Other Parts Discussed in Thread: CC2530, Z-STACK
Hi Ti,
How to set the our required transmit power in cc2530 using write configuration command?
Yes, you should check RF design first. You can connect your module with SmartRF Studio 7 and test TX and RX on it.
Dear YK Chen
is it possible to measure cc2530 consumption current using cro while it is in transmitting mode ?
You can try to check the macTxFrame() and txComplete() to see if you can get the information you want.
