CC2530: Make CC2530 read when button is pressed (Not released)
Part Number: CC2530
How can I make it so that the CC2530 reads when the button is pressed, but not released? Right now, if I hold the button down, the CC2530 doesn't respond until I release the button. So I need it so the CC2530 read the actual pressing part. This is a problem because the factory reset doesn't work. The factory reset code needs to know if the button is pressed and held, but unfortunately the CC2530 only reads the release of the button. How can this problem be fixed? Is a circuitry problem of a programming problem? (My button circuit is looked like the below, but connected to the CC2530)
  Filename:       hal_key.c
  Revised:        $Date: 2010-09-15 19:02:45 -0700 (Wed, 15 Sep 2010) $
  Revision:       $Revision: 23815 $
  Description:    This file contains the interface to the HAL KEY Service.
  Copyright 2006-2010 Texas Instruments Incorporated. All rights reserved.
  IMPORTANT: Your use of this Software is limited to those specific rights
  granted under the terms of a software license agreement between the user
  who downloaded the software, his/her employer (which must be your employer)
  and Texas Instruments Incorporated (the "License").  You may not use this
  Software unless you agree to abide by the terms of the License. The License
  limits your use, and you acknowledge, that the Software may not be modified,
  copied or distributed unless embedded on a Texas Instruments microcontroller
  or used solely and exclusively in conjunction with a Texas Instruments radio
  frequency transceiver, which is integrated into your product.  Other than for
  the foregoing purpose, you may not use, reproduce, copy, prepare derivative
  works of, modify, distribute, perform, display or sell this Software and/or
  its documentation for any purpose.
  YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
  PROVIDED �AS IS?WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
  INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
  NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
  TEXAS INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT,
  NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
  LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
  INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
  OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
  OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
  (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
  Should you have any questions regarding your right to use this Software,
  contact Texas Instruments Incorporated at www.TI.com.
 NOTE: If polling is used, the hal_driver task schedules the KeyRead()
       to occur every 100ms.  This should be long enough to naturally
       debounce the keys.  The KeyRead() function remembers the key
       state of the previous poll and will only return a non-zero
       value if the key state changes.
 NOTE: If interrupts are used, the KeyRead() function is scheduled
       25ms after the interrupt occurs by the ISR.  This delay is used
       for key debouncing.  The ISR disables any further Key interrupt
       until KeyRead() is executed.  KeyRead() will re-enable Key
       interrupts after executing.  Unlike polling, when interrupts
       are enabled, the previous key state is not remembered.  This
       means that KeyRead() will return the current state of the keys
       (not a change in state of the keys).
 NOTE: If interrupts are used, the KeyRead() fucntion is scheduled by
       the ISR.  Therefore, the joystick movements will only be detected
       during a pushbutton interrupt caused by S1 or the center joystick
       pushbutton.
 NOTE: When a switch like S1 is pushed, the S1 signal goes from a normally
       high state to a low state.  This transition is typically clean.  The
       duration of the low state is around 200ms.  When the signal returns
       to the high state, there is a high likelihood of signal bounce, which
       causes a unwanted interrupts.  Normally, we would set the interrupt
       edge to falling edge to generate an interrupt when S1 is pushed, but
       because of the signal bounce, it is better to set the edge to rising
       edge to generate an interrupt when S1 is released.  The debounce logic
       can then filter out the signal bounce.  The result is that we typically
       get only 1 interrupt per button push.  This mechanism is not totally
       foolproof because occasionally, signal bound occurs during the falling
       edge as well.  A similar mechanism is used to handle the joystick
       pushbutton on the DB.  For the EB, we do not have independent control
       of the interrupt edge for the S1 and center joystick pushbutton.  As
       a result, only one or the other pushbuttons work reasonably well with
       interrupts.  The default is the make the S1 switch on the EB work more
       reliably.
