Problem in use of WatchDog on cc2538
Other Parts Discussed in Thread: CC2538, Z-STACK
Hi
When i enable watchdog, event of keys generate only 1 time then my endpoint does not receive any event of keys.
But when i disable the watchdog, it is work fine.
Please guide me.
  • No one can help me.
  • As I remember, CC2538 example in Z-Stack uses watchdog timer to do denounce and this might be related to your problem.Can you specify what example your test is based on and how do you enable watchdog?
  • I use sampleLight example.
    I use
    WatchdogEnable( WATCHDOG_INTERVAL_32768 );
    befor
    osal_start_system();
    in ZMain.c file.
  • Do you call WatchdogClear to reset watchdog periodically?
  • yes, I set a timer that runs each 100 ms and call WatchdogClear();
  • Try to extend this 100ms to 1000 ms.
  • I try 1000ms.
    But the problem is not resolved.
  • Can you show me how you do watchdog clear?
  • static void zclSampleLight_WatchDog_Loop(void){
    WatchdogClear();
    osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_LIGHT_WATCHDOG_EVT, 999);
  • Where do you put zclSampleLight_WatchDog_Loop in your code?
  • 1- end of void zclSampleLight_Init( byte task_id )
    2- in uint16 zclSampleLight_event_loop( uint8 task_id, uint16 events ):
    if ( events & SAMPLELIGHT_LIGHT_WATCHDOG_EVT )
    zclSampleLight_WatchDog_Loop();
    return ( events ^ SAMPLELIGHT_LIGHT_WATCHDOG_EVT );
  • What's your define on SAMPLELIGHT_LIGHT_WATCHDOG_EVT?
  • #define SAMPLELIGHT_LIGHT_WATCHDOG_EVT 0x0400
    in zcl_samplelight.h
  • I do the test and don't see similar problem. I attach my zcl_samplelight.c for your reference.
      Filename:       zcl_sampleLight.c
      Revised:        $Date: 2014-10-24 16:04:46 -0700 (Fri, 24 Oct 2014) $
      Revision:       $Revision: 40796 $
      Description:    Zigbee Cluster Library - sample device application.
      Copyright 2006-2014 Texas Instruments Incorporated. All rights reserved.
      IMPORTANT: Your use of this Software is limited to those specific rights
      granted under the terms of a software license agreement between the user
      who downloaded the software, his/her employer (which must be your employer)
      and Texas Instruments Incorporated (the "License").  You may not use this
      Software unless you agree to abide by the terms of the License. The License
      limits your use, and you acknowledge, that the Software may not be modified,
      copied or distributed unless embedded on a Texas Instruments microcontroller
      or used solely and exclusively in conjunction with a Texas Instruments radio
      frequency transceiver, which is integrated into your product.  Other than for
      the foregoing purpose, you may not use, reproduce, copy, prepare derivative
      works of, modify, distribute, perform, display or sell this Software and/or
      its documentation for any purpose.
      YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
      PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
      INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
      NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
      TEXAS INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT,
      NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
      LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
      INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
      OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
      OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
      (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
      Should you have any questions regarding your right to use this Software,
      contact Texas Instruments Incorporated at www.TI.com.
      This application implements a ZigBee HA 1.2 Light. It can be configured as an
      On/Off light, or as a dimmable light. The following flags must be defined in
      the compiler's pre-defined symbols.
      ZCL_ON_OFF
      ZCL_LEVEL_CTRL    (only if dimming functionality desired)
      HOLD_AUTO_START
      ZCL_EZMODE
      This device supports all mandatory and optional commands/attributes for the
      OnOff (0x0006) and LevelControl (0x0008) clusters.
      SCREEN MODES
      Main:
        - SW1: Toggle local light
        - SW2: Invoke EZMode
        - SW4: Enable/Disable local permit join
        - SW5: Go to Help screen
     * INCLUDES
    #include "ZComDef.h"
    #include "OSAL.h"
    #include "AF.h"
    #include "ZDApp.h"
    #include "ZDObject.h"
    #include "MT_SYS.h"
    #include "nwk_util.h"
    #include "zcl.h"
    #include "zcl_general.h"
    #include "zcl_ha.h"
    #include "zcl_ezmode.h"
    #include "zcl_diagnostic.h"
    #include "zcl_samplelight.h"
    #include "onboard.h"
    #include "watchdog.h"
    /* HAL */
    #include "hal_lcd.h"
    #include "hal_led.h"
    #include "hal_key.h"
    #if ( defined (ZGP_DEVICE_TARGET) || defined (ZGP_DEVICE_TARGETPLUS) \
          || defined (ZGP_DEVICE_COMBO) || defined (ZGP_DEVICE_COMBO_MIN) )
    #include "zgp_translationtable.h"
      #if (SUPPORTED_S_FEATURE(SUPP_ZGP_FEATURE_TRANSLATION_TABLE))
        #define ZGP_AUTO_TT
      #endif
    #endif
    #if (defined HAL_BOARD_ZLIGHT) || (defined HAL_PWM)
    #include "math.h"
    #include "hal_timer.h"
    #endif
    #include "NLMEDE.h"
     * MACROS
     * CONSTANTS
    #define LEVEL_MAX                 0xFE
    #define LEVEL_MIN                 0x0
    #define GAMMA_VALUE               2
    #define PWM_FULL_DUTY_CYCLE       1000
    #elif (defined HAL_PWM)
    #endif
     * TYPEDEFS
     * GLOBAL VARIABLES
    byte zclSampleLight_TaskID;
    uint8 zclSampleLightSeqNum;
     * GLOBAL FUNCTIONS
     * LOCAL VARIABLES
    afAddrType_t zclSampleLight_DstAddr;
    #ifdef ZCL_EZMODE
    static void zclSampleLight_ProcessZDOMsgs( zdoIncomingMsg_t *pMsg );
    static void zclSampleLight_EZModeCB( zlcEZMode_State_t state, zclEZMode_CBData_t *pData );
    // register EZ-Mode with task information (timeout events, callback, etc...)
    static const zclEZMode_RegisterData_t zclSampleLight_RegisterEZModeData =
      &zclSampleLight_TaskID,
      SAMPLELIGHT_EZMODE_NEXTSTATE_EVT,
      SAMPLELIGHT_EZMODE_TIMEOUT_EVT,
      &zclSampleLightSeqNum,
    #else
    uint16 bindingInClusters[] =
      ZCL_CLUSTER_ID_GEN_ON_OFF
    #ifdef ZCL_LEVEL_CTRL
      , ZCL_CLUSTER_ID_GEN_LEVEL_CONTROL
    #endif
    #define ZCLSAMPLELIGHT_BINDINGLIST (sizeof(bindingInClusters) / sizeof(bindingInClusters[0]))
    #endif  // ZCL_EZMODE
    // Test Endpoint to allow SYS_APP_MSGs
    static endPointDesc_t sampleLight_TestEp =
      SAMPLELIGHT_ENDPOINT,
      (SimpleDescriptionFormat_t *)NULL,  // No Simple description for this test endpoint
      (afNetworkLatencyReq_t)0            // No Network Latency req
    uint8 giLightScreenMode = LIGHT_MAINMODE;   // display the main screen mode first
    uint8 gPermitDuration = 0;    // permit joining default to disabled
    devStates_t zclSampleLight_NwkState = DEV_INIT;
    #if ZCL_LEVEL_CTRL
    uint8 zclSampleLight_WithOnOff;       // set to TRUE if state machine should set light on/off
    uint8 zclSampleLight_NewLevel;        // new level when done moving
    bool  zclSampleLight_NewLevelUp;      // is direction to new level up or down?
    int32 zclSampleLight_CurrentLevel32;  // current level, fixed point (e.g. 192.456)
    int32 zclSampleLight_Rate32;          // rate in units, fixed point (e.g. 16.123)
    uint8 zclSampleLight_LevelLastLevel;  // to save the Current Level before the light was turned OFF
    #endif
     * LOCAL FUNCTIONS
    static void zclSampleLight_HandleKeys( byte shift, byte keys );
    static void zclSampleLight_BasicResetCB( void );
    static void zclSampleLight_IdentifyCB( zclIdentify_t *pCmd );
    static void zclSampleLight_IdentifyQueryRspCB( zclIdentifyQueryRsp_t *pRsp );
    static void zclSampleLight_OnOffCB( uint8 cmd );
    static void zclSampleLight_ProcessIdentifyTimeChange( void );
    static void zclSampleLight_LevelControlMoveToLevelCB( zclLCMoveToLevel_t *pCmd );
    static void zclSampleLight_LevelControlMoveCB( zclLCMove_t *pCmd );
    static void zclSampleLight_LevelControlStepCB( zclLCStep_t *pCmd );
    static void zclSampleLight_LevelControlStopCB( void );
    static void zclSampleLight_DefaultMove( void );
    static uint32 zclSampleLight_TimeRateHelper( uint8 newLevel );
    static uint16 zclSampleLight_GetTime ( uint8 level, uint16 time );
    static void zclSampleLight_MoveBasedOnRate( uint8 newLevel, uint32 rate );
    static void zclSampleLight_MoveBasedOnTime( uint8 newLevel, uint16 time );
    static void zclSampleLight_AdjustLightLevel( void );
    #endif
    // app display functions
    static void zclSampleLight_LcdDisplayUpdate( void );
    #ifdef LCD_SUPPORTED
    static void zclSampleLight_LcdDisplayMainMode( void );
    static void zclSampleLight_LcdDisplayHelpMode( void );
    #endif
    static void zclSampleLight_DisplayLight( void );
    void zclSampleLight_UpdateLampLevel( uint8 level );
    #endif
    // Functions to process ZCL Foundation incoming Command/Response messages
    static void zclSampleLight_ProcessIncomingMsg( zclIncomingMsg_t *msg );
    #ifdef ZCL_READ
    static uint8 zclSampleLight_ProcessInReadRspCmd( zclIncomingMsg_t *pInMsg );
    #endif
    #ifdef ZCL_WRITE
    static uint8 zclSampleLight_ProcessInWriteRspCmd( zclIncomingMsg_t *pInMsg );
    #endif
    static uint8 zclSampleLight_ProcessInDefaultRspCmd( zclIncomingMsg_t *pInMsg );
    #ifdef ZCL_DISCOVER
    static uint8 zclSampleLight_ProcessInDiscCmdsRspCmd( zclIncomingMsg_t *pInMsg );
    static uint8 zclSampleLight_ProcessInDiscAttrsRspCmd( zclIncomingMsg_t *pInMsg );
    static uint8 zclSampleLight_ProcessInDiscAttrsExtRspCmd( zclIncomingMsg_t *pInMsg );
    #endif
     * STATUS STRINGS
    const char sDeviceName[]   = "  Sample Light";
    const char sClearLine[]    = " ";
    const char sSwLight[]      = "SW1: ToggleLight";  // 16 chars max
    const char sSwEZMode[]     = "SW2: EZ-Mode";
    char sSwHelp[]             = "SW5: Help       ";  // last character is * if NWK open
    const char sLightOn[]      = "    LIGHT ON ";
    const char sLightOff[]     = "    LIGHT OFF";
     #if ZCL_LEVEL_CTRL
     char sLightLevel[]        = "    LEVEL ###"; // displays level 1-254
     #endif
    #endif
     * ZCL General Profile Callback table
    static zclGeneral_AppCallbacks_t zclSampleLight_CmdCallbacks =
      zclSampleLight_BasicResetCB,            // Basic Cluster Reset command
      zclSampleLight_IdentifyCB,              // Identify command
    #ifdef ZCL_EZMODE
      NULL,                                   // Identify EZ-Mode Invoke command
      NULL,                                   // Identify Update Commission State command
    #endif
      NULL,                                   // Identify Trigger Effect command
      zclSampleLight_IdentifyQueryRspCB,      // Identify Query Response command
      zclSampleLight_OnOffCB,                 // On/Off cluster commands
      NULL,                                   // On/Off cluster enhanced command Off with Effect
      NULL,                                   // On/Off cluster enhanced command On with Recall Global Scene
      NULL,                                   // On/Off cluster enhanced command On with Timed Off
      zclSampleLight_LevelControlMoveToLevelCB, // Level Control Move to Level command
      zclSampleLight_LevelControlMoveCB,        // Level Control Move command
      zclSampleLight_LevelControlStepCB,        // Level Control Step command
      zclSampleLight_LevelControlStopCB,        // Level Control Stop command
    #endif
    #ifdef ZCL_GROUPS
      NULL,                                   // Group Response commands
    #endif
    #ifdef ZCL_SCENES
      NULL,                                  // Scene Store Request command
      NULL,                                  // Scene Recall Request command
      NULL,                                  // Scene Response command
    #endif
    #ifdef ZCL_ALARMS
      NULL,                                  // Alarm (Response) commands
    #endif
    #ifdef SE_UK_EXT
      NULL,                                  // Get Event Log command
      NULL,                                  // Publish Event Log command
    #endif
      NULL,                                  // RSSI Location command
      NULL                                   // RSSI Location Response command
     * @fn          zclSampleLight_Init
     * @brief       Initialization function for the zclGeneral layer.
