OTA image on 2530/38
Other Parts Discussed in Thread: Z-STACK, CC2530
Hi TI,
I am able to run OTA Z-Stack 1.2.1 on 2530/38 which have been first flashed with:
Router OTA Client version xxx/ OTA Router Client-Img A withBoot
respectively.
I have made :
Application version yyyy/ an Image B for 2530/38 respectively and pointed otaServer to it.. but in Deivce list section otaServer prints in front of CC2530/38 Node that " No Image was found for Device".
How can I force otaServer to do the download? I made Broadcast notify image but again it doesn't upgrade any of them.
    It is not clear what causing this issue. Did you follow the exact steps from the respective guide? You can find it in the Documents section of the installed Z-Stack package, under the name Z-Stack OTA Upgrade User's Guide.pdf
    If there is no specific reason you are using Z-Stack 1.2.1, I suggest moving to the latest Z-Stack, 1.2.2. the download is available at http://www.ti.com/tool/z-stack
    OD