 *                                            INCLUDES
#include "hal_mcu.h"
#include "hal_defs.h"
#include "hal_types.h"
#include "hal_board.h"
#include "hal_drivers.h"
#include "hal_adc.h"
#include "hal_key.h"
#include "osal.h"
#if (defined HAL_KEY) && (HAL_KEY == TRUE)
 *                                              MACROS
 *                                            CONSTANTS
#define HAL_KEY_RISING_EDGE   0
#define HAL_KEY_FALLING_EDGE  1
#define HAL_KEY_DEBOUNCE_VALUE  25
/* CPU port interrupt */
#define HAL_KEY_CPU_PORT_0_IF P0IF
#define HAL_KEY_CPU_PORT_1_IF P1IF
#define HAL_KEY_CPU_PORT_2_IF P2IF
/* SW_6 is at P0.1 */
#define HAL_KEY_SW_6_PORT   P2
#define HAL_KEY_SW_6_BIT    BV(0)
#define HAL_KEY_SW_6_SEL    P2SEL
#define HAL_KEY_SW_6_DIR    P2DIR
/* edge interrupt */
#define HAL_KEY_SW_6_EDGEBIT  BV(3)
#define HAL_KEY_SW_6_EDGE     HAL_KEY_FALLING_EDGE
/* SW_6 interrupts */
#define HAL_KEY_SW_6_IEN      IEN2  /* CPU interrupt mask register */
#define HAL_KEY_SW_6_IENBIT   BV(1) /* Mask bit for all of Port_0 */
#define HAL_KEY_SW_6_ICTL     P2IEN /* Port Interrupt Control register */
#define HAL_KEY_SW_6_ICTLBIT  BV(0) /* P0IEN - P0.1 enable/disable bit */
#define HAL_KEY_SW_6_PXIFG    P2IFG /* Interrupt flag at source */
#define HAL_KEY_SW_1_PORT P1
#define HAL_KEY_SW_1_BIT BV(7)
#define HAL_KEY_SW_1_SEL P1SEL
#define HAL_KEY_SW_1_DIR P1DIR
#define HAL_KEY_SW_1_EDGEBIT BV(2)
#define HAL_KEY_SW_1_EDGE HAL_KEY_FALLING_EDGE
#define HAL_KEY_SW_1_IEN IEN2
#define HAL_KEY_SW_1_IENBIT BV(4)
#define HAL_KEY_SW_1_ICTL P1IEN
#define HAL_KEY_SW_1_ICTLBIT BV(7)
#define HAL_KEY_SW_1_PXIFG P1IFG
#define HAL_KEY_SW_2_PORT P1
#define HAL_KEY_SW_2_BIT BV(6)
#define HAL_KEY_SW_2_SEL P1SEL
#define HAL_KEY_SW_2_DIR P1DIR
#define HAL_KEY_SW_2_EDGEBIT BV(2)
#define HAL_KEY_SW_2_EDGE HAL_KEY_FALLING_EDGE
#define HAL_KEY_SW_2_IEN IEN2
#define HAL_KEY_SW_2_IENBIT BV(4)
#define HAL_KEY_SW_2_ICTL P1IEN
#define HAL_KEY_SW_2_ICTLBIT BV(6)
#define HAL_KEY_SW_2_PXIFG P1IFG
#define port P1_7
#define port2 P1_6
 *                                            TYPEDEFS
 *                                        GLOBAL VARIABLES
static uint8 halKeySavedKeys;     /* used to store previous key state in polling mode */
static halKeyCBack_t pHalKeyProcessFunction;
static uint8 HalKeyConfigured;
bool Hal_KeyIntEnable;            /* interrupt enable/disable flag */
 *                                        FUNCTIONS - Local
void halProcessKeyInterrupt(void);
 *                                        FUNCTIONS - API
 * @fn      HalKeyInit
 * @brief   Initilize Key Service
 * @param   none
 * @return  None
void HalKeyInit( void )
  /* Initialize previous key to 0 */
  halKeySavedKeys = 0;
  HAL_KEY_SW_6_SEL &= ~(HAL_KEY_SW_6_BIT);    /* Set pin function to GPIO */
  HAL_KEY_SW_6_DIR &= ~(HAL_KEY_SW_6_BIT);    /* Set pin direction to Input */
  HAL_KEY_SW_1_SEL &= ~(HAL_KEY_SW_1_BIT);    /* Set pin function to GPIO */
  HAL_KEY_SW_1_DIR &= ~(HAL_KEY_SW_1_BIT);    /* Set pin direction to Input */
  HAL_KEY_SW_2_SEL &= ~(HAL_KEY_SW_2_BIT);    /* Set pin function to GPIO */
  HAL_KEY_SW_2_DIR &= ~(HAL_KEY_SW_2_BIT);    /* Set pin direction to Input */
