Which file i can get port & pin configuration of led connected in light project for toggling,on and off process under home automation in z-stack home 1.2.2?
Dono why its happening. Thrice i have done same process(replacing doorlock with Beeper as per the document). i am getting same errors all the time. i have included the error report. these all errors are related to door lock cluster and defined in zcl_closures.h. By replacing "Beeper" with "DoorLock" it can be found corresponding original definitions defined in zcl_closures.h. zcl_closures.h is not renamed as per the document and so error occures.error.rar
I try to change SampleDoorLock project to Beeper and there is no problem. Please refer to the attached Beeper.rar
Hi Yikai,
Here i have included sniffer log for third party presence sensor associated with my own coordinator. I can get device announce data in hyper terminal but not able to get end point through active EP request and simple desc response through simple desc request. I think device has been programmed for polling only once because i don't see any polling packets in sniffer and so only i am not able to get these data. If possible can you please tell me what endpoint and simple descriptor it is using? Please consider packets from device with short address 0x61962021.data.psd
After I check 2021.data.psd, the endpoint of third party presence sensor should be 3. By the way, I don't see your coordinator send active endpoint request.
I think the 3rd party device shouldn't be not polling. Does this device get Zigbee certified?
I don't think this is a Zigbee alliance certified product so I suggest you don't waste your time on it.