     * @param       none
     * @return      none
      zclSampleLight_TaskID = task_id;
      // Set destination address to indirect
      zclSampleLight_DstAddr.addrMode = (afAddrMode_t)AddrNotPresent;
      zclSampleLight_DstAddr.endPoint = 0;
      zclSampleLight_DstAddr.addr.shortAddr = 0;
      // This app is part of the Home Automation Profile
      zclHA_Init( &zclSampleLight_SimpleDesc );
      // Register the ZCL General Cluster Library callback functions
      zclGeneral_RegisterCmdCallbacks( SAMPLELIGHT_ENDPOINT, &zclSampleLight_CmdCallbacks );
      // Register the application's attribute list
      zcl_registerAttrList( SAMPLELIGHT_ENDPOINT, zclSampleLight_NumAttributes, zclSampleLight_Attrs );
      // Register the Application to receive the unprocessed Foundation command/response messages
      zcl_registerForMsg( zclSampleLight_TaskID );
    #ifdef ZCL_DISCOVER
      // Register the application's command list
      zcl_registerCmdList( SAMPLELIGHT_ENDPOINT, zclCmdsArraySize, zclSampleLight_Cmds );
    #endif
      // Register for all key events - This app will handle all key events
      RegisterForKeys( zclSampleLight_TaskID );
      // Register for a test endpoint
      afRegister( &sampleLight_TestEp );
    #ifdef ZCL_EZMODE
      // Register EZ-Mode
      zcl_RegisterEZMode( &zclSampleLight_RegisterEZModeData );
      // Register with the ZDO to receive Match Descriptor Responses
      ZDO_RegisterForZDOMsg(task_id, Match_Desc_rsp);
    #endif
      HalTimer1Init( 0 );
      halTimer1SetChannelDuty( WHITE_LED, 0 );
      halTimer1SetChannelDuty( RED_LED, 0 );
      halTimer1SetChannelDuty( BLUE_LED, 0 );
      halTimer1SetChannelDuty( GREEN_LED, 0 );
      // find if we are already on a network from NV_RESTORE
      uint8 state;
      NLME_GetRequest( nwkNwkState, 0, &state );
      if ( state < NWK_ENDDEVICE )
        // Start EZMode on Start up to avoid button press
        osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_START_EZMODE_EVT, 500 );
    #if ZCL_LEVEL_CTRL
      zclSampleLight_DefaultMove();
    #endif
    #endif // #if (defined HAL_BOARD_ZLIGHT) || (defined HAL_PWM)
    #ifdef ZCL_DIAGNOSTIC
      // Register the application's callback function to read/write attribute data.
      // This is only required when the attribute data format is unknown to ZCL.
      zcl_registerReadWriteCB( SAMPLELIGHT_ENDPOINT, zclDiagnostic_ReadWriteAttrCB, NULL );
      if ( zclDiagnostic_InitStats() == ZSuccess )
        // Here the user could start the timer to save Diagnostics to NV
    #endif
      HalLcdWriteString ( (char *)sDeviceName, HAL_LCD_LINE_3 );
    #endif  // LCD_SUPPORTED
    #ifdef ZGP_AUTO_TT
      zgpTranslationTable_RegisterEP ( &zclSampleLight_SimpleDesc );
    #endif
      osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_LIGHT_WATCHDOG_EVT, 100);
     * @fn          zclSample_event_loop
     * @brief       Event Loop Processor for zclGeneral.
     * @param       none
     * @return      none
      afIncomingMSGPacket_t *MSGpkt;
      (void)task_id;  // Intentionally unreferenced parameter
      if ( events & SYS_EVENT_MSG )
        while ( (MSGpkt = (afIncomingMSGPacket_t *)osal_msg_receive( zclSampleLight_TaskID )) )
          switch ( MSGpkt->hdr.event )
    #ifdef ZCL_EZMODE
            case ZDO_CB_MSG:
              zclSampleLight_ProcessZDOMsgs( (zdoIncomingMsg_t *)MSGpkt );
              break;
    #endif
            case ZCL_INCOMING_MSG:
              // Incoming ZCL Foundation command/response messages
              zclSampleLight_ProcessIncomingMsg( (zclIncomingMsg_t *)MSGpkt );
              break;
            case KEY_CHANGE:
              zclSampleLight_HandleKeys( ((keyChange_t *)MSGpkt)->state, ((keyChange_t *)MSGpkt)->keys );
              break;
            case ZDO_STATE_CHANGE:
              zclSampleLight_NwkState = (devStates_t)(MSGpkt->hdr.status);
              // now on the network
              if ( (zclSampleLight_NwkState == DEV_ZB_COORD) ||
                   (zclSampleLight_NwkState == DEV_ROUTER)   ||
                   (zclSampleLight_NwkState == DEV_END_DEVICE) )
                zclSampleLight_LcdDisplayUpdate();
    #ifdef ZCL_EZMODE
                zcl_EZModeAction( EZMODE_ACTION_NETWORK_STARTED, NULL );
              break;
            default:
              break;
          // Release the memory
          osal_msg_deallocate( (uint8 *)MSGpkt );
        // return unprocessed events
        return (events ^ SYS_EVENT_MSG);
      if ( events & SAMPLELIGHT_IDENTIFY_TIMEOUT_EVT )
        if ( zclSampleLight_IdentifyTime > 0 )
          zclSampleLight_IdentifyTime--;
        zclSampleLight_ProcessIdentifyTimeChange();
        return ( events ^ SAMPLELIGHT_IDENTIFY_TIMEOUT_EVT );
      if ( events & SAMPLELIGHT_MAIN_SCREEN_EVT )
        return ( events ^ SAMPLELIGHT_MAIN_SCREEN_EVT );
    #ifdef ZCL_EZMODE
      // event to start EZMode on startup with a delay
      if ( events & SAMPLELIGHT_START_EZMODE_EVT )
        // Invoke EZ-Mode
        zclEZMode_InvokeData_t ezModeData;
        // Invoke EZ-Mode
        ezModeData.endpoint = SAMPLELIGHT_ENDPOINT; // endpoint on which to invoke EZ-Mode
          ezModeData.onNetwork = TRUE;      // node is already on the network
        else
          ezModeData.onNetwork = FALSE;     // node is not yet on the network
        ezModeData.initiator = FALSE;          // OnOffLight is a target
        ezModeData.numActiveOutClusters = 0;
        ezModeData.pActiveOutClusterIDs = NULL;
        ezModeData.numActiveInClusters = 0;
        zcl_InvokeEZMode( &ezModeData );
        return ( events ^ SAMPLELIGHT_START_EZMODE_EVT );
      // going on to next state
      if ( events & SAMPLELIGHT_EZMODE_NEXTSTATE_EVT )
        zcl_EZModeAction ( EZMODE_ACTION_PROCESS, NULL );   // going on to next state
        return ( events ^ SAMPLELIGHT_EZMODE_NEXTSTATE_EVT );
      // the overall EZMode timer expired, so we timed out
      if ( events & SAMPLELIGHT_EZMODE_TIMEOUT_EVT )
        zcl_EZModeAction ( EZMODE_ACTION_TIMED_OUT, NULL ); // EZ-Mode timed out
        return ( events ^ SAMPLELIGHT_EZMODE_TIMEOUT_EVT );
    #endif // ZLC_EZMODE
      if ( events & SAMPLELIGHT_LEVEL_CTRL_EVT )
        zclSampleLight_AdjustLightLevel();
        return ( events ^ SAMPLELIGHT_LEVEL_CTRL_EVT );
    #endif
        WatchdogClear();
      // Discard unknown events
      return 0;
     * @fn      zclSampleLight_HandleKeys
     * @brief   Handles all key events for this device.
     * @param   shift - true if in shift/alt.
     * @param   keys - bit field for key events. Valid entries:
     *                 HAL_KEY_SW_5
     *                 HAL_KEY_SW_4
     *                 HAL_KEY_SW_2
     *                 HAL_KEY_SW_1
     * @return  none
      if ( keys & HAL_KEY_SW_1 )
        // toggle local light immediately
        zclSampleLight_OnOff = zclSampleLight_OnOff ? LIGHT_OFF : LIGHT_ON;
        zclSampleLight_LevelCurrentLevel = zclSampleLight_OnOff ? zclSampleLight_LevelOnLevel : ATTR_LEVEL_MIN_LEVEL;
    #endif
      if ( keys & HAL_KEY_SW_2 )
        zclSampleLight_BasicResetCB();
    #else
    #ifdef ZCL_EZMODE
          // Invoke EZ-Mode
          // Invoke EZ-Mode
          else
    #else // NOT EZ-Mode
          zAddrType_t dstAddr;
          HalLedSet ( HAL_LED_4, HAL_LED_MODE_OFF );
          // Initiate an End Device Bind Request, this bind request will
          // only use a cluster list that is important to binding.
          dstAddr.addrMode = afAddr16Bit;
          dstAddr.addr.shortAddr = 0;   // Coordinator makes the match
          ZDP_EndDeviceBindReq( &dstAddr, NLME_GetShortAddr(),
                               ZCL_HA_PROFILE_ID,
                               ZCLSAMPLELIGHT_BINDINGLIST, bindingInClusters,
                               0, NULL,   // No Outgoing clusters to bind
                               TRUE );
    #endif // HAL_BOARD_ZLIGHT
      if ( keys & HAL_KEY_SW_3 )
        NLME_SendNetworkStatus( zclSampleLight_DstAddr.addr.shortAddr,
                           NLME_GetShortAddr(), NWKSTAT_NONTREE_LINK_FAILURE, FALSE );
      if ( keys & HAL_KEY_SW_4 )
        if ( ( zclSampleLight_NwkState == DEV_ZB_COORD ) ||
              ( zclSampleLight_NwkState == DEV_ROUTER ) )
          zAddrType_t tmpAddr;
          tmpAddr.addrMode = Addr16Bit;
          tmpAddr.addr.shortAddr = NLME_GetShortAddr();
          // toggle permit join
          gPermitDuration = gPermitDuration ? 0 : 0xff;
          // Trust Center significance is always true
          ZDP_MgmtPermitJoinReq( &tmpAddr, gPermitDuration, TRUE, FALSE );
      // Shift F5 does a Basic Reset (factory defaults)
      if ( shift && ( keys & HAL_KEY_SW_5 ) )
      else if ( keys & HAL_KEY_SW_5 )
        giLightScreenMode = giLightScreenMode ? LIGHT_MAINMODE : LIGHT_HELPMODE;
      // update the display, including the light
     * @fn      zclSampleLight_LcdDisplayUpdate
     * @brief   Called to update the LCD display.
     * @param   none
     * @return  none
      if ( giLightScreenMode == LIGHT_HELPMODE )
        zclSampleLight_LcdDisplayHelpMode();
      else
        zclSampleLight_LcdDisplayMainMode();
    #endif
      zclSampleLight_DisplayLight();
     * @fn      zclSampleLight_UpdateLampLevel
     * @brief   Update lamp level output with gamma compensation
     * @param   level
     * @return  none
      uint16 gammaCorrectedLevel;
      // gamma correct the level
      gammaCorrectedLevel = (uint16) ( pow( ( (float)level / LEVEL_MAX ), (float)GAMMA_VALUE ) * (float)LEVEL_MAX);
      halTimer1SetChannelDuty(WHITE_LED, (uint16)(((uint32)gammaCorrectedLevel*PWM_FULL_DUTY_CYCLE)/LEVEL_MAX) );
    #endif
     * @fn      zclSampleLight_DisplayLight
     * @brief   Displays current state of light on LED and also on main display if supported.
     * @param   none
     * @return  none
      // set the LED1 based on light (on or off)
      if ( zclSampleLight_OnOff == LIGHT_ON )
        HalLedSet ( HAL_LED_1, HAL_LED_MODE_ON );
      else
        HalLedSet ( HAL_LED_1, HAL_LED_MODE_OFF );
      if (giLightScreenMode == LIGHT_MAINMODE)
        // display current light level
        if ( ( zclSampleLight_LevelCurrentLevel == ATTR_LEVEL_MIN_LEVEL ) &&
             ( zclSampleLight_OnOff == LIGHT_OFF ) )
          HalLcdWriteString( (char *)sLightOff, HAL_LCD_LINE_2 );
        else if ( ( zclSampleLight_LevelCurrentLevel >= ATTR_LEVEL_MAX_LEVEL ) ||
                  ( zclSampleLight_LevelCurrentLevel == zclSampleLight_LevelOnLevel ) ||
                   ( ( zclSampleLight_LevelOnLevel == ATTR_LEVEL_ON_LEVEL_NO_EFFECT ) &&
                     ( zclSampleLight_LevelCurrentLevel == zclSampleLight_LevelLastLevel ) ) )
          HalLcdWriteString( (char *)sLightOn, HAL_LCD_LINE_2 );
        else    // "    LEVEL ###"
          zclHA_uint8toa( zclSampleLight_LevelCurrentLevel, &sLightLevel[10] );
          HalLcdWriteString( (char *)sLightLevel, HAL_LCD_LINE_2 );
    #else
        if ( zclSampleLight_OnOff )
        else
    #endif // ZCL_LEVEL_CTRL
     * @fn      zclSampleLight_LcdDisplayMainMode
     * @brief   Called to display the main screen on the LCD.
     * @param   none
     * @return  none
      // display line 1 to indicate NWK status
      if ( zclSampleLight_NwkState == DEV_ZB_COORD )
        zclHA_LcdStatusLine1( ZCL_HA_STATUSLINE_ZC );
      else if ( zclSampleLight_NwkState == DEV_ROUTER )
        zclHA_LcdStatusLine1( ZCL_HA_STATUSLINE_ZR );
      else if ( zclSampleLight_NwkState == DEV_END_DEVICE )
        zclHA_LcdStatusLine1( ZCL_HA_STATUSLINE_ZED );
      // end of line 3 displays permit join status (*)
      if ( gPermitDuration )
        sSwHelp[15] = '*';
      else
        sSwHelp[15] = ' ';
      HalLcdWriteString( (char *)sSwHelp, HAL_LCD_LINE_3 );
     * @fn      zclSampleLight_LcdDisplayHelpMode
     * @brief   Called to display the SW options on the LCD.
