Other Parts Discussed in Thread: CC2538, CC2592
Hi TI,
Below is the test I have performed using cc2538+cc2592 ZigBee module with Z-STACK-HOME:1.2.2a Loaded in it.
1. Started COORDINATOR-1 with 0xABCD PAN id by allowing it form a network in best channel by scanning all the channels. As a result Coordinator started in 0x14 channel
2. Started a END DEVICE with 0xABCD PAN id by allowing it to scan all the channels. As a result End device has joined to the above coordinator.
3. Started another COORDINATOR - 2 with 0xABCD PAN id by allowing it to scan all the channels . As a result Coordinator has started in channel 0x0B.
4. Turned off the COORDINATOR-1 which is in channel 0x14.
Observations:
1.The end device which has lost its parent releases orphan notification and scans all channels for a parent.
2.COORDINATOR - 2 responds to the beacon request of the end device .
But the end device does not get associated with the COORDINATOR - 2 . Why is this happening?
The end device is continuously scanning all the channels without any successful association with a FFD.
