pMsg = (macCbackEvent_t *) osal_msg_allocate(len)) != NULL)
            /* Copy data over and pass them up */
            osal_memcpy(pMsg, pData, sizeof(macMlmeBeaconNotifyInd_t));
            pMsg->beaconNotifyInd.pPanDesc = (macPanDesc_t *) ((uint8 *) pMsg + sizeof(macMlmeBeaconNotifyInd_t));
            osal_memcpy(pMsg->beaconNotifyInd.pPanDesc, pData->beaconNotifyInd.pPanDesc, sizeof(macPanDesc_t));
            pMsg->beaconNotifyInd.pSdu = (uint8 *) (pMsg->beaconNotifyInd.pPanDesc + 1);
            osal_memcpy(pMsg->beaconNotifyInd.pSdu, pData->beaconNotifyInd.pSdu, pData->beaconNotifyInd.sduLength);
          break;
          pMsg = pData;
          break;
        default:
            osal_memcpy(pMsg, pData, len);
          break;
      if (pMsg != NULL)
        osal_msg_send(MSA_TaskId, (uint8 *) pMsg);
     * @fn      MAC_CbackCheckPending
     * @brief   Returns the number of indirect messages pending in the application
     * @param   None
     * @return  Number of indirect messages in the application
    uint8 MAC_CbackCheckPending(void)
      return (0);
     * @fn          MAC_CbackQueryRetransmit
     * @brief       This function callback function returns whether or not to continue MAC
     *              retransmission.
     *              A return value '0x00' will indicate no continuation of retry and a return value
     *              '0x01' will indicate to continue retransmission. This callback function shall be
     *              used to stop continuing retransmission for RF4CE.
     *              MAC shall call this callback function whenever it finishes transmitting a packet
     *              for macMaxFrameRetries times.
     * input parameters
     * None.
     * output parameters
     * None.
     * @return      0x00 to stop retransmission, 0x01 to continue retransmission.
    uint8 MAC_CbackQueryRetransmit(void)
      /* Stub */
      return(0);
     * @fn      MSA_CoordinatorStartup()
     * @brief   Update the timer per tick
     * @param   n/a
     * @return  None
    void MSA_CoordinatorStartup()
      macMlmeStartReq_t   startReq;
      /* Setup MAC_EXTENDED_ADDRESS */
      sAddrExtCpy(msa_ExtAddr, msa_ExtAddr1);
      MAC_MlmeSetReq(MAC_EXTENDED_ADDRESS, &msa_ExtAddr);
      /* Setup MAC_SHORT_ADDRESS */
      MAC_MlmeSetReq(MAC_SHORT_ADDRESS, &msa_CoordShortAddr);
      /* Setup MAC_BEACON_PAYLOAD_LENGTH */
      MAC_MlmeSetReq(MAC_BEACON_PAYLOAD_LENGTH, &msa_BeaconPayloadLen);
      /* Setup MAC_BEACON_PAYLOAD */
      MAC_MlmeSetReq(MAC_BEACON_PAYLOAD, &msa_BeaconPayload);
      /* Enable RX */
      MAC_MlmeSetReq(MAC_RX_ON_WHEN_IDLE, &msa_MACTrue);
      /* Setup MAC_ASSOCIATION_PERMIT */
      MAC_MlmeSetReq(MAC_ASSOCIATION_PERMIT, &msa_MACTrue);
      /* Fill in the information for the start request structure */
      startReq.startTime = 0;
      startReq.panId = msa_PanId;
      startReq.logicalChannel = MSA_MAC_CHANNEL;
      startReq.beaconOrder = msa_BeaconOrder;
      startReq.superframeOrder = msa_SuperFrameOrder;
      startReq.panCoordinator = TRUE;
      startReq.batteryLifeExt = FALSE;
      startReq.coordRealignment = FALSE;
      startReq.realignSec.securityLevel = FALSE;
      startReq.beaconSec.securityLevel = FALSE;
      /* Call start request to start the device as a coordinator */
      MAC_MlmeStartReq(&startReq);
      /* Allow Beacon mode coordinator to sleep */
      if (msa_BeaconOrder != 15)
        /* Power saving */
        MSA_PowerMgr (MSA_PWR_MGMT_ENABLED);
     * @fn      MSA_DeviceStartup()
     * @param   beaconEnable: TRUE/FALSE
     * @return  None
    void MSA_DeviceStartup()
      uint16 AtoD = 0;
    #if (defined HAL_ADC) && (HAL_ADC == TRUE)
      AtoD = HalAdcRead (MSA_HAL_ADC_CHANNEL, MSA_HAL_ADC_RESOLUTION);
    #else
      AtoD = MAC_RADIO_RANDOM_WORD();
    #endif
    #if defined (HAL_BOARD_CC2420DB) || defined (HAL_BOARD_DZ1611) || defined (HAL_BOARD_DZ1612) || \
      /* Use HI and LO of AtoD on CC2420 and MSP430 */
      msa_ExtAddr2[6] = HI_UINT16( AtoD );
      msa_ExtAddr2[7] = LO_UINT16( AtoD );
    #else
      /* On CC2430 and CC2530 use current MAC timer */
      AtoD = macMcuPrecisionCount();
    #endif