     * @param   none
     * @return  none
      HalLcdWriteString( (char *)sSwLight, HAL_LCD_LINE_1 );
      HalLcdWriteString( (char *)sSwEZMode, HAL_LCD_LINE_2 );
     * @fn      zclSampleLight_ProcessIdentifyTimeChange
     * @brief   Called to process any change to the IdentifyTime attribute.
     * @param   none
     * @return  none
        osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_IDENTIFY_TIMEOUT_EVT, 1000 );
        HalLedBlink ( HAL_LED_4, 0xFF, HAL_LED_DEFAULT_DUTY_CYCLE, HAL_LED_DEFAULT_FLASH_TIME );
      else
    #ifdef ZCL_EZMODE
        if ( zclSampleLight_IdentifyCommissionState & EZMODE_COMMISSION_OPERATIONAL )
          HalLedSet ( HAL_LED_4, HAL_LED_MODE_ON );
        else
    #endif
        osal_stop_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_IDENTIFY_TIMEOUT_EVT );
     * @fn      zclSampleLight_BasicResetCB
     * @brief   Callback from the ZCL General Cluster Library
     *          to set all the Basic Cluster attributes to default values.
     * @param   none
     * @return  none
      NLME_LeaveReq_t leaveReq;
      // Set every field to 0
      osal_memset( &leaveReq, 0, sizeof( NLME_LeaveReq_t ) );
      // This will enable the device to rejoin the network after reset.
      leaveReq.rejoin = TRUE;
      // Set the NV startup option to force a "new" join.
      zgWriteStartupOptions( ZG_STARTUP_SET, ZCD_STARTOPT_DEFAULT_NETWORK_STATE );
      // Leave the network, and reset afterwards
      if ( NLME_LeaveReq( &leaveReq ) != ZSuccess )
        // Couldn't send out leave; prepare to reset anyway
        ZDApp_LeaveReset( FALSE );
     * @fn      zclSampleLight_IdentifyCB
     * @brief   Callback from the ZCL General Cluster Library when
     *          it received an Identity Command for this application.
     * @param   srcAddr - source address and endpoint of the response message
     * @param   identifyTime - the number of seconds to identify yourself
     * @return  none
      zclSampleLight_IdentifyTime = pCmd->identifyTime;
     * @fn      zclSampleLight_IdentifyQueryRspCB
     *          it received an Identity Query Response Command for this application.
     * @param   srcAddr - requestor's address
     * @param   timeout - number of seconds to identify yourself (valid for query response)
     * @return  none
      (void)pRsp;
    #ifdef ZCL_EZMODE
        zclEZMode_ActionData_t data;
        data.pIdentifyQueryRsp = pRsp;
        zcl_EZModeAction ( EZMODE_ACTION_IDENTIFY_QUERY_RSP, &data );
    #endif
     * @fn      zclSampleLight_OnOffCB
     *          it received an On/Off Command for this application.
     * @param   cmd - COMMAND_ON, COMMAND_OFF or COMMAND_TOGGLE
     * @return  none
      afIncomingMSGPacket_t *pPtr = zcl_getRawAFMsg();
      zclSampleLight_DstAddr.addr.shortAddr = pPtr->srcAddr.addr.shortAddr;
      // Turn on the light
      if ( cmd == COMMAND_ON )
        zclSampleLight_OnOff = LIGHT_ON;
      // Turn off the light
      else if ( cmd == COMMAND_OFF )
        zclSampleLight_OnOff = LIGHT_OFF;
      // Toggle the light
      else if ( cmd == COMMAND_TOGGLE )
        if ( zclSampleLight_OnOff == LIGHT_OFF )
        else
    #if ZCL_LEVEL_CTRL
      zclSampleLight_DefaultMove( );
    #endif
      zclSampleLight_LcdDisplayUpdate( );
     * @fn      zclSampleLight_TimeRateHelper
     * @brief   Calculate time based on rate, and startup level state machine
     * @param   newLevel - new level for current level
     * @return  diff (directly), zclSampleLight_CurrentLevel32 and zclSampleLight_NewLevel, zclSampleLight_NewLevelUp
      uint32 diff;
      uint32 newLevel32;
      // remember current and new level
      zclSampleLight_NewLevel = newLevel;
      zclSampleLight_CurrentLevel32 = (uint32)1000 * zclSampleLight_LevelCurrentLevel;
      // calculate diff
      newLevel32 = (uint32)1000 * newLevel;
      if ( zclSampleLight_LevelCurrentLevel > newLevel )
        diff = zclSampleLight_CurrentLevel32 - newLevel32;
        zclSampleLight_NewLevelUp = FALSE;  // moving down
      else
        diff = newLevel32 - zclSampleLight_CurrentLevel32;
        zclSampleLight_NewLevelUp = TRUE;   // moving up
      return ( diff );
     * @fn      zclSampleLight_MoveBasedOnRate
     * @param   rate16   - fixed point rate (e.g. 16.123)
     * @return  none
      uint32 diff;
      // determine how much time (in 10ths of seconds) based on the difference and rate
      zclSampleLight_Rate32 = rate;
      diff = zclSampleLight_TimeRateHelper( newLevel );
      zclSampleLight_LevelRemainingTime = diff / rate;
      if ( !zclSampleLight_LevelRemainingTime )
        zclSampleLight_LevelRemainingTime = 1;
      osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_LEVEL_CTRL_EVT, 100 );
     * @fn      zclSampleLight_MoveBasedOnTime
     * @brief   Calculate rate based on time, and startup level state machine
     * @param   time      - in 10ths of seconds
     * @return  none
      uint16 diff;
      // determine rate (in units) based on difference and time
      zclSampleLight_LevelRemainingTime = zclSampleLight_GetTime( newLevel, time );
      zclSampleLight_Rate32 = diff / time;
     * @fn      zclSampleLight_GetTime
     * @brief   Determine amount of time that MoveXXX will take to complete.
     * @param   level = new level to move to
     *          time  = 0xffff=default, or 0x0000-n amount of time in tenths of seconds.
     * @return  none
    static uint16 zclSampleLight_GetTime( uint8 level, uint16 time )
      // there is a hiearchy of the amount of time to use for transistioning
      // check each one in turn. If none of defaults are set, then use fastest
      // time possible.
      if ( time == 0xFFFF )
        // use On or Off Transition Time if set (not 0xffff)
          time = zclSampleLight_LevelOffTransitionTime;
        else
          time = zclSampleLight_LevelOnTransitionTime;
        // else use OnOffTransitionTime if set (not 0xffff)
          time = zclSampleLight_LevelOnOffTransitionTime;
        // else as fast as possible
          time = 1;
      if ( !time )
        time = 1; // as fast as possible
      return ( time );
     * @fn      zclSampleLight_DefaultMove
     * @brief   We were turned on/off. Use default time to move to on or off.
     * @param   zclSampleLight_OnOff - must be set prior to calling this function.
     * @return  none
      uint8  newLevel;
      uint32 rate;      // fixed point decimal (3 places, eg. 16.345)
      uint16 time;
      // if moving to on position, move to on level
        if ( zclSampleLight_LevelOnLevel == ATTR_LEVEL_ON_LEVEL_NO_EFFECT )
          // The last Level (before going OFF) should be used)
          newLevel = zclSampleLight_LevelLastLevel;
        else
          newLevel = zclSampleLight_LevelOnLevel;
      else
        newLevel = ATTR_LEVEL_MIN_LEVEL;
          // Save the current Level before going OFF to use it when the light turns ON
          // it should be back to this level
          zclSampleLight_LevelLastLevel = zclSampleLight_LevelCurrentLevel;
        time = 1;
      // calculate rate based on time (int 10ths) for full transition (1-254)
      rate = 255000 / time;    // units per tick, fixed point, 3 decimal places (e.g. 8500 = 8.5 units per tick)
      // start up state machine.
      zclSampleLight_WithOnOff = TRUE;
      zclSampleLight_MoveBasedOnRate( newLevel, rate );
     * @fn      zclSampleLight_AdjustLightLevel
     * @brief   Called each 10th of a second while state machine running
     * @param   none
     * @return  none
      // one tick (10th of a second) less
      if ( zclSampleLight_LevelRemainingTime )
        --zclSampleLight_LevelRemainingTime;
      // no time left, done
      if ( zclSampleLight_LevelRemainingTime == 0)
        zclSampleLight_LevelCurrentLevel = zclSampleLight_NewLevel;
      // still time left, keep increment/decrementing
      else
        if ( zclSampleLight_NewLevelUp )
          zclSampleLight_CurrentLevel32 += zclSampleLight_Rate32;
        else
          zclSampleLight_CurrentLevel32 -= zclSampleLight_Rate32;
        zclSampleLight_LevelCurrentLevel = (uint8)( zclSampleLight_CurrentLevel32 / 1000 );
      zclSampleLight_UpdateLampLevel(zclSampleLight_LevelCurrentLevel);
    #endif
      // also affect on/off
      if ( zclSampleLight_WithOnOff )
        if ( zclSampleLight_LevelCurrentLevel > ATTR_LEVEL_MIN_LEVEL )
          ENABLE_LAMP;
    #endif
        else
          DISABLE_LAMP;
    #endif
      // display light level as we go
      zclSampleLight_DisplayLight( );
      // keep ticking away
     * @fn      zclSampleLight_LevelControlMoveToLevelCB
     *          it received a LevelControlMoveToLevel Command for this application.
     * @param   pCmd - ZigBee command parameters
     * @return  none
      zclSampleLight_WithOnOff = pCmd->withOnOff;
      zclSampleLight_MoveBasedOnTime( pCmd->level, pCmd->transitionTime );
     * @fn      zclSampleLight_LevelControlMoveCB
     *          it received a LevelControlMove Command for this application.
     * @return  none
      uint8 newLevel;
      uint32 rate;
      // convert rate from units per second to units per tick (10ths of seconds)
      // and move at that right up or down
      if ( pCmd->moveMode == LEVEL_MOVE_UP )
        newLevel = ATTR_LEVEL_MAX_LEVEL;  // fully on
      else
        newLevel = ATTR_LEVEL_MIN_LEVEL; // fully off
      rate = (uint32)100 * pCmd->rate;
     * @fn      zclSampleLight_LevelControlStepCB
     * @return  none
      uint8 newLevel;
      // determine new level, but don't exceed boundaries
      if ( pCmd->stepMode == LEVEL_MOVE_UP )
        if ( (uint16)zclSampleLight_LevelCurrentLevel + pCmd->amount > ATTR_LEVEL_MAX_LEVEL )
        else
          newLevel = zclSampleLight_LevelCurrentLevel + pCmd->amount;
      else
        if ( pCmd->amount >= zclSampleLight_LevelCurrentLevel )
        else
          newLevel = zclSampleLight_LevelCurrentLevel - pCmd->amount;
      // move to the new level
      zclSampleLight_MoveBasedOnTime( newLevel, pCmd->transitionTime );
     * @fn      zclSampleLight_LevelControlStopCB
     *          it received an Level Control Stop Command for this application.
     * @return  none
      // stop immediately
      osal_stop_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_LEVEL_CTRL_EVT );
      zclSampleLight_LevelRemainingTime = 0;
    #endif
     *  Functions for processing ZCL Foundation incoming Command/Response messages
     * @fn      zclSampleLight_ProcessIncomingMsg
     * @brief   Process ZCL Foundation incoming message
     * @param   pInMsg - pointer to the received message
     * @return  none
    static void zclSampleLight_ProcessIncomingMsg( zclIncomingMsg_t *pInMsg )
      switch ( pInMsg->zclHdr.commandID )
    #ifdef ZCL_READ
        case ZCL_CMD_READ_RSP:
          zclSampleLight_ProcessInReadRspCmd( pInMsg );
          break;
    #endif
    #ifdef ZCL_WRITE
        case ZCL_CMD_WRITE_RSP:
          zclSampleLight_ProcessInWriteRspCmd( pInMsg );
          break;
    #endif
    #ifdef ZCL_REPORT
        // Attribute Reporting implementation should be added here
        case ZCL_CMD_CONFIG_REPORT:
          // zclSampleLight_ProcessInConfigReportCmd( pInMsg );
          break;
        case ZCL_CMD_CONFIG_REPORT_RSP:
          // zclSampleLight_ProcessInConfigReportRspCmd( pInMsg );
          break;
        case ZCL_CMD_READ_REPORT_CFG:
          // zclSampleLight_ProcessInReadReportCfgCmd( pInMsg );
          break;
        case ZCL_CMD_READ_REPORT_CFG_RSP:
          // zclSampleLight_ProcessInReadReportCfgRspCmd( pInMsg );
          break;
        case ZCL_CMD_REPORT:
          // zclSampleLight_ProcessInReportCmd( pInMsg );
          break;
    #endif
        case ZCL_CMD_DEFAULT_RSP:
          zclSampleLight_ProcessInDefaultRspCmd( pInMsg );
          break;
    #ifdef ZCL_DISCOVER
        case ZCL_CMD_DISCOVER_CMDS_RECEIVED_RSP:
          zclSampleLight_ProcessInDiscCmdsRspCmd( pInMsg );
          break;
        case ZCL_CMD_DISCOVER_CMDS_GEN_RSP:
          break;
        case ZCL_CMD_DISCOVER_ATTRS_RSP:
          zclSampleLight_ProcessInDiscAttrsRspCmd( pInMsg );
          break;
        case ZCL_CMD_DISCOVER_ATTRS_EXT_RSP:
          zclSampleLight_ProcessInDiscAttrsExtRspCmd( pInMsg );
          break;
    #endif
        default:
          break;
      if ( pInMsg->attrCmd )
        osal_mem_free( pInMsg->attrCmd );
    #ifdef ZCL_READ
     * @fn      zclSampleLight_ProcessInReadRspCmd
     * @brief   Process the "Profile" Read Response Command
     * @param   pInMsg - incoming message to process
     * @return  none
      zclReadRspCmd_t *readRspCmd;
      uint8 i;
      readRspCmd = (zclReadRspCmd_t *)pInMsg->attrCmd;
      for (i = 0; i < readRspCmd->numAttr; i++)
        // Notify the originator of the results of the original read attributes
        // attempt and, for each successfull request, the value of the requested
        // attribute
      return ( TRUE );
    #endif // ZCL_READ
    #ifdef ZCL_WRITE
     * @fn      zclSampleLight_ProcessInWriteRspCmd
     * @brief   Process the "Profile" Write Response Command
     * @return  none
      zclWriteRspCmd_t *writeRspCmd;
      uint8 i;
      writeRspCmd = (zclWriteRspCmd_t *)pInMsg->attrCmd;
      for ( i = 0; i < writeRspCmd->numAttr; i++ )
        // Notify the device of the results of the its original write attributes
        // command.
      return ( TRUE );
    #endif // ZCL_WRITE
     * @fn      zclSampleLight_ProcessInDefaultRspCmd
     * @brief   Process the "Profile" Default Response Command
     * @return  none
      // zclDefaultRspCmd_t *defaultRspCmd = (zclDefaultRspCmd_t *)pInMsg->attrCmd;
      // Device is notified of the Default Response command.