  /* Initialize callback function */
  pHalKeyProcessFunction  = NULL;
  /* Start with key is not configured */
  HalKeyConfigured = FALSE;
 * @fn      HalKeyConfig
 * @brief   Configure the Key serivce
 * @param   interruptEnable - TRUE/FALSE, enable/disable interrupt
 *          cback - pointer to the CallBack function
 * @return  None
void HalKeyConfig (bool interruptEnable, halKeyCBack_t cback)
  /* Enable/Disable Interrupt or */
  Hal_KeyIntEnable = interruptEnable;
  /* Register the callback fucntion */
  pHalKeyProcessFunction = cback;
  /* Determine if interrupt is enable or not */
  if (Hal_KeyIntEnable)
    /* Rising/Falling edge configuratinn */
    PICTL &= ~(HAL_KEY_SW_6_EDGEBIT);    /* Clear the edge bit */
    /* For falling edge, the bit must be set. */
  #if (HAL_KEY_SW_6_EDGE == HAL_KEY_FALLING_EDGE)
    PICTL |= HAL_KEY_SW_6_EDGEBIT;
  #endif
    PICTL &= ~(HAL_KEY_SW_1_EDGEBIT);    /* Clear the edge bit */
  #if (HAL_KEY_SW_1_EDGE == HAL_KEY_FALLING_EDGE)
    PICTL |= HAL_KEY_SW_1_EDGEBIT;
  #endif
    PICTL &= ~(HAL_KEY_SW_2_EDGEBIT);    /* Clear the edge bit */
  #if (HAL_KEY_SW_2_EDGE == HAL_KEY_FALLING_EDGE)
    PICTL |= HAL_KEY_SW_2_EDGEBIT;
  #endif
    /* Interrupt configuration:
     * - Enable interrupt generation at the port
     * - Enable CPU interrupt
     * - Clear any pending interrupt
    HAL_KEY_SW_6_ICTL |= HAL_KEY_SW_6_ICTLBIT;
    HAL_KEY_SW_6_IEN |= HAL_KEY_SW_6_IENBIT;
    HAL_KEY_SW_6_PXIFG = ~(HAL_KEY_SW_6_BIT);
    HAL_KEY_SW_1_ICTL |= HAL_KEY_SW_1_ICTLBIT;
    HAL_KEY_SW_1_IEN |= HAL_KEY_SW_1_IENBIT;
    HAL_KEY_SW_1_PXIFG = ~(HAL_KEY_SW_1_BIT);
    HAL_KEY_SW_2_ICTL |= HAL_KEY_SW_2_ICTLBIT;
    HAL_KEY_SW_2_IEN |= HAL_KEY_SW_2_IENBIT;
    HAL_KEY_SW_2_PXIFG = ~(HAL_KEY_SW_2_BIT);
    /* Do this only after the hal_key is configured - to work with sleep stuff */
    if (HalKeyConfigured == TRUE)
      osal_stop_timerEx(Hal_TaskID, HAL_KEY_EVENT);  /* Cancel polling if active */
  else    /* Interrupts NOT enabled */
    HAL_KEY_SW_6_ICTL &= ~(HAL_KEY_SW_6_ICTLBIT); /* don't generate interrupt */
    HAL_KEY_SW_6_IEN &= ~(HAL_KEY_SW_6_IENBIT);   /* Clear interrupt enable bit */
    HAL_KEY_SW_1_ICTL &= ~(HAL_KEY_SW_1_ICTLBIT); /* don't generate interrupt */
    HAL_KEY_SW_1_IEN &= ~(HAL_KEY_SW_1_IENBIT);   /* Clear interrupt enable bit */
    HAL_KEY_SW_2_ICTL &= ~(HAL_KEY_SW_2_ICTLBIT); /* don't generate interrupt */
    HAL_KEY_SW_2_IEN &= ~(HAL_KEY_SW_2_IENBIT);   /* Clear interrupt enable bit */
    osal_set_event(Hal_TaskID, HAL_KEY_EVENT);
  /* Key now is configured */
  HalKeyConfigured = TRUE;
 * @fn      HalKeyRead
 * @brief   Read the current value of a key
 * @param   None
 * @return  keys - current keys status
uint8 HalKeyRead ( void )
  uint8 keys = 0;
  if (P2_0==0/*HAL_PUSH_BUTTON1()*/)
    keys |= HAL_KEY_SW_6;
  if (port==0)
    keys |= HAL_KEY_SW_1;
  if (port2==0)
    keys |= HAL_KEY_SW_2;
  return keys;
 * @fn      HalKeyPoll
 * @brief   Called by hal_driver to poll the keys
 * @param   None
 * @return  None
void HalKeyPoll (void)
  uint8 keys = 0;
  /* If interrupts are not enabled, previous key status and current key status
   * are compared to find out if a key has changed status.