      sAddrExtCpy(msa_ExtAddr, msa_ExtAddr2);
      /* Setup PAN ID */
      MAC_MlmeSetReq(MAC_PAN_ID, &msa_PanId);
      /* This device is setup for Direct Message */
      else
        MAC_MlmeSetReq(MAC_RX_ON_WHEN_IDLE, &msa_MACFalse);
      /* Setup Coordinator short address */
      MAC_MlmeSetReq(MAC_COORD_SHORT_ADDRESS, &msa_AssociateReq.coordAddress.addr.shortAddr);
      /* Setup Coordinator short address for security */
      MAC_MlmeSetSecurityReq(MAC_PAN_COORD_SHORT_ADDRESS, &msa_AssociateReq.coordAddress.addr.shortAddr);
        /* Setup Beacon Order */
        MAC_MlmeSetReq(MAC_BEACON_ORDER, &msa_BeaconOrder);
        /* Setup Super Frame Order */
        MAC_MlmeSetReq(MAC_SUPERFRAME_ORDER, &msa_SuperFrameOrder);
        /* Sync request */
        MSA_SyncReq();
      /* Power saving */
     * @fn      MSA_AssociateReq()
     * @brief
     * @param    None
     * @return  None
      MAC_MlmeAssociateReq(&msa_AssociateReq);
     * @fn      MSA_AssociateRsp()
     * @brief   This routine is called by Associate_Ind inorder to return the response to the device
     * @param   pMsg - pointer to the structure recieved by MAC_MLME_ASSOCIATE_IND
     * @return  None
      /* Assign the short address  for the Device, from pool */
      uint16 assocShortAddress = msa_DevShortAddrList[msa_NumOfDevices];
      uint16 panID;
      /* Add device to device table for security */
      MSA_SecuredDeviceTableUpdate(panID, assocShortAddress,
                                   pMsg->associateInd.deviceAddress,
      /* Build the record for this device */
      msa_DeviceRecord[msa_NumOfDevices].devShortAddr = msa_DevShortAddrList[msa_NumOfDevices];
      msa_DeviceRecord[msa_NumOfDevices].isDirectMsg = pMsg->associateInd.capabilityInformation & MAC_CAPABLE_RX_ON_IDLE;
      msa_NumOfDevices++;
      /* If the number of devices are more than MAX_DEVICE_NUM, turn off the association permit */
      if (msa_NumOfDevices == MSA_MAX_DEVICE_NUM)
        MAC_MlmeSetReq(MAC_ASSOCIATION_PERMIT, &msa_MACFalse);
      /* Fill in association respond message */
      sAddrExtCpy(msa_AssociateRsp.deviceAddress, pMsg->associateInd.deviceAddress);
      msa_AssociateRsp.assocShortAddress = assocShortAddress;
      msa_AssociateRsp.status = MAC_SUCCESS;
      msa_AssociateRsp.sec.securityLevel = MAC_SEC_LEVEL_NONE;
      /* Call Associate Response */
      MAC_MlmeAssociateRsp(&msa_AssociateRsp);
     * @fn      MSA_McpsDataReq()
     * @brief   This routine calls the Data Request
     * @param   data       - contains the data that would be sent
     *          dataLength - length of the data that will be sent
     * @return  None
      macMcpsDataReq_t  *pData;
      static uint8      handle = 0;
      if ((pData = MAC_McpsDataAlloc(dataLength, msa_securityLevel, msa_keyIdMode)) != NULL)
        pData->mac.srcAddrMode = SADDR_MODE_SHORT;
        pData->mac.dstAddr.addrMode = SADDR_MODE_SHORT;
        pData->mac.dstAddr.addr.shortAddr = dstShortAddr;
        pData->mac.dstPanId = msa_PanId;
        pData->mac.msduHandle = handle++;
        pData->mac.txOptions = MAC_TXOPTION_ACK;
        /* MAC security parameters */
        osal_memcpy( pData->sec.keySource, msa_keySource, MAC_KEY_SOURCE_MAX_LEN );
        pData->sec.securityLevel = msa_securityLevel;
        pData->sec.keyIdMode = msa_keyIdMode;
        pData->sec.keyIndex = msa_keyIndex;
        /* If it's the coordinator and the device is in-direct message */
        if (msa_IsCoordinator)
          if (!directMsg)
            pData->mac.txOptions |= MAC_TXOPTION_INDIRECT;
        /* Copy data */
        osal_memcpy (pData->msdu.p, data, dataLength);
        /* Send out data request */
        MAC_McpsDataReq(pData);
     * @fn      MSA_McpsPollReq()
     * @brief   Performs a poll request on the coordinator
     * @param   None
     * @return  None
      macMlmePollReq_t  pollReq;
      /* Fill in information for poll request */
      pollReq.coordAddress.addrMode = SADDR_MODE_SHORT;
      pollReq.coordAddress.addr.shortAddr = msa_CoordShortAddr;
      pollReq.coordPanId = msa_PanId;
      pollReq.sec.securityLevel = MAC_SEC_LEVEL_NONE;
      /* Call poll reuqest */