      (void)pInMsg;
      return ( TRUE );
    #ifdef ZCL_DISCOVER
     * @fn      zclSampleLight_ProcessInDiscCmdsRspCmd
     * @brief   Process the Discover Commands Response Command
     * @return  none
      zclDiscoverCmdsCmdRsp_t *discoverRspCmd;
      uint8 i;
      discoverRspCmd = (zclDiscoverCmdsCmdRsp_t *)pInMsg->attrCmd;
      for ( i = 0; i < discoverRspCmd->numCmd; i++ )
        // Device is notified of the result of its attribute discovery command.
      return ( TRUE );
     * @fn      zclSampleLight_ProcessInDiscAttrsRspCmd
     * @brief   Process the "Profile" Discover Attributes Response Command
     * @return  none
      zclDiscoverAttrsRspCmd_t *discoverRspCmd;
      uint8 i;
      discoverRspCmd = (zclDiscoverAttrsRspCmd_t *)pInMsg->attrCmd;
      for ( i = 0; i < discoverRspCmd->numAttr; i++ )
      return ( TRUE );
     * @fn      zclSampleLight_ProcessInDiscAttrsExtRspCmd
     * @brief   Process the "Profile" Discover Attributes Extended Response Command
     * @return  none
      zclDiscoverAttrsExtRsp_t *discoverRspCmd;
      uint8 i;
      discoverRspCmd = (zclDiscoverAttrsExtRsp_t *)pInMsg->attrCmd;
      return ( TRUE );
    #endif // ZCL_DISCOVER
    #if ZCL_EZMODE
     * @fn      zclSampleLight_ProcessZDOMsgs
     * @brief   Called when this node receives a ZDO/ZDP response.
     * @param   none
     * @return  status
      ZDO_MatchDescRsp_t *pMatchDescRsp;
      // Let EZ-Mode know of the Simple Descriptor Response
      if ( pMsg->clusterID == Match_Desc_rsp )
        pMatchDescRsp = ZDO_ParseEPListRsp( pMsg );
        data.pMatchDescRsp = pMatchDescRsp;
        zcl_EZModeAction( EZMODE_ACTION_MATCH_DESC_RSP, &data );
        osal_mem_free( pMatchDescRsp );
     * @fn      zclSampleLight_EZModeCB
     * @brief   The Application is informed of events. This can be used to show on the UI what is
    *           going on during EZ-Mode steering/finding/binding.
     * @param   state - an
     * @return  none
      char *pStr;
      uint8 err;
    #endif
      // time to go into identify mode
      if ( state == EZMODE_STATE_IDENTIFYING )
        HalLcdWriteString( "EZMode", HAL_LCD_LINE_2 );
    #endif
        zclSampleLight_IdentifyTime = ( EZMODE_TIME / 1000 );  // convert to seconds
      // autoclosing, show what happened (success, cancelled, etc...)
      if( state == EZMODE_STATE_AUTOCLOSE )
        pStr = NULL;
        err = pData->sAutoClose.err;
        if ( err == EZMODE_ERR_SUCCESS )
          pStr = "EZMode: Success";
        else if ( err == EZMODE_ERR_NOMATCH )
          pStr = "EZMode: NoMatch"; // not a match made in heaven
        if ( pStr )
          if ( giLightScreenMode == LIGHT_MAINMODE )
            HalLcdWriteString ( pStr, HAL_LCD_LINE_2 );
    #endif
      // finished, either show DstAddr/EP, or nothing (depending on success or not)
      if( state == EZMODE_STATE_FINISH )
        // turn off identify mode
        zclSampleLight_IdentifyTime = 0;
        // if successful, inform user which nwkaddr/ep we bound to
        pStr = NULL;
        err = pData->sFinish.err;
        if( err == EZMODE_ERR_SUCCESS )
          // already stated on autoclose
        else if ( err == EZMODE_ERR_CANCELLED )
          pStr = "EZMode: Cancel";
        else if ( err == EZMODE_ERR_BAD_PARAMETER )
          pStr = "EZMode: BadParm";
        else if ( err == EZMODE_ERR_TIMEDOUT )
          pStr = "EZMode: TimeOut";
        if ( pStr )
    #endif
        // show main UI screen 3 seconds after binding
        osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_MAIN_SCREEN_EVT, 3000 );
  • these are my project files.
      Revised:        $Date: 2014-07-01 22:24:24 -0700 (Tue, 01 Jul 2014) $
      Revision:       $Revision: 39317 $
      ZCL_ON_OFF
      HOLD_AUTO_START
      ZCL_EZMODE
      SCREEN MODES
      Main:
     * INCLUDES
    #include "OSAL.h"
    #include "AF.h"
    #include "ZDApp.h"
    #include "MT_SYS.h"
    #include "zcl.h"
    #include "zcl_ha.h"
    /* HAL */
        #define ZGP_AUTO_TT
      #endif
    #endif
    #include "math.h"
    #endif
    #include "NLMEDE.h"
    #include "hal_adc.h"
     * MACROS
     * CONSTANTS
    #endif
    #define LIGHT_INTERVAL_DELAY_TIME            500
     * TYPEDEFS
     * GLOBAL VARIABLES
    byte zclSampleLight_ResetKeyPressed;
    byte zclSampleLight_LightDelay;
    uint16 maxSensorReadValue;
     * GLOBAL FUNCTIONS
     * LOCAL VARIABLES
    #ifdef ZCL_EZMODE
    #else
    #endif
    #if ZCL_LEVEL_CTRL
    #endif
     * LOCAL FUNCTIONS
    static void zclSampleLight_WatchDog_Loop(void);
    static void zclSampleLight_ReadSensorCurrent(void);
    static void zclSampleLight_SendSensorInformation(void);
    #endif
    #endif
    #endif
    #ifdef ZCL_READ
    #endif
    #ifdef ZCL_WRITE
    #endif
    #ifdef ZCL_DISCOVER
    #endif
     * STATUS STRINGS
     #if ZCL_LEVEL_CTRL
     #endif
    #endif
    #ifdef ZCL_EZMODE
    #endif
    #endif
    #ifdef ZCL_GROUPS
    #endif
    #ifdef ZCL_SCENES
    #endif
    #ifdef ZCL_ALARMS
    #endif
    #ifdef SE_UK_EXT
    #endif
     * @param       none
     * @return      none
    #ifdef ZCL_DISCOVER
    #endif
    #ifdef ZCL_EZMODE
      // Register EZ-Mode
    #endif
      HalTimer1Init( 0 );
      uint8 state;
    #if ZCL_LEVEL_CTRL
    #endif
    #endif
    #ifdef ZGP_AUTO_TT
    #endif
      osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_READ_SENSOR_CURRENT_EVT, 3000 );
      osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_REPORT_SENSOR_INFORMATION_EVT, 1 );
      HalLedBlink( HAL_LED_3, 255, 30, 1000 );
    #ifdef HAMID_PM1
      /* If WDT is used, this is a good place to enable it. */
    #endif
     * @param       none
     * @return      none
    #ifdef ZCL_EZMODE
            case ZDO_CB_MSG:
              break;
    #endif
              break;
            case KEY_CHANGE:
              osal_msg_send( zclSampleLight_TaskID+1, (uint8 *) MSGpkt );
              break;
    #ifdef ZCL_EZMODE
              break;
            default:
              break;
    #ifdef ZCL_EZMODE
        // Invoke EZ-Mode
        // Invoke EZ-Mode
        else
    #endif
      if ( events & SAMPLELIGHT_READ_SENSOR_CURRENT_EVT )
        zclSampleLight_ReadSensorCurrent();
        return ( events ^ SAMPLELIGHT_READ_SENSOR_CURRENT_EVT );
      if ( events & SAMPLELIGHT_REPORT_SENSOR_INFORMATION_EVT )
        zclSampleLight_SendSensorInformation();
        return ( events ^ SAMPLELIGHT_REPORT_SENSOR_INFORMATION_EVT );
       if ( events & SAMPLELIGHT_RESET_KEY_PRESSED_EVT )
        if(zclSampleLight_ResetKeyPressed==1){
          zclSampleLight_ResetKeyPressed=0;
        return ( events ^ SAMPLELIGHT_RESET_KEY_PRESSED_EVT );
       if ( events & SAMPLELIGHT_LIGHT_DELAY_EVT )
        zclSampleLight_LightDelay=0;
        return ( events ^ SAMPLELIGHT_LIGHT_DELAY_EVT );
      return 0;
     * @return  none
      WatchdogClear();
      osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_LIGHT_WATCHDOG_EVT, 900 );
     * @return  none
    static void zclSampleLight_SendSensorInformation(void){
        double iRMS;
        int16 maxMinusOffset=maxSensorReadValue-1650;
        if(maxMinusOffset<0)
          maxMinusOffset=-maxMinusOffset;
        iRMS=(maxMinusOffset*20);
        iRMS=iRMS/1650;
        iRMS=(iRMS/1.414)*1000;
        uint32 power=(uint32)(iRMS*220);
        maxSensorReadValue=0;
     #ifdef ZCL_REPORT
        afAddrType_t dstAddr1;
        dstAddr1.addrMode=(afAddrMode_t)Addr16Bit;
        dstAddr1.endPoint=3;
        dstAddr1.addr.shortAddr=0x0;
        zclReportCmd_t *rptcmd;
        rptcmd = osal_mem_alloc( sizeof(zclReportCmd_t) + sizeof(zclReport_t) );
        rptcmd->numAttr = 1;
        rptcmd->attrList[0].attrID = ATTRID_SENSOR_CURRENT_A4;
        rptcmd->attrList[0].dataType = ZCL_DATATYPE_UINT32;
        rptcmd->attrList[0].attrData = (uint8*)&power;
        zcl_SendReportCmd(SAMPLELIGHT_ENDPOINT, &dstAddr1, ZCL_CLUSTER_ID_GEN_ON_OFF, rptcmd,ZCL_FRAME_SERVER_CLIENT_DIR, false, zclSampleLightSeqNum );
        osal_mem_free( rptcmd );
    #endif
        osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_REPORT_SENSOR_INFORMATION_EVT, 3000 );
     * @return  none
    static void zclSampleLight_ReadSensorCurrent(void){
        uint16 value1 = HalAdcRead(HAL_ADC_CHANNEL_4,HAL_ADC_RESOLUTION_12);
        float volt=(value1*3.3)/2047;
        value1=(uint16)(volt*1000);
        uint16 value2 = HalAdcRead(HAL_ADC_CHANNEL_4,HAL_ADC_RESOLUTION_12);
        volt=(value2*3.3)/2047;
        value2=(uint16)(volt*1000);
        uint16 value3 = HalAdcRead(HAL_ADC_CHANNEL_4,HAL_ADC_RESOLUTION_12);
        volt=(value3*3.3)/2047;
        value3=(uint16)(volt*1000);
        uint16 value4 = HalAdcRead(HAL_ADC_CHANNEL_4,HAL_ADC_RESOLUTION_12);
        volt=(value4*3.3)/2047;
        value4=(uint16)(volt*1000);
        uint16 value = value1+value2+value3+value4;
        value=(uint16)value/4;
        if(value>maxSensorReadValue)
          maxSensorReadValue=value;
        osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_READ_SENSOR_CURRENT_EVT, 1 );
     *                 HAL_KEY_SW_5
     *                 HAL_KEY_SW_4
     *                 HAL_KEY_SW_2
     *                 HAL_KEY_SW_1
     * @return  none
          if(zclSampleLight_LightDelay==0){
        zclSampleLight_LightDelay=1;
        osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_LIGHT_DELAY_EVT, LIGHT_INTERVAL_DELAY_TIME );
    #endif
     #ifdef ZCL_REPORT
        rptcmd->attrList[0].attrID = ATTRID_ON_OFF;
        rptcmd->attrList[0].dataType = ZCL_DATATYPE_UINT8;
        rptcmd->attrList[0].attrData = (uint8*)&zclSampleLight_OnOff;
        zcl_SendReportCmd(SAMPLELIGHT_ENDPOINT, &dstAddr1,ZCL_CLUSTER_ID_GEN_ON_OFF, rptcmd,ZCL_FRAME_SERVER_CLIENT_DIR, false, zclSampleLightSeqNum );
        HalLcdWriteString( "Send Report", HAL_LCD_LINE_4 );
    #endif
    #else
    #ifdef ZCL_EZMODE
          // Invoke EZ-Mode
          // Invoke EZ-Mode
          else
                               ZCL_HA_PROFILE_ID,
                               TRUE );
        if(zclSampleLight_ResetKeyPressed==0){
            zclSampleLight_ResetKeyPressed=1;
          osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_RESET_KEY_PRESSED_EVT, 3000 );
          }else{
            zclSampleLight_ResetKeyPressed++;
          NLME_PermitJoiningRequest( gPermitDuration );
     * @param   none
     * @return  none
      else
    #endif
     * @param   level
     * @return  none
    #endif
     * @param   none
     * @return  none
      else
    #else
        else
     * @param   none
     * @return  none
        sSwHelp[15] = '*';
      else
        sSwHelp[15] = ' ';
     * @param   none
     * @return  none
     * @param   none
     * @return  none
      else
    #ifdef ZCL_EZMODE
        else
    #endif
     * @param   none
     * @return  none
     * @return  none
     * @return  none
      (void)pRsp;
    #ifdef ZCL_EZMODE
    #endif
     * @return  none
      // Toggle the light
        else
    #if ZCL_LEVEL_CTRL
    #endif
      uint32 diff;
      uint32 newLevel32;
      // calculate diff
      else
      return ( diff );
     * @return  none
      uint32 diff;
     * @return  none
      uint16 diff;
     * @return  none
      // time possible.