  if (!Hal_KeyIntEnable)
    if (keys == halKeySavedKeys)
      /* Exit - since no keys have changed */
      return;
    /* Store the current keys for comparation next time */
    halKeySavedKeys = keys;
  else
    /* Key interrupt handled here */
  if (port==0)
  if (port2==0)
  /* Invoke Callback if new keys were depressed */
  if (keys && (pHalKeyProcessFunction))
    (pHalKeyProcessFunction) (keys, HAL_KEY_STATE_NORMAL);
 * @fn      halGetJoyKeyInput
 * @brief   Map the ADC value to its corresponding key.
 * @param   None
 * @return  keys - current joy key status
 * @fn      halProcessKeyInterrupt
 * @brief   Checks to see if it's a valid key interrupt, saves interrupt driven key states for
 *          processing by HalKeyRead(), and debounces keys by scheduling HalKeyRead() 25ms later.
 * @param
 * @return
void halProcessKeyInterrupt (void)
  bool valid=FALSE;
  if (HAL_KEY_SW_6_PXIFG & HAL_KEY_SW_6_BIT)  /* Interrupt Flag has been set */
    HAL_KEY_SW_6_PXIFG = ~(HAL_KEY_SW_6_BIT); /* Clear Interrupt Flag */
    valid = TRUE;
  if (HAL_KEY_SW_1_PXIFG & HAL_KEY_SW_1_BIT)  /* Interrupt Flag has been set */
    HAL_KEY_SW_1_PXIFG = ~(HAL_KEY_SW_1_BIT); /* Clear Interrupt Flag */
    valid = TRUE;
  if (HAL_KEY_SW_2_PXIFG & HAL_KEY_SW_2_BIT)  /* Interrupt Flag has been set */
    HAL_KEY_SW_2_PXIFG = ~(HAL_KEY_SW_2_BIT); /* Clear Interrupt Flag */
    valid = TRUE;
  if (valid)
    osal_start_timerEx (Hal_TaskID, HAL_KEY_EVENT, HAL_KEY_DEBOUNCE_VALUE);
 * @fn      HalKeyEnterSleep
 * @brief  - Get called to enter sleep mode
 * @param
 * @return
void HalKeyEnterSleep ( void )
 * @fn      HalKeyExitSleep
 * @brief   - Get called when sleep is over
 * @param
 * @return  - return saved keys
uint8 HalKeyExitSleep ( void )
  /* Wake up and read keys */
  return ( HalKeyRead () );
 *                                    INTERRUPT SERVICE ROUTINE
 * @fn      halKeyPort0Isr
 * @brief   Port0 ISR
 * @param
 * @return
HAL_ISR_FUNCTION( halKeyPort1Isr, P1INT_VECTOR )
  HAL_ENTER_ISR();
    halProcessKeyInterrupt();
    Clear the CPU interrupt flag for Port_0
    PxIFG has to be cleared before PxIF
  HAL_KEY_SW_1_PXIFG = 0;
  HAL_KEY_SW_2_PXIFG = 0;
  HAL_KEY_CPU_PORT_1_IF = 0;
  CLEAR_SLEEP_MODE();
  HAL_EXIT_ISR();
 * @fn      halKeyPort2Isr
 * @brief   Port2 ISR
 * @param
 * @return
HAL_ISR_FUNCTION( halKeyPort2Isr, P2INT_VECTOR )
  HAL_ENTER_ISR();
  HAL_KEY_SW_6_PXIFG = 0;
  HAL_KEY_CPU_PORT_2_IF = 0;
  CLEAR_SLEEP_MODE();
  HAL_EXIT_ISR();
#else
void HalKeyInit(void){}
void HalKeyConfig(bool interruptEnable, halKeyCBack_t cback){}
uint8 HalKeyRead(void){ return 0;}