      MAC_MlmePollReq(&pollReq);
     * @fn      MacSampelApp_ScanReq()
     * @brief   Performs active scan on specified channel
     * @param   None
     * @return  None
      macMlmeScanReq_t scanReq;
      /* Fill in information for scan request structure */
      scanReq.scanChannels = (uint32) 1 << MSA_MAC_CHANNEL;
      scanReq.scanType = scanType;
      scanReq.scanDuration = scanDuration;
      scanReq.maxResults = MSA_MAC_MAX_RESULTS;
      scanReq.permitJoining = MSA_EBR_PERMITJOINING;
      scanReq.linkQuality = MSA_EBR_LINKQUALITY;
      scanReq.percentFilter = MSA_EBR_PERCENTFILTER;
      scanReq.result.pPanDescriptor = msa_PanDesc;
      osal_memset(&scanReq.sec, 0, sizeof(macSec_t));
      /* Call scan request */
      MAC_MlmeScanReq(&scanReq);
     * @fn      MSA_SyncReq()
     * @brief   Sync Request
     * @param   None
     * @return  None
      macMlmeSyncReq_t syncReq;
      /* Fill in information for sync request structure */
      syncReq.logicalChannel = MSA_MAC_CHANNEL;
      syncReq.channelPage    = MAC_CHANNEL_PAGE_0;
      syncReq.trackBeacon    = TRUE;
      /* Call sync request */
      MAC_MlmeSyncReq(&syncReq);
     * @fn      MSA_BeaconPayLoadCheck()
     * @brief   Check if the beacon comes from MSA but not zigbee
     * @param   pSdu - pointer to the buffer that contains the data
     * @return  TRUE or FALSE
      uint8 i = 0;
      for (i=0; i<msa_BeaconPayloadLen; i++)
        if (pSdu[i] != msa_BeaconPayload[i])
          return FALSE;
      return TRUE;
     * @fn      MSA_DataCheck()
     * @brief   Check if the data match with the predefined data
     * @param    data - pointer to the buffer where the data will be checked against the predefined data
     * @return  TRUE if the data matched else it's the response / echo packet
      uint8 i = 0;
      if (data[0] == dataLength)
        for (i=MSA_HEADER_LENGTH; i<(data[0] - 1); i++)
           if (data[i] != msa_Data1[i])
             return FALSE;
      else
        return FALSE;
      return TRUE;
     * @fn      MSA_HandleKeys
     * @brief   Callback service for keys
     * @param   keys  - keys that were pressed
     *          state - shifted
     * @return  void
    void MSA_HandleKeys(uint8 keys, uint8 shift)
    #ifdef HAL_BOARD_LM3S9B96
      static uint8 msa_keyPressCount = 0;
      /* LM3S9B96 board has only one switch. For MSA, pressing SW1 once generates HAL_KEY_SW_1 event.
       * Pressing SW1 the 2nd time generates HAL_KEY_SW_2 event. Pressing SW1 the 3rd or more time
       * also generates HAL_KEY_SW_2 event.
      if (msa_keyPressCount == 0)
        keys = HAL_KEY_SW_1;
        msa_keyPressCount++;
      else
        keys = HAL_KEY_SW_2;
    #endif /* HAL_BOARD_LM3S9B96 */
      if ( keys & HAL_KEY_SW_1 )
        /* Start the device as a direct message device and beacon disabled*/
        if (!msa_IsStarted)
          /* Decide if direct or indirect messaging is used */
          msa_IsDirectMsg = MSA_DIRECT_MSG_ENABLED;
            /* Start the device as an DIRECT messaging device */
              MSA_ScanReq(MAC_SCAN_PASSIVE, MSA_MAC_BEACON_ORDER + 1);
            else
              MSA_ScanReq(MAC_SCAN_ACTIVE, 3);
          else
             /* Start the device as an INDIRECT messaging device and beacon disabled */
             /* Beacon network doesn't work with polling */
             if (!msa_IsStarted)
    #ifdef HAL_BOARD_CC2530USB
        /* CC2531DK_Dongle has no Reset button - use S1 if msa_IsStarted */
        else
          /* Wait until user releases S1 */
          while ( HAL_PUSH_BUTTON1() );
          /* Soft reset leaves USB stuff alone */
          SystemResetSoft();
    #endif /* HAL_BOARD_CC2530USB */
      if ( keys & HAL_KEY_SW_2 )
        /* Start sending message */
        if (msa_IsStarted)
          /* Set App's state to SEND or IDLE */
          if (msa_State == MSA_IDLE_STATE)
            msa_State = MSA_SEND_STATE;
          else
          /* Send Event to the App to carry out the changes */
          osal_start_timerEx(MSA_TaskId, MSA_SEND_EVENT, 100);
    plz do look into the code.
  • I am using 8bit ADC
  • Though the adc it of 12bit, we can configure it for 8 bit