        else
          time = 1;
      if ( !time )
      return ( time );
     * @return  none
      uint8  newLevel;
      uint16 time;
        else
      else
        time = 1;
     * @param   none
     * @return  none
      else
        else
    #endif
          ENABLE_LAMP;
    #endif
        else
          DISABLE_LAMP;
    #endif
     * @return  none
     * @return  none
      uint8 newLevel;
      uint32 rate;
      else
     * @return  none
      uint8 newLevel;
        else
      else
        else
     * @return  none
      // stop immediately
    #endif
     * @return  none
    #ifdef ZCL_READ
          break;
    #endif
    #ifdef ZCL_WRITE
          break;
    #endif
    #ifdef ZCL_REPORT
          break;
          break;
          break;
          break;
          break;
    #endif
          break;
    #ifdef ZCL_DISCOVER
          break;
          break;
          break;
          break;
    #endif
        default:
          break;
    #ifdef ZCL_READ
     * @return  none
      uint8 i;
        // attribute
      return ( TRUE );
    #endif // ZCL_READ
    #ifdef ZCL_WRITE
     * @return  none
      uint8 i;
        // command.
      return ( TRUE );
    #endif // ZCL_WRITE
     * @return  none
      (void)pInMsg;
      return ( TRUE );
    #ifdef ZCL_DISCOVER
     * @return  none
      uint8 i;
      return ( TRUE );
     * @return  none
      uint8 i;
      return ( TRUE );
     * @return  none
      uint8 i;
      return ( TRUE );
    #if ZCL_EZMODE
     * @param   none
     * @return  status
     * @param   state - an
     * @return  none
      char *pStr;
      uint8 err;
    #endif
    #endif
        pStr = NULL;
        if ( pStr )
    #endif
        pStr = NULL;
        if ( pStr )
    #endif
    8816.zcl_samplelight.h
      Filename:       zcl_samplelight_data.c
      Revised:        $Date: 2014-05-12 13:14:02 -0700 (Mon, 12 May 2014) $
      Revision:       $Revision: 38502 $
     * INCLUDES
    #include "OSAL.h"
    #include "AF.h"
    #include "ZDConfig.h"
    #include "zcl.h"
    #include "zcl_ha.h"
    #include "zcl_poll_control.h"
    #include "zcl_electrical_measurement.h"
    #include "zcl_meter_identification.h"
    #include "zcl_appliance_identification.h"
    #include "zcl_appliance_events_alerts.h"
    #include "zcl_power_profile.h"
    #include "zcl_appliance_control.h"
    #include "zcl_appliance_statistics.h"
    #include "zcl_hvac.h"
     * CONSTANTS
    #define SAMPLELIGHT_DEVICE_VERSION     0
    #define SAMPLELIGHT_FLAGS              0
    #define SAMPLELIGHT_HWVERSION          1
    #define SAMPLELIGHT_ZCLVERSION         1
     * TYPEDEFS
     * MACROS
     * GLOBAL VARIABLES
    // Basic Cluster
    const uint8 zclSampleLight_HWRevision = SAMPLELIGHT_HWVERSION;
    const uint8 zclSampleLight_ZCLVersion = SAMPLELIGHT_ZCLVERSION;
    const uint8 zclSampleLight_ManufacturerName[] = { 16, 'T','e','x','a','s','I','n','s','t','r','u','m','e','n','t','s' };
    const uint8 zclSampleLight_ModelId[] = { 16, 'T','I','0','0','0','1',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ' };
    const uint8 zclSampleLight_DateCode[] = { 16, '2','0','0','6','0','8','3','1',' ',' ',' ',' ',' ',' ',' ',' ' };
    const uint8 zclSampleLight_PowerSource = POWER_SOURCE_MAINS_1_PHASE;
    uint8 zclSampleLight_LocationDescription[17] = { 16, ' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ' };
    uint8 zclSampleLight_PhysicalEnvironment = 0;
    uint8 zclSampleLight_DeviceEnable = DEVICE_ENABLED;
    // Identify Cluster
    uint16 zclSampleLight_IdentifyTime = 0;
    #ifdef ZCL_EZMODE
    uint8  zclSampleLight_IdentifyCommissionState;
    #endif
    // On/Off Cluster
    uint8  zclSampleLight_OnOff = LIGHT_OFF;
    // Level Control Cluster
    uint8  zclSampleLight_LevelCurrentLevel = ATTR_LEVEL_MIN_LEVEL;
    uint16 zclSampleLight_LevelRemainingTime;
    uint16 zclSampleLight_LevelOnOffTransitionTime = 20;
    uint8  zclSampleLight_LevelOnLevel = ATTR_LEVEL_MID_LEVEL;
    uint16 zclSampleLight_LevelOnTransitionTime = 20;
    uint16 zclSampleLight_LevelOffTransitionTime = 20;
    uint8  zclSampleLight_LevelDefaultMoveRate = 0;   // as fast as possible
    #endif
    #if ZCL_DISCOVER
    CONST zclCommandRec_t zclSampleLight_Cmds[] =
        ZCL_CLUSTER_ID_GEN_BASIC,
        COMMAND_BASIC_RESET_FACT_DEFAULT,
        CMD_DIR_SERVER_RECEIVED
        COMMAND_OFF,
        COMMAND_ON,
        COMMAND_TOGGLE,
    #ifdef ZCL_LEVEL_CONTROL
        ZCL_CLUSTER_ID_GEN_LEVEL_CONTROL,
        COMMAND_LEVEL_MOVE_TO_LEVEL,
        COMMAND_LEVEL_MOVE,
        COMMAND_LEVEL_STEP,
        COMMAND_LEVEL_STOP,
        COMMAND_LEVEL_MOVE_TO_LEVEL_WITH_ON_OFF,
        COMMAND_LEVEL_MOVE_WITH_ON_OFF,
        COMMAND_LEVEL_STEP_WITH_ON_OFF,
        COMMAND_LEVEL_STOP_WITH_ON_OFF,
    #endif // ZCL_LEVEL_CONTROL
    CONST uint8 zclCmdsArraySize = ( sizeof(zclSampleLight_Cmds) / sizeof(zclSampleLight_Cmds[0]) );
     * ATTRIBUTE DEFINITIONS - Uses REAL cluster IDs
    CONST zclAttrRec_t zclSampleLight_Attrs[] =
      // *** General Basic Cluster Attributes ***
        ZCL_CLUSTER_ID_GEN_BASIC,             // Cluster IDs - defined in the foundation (ie. zcl.h)
        {  // Attribute record
          ATTRID_BASIC_HW_VERSION,            // Attribute ID - Found in Cluster Library header (ie. zcl_general.h)
          ZCL_DATATYPE_UINT8,                 // Data Type - found in zcl.h
          ACCESS_CONTROL_READ,                // Variable access control - found in zcl.h
          (void *)&zclSampleLight_HWRevision  // Pointer to attribute variable
          ATTRID_BASIC_ZCL_VERSION,
          ZCL_DATATYPE_UINT8,
          (void *)&zclSampleLight_ZCLVersion
          ATTRID_BASIC_MANUFACTURER_NAME,
          ZCL_DATATYPE_CHAR_STR,
          (void *)zclSampleLight_ManufacturerName
          ATTRID_BASIC_MODEL_ID,
          (void *)zclSampleLight_ModelId
          ATTRID_BASIC_DATE_CODE,
          (void *)zclSampleLight_DateCode
          ATTRID_BASIC_POWER_SOURCE,
          ZCL_DATATYPE_UINT8,
          (void *)&zclSampleLight_PowerSource
          ATTRID_BASIC_LOCATION_DESC,
          (ACCESS_CONTROL_READ | ACCESS_CONTROL_WRITE),
          (void *)zclSampleLight_LocationDescription
          ATTRID_BASIC_PHYSICAL_ENV,
          ZCL_DATATYPE_UINT8,
          (void *)&zclSampleLight_PhysicalEnvironment
          ATTRID_BASIC_DEVICE_ENABLED,
          ZCL_DATATYPE_BOOLEAN,
          (void *)&zclSampleLight_DeviceEnable
    #ifdef ZCL_IDENTIFY
      // *** Identify Cluster Attribute ***
        ZCL_CLUSTER_ID_GEN_IDENTIFY,
          ATTRID_IDENTIFY_TIME,
          ZCL_DATATYPE_UINT16,
          (void *)&zclSampleLight_IdentifyTime
     #ifdef ZCL_EZMODE
          ATTRID_IDENTIFY_COMMISSION_STATE,
          ZCL_DATATYPE_UINT8,
          (ACCESS_CONTROL_READ),
          (void *)&zclSampleLight_IdentifyCommissionState
    #endif
      // *** On/Off Cluster Attributes ***
          ATTRID_ON_OFF,
          (void *)&zclSampleLight_OnOff
          ATTRID_LEVEL_CURRENT_LEVEL,
          ZCL_DATATYPE_UINT8,
          (void *)&zclSampleLight_LevelCurrentLevel
          ATTRID_LEVEL_REMAINING_TIME,
          (void *)&zclSampleLight_LevelRemainingTime
          ATTRID_LEVEL_ON_OFF_TRANSITION_TIME,
          ACCESS_CONTROL_READ | ACCESS_CONTROL_WRITE,
          (void *)&zclSampleLight_LevelOnOffTransitionTime
          ATTRID_LEVEL_ON_LEVEL,
          ZCL_DATATYPE_UINT8,
          (void *)&zclSampleLight_LevelOnLevel
          ATTRID_LEVEL_ON_TRANSITION_TIME,
          (void *)&zclSampleLight_LevelOnTransitionTime
          ATTRID_LEVEL_OFF_TRANSITION_TIME,
          (void *)&zclSampleLight_LevelOffTransitionTime
          ATTRID_LEVEL_DEFAULT_MOVE_RATE,
          ZCL_DATATYPE_UINT8,
          (void *)&zclSampleLight_LevelDefaultMoveRate
    #endif
        ZCL_CLUSTER_ID_HA_DIAGNOSTIC,
          ATTRID_DIAGNOSTIC_NUMBER_OF_RESETS,
          NULL // Use application's callback to Read this attribute
          ATTRID_DIAGNOSTIC_PERSISTENT_MEMORY_WRITES,
          ATTRID_DIAGNOSTIC_MAC_RX_BCAST,
          ZCL_DATATYPE_UINT32,
          ATTRID_DIAGNOSTIC_MAC_TX_BCAST,
          ATTRID_DIAGNOSTIC_MAC_RX_UCAST,
          ATTRID_DIAGNOSTIC_MAC_TX_UCAST,
          ATTRID_DIAGNOSTIC_MAC_TX_UCAST_RETRY,
          ATTRID_DIAGNOSTIC_MAC_TX_UCAST_FAIL,
          ATTRID_DIAGNOSTIC_APS_RX_BCAST,
          ATTRID_DIAGNOSTIC_APS_TX_BCAST,
          ATTRID_DIAGNOSTIC_APS_RX_UCAST,
          ATTRID_DIAGNOSTIC_APS_TX_UCAST_SUCCESS,
          ATTRID_DIAGNOSTIC_APS_TX_UCAST_RETRY,
          ATTRID_DIAGNOSTIC_APS_TX_UCAST_FAIL,
          ATTRID_DIAGNOSTIC_ROUTE_DISC_INITIATED,
          ATTRID_DIAGNOSTIC_NEIGHBOR_ADDED,
          ATTRID_DIAGNOSTIC_NEIGHBOR_REMOVED,
          ATTRID_DIAGNOSTIC_NEIGHBOR_STALE,
          ATTRID_DIAGNOSTIC_JOIN_INDICATION,
          ATTRID_DIAGNOSTIC_CHILD_MOVED,
          ATTRID_DIAGNOSTIC_NWK_FC_FAILURE,
          ATTRID_DIAGNOSTIC_APS_FC_FAILURE,
          ATTRID_DIAGNOSTIC_APS_UNAUTHORIZED_KEY,
          ATTRID_DIAGNOSTIC_NWK_DECRYPT_FAILURES,
          ATTRID_DIAGNOSTIC_APS_DECRYPT_FAILURES,
          ATTRID_DIAGNOSTIC_PACKET_BUFFER_ALLOCATE_FAILURES,
          ATTRID_DIAGNOSTIC_RELAYED_UCAST,
          ATTRID_DIAGNOSTIC_PHY_TO_MAC_QUEUE_LIMIT_REACHED,
          ATTRID_DIAGNOSTIC_PACKET_VALIDATE_DROP_COUNT,
          ATTRID_DIAGNOSTIC_AVERAGE_MAC_RETRY_PER_APS_MESSAGE_SENT,
          ATTRID_DIAGNOSTIC_LAST_MESSAGE_LQI,
          ZCL_DATATYPE_UINT8,
          ATTRID_DIAGNOSTIC_LAST_MESSAGE_RSSI,
          ZCL_DATATYPE_INT8,
    #endif // ZCL_DIAGNOSTIC
    uint8 CONST zclSampleLight_NumAttributes = ( sizeof(zclSampleLight_Attrs) / sizeof(zclSampleLight_Attrs[0]) );
     * SIMPLE DESCRIPTOR
    // This is the Cluster ID List and should be filled with Application
    // specific cluster IDs.
    const cId_t zclSampleLight_InClusterList[] =
      ZCL_CLUSTER_ID_GEN_GROUPS,
      ZCL_CLUSTER_ID_GEN_SCENES,
    #endif
    // work-around for compiler bug... IAR can't calculate size of array with #if options.