void HalKeyPoll(void){}
#endif /* HAL_KEY */
 * INCLUDES
#include "ZComDef.h"
#include "OSAL.h"
#include "AF.h"
#include "ZDApp.h"
#include "ZDObject.h"
#include "MT_SYS.h"
#include "nwk_util.h"
#include "zcl.h"
#include "zcl_general.h"
#include "zcl_ha.h"
#include "zcl_ezmode.h"
#include "zcl_diagnostic.h"
#include "zcl_samplelight.h"
#include "onboard.h"
/* HAL */
#include "hal_lcd.h"
//#include "hal_led.h"
#if ( defined (ZGP_DEVICE_TARGET) || defined (ZGP_DEVICE_TARGETPLUS) \
      || defined (ZGP_DEVICE_COMBO) || defined (ZGP_DEVICE_COMBO_MIN) )
#include "zgp_translationtable.h"
  #if (SUPPORTED_S_FEATURE(SUPP_ZGP_FEATURE_TRANSLATION_TABLE))
    #define ZGP_AUTO_TT
  #endif
#endif
#if (defined HAL_BOARD_ZLIGHT) || (defined HAL_PWM)
#include "math.h"
#include "hal_timer.h"
#endif
#include "NLMEDE.h"
 * MACROS
 * CONSTANTS
#define LEVEL_MAX                 0xFE
#define LEVEL_MIN                 0x0
#define GAMMA_VALUE               2
#define PWM_FULL_DUTY_CYCLE       1000
#elif (defined HAL_PWM)
#endif
 * TYPEDEFS
 * GLOBAL VARIABLES
byte zclSampleLight_TaskID;
uint8 zclSampleLightSeqNum;
 * GLOBAL FUNCTIONS
 * LOCAL VARIABLES
afAddrType_t zclSampleLight_DstAddr;
#ifdef ZCL_EZMODE
static void zclSampleLight_ProcessZDOMsgs( zdoIncomingMsg_t *pMsg );
static void zclSampleLight_EZModeCB( zlcEZMode_State_t state, zclEZMode_CBData_t *pData );
// register EZ-Mode with task information (timeout events, callback, etc...)
static const zclEZMode_RegisterData_t zclSampleLight_RegisterEZModeData =
  &zclSampleLight_TaskID,
  SAMPLELIGHT_EZMODE_NEXTSTATE_EVT,
  SAMPLELIGHT_EZMODE_TIMEOUT_EVT,
  &zclSampleLightSeqNum,
#else
uint16 bindingInClusters[] =
  ZCL_CLUSTER_ID_GEN_ON_OFF
#ifdef ZCL_LEVEL_CTRL
  , ZCL_CLUSTER_ID_GEN_LEVEL_CONTROL
#endif
#define ZCLSAMPLELIGHT_BINDINGLIST (sizeof(bindingInClusters) / sizeof(bindingInClusters[0]))
#endif  // ZCL_EZMODE
// Test Endpoint to allow SYS_APP_MSGs
static endPointDesc_t sampleLight_TestEp =
  SAMPLELIGHT_ENDPOINT,
  (SimpleDescriptionFormat_t *)NULL,  // No Simple description for this test endpoint
  (afNetworkLatencyReq_t)0            // No Network Latency req
uint8 giLightScreenMode = LIGHT_MAINMODE;   // display the main screen mode first
uint8 gPermitDuration = 0;    // permit joining default to disabled
devStates_t zclSampleLight_NwkState = DEV_INIT;
#if ZCL_LEVEL_CTRL
uint8 zclSampleLight_WithOnOff;       // set to TRUE if state machine should set light on/off
uint8 zclSampleLight_NewLevel;        // new level when done moving
bool  zclSampleLight_NewLevelUp;      // is direction to new level up or down?
