Z-stack for Tiva
Other Parts Discussed in Thread: Z-STACK, CC2538
Hi, everyone
I have a questioin.
I want to use Z-stack with Tiva.
I found Z-stack for LM3S9B96.
Do you know about Z-stack of LM3S9B96 use with Tiva
Best Regards
Hiroyasu
  • Hi Hiroyasu,
    The last version of Z-Stack that supported LM3S9B96 was Z-Stack 2.5.1. With newer versions, we no longer support LM3S9B96 and currently we don't have any plan to support Tiva either.
    - Cetri
  • Hi,Cetri
    Thank you for your reply.
    I want to change devise from Stellaris to Tiva TM4C123x.
    But Z-stack has library. I do not see library's source code.
    Does this library include stellarisware API for LM3Sxxx?
    We can modify source code, if library of Z-stack does not include stellarisware API for LM3Sxxx.
    Best regards
    Hiroyasu
  • Hi Hiroyasu,
    The library doesn't contain Stellarisware. However, I still wouldn't recommend starting a new project with an outdated solution. If you are planning to get your product ZigBee-certified, Z-Stack 2.5.1 or earlier versions are not the right choices. Compliance to ZigBee core spec revision 20 is not guaranteed with those versions. Besides, it will be very hard for you to be supported if you run into any issues with older version of software.
    - Cetri
  • Hi, Cetri.
    On behalf of the Hiroyasu, and then reply
    Do you mean whatis this??
    Zigbee standard? ?
    hamada
  • Hi Hamada,
    Yes, Z-Stack 2.5.1 was certified as ZigBee Core spec r19-compliant platform. Currently now r19 certification is no longer available for new products and r21 is coming up. We have no plans to support r20 and future revisions on Stellaris/Tiva at this moment.
    If you are interested in ARM Cortex M3 core-based platform, CC2538 can be considered as an alternative. Thanks.
    - Cetri
  • Hi, Cetri.
    Thank you for reply.
    In the case of the configuration of the Z-stack 2.5.1 and Tiva, do you may be considered to correspond to the ZigBee core spec r19?
  • Hi Hamada,
    Yes, but please note that r19 has some issues of interoperability between stack vendors. r20 is the revision where the issues are cleared by ZigBee Alliance. It is strongly discouraged to use old revision of standard and old version stack software for new development projects.
    - Cetri