     #define ZCLSAMPLELIGHT_MAX_INCLUSTERS   6
    #else
     #define ZCLSAMPLELIGHT_MAX_INCLUSTERS   5
    #endif
    const cId_t zclSampleLight_OutClusterList[] =
    #define ZCLSAMPLELIGHT_MAX_OUTCLUSTERS  (sizeof(zclSampleLight_OutClusterList) / sizeof(zclSampleLight_OutClusterList[0]))
    SimpleDescriptionFormat_t zclSampleLight_SimpleDesc =
      SAMPLELIGHT_ENDPOINT,                  //  int Endpoint;
      ZCL_HA_PROFILE_ID,                     //  uint16 AppProfId;
      ZCL_HA_DEVICEID_DIMMABLE_LIGHT,        //  uint16 AppDeviceId;
    #else
      ZCL_HA_DEVICEID_ON_OFF_LIGHT,          //  uint16 AppDeviceId;
    #endif
      SAMPLELIGHT_DEVICE_VERSION,            //  int   AppDevVer:4;
      SAMPLELIGHT_FLAGS,                     //  int   AppFlags:4;
      ZCLSAMPLELIGHT_MAX_INCLUSTERS,         //  byte  AppNumInClusters;
      (cId_t *)zclSampleLight_InClusterList, //  byte *pAppInClusterList;
      ZCLSAMPLELIGHT_MAX_OUTCLUSTERS,        //  byte  AppNumInClusters;
      (cId_t *)zclSampleLight_OutClusterList //  byte *pAppInClusterList;
     * GLOBAL FUNCTIONS
     * LOCAL FUNCTIONS
      ZCL_ON_OFF
      HOLD_AUTO_START
      ZCL_EZMODE
      SCREEN MODES
      Main:
     * INCLUDES
    #include "OSAL.h"
    #include "AF.h"
    #include "ZDApp.h"
    #include "MT_SYS.h"
    #include "zcl.h"
    #include "zcl_ha.h"
    #include "zcl_samplelight1.h"
    /* HAL */
        #define ZGP_AUTO_TT
      #endif
    #endif
    #include "math.h"
    #endif
    #include "NLMEDE.h"
     * MACROS
     * CONSTANTS
    #endif
    #define LIGHT1_INTERVAL_DELAY_TIME            500
     * TYPEDEFS
     * GLOBAL VARIABLES
    byte zclSampleLight1_TaskID;
    uint8 zclSampleLight1SeqNum;
    byte zclSampleLight1_LightDelay;
    uint16 maxSensorReadValue1;
     * GLOBAL FUNCTIONS
     * LOCAL VARIABLES
    afAddrType_t zclSampleLight1_DstAddr;
    #ifdef ZCL_EZMODE
    static void zclSampleLight1_ProcessZDOMsgs( zdoIncomingMsg_t *pMsg );
    static void zclSampleLight1_EZModeCB( zlcEZMode_State_t state, zclEZMode_CBData_t *pData );
    static const zclEZMode_RegisterData_t zclSampleLight1_RegisterEZModeData =
      &zclSampleLight1_TaskID,
      SAMPLELIGHT1_EZMODE_NEXTSTATE_EVT,
      SAMPLELIGHT1_EZMODE_TIMEOUT_EVT,
      &zclSampleLight1SeqNum,
    #else
    uint16 bindingInClusters1[] =
    #endif
    #define ZCLSAMPLELIGHT1_BINDINGLIST (sizeof(bindingInClusters1) / sizeof(bindingInClusters1[0]))
    static endPointDesc_t sampleLight1_TestEp =
      SAMPLELIGHT1_ENDPOINT,
    uint8 giLightScreenMode1 = LIGHT1_MAINMODE;   // display the main screen mode first
    uint8 gPermitDuration1 = 0;    // permit joining default to disabled
    devStates_t zclSampleLight1_NwkState = DEV_INIT;
    #if ZCL_LEVEL_CTRL
    uint8 zclSampleLight1_WithOnOff;       // set to TRUE if state machine should set light on/off
    uint8 zclSampleLight1_NewLevel;        // new level when done moving
    bool  zclSampleLight1_NewLevelUp;      // is direction to new level up or down?
    int32 zclSampleLight1_CurrentLevel32;  // current level, fixed point (e.g. 192.456)
    int32 zclSampleLight1_Rate32;          // rate in units, fixed point (e.g. 16.123)
    uint8 zclSampleLight1_LevelLastLevel;  // to save the Current Level before the light was turned OFF
    #endif
     * LOCAL FUNCTIONS
    static void zclSampleLight1_ReadSensorCurrent(void);
    static void zclSampleLight1_SendSensorInformation(void);
    static void zclSampleLight1_HandleKeys( byte shift, byte keys );
    static void zclSampleLight1_BasicResetCB( void );
    static void zclSampleLight1_IdentifyCB( zclIdentify_t *pCmd );
    static void zclSampleLight1_IdentifyQueryRspCB( zclIdentifyQueryRsp_t *pRsp );
    static void zclSampleLight1_OnOffCB( uint8 cmd );
    static void zclSampleLight1_ProcessIdentifyTimeChange( void );
    static void zclSampleLight1_LevelControlMoveToLevelCB( zclLCMoveToLevel_t *pCmd );
    static void zclSampleLight1_LevelControlMoveCB( zclLCMove_t *pCmd );
    static void zclSampleLight1_LevelControlStepCB( zclLCStep_t *pCmd );
    static void zclSampleLight1_LevelControlStopCB( void );
    static void zclSampleLight1_DefaultMove( void );
    static uint32 zclSampleLight1_TimeRateHelper( uint8 newLevel );
    static uint16 zclSampleLight1_GetTime ( uint8 level, uint16 time );
    static void zclSampleLight1_MoveBasedOnRate( uint8 newLevel, uint32 rate );
    static void zclSampleLight1_MoveBasedOnTime( uint8 newLevel, uint16 time );
    static void zclSampleLight1_AdjustLightLevel( void );
    #endif
    static void zclSampleLight1_LcdDisplayUpdate( void );
    static void zclSampleLight1_LcdDisplayMainMode( void );
    static void zclSampleLight1_LcdDisplayHelpMode( void );
    #endif
    static void zclSampleLight1_DisplayLight( void );
    void zclSampleLight1_UpdateLampLevel( uint8 level );
    #endif
    static void zclSampleLight1_ProcessIncomingMsg( zclIncomingMsg_t *msg );
    #ifdef ZCL_READ
    static uint8 zclSampleLight1_ProcessInReadRspCmd( zclIncomingMsg_t *pInMsg );
    #endif
    #ifdef ZCL_WRITE
    static uint8 zclSampleLight1_ProcessInWriteRspCmd( zclIncomingMsg_t *pInMsg );
    #endif
    static uint8 zclSampleLight1_ProcessInDefaultRspCmd( zclIncomingMsg_t *pInMsg );
    #ifdef ZCL_DISCOVER
    static uint8 zclSampleLight1_ProcessInDiscCmdsRspCmd( zclIncomingMsg_t *pInMsg );
    static uint8 zclSampleLight1_ProcessInDiscAttrsRspCmd( zclIncomingMsg_t *pInMsg );
    static uint8 zclSampleLight1_ProcessInDiscAttrsExtRspCmd( zclIncomingMsg_t *pInMsg );
    #endif
     * STATUS STRINGS
    const char ssDeviceName[]   = "  Sample Light";
    const char ssClearLine[]    = " ";
    const char ssSwLight[]      = "SW1: ToggleLight";  // 16 chars max
    const char ssSwEZMode[]     = "SW2: EZ-Mode";
    char ssSwHelp[]             = "SW5: Help       ";  // last character is * if NWK open
    const char ssLightOn[]      = "    LIGHT ON ";
    const char ssLightOff[]     = "    LIGHT OFF";
     #if ZCL_LEVEL_CTRL
     char ssLightLevel[]        = "    LEVEL ###"; // displays level 1-254
     #endif
    #endif
    static zclGeneral_AppCallbacks_t zclSampleLight1_CmdCallbacks =
      zclSampleLight1_BasicResetCB,            // Basic Cluster Reset command
      zclSampleLight1_IdentifyCB,              // Identify command
    #ifdef ZCL_EZMODE
    #endif
      zclSampleLight1_IdentifyQueryRspCB,      // Identify Query Response command
      zclSampleLight1_OnOffCB,                 // On/Off cluster commands
      zclSampleLight1_LevelControlMoveToLevelCB, // Level Control Move to Level command
      zclSampleLight1_LevelControlMoveCB,        // Level Control Move command
      zclSampleLight1_LevelControlStepCB,        // Level Control Step command
      zclSampleLight1_LevelControlStopCB,        // Level Control Stop command
    #endif
    #ifdef ZCL_GROUPS
    #endif
    #ifdef ZCL_SCENES
    #endif
    #ifdef ZCL_ALARMS
    #endif
    #ifdef SE_UK_EXT
    #endif
     * @fn          zclSampleLight1_Init
     * @param       none
     * @return      none
    void zclSampleLight1_Init( byte task_id )
      zclSampleLight1_TaskID = task_id;
      zclSampleLight1_DstAddr.addrMode = (afAddrMode_t)AddrNotPresent;
      zclSampleLight1_DstAddr.endPoint = 0;
      zclSampleLight1_DstAddr.addr.shortAddr = 0;
      zclHA_Init( &zclSampleLight1_SimpleDesc );
      zclGeneral_RegisterCmdCallbacks( SAMPLELIGHT1_ENDPOINT, &zclSampleLight1_CmdCallbacks );
      zcl_registerAttrList( SAMPLELIGHT1_ENDPOINT, zclSampleLight1_NumAttributes, zclSampleLight1_Attrs );
      zcl_registerForMsg( zclSampleLight1_TaskID );
    #ifdef ZCL_DISCOVER
      zcl_registerCmdList( SAMPLELIGHT1_ENDPOINT, zclCmdsArraySize, zclSampleLight1_Cmds );
    #endif
      RegisterForKeys( zclSampleLight1_TaskID );
      afRegister( &sampleLight1_TestEp );
    #ifdef ZCL_EZMODE
      // Register EZ-Mode
      zcl_RegisterEZMode( &zclSampleLight1_RegisterEZModeData );
    #endif
      HalTimer1Init( 0 );
      uint8 state;
        osal_start_timerEx( zclSampleLight1_TaskID, SAMPLELIGHT1_START_EZMODE_EVT, 500 );
    #if ZCL_LEVEL_CTRL
      zclSampleLight1_DefaultMove();
    #endif
      zcl_registerReadWriteCB( SAMPLELIGHT1_ENDPOINT, zclDiagnostic_ReadWriteAttrCB, NULL );
    #endif
      HalLcdWriteString ( (char *)ssDeviceName, HAL_LCD_LINE_3 );
    #ifdef ZGP_AUTO_TT
      zgpTranslationTable_RegisterEP ( &zclSampleLight1_SimpleDesc );
    #endif
      osal_start_timerEx( zclSampleLight1_TaskID, SAMPLELIGHT1_READ_SENSOR_CURRENT_EVT, 3000 );
      osal_start_timerEx( zclSampleLight1_TaskID, SAMPLELIGHT1_REPORT_SENSOR_INFORMATION_EVT, 1 );
     * @param       none
     * @return      none
    uint16 zclSampleLight1_event_loop( uint8 task_id, uint16 events )
        while ( (MSGpkt = (afIncomingMSGPacket_t *)osal_msg_receive( zclSampleLight1_TaskID )) )
    #ifdef ZCL_EZMODE
            case ZDO_CB_MSG:
              zclSampleLight1_ProcessZDOMsgs( (zdoIncomingMsg_t *)MSGpkt );
              break;
    #endif
              zclSampleLight1_ProcessIncomingMsg( (zclIncomingMsg_t *)MSGpkt );
              break;
            case KEY_CHANGE:
              zclSampleLight1_HandleKeys( ((keyChange_t *)MSGpkt)->state, ((keyChange_t *)MSGpkt)->keys );
              break;
              zclSampleLight1_NwkState = (devStates_t)(MSGpkt->hdr.status);
              if ( (zclSampleLight1_NwkState == DEV_ZB_COORD) ||
                   (zclSampleLight1_NwkState == DEV_ROUTER)   ||