int32 zclSampleLight_CurrentLevel32;  // current level, fixed point (e.g. 192.456)
int32 zclSampleLight_Rate32;          // rate in units, fixed point (e.g. 16.123)
uint8 zclSampleLight_LevelLastLevel;  // to save the Current Level before the light was turned OFF
#endif
 * LOCAL FUNCTIONS
static void zclSampleLight_HandleKeys( byte shift, byte keys );
static void zclSampleLight_BasicResetCB( void );
static void zclSampleLight_IdentifyCB( zclIdentify_t *pCmd );
static void zclSampleLight_IdentifyQueryRspCB( zclIdentifyQueryRsp_t *pRsp );
static void zclSampleLight_OnOffCB( uint8 cmd );
static void zclSampleLight_ProcessIdentifyTimeChange( void );
static void zclSampleLight_LevelControlMoveToLevelCB( zclLCMoveToLevel_t *pCmd );
static void zclSampleLight_LevelControlMoveCB( zclLCMove_t *pCmd );
static void zclSampleLight_LevelControlStepCB( zclLCStep_t *pCmd );
static void zclSampleLight_LevelControlStopCB( void );
static void zclSampleLight_DefaultMove( void );
static uint32 zclSampleLight_TimeRateHelper( uint8 newLevel );
static uint16 zclSampleLight_GetTime ( uint8 level, uint16 time );
static void zclSampleLight_MoveBasedOnRate( uint8 newLevel, uint32 rate );
static void zclSampleLight_MoveBasedOnTime( uint8 newLevel, uint16 time );
static void zclSampleLight_AdjustLightLevel( void );
#endif
// app display functions
static void zclSampleLight_LcdDisplayUpdate( void );
#ifdef LCD_SUPPORTED
static void zclSampleLight_LcdDisplayMainMode( void );
static void zclSampleLight_LcdDisplayHelpMode( void );
#endif
static void zclSampleLight_DisplayLight( void );
void zclSampleLight_UpdateLampLevel( uint8 level );
#endif
// Functions to process ZCL Foundation incoming Command/Response messages
static void zclSampleLight_ProcessIncomingMsg( zclIncomingMsg_t *msg );
#ifdef ZCL_READ
static uint8 zclSampleLight_ProcessInReadRspCmd( zclIncomingMsg_t *pInMsg );
#endif
#ifdef ZCL_WRITE
static uint8 zclSampleLight_ProcessInWriteRspCmd( zclIncomingMsg_t *pInMsg );
#endif
static uint8 zclSampleLight_ProcessInDefaultRspCmd( zclIncomingMsg_t *pInMsg );
#ifdef ZCL_DISCOVER
static uint8 zclSampleLight_ProcessInDiscCmdsRspCmd( zclIncomingMsg_t *pInMsg );
static uint8 zclSampleLight_ProcessInDiscAttrsRspCmd( zclIncomingMsg_t *pInMsg );
static uint8 zclSampleLight_ProcessInDiscAttrsExtRspCmd( zclIncomingMsg_t *pInMsg );
#endif
 * STATUS STRINGS
const char sDeviceName[]   = "  Sample Light";
const char sClearLine[]    = " ";
const char sSwLight[]      = "SW1: ToggleLight";  // 16 chars max
const char sSwEZMode[]     = "SW2: EZ-Mode";
char sSwHelp[]             = "SW5: Help       ";  // last character is * if NWK open
const char sLightOn[]      = "    LIGHT ON ";
const char sLightOff[]     = "    LIGHT OFF";
 #if ZCL_LEVEL_CTRL
 char sLightLevel[]        = "    LEVEL ###"; // displays level 1-254
 #endif
#endif
 * ZCL General Profile Callback table
static zclGeneral_AppCallbacks_t zclSampleLight_CmdCallbacks =
  zclSampleLight_BasicResetCB,            // Basic Cluster Reset command
  zclSampleLight_IdentifyCB,              // Identify command
#ifdef ZCL_EZMODE
  NULL,                                   // Identify EZ-Mode Invoke command
  NULL,                                   // Identify Update Commission State command
#endif
  NULL,                                   // Identify Trigger Effect command
  zclSampleLight_IdentifyQueryRspCB,      // Identify Query Response command
  zclSampleLight_OnOffCB,                 // On/Off cluster commands
  NULL,                                   // On/Off cluster enhanced command Off with Effect
  NULL,                                   // On/Off cluster enhanced command On with Recall Global Scene
  NULL,                                   // On/Off cluster enhanced command On with Timed Off
  zclSampleLight_LevelControlMoveToLevelCB, // Level Control Move to Level command
  zclSampleLight_LevelControlMoveCB,        // Level Control Move command
  zclSampleLight_LevelControlStepCB,        // Level Control Step command
  zclSampleLight_LevelControlStopCB,        // Level Control Stop command
#endif
#ifdef ZCL_GROUPS
  NULL,                                   // Group Response commands
#endif
#ifdef ZCL_SCENES
  NULL,                                  // Scene Store Request command
  NULL,                                  // Scene Recall Request command
  NULL,                                  // Scene Response command
#endif
#ifdef ZCL_ALARMS
  NULL,                                  // Alarm (Response) commands
#endif
#ifdef SE_UK_EXT
  NULL,                                  // Get Event Log command
  NULL,                                  // Publish Event Log command
#endif
  NULL,                                  // RSSI Location command
  NULL                                   // RSSI Location Response command
 * @fn          zclSampleLight_Init
 * @brief       Initialization function for the zclGeneral layer.
