Other Parts Discussed in Thread: CC2531, CC2530, Z-STACK
hello,
I am using Gateway client application on BBB with cc2531 coordinator connected through USB and router device is smart RF board with cc2530 EM connected to it.
- I want to do OTA client application on CC2530 and upgrade image through the OTA server. I read the document from following path
Texas Instruments\Z-Stack Home 1.2.1\Documents\Z-Stack OTA Upgrade User's Guide.pdf
- and come to know that in the sample swich directory code for ota client for ROUTER as well EB is given.
- So I start with sampleswitch from
Texas Instruments\Z-Stack Home 1.2.1\Projects\zstack\HomeAutomation\SampleSwitch\CC2530DB\SampleSwitch.eww
and select RouterEB -OTAclient
- I made changes in option-> linker-> output ...
1. in output file select override default and give name sampleswitch.hex
2. In format select other, output format - intel-extended, variant - none, module-local symbols - all
-rebuild the code and generated .hex file
-but when I try to upload file using flash programmer, it gives me error "CC2530 - ID0129: HEX file content at address 0x7C7FF exceeds chip's 256 kB flash size".
Can any one tell me why I am getting this error since I am not changing any thing in the sample code?