                   (zclSampleLight1_NwkState == DEV_END_DEVICE) )
                zclSampleLight1_LcdDisplayUpdate();
    #ifdef ZCL_EZMODE
              break;
            default:
              break;
      if ( events & SAMPLELIGHT1_IDENTIFY_TIMEOUT_EVT )
        if ( zclSampleLight1_IdentifyTime > 0 )
          zclSampleLight1_IdentifyTime--;
        zclSampleLight1_ProcessIdentifyTimeChange();
        return ( events ^ SAMPLELIGHT1_IDENTIFY_TIMEOUT_EVT );
      if ( events & SAMPLELIGHT1_MAIN_SCREEN_EVT )
        return ( events ^ SAMPLELIGHT1_MAIN_SCREEN_EVT );
    #ifdef ZCL_EZMODE
      if ( events & SAMPLELIGHT1_START_EZMODE_EVT )
        // Invoke EZ-Mode
        // Invoke EZ-Mode
        ezModeData.endpoint = SAMPLELIGHT1_ENDPOINT; // endpoint on which to invoke EZ-Mode
        else
        return ( events ^ SAMPLELIGHT1_START_EZMODE_EVT );
      if ( events & SAMPLELIGHT1_EZMODE_NEXTSTATE_EVT )
        return ( events ^ SAMPLELIGHT1_EZMODE_NEXTSTATE_EVT );
      if ( events & SAMPLELIGHT1_EZMODE_TIMEOUT_EVT )
        return ( events ^ SAMPLELIGHT1_EZMODE_TIMEOUT_EVT );
      if ( events & SAMPLELIGHT1_LEVEL_CTRL_EVT )
        zclSampleLight1_AdjustLightLevel();
        return ( events ^ SAMPLELIGHT1_LEVEL_CTRL_EVT );
    #endif
      if ( events & SAMPLELIGHT1_READ_SENSOR_CURRENT_EVT )
        zclSampleLight1_ReadSensorCurrent();
        return ( events ^ SAMPLELIGHT1_READ_SENSOR_CURRENT_EVT );
      if ( events & SAMPLELIGHT1_REPORT_SENSOR_INFORMATION_EVT )
        zclSampleLight1_SendSensorInformation();
        return ( events ^ SAMPLELIGHT1_REPORT_SENSOR_INFORMATION_EVT );
       if ( events & SAMPLELIGHT1_LIGHT_DELAY_EVT )
        zclSampleLight1_LightDelay=0;
        return ( events ^ SAMPLELIGHT1_LIGHT_DELAY_EVT );
      return 0;
     * @return  none
    static void zclSampleLight1_SendSensorInformation(void){
        double iRMS;
        int16 maxMinusOffset=maxSensorReadValue1-1650;
        iRMS=iRMS/1650;
        maxSensorReadValue1=0;
     #ifdef ZCL_REPORT
        rptcmd->attrList[0].attrID = ATTRID_SENSOR_CURRENT_A5;
        rptcmd->attrList[0].dataType = ZCL_DATATYPE_UINT16;
        zcl_SendReportCmd(SAMPLELIGHT1_ENDPOINT, &dstAddr1, ZCL_CLUSTER_ID_GEN_ON_OFF, rptcmd,ZCL_FRAME_SERVER_CLIENT_DIR, false, zclSampleLight1SeqNum );
    #endif
        osal_start_timerEx( zclSampleLight1_TaskID, SAMPLELIGHT1_REPORT_SENSOR_INFORMATION_EVT, 3000 );
     * @return  none
    static void zclSampleLight1_ReadSensorCurrent(void){
        uint16 value1 = HalAdcRead(HAL_ADC_CHANNEL_5,HAL_ADC_RESOLUTION_12);
        uint16 value2 = HalAdcRead(HAL_ADC_CHANNEL_5,HAL_ADC_RESOLUTION_12);
        uint16 value3 = HalAdcRead(HAL_ADC_CHANNEL_5,HAL_ADC_RESOLUTION_12);
        uint16 value4 = HalAdcRead(HAL_ADC_CHANNEL_5,HAL_ADC_RESOLUTION_12);
        if(value>maxSensorReadValue1)
          maxSensorReadValue1=value;
        osal_start_timerEx( zclSampleLight1_TaskID, SAMPLELIGHT1_READ_SENSOR_CURRENT_EVT, 1 );
     * @fn      zclSampleLight1_HandleKeys
     *                 HAL_KEY_SW_5
     *                 HAL_KEY_SW_4
     *                 HAL_KEY_SW_2
     *                 HAL_KEY_SW_1
     * @return  none
          if(zclSampleLight1_LightDelay==0){
        zclSampleLight1_LightDelay=1;
        osal_start_timerEx( zclSampleLight1_TaskID, SAMPLELIGHT1_LIGHT_DELAY_EVT, LIGHT1_INTERVAL_DELAY_TIME );
        zclSampleLight1_OnOff = zclSampleLight1_OnOff ? LIGHT1_OFF : LIGHT1_ON;
        zclSampleLight1_LevelCurrentLevel = zclSampleLight1_OnOff ? zclSampleLight1_LevelOnLevel : ATTR_LEVEL_MIN_LEVEL;
    #endif
     #ifdef ZCL_REPORT
        rptcmd->attrList[0].attrData = (uint8*)&zclSampleLight1_OnOff;
        zcl_SendReportCmd(SAMPLELIGHT1_ENDPOINT, &dstAddr1,ZCL_CLUSTER_ID_GEN_ON_OFF, rptcmd,ZCL_FRAME_SERVER_CLIENT_DIR, false, zclSampleLight1SeqNum );
        osal_start_timerEx( zclSampleLight1_TaskID, SAMPLELIGHT1_MAIN_SCREEN_EVT, 3000 );
    #endif
        if ( ( zclSampleLight1_NwkState == DEV_ZB_COORD ) ||
              ( zclSampleLight1_NwkState == DEV_ROUTER ) )
          gPermitDuration1 = gPermitDuration1 ? 0 : 0xff;
          NLME_PermitJoiningRequest( gPermitDuration1 );
        zclSampleLight1_BasicResetCB();
        giLightScreenMode1 = giLightScreenMode1 ? LIGHT1_MAINMODE : LIGHT1_HELPMODE;
     * @fn      zclSampleLight1_LcdDisplayUpdate
     * @param   none
     * @return  none
      if ( giLightScreenMode1 == LIGHT1_HELPMODE )
        zclSampleLight1_LcdDisplayHelpMode();
      else
        zclSampleLight1_LcdDisplayMainMode();
    #endif
      zclSampleLight1_DisplayLight();
     * @fn      zclSampleLight1_UpdateLampLevel
     * @param   level
     * @return  none
    #endif
     * @fn      zclSampleLight1_DisplayLight
     * @param   none
     * @return  none
      if ( zclSampleLight1_OnOff == LIGHT1_ON )
        HalLedSet ( HAL_LED_2, HAL_LED_MODE_ON );
      else
        HalLedSet ( HAL_LED_2, HAL_LED_MODE_OFF );
      if (giLightScreenMode1 == LIGHT1_MAINMODE)
        if ( ( zclSampleLight1_LevelCurrentLevel == ATTR_LEVEL_MIN_LEVEL ) &&
             ( zclSampleLight1_OnOff == LIGHT1_OFF ) )
          HalLcdWriteString( (char *)ssLightOff, HAL_LCD_LINE_2 );
        else if ( ( zclSampleLight1_LevelCurrentLevel >= ATTR_LEVEL_MAX_LEVEL ) ||
                  ( zclSampleLight1_LevelCurrentLevel == zclSampleLight1_LevelOnLevel ) ||
                   ( ( zclSampleLight1_LevelOnLevel == ATTR_LEVEL_ON_LEVEL_NO_EFFECT ) &&
                     ( zclSampleLight1_LevelCurrentLevel == zclSampleLight1_LevelLastLevel ) ) )
          HalLcdWriteString( (char *)ssLightOn, HAL_LCD_LINE_2 );
          zclHA_uint8toa( zclSampleLight1_LevelCurrentLevel, &ssLightLevel[10] );
          HalLcdWriteString( (char *)ssLightLevel, HAL_LCD_LINE_2 );
    #else
        if ( zclSampleLight1_OnOff )
        else
     * @fn      zclSampleLight1_LcdDisplayMainMode
     * @param   none
     * @return  none
      if ( zclSampleLight1_NwkState == DEV_ZB_COORD )
      else if ( zclSampleLight1_NwkState == DEV_ROUTER )
      else if ( zclSampleLight1_NwkState == DEV_END_DEVICE )
      if ( gPermitDuration1 )
        ssSwHelp[15] = '*';
      else
        ssSwHelp[15] = ' ';
      HalLcdWriteString( (char *)ssSwHelp, HAL_LCD_LINE_3 );
     * @fn      zclSampleLight1_LcdDisplayHelpMode
     * @param   none
     * @return  none
      HalLcdWriteString( (char *)ssSwLight, HAL_LCD_LINE_1 );
      HalLcdWriteString( (char *)ssSwEZMode, HAL_LCD_LINE_2 );
     * @fn      zclSampleLight1_ProcessIdentifyTimeChange
     * @param   none
     * @return  none
        osal_start_timerEx( zclSampleLight1_TaskID, SAMPLELIGHT1_IDENTIFY_TIMEOUT_EVT, 1000 );
      else
    #ifdef ZCL_EZMODE
        if ( zclSampleLight1_IdentifyCommissionState & EZMODE_COMMISSION_OPERATIONAL )
        else
    #endif
        osal_stop_timerEx( zclSampleLight1_TaskID, SAMPLELIGHT1_IDENTIFY_TIMEOUT_EVT );
     * @fn      zclSampleLight1_BasicResetCB
     * @param   none
     * @return  none
     * @fn      zclSampleLight1_IdentifyCB
     * @return  none
      zclSampleLight1_IdentifyTime = pCmd->identifyTime;
     * @fn      zclSampleLight1_IdentifyQueryRspCB
     * @return  none
      (void)pRsp;
    #ifdef ZCL_EZMODE
    #endif
     * @fn      zclSampleLight1_OnOffCB
     * @return  none
        zclSampleLight1_OnOff = LIGHT1_ON;
        zclSampleLight1_OnOff = LIGHT1_OFF;
      // Toggle the light
        if ( zclSampleLight1_OnOff == LIGHT1_OFF )
        else
    #if ZCL_LEVEL_CTRL
      zclSampleLight1_DefaultMove( );
    #endif
      zclSampleLight1_LcdDisplayUpdate( );
     * @fn      zclSampleLight1_TimeRateHelper
     * @return  diff (directly), zclSampleLight1_CurrentLevel32 and zclSampleLight1_NewLevel, zclSampleLight1_NewLevelUp
      uint32 diff;
      uint32 newLevel32;
      zclSampleLight1_NewLevel = newLevel;
      zclSampleLight1_CurrentLevel32 = (uint32)1000 * zclSampleLight1_LevelCurrentLevel;
      // calculate diff
      if ( zclSampleLight1_LevelCurrentLevel > newLevel )
        diff = zclSampleLight1_CurrentLevel32 - newLevel32;
        zclSampleLight1_NewLevelUp = FALSE;  // moving down
      else
        diff = newLevel32 - zclSampleLight1_CurrentLevel32;
        zclSampleLight1_NewLevelUp = TRUE;   // moving up
      return ( diff );
     * @fn      zclSampleLight1_MoveBasedOnRate
     * @return  none
      uint32 diff;
      zclSampleLight1_Rate32 = rate;
      diff = zclSampleLight1_TimeRateHelper( newLevel );
      zclSampleLight1_LevelRemainingTime = diff / rate;
      if ( !zclSampleLight1_LevelRemainingTime )
        zclSampleLight1_LevelRemainingTime = 1;
      osal_start_timerEx( zclSampleLight1_TaskID, SAMPLELIGHT1_LEVEL_CTRL_EVT, 100 );
     * @fn      zclSampleLight1_MoveBasedOnTime
     * @return  none
      uint16 diff;
      zclSampleLight1_LevelRemainingTime = zclSampleLight1_GetTime( newLevel, time );
      zclSampleLight1_Rate32 = diff / time;
     * @fn      zclSampleLight1_GetTime
     * @return  none
    static uint16 zclSampleLight1_GetTime( uint8 level, uint16 time )
      // time possible.
          time = zclSampleLight1_LevelOffTransitionTime;
        else
          time = zclSampleLight1_LevelOnTransitionTime;
          time = zclSampleLight1_LevelOnOffTransitionTime;
          time = 1;
      if ( !time )
      return ( time );
     * @fn      zclSampleLight1_DefaultMove
     * @param   zclSampleLight1_OnOff - must be set prior to calling this function.
     * @return  none
      uint8  newLevel;
      uint16 time;
        if ( zclSampleLight1_LevelOnLevel == ATTR_LEVEL_ON_LEVEL_NO_EFFECT )
          newLevel = zclSampleLight1_LevelLastLevel;
        else
          newLevel = zclSampleLight1_LevelOnLevel;
      else
          zclSampleLight1_LevelLastLevel = zclSampleLight1_LevelCurrentLevel;
        time = 1;
      zclSampleLight1_WithOnOff = TRUE;
      zclSampleLight1_MoveBasedOnRate( newLevel, rate );
     * @fn      zclSampleLight1_AdjustLightLevel
     * @param   none
     * @return  none
      if ( zclSampleLight1_LevelRemainingTime )
        --zclSampleLight1_LevelRemainingTime;
      if ( zclSampleLight1_LevelRemainingTime == 0)
        zclSampleLight1_LevelCurrentLevel = zclSampleLight1_NewLevel;
      else
        if ( zclSampleLight1_NewLevelUp )
          zclSampleLight1_CurrentLevel32 += zclSampleLight1_Rate32;
        else
          zclSampleLight1_CurrentLevel32 -= zclSampleLight1_Rate32;
        zclSampleLight1_LevelCurrentLevel = (uint8)( zclSampleLight1_CurrentLevel32 / 1000 );
      zclSampleLight1_UpdateLampLevel(zclSampleLight1_LevelCurrentLevel);
    #endif
      if ( zclSampleLight1_WithOnOff )
        if ( zclSampleLight1_LevelCurrentLevel > ATTR_LEVEL_MIN_LEVEL )
          ENABLE_LAMP;
    #endif
        else
          DISABLE_LAMP;
    #endif
      zclSampleLight1_DisplayLight( );
     * @fn      zclSampleLight1_LevelControlMoveToLevelCB
     * @return  none
      zclSampleLight1_WithOnOff = pCmd->withOnOff;
      zclSampleLight1_MoveBasedOnTime( pCmd->level, pCmd->transitionTime );
     * @fn      zclSampleLight1_LevelControlMoveCB
     * @return  none
      uint8 newLevel;
      uint32 rate;
      else
     * @fn      zclSampleLight1_LevelControlStepCB
     * @return  none
      uint8 newLevel;
        if ( (uint16)zclSampleLight1_LevelCurrentLevel + pCmd->amount > ATTR_LEVEL_MAX_LEVEL )
        else
          newLevel = zclSampleLight1_LevelCurrentLevel + pCmd->amount;
      else
        if ( pCmd->amount >= zclSampleLight1_LevelCurrentLevel )
        else
          newLevel = zclSampleLight1_LevelCurrentLevel - pCmd->amount;
      zclSampleLight1_MoveBasedOnTime( newLevel, pCmd->transitionTime );
     * @fn      zclSampleLight1_LevelControlStopCB
     * @return  none
      // stop immediately
      osal_stop_timerEx( zclSampleLight1_TaskID, SAMPLELIGHT1_LEVEL_CTRL_EVT );
      zclSampleLight1_LevelRemainingTime = 0;
    #endif
     * @fn      zclSampleLight1_ProcessIncomingMsg
     * @return  none
    static void zclSampleLight1_ProcessIncomingMsg( zclIncomingMsg_t *pInMsg )
    #ifdef ZCL_READ
          zclSampleLight1_ProcessInReadRspCmd( pInMsg );
          break;
    #endif
    #ifdef ZCL_WRITE
          zclSampleLight1_ProcessInWriteRspCmd( pInMsg );
          break;
    #endif
    #ifdef ZCL_REPORT
          // zclSampleLight1_ProcessInConfigReportCmd( pInMsg );
          break;
          // zclSampleLight1_ProcessInConfigReportRspCmd( pInMsg );
          break;
          // zclSampleLight1_ProcessInReadReportCfgCmd( pInMsg );
          break;
          // zclSampleLight1_ProcessInReadReportCfgRspCmd( pInMsg );
          break;
          // zclSampleLight1_ProcessInReportCmd( pInMsg );
          break;
    #endif
          zclSampleLight1_ProcessInDefaultRspCmd( pInMsg );
          break;
    #ifdef ZCL_DISCOVER
          zclSampleLight1_ProcessInDiscCmdsRspCmd( pInMsg );
          break;
          break;
          zclSampleLight1_ProcessInDiscAttrsRspCmd( pInMsg );
          break;
          zclSampleLight1_ProcessInDiscAttrsExtRspCmd( pInMsg );
          break;
    #endif
        default:
          break;
    #ifdef ZCL_READ
     * @fn      zclSampleLight1_ProcessInReadRspCmd
     * @return  none
      uint8 i;
        // attribute
      return ( TRUE );
    #endif // ZCL_READ
    #ifdef ZCL_WRITE
     * @fn      zclSampleLight1_ProcessInWriteRspCmd
     * @return  none
      uint8 i;
        // command.
      return ( TRUE );
    #endif // ZCL_WRITE
     * @fn      zclSampleLight1_ProcessInDefaultRspCmd
     * @return  none
      (void)pInMsg;
      return ( TRUE );
    #ifdef ZCL_DISCOVER
     * @fn      zclSampleLight1_ProcessInDiscCmdsRspCmd
     * @return  none
      uint8 i;
      return ( TRUE );
     * @fn      zclSampleLight1_ProcessInDiscAttrsRspCmd
     * @return  none
      uint8 i;
      return ( TRUE );
     * @fn      zclSampleLight1_ProcessInDiscAttrsExtRspCmd
     * @return  none
      uint8 i;
      return ( TRUE );
    #if ZCL_EZMODE
     * @fn      zclSampleLight1_ProcessZDOMsgs
     * @param   none
     * @return  status
     * @fn      zclSampleLight1_EZModeCB
     * @param   state - an
     * @return  none
    #ifdef LCD_SUPPORTED
      char *pStr;
      uint8 err;
    #endif
    #endif
        zclSampleLight1_IdentifyTime = ( EZMODE_TIME / 1000 );  // convert to seconds
        pStr = NULL;
        if ( pStr )
          if ( giLightScreenMode1 == LIGHT1_MAINMODE )
    #endif
        zclSampleLight1_IdentifyTime = 0;
        pStr = NULL;
        if ( pStr )
    #endif
    #endif // ZCL_EZMODE
    zcl_samplelight1.h
      Description:    Zigbee Cluster Library - sample device application.
      Copyright 2006-2014 Texas Instruments Incorporated. All rights reserved.
      IMPORTANT: Your use of this Software is limited to those specific rights
      granted under the terms of a software license agreement between the user
      who downloaded the software, his/her employer (which must be your employer)
      and Texas Instruments Incorporated (the "License").  You may not use this
      Software unless you agree to abide by the terms of the License. The License
      limits your use, and you acknowledge, that the Software may not be modified,
      copied or distributed unless embedded on a Texas Instruments microcontroller
      or used solely and exclusively in conjunction with a Texas Instruments radio
      frequency transceiver, which is integrated into your product.  Other than for
      the foregoing purpose, you may not use, reproduce, copy, prepare derivative
      works of, modify, distribute, perform, display or sell this Software and/or
      its documentation for any purpose.
      YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
      PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
      INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
      NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
      TEXAS INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT,
      NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
      LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
      INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
      OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
      OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
      (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
      Should you have any questions regarding your right to use this Software,
      contact Texas Instruments Incorporated at www.TI.com.
     * INCLUDES
    #include "ZComDef.h"
    #include "OSAL.h"
    #include "AF.h"
    #include "zcl.h"
    #include "zcl_general.h"
    #include "zcl_ha.h"
    #include "zcl_ezmode.h"
    #include "zcl_diagnostic.h"
     * CONSTANTS
    #define SAMPLELIGHT1_DEVICE_VERSION     0
    #define SAMPLELIGHT1_FLAGS              0
    #define SAMPLELIGHT1_HWVERSION          1
    #define SAMPLELIGHT1_ZCLVERSION         1
     * TYPEDEFS
     * MACROS
     * GLOBAL VARIABLES
    // Basic Cluster
    const uint8 zclSampleLight1_HWRevision = SAMPLELIGHT1_HWVERSION;
    const uint8 zclSampleLight1_ZCLVersion = SAMPLELIGHT1_ZCLVERSION;
    const uint8 zclSampleLight1_ManufacturerName[] = { 16, 'T','e','x','a','s','I','n','s','t','r','u','m','e','n','t','s' };
    const uint8 zclSampleLight1_ModelId[] = { 16, 'T','I','0','0','0','1',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ' };
    const uint8 zclSampleLight1_DateCode[] = { 16, '2','0','0','6','0','8','3','1',' ',' ',' ',' ',' ',' ',' ',' ' };
    const uint8 zclSampleLight1_PowerSource = POWER_SOURCE_MAINS_1_PHASE;
    uint8 zclSampleLight1_LocationDescription[17] = { 16, ' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ',' ' };
    uint8 zclSampleLight1_PhysicalEnvironment = 0;
    uint8 zclSampleLight1_DeviceEnable = DEVICE_ENABLED;
    // Identify Cluster
    uint16 zclSampleLight1_IdentifyTime = 0;
    #ifdef ZCL_EZMODE
    uint8  zclSampleLight1_IdentifyCommissionState;
    #endif
    // On/Off Cluster
    uint8  zclSampleLight1_OnOff = LIGHT1_OFF;
    #ifdef ZCL_LEVEL_CTRL
    uint8  zclSampleLight1_LevelCurrentLevel = ATTR_LEVEL_MIN_LEVEL;
    uint16 zclSampleLight1_LevelRemainingTime;
    uint16 zclSampleLight1_LevelOnOffTransitionTime = 20;
    uint8  zclSampleLight1_LevelOnLevel = ATTR_LEVEL_MID_LEVEL;
    uint16 zclSampleLight1_LevelOnTransitionTime = 20;
    uint16 zclSampleLight1_LevelOffTransitionTime = 20;
    uint8  zclSampleLight1_LevelDefaultMoveRate = 0;   // as fast as possible
    #endif
    #if ZCL_DISCOVER
    CONST zclCommandRec_t zclSampleLight1_Cmds[] =
        COMMAND_OFF,
        COMMAND_ON,
        COMMAND_TOGGLE,
        COMMAND_LEVEL_MOVE,
        COMMAND_LEVEL_STEP,
        COMMAND_LEVEL_STOP,
    CONST uint8 zclCmdsArraySize = ( sizeof(zclSampleLight1_Cmds) / sizeof(zclSampleLight1_Cmds[0]) );
    CONST zclAttrRec_t zclSampleLight1_Attrs[] =
          (void *)&zclSampleLight1_HWRevision  // Pointer to attribute variable
          ZCL_DATATYPE_UINT8,
          (void *)&zclSampleLight1_ZCLVersion
          (void *)zclSampleLight1_ManufacturerName
          (void *)zclSampleLight1_ModelId
          (void *)zclSampleLight1_DateCode
          ZCL_DATATYPE_UINT8,
          (void *)&zclSampleLight1_PowerSource
          (void *)zclSampleLight1_LocationDescription
          ZCL_DATATYPE_UINT8,
          (void *)&zclSampleLight1_PhysicalEnvironment
          (void *)&zclSampleLight1_DeviceEnable
    #ifdef ZCL_IDENTIFY
          (void *)&zclSampleLight1_IdentifyTime
     #ifdef ZCL_EZMODE
          ZCL_DATATYPE_UINT8,
          (void *)&zclSampleLight1_IdentifyCommissionState
    #endif
          ATTRID_ON_OFF,
          (void *)&zclSampleLight1_OnOff
          ZCL_DATATYPE_UINT8,
          (void *)&zclSampleLight1_LevelCurrentLevel
          (void *)&zclSampleLight1_LevelRemainingTime
          (void *)&zclSampleLight1_LevelOnOffTransitionTime
          ZCL_DATATYPE_UINT8,
          (void *)&zclSampleLight1_LevelOnLevel
          (void *)&zclSampleLight1_LevelOnTransitionTime
          (void *)&zclSampleLight1_LevelOffTransitionTime
          ZCL_DATATYPE_UINT8,
          (void *)&zclSampleLight1_LevelDefaultMoveRate
    #endif
     #ifdef ZCL_DIAGNOSTIC
          ZCL_DATATYPE_UINT8,
          ZCL_DATATYPE_INT8,
    uint8 CONST zclSampleLight1_NumAttributes = ( sizeof(zclSampleLight1_Attrs) / sizeof(zclSampleLight1_Attrs[0]) );
     * SIMPLE DESCRIPTOR
    const cId_t zclSampleLight1_InClusterList[] =
      , ZCL_CLUSTER_ID_GEN_LEVEL_CONTROL
    #endif
     #define ZCLSAMPLELIGHT1_MAX_INCLUSTERS   6
    #else
     #define ZCLSAMPLELIGHT1_MAX_INCLUSTERS   5
    #endif
    const cId_t zclSampleLight1_OutClusterList[] =
    #define ZCLSAMPLELIGHT1_MAX_OUTCLUSTERS  (sizeof(zclSampleLight1_OutClusterList) / sizeof(zclSampleLight1_OutClusterList[0]))
    SimpleDescriptionFormat_t zclSampleLight1_SimpleDesc =
      SAMPLELIGHT1_ENDPOINT,                  //  int Endpoint;
    #else
    #endif
      SAMPLELIGHT1_DEVICE_VERSION,            //  int   AppDevVer:4;
      SAMPLELIGHT1_FLAGS,                     //  int   AppFlags:4;
      ZCLSAMPLELIGHT1_MAX_INCLUSTERS,         //  byte  AppNumInClusters;
      (cId_t *)zclSampleLight1_InClusterList, //  byte *pAppInClusterList;
      ZCLSAMPLELIGHT1_MAX_OUTCLUSTERS,        //  byte  AppNumInClusters;
      (cId_t *)zclSampleLight1_OutClusterList //  byte *pAppInClusterList;
     * GLOBAL FUNCTIONS
     * LOCAL FUNCTIONS
  • Do you try my zcl_samplelight.c?
  • Yes, but problem does not solved.
  • I am pretty sure my zcl_samplelight.c works well. Try to install clean Z-Stack Home 1.2.2 and only replace my zcl_samplelight.c and test again.
  • Might be a hardware problem?
  • I don't think so. I think you must modify something in Z-Stack so it doesn't work. Please install a new Z-Stack Home 1.2.2 and test again.
  • Thank you, it works fine.
    I add these lines for set both edge key in hal_key.c:
    GPIOIntTypeSet(BSP_KEY_DIR_BASE, BSP_KEY_DIR_ALL, GPIO_BOTH_EDGES);
    GPIOIntTypeSet(BSP_KEY_SEL_BASE, BSP_KEY_SELECT, GPIO_BOTH_EDGES);
    Could this be causing the problem?
  • You can try to comment out these two lines to beefy it.
  • Maybe you can try the following workaround:
    Just change the define for the display buffer in lcd_dogm128_6.h
    from
    #define LCD_BYTES               1024    // Number of bytes needed in LCD buffer
    to
    #define LCD_BYTES               1025    // Number of bytes needed in LCD buffer
    Increasing this buffer will fix overwriting the first byte of the nex variable in RAM after Display update routine. Seems there is a problem with the indexing there.
     I`ve had the same issue here with the per test software for cc2538dk using ccs 6.0.
    Best regards
    Christian