 * @param       none
 * @return      none
//uint16 adc_ain2 = 0;
#define DATA_PIN P0_5
#define forward P1_2
#define backward P1_3
#define time 110
static int no = 0;
#define PERIODIC_EVT 0x4000
#define PERIODIC_EVT2 0x0001
void zclSampleLight_Init( byte task_id )
  zclSampleLight_TaskID = task_id;
  osal_start_timerEx( zclSampleLight_TaskID, PERIODIC_EVT, 10 );
  osal_start_timerEx( zclSampleLight_TaskID, PERIODIC_EVT2, 10 );
  // Set destination address to indirect
  zclSampleLight_DstAddr.addrMode = (afAddrMode_t)AddrNotPresent;
  zclSampleLight_DstAddr.endPoint = 0;
  zclSampleLight_DstAddr.addr.shortAddr = 0;
  // This app is part of the Home Automation Profile
  zclHA_Init( &zclSampleLight_SimpleDesc );
  // Register the ZCL General Cluster Library callback functions
  zclGeneral_RegisterCmdCallbacks( SAMPLELIGHT_ENDPOINT, &zclSampleLight_CmdCallbacks );
  // Register the application's attribute list
  zcl_registerAttrList( SAMPLELIGHT_ENDPOINT, zclSampleLight_NumAttributes, zclSampleLight_Attrs );
  // Register the Application to receive the unprocessed Foundation command/response messages
  zcl_registerForMsg( zclSampleLight_TaskID );
#ifdef ZCL_DISCOVER
  // Register the application's command list
  zcl_registerCmdList( SAMPLELIGHT_ENDPOINT, zclCmdsArraySize, zclSampleLight_Cmds );
#endif
  // Register for all key events - This app will handle all key events
  RegisterForKeys( zclSampleLight_TaskID );
  // Register for a test endpoint
  afRegister( &sampleLight_TestEp );
#ifdef ZCL_EZMODE
  // Register EZ-Mode
  zcl_RegisterEZMode( &zclSampleLight_RegisterEZModeData );
  // Register with the ZDO to receive Match Descriptor Responses
  ZDO_RegisterForZDOMsg(task_id, Match_Desc_rsp);
#endif
  HalTimer1Init( 0 );
  halTimer1SetChannelDuty( WHITE_LED, 0 );
  halTimer1SetChannelDuty( RED_LED, 0 );
  halTimer1SetChannelDuty( BLUE_LED, 0 );
  halTimer1SetChannelDuty( GREEN_LED, 0 );
  // find if we are already on a network from NV_RESTORE
  uint8 state;
  NLME_GetRequest( nwkNwkState, 0, &state );
  if ( state < NWK_ENDDEVICE )
    // Start EZMode on Start up to avoid button press
    osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_START_EZMODE_EVT, 500 );
#if ZCL_LEVEL_CTRL
  zclSampleLight_DefaultMove();
#endif
#endif // #if (defined HAL_BOARD_ZLIGHT) || (defined HAL_PWM)
#ifdef ZCL_DIAGNOSTIC
  // Register the application's callback function to read/write attribute data.
  // This is only required when the attribute data format is unknown to ZCL.
  zcl_registerReadWriteCB( SAMPLELIGHT_ENDPOINT, zclDiagnostic_ReadWriteAttrCB, NULL );
  if ( zclDiagnostic_InitStats() == ZSuccess )
    // Here the user could start the timer to save Diagnostics to NV
#endif
  HalLcdWriteString ( (char *)sDeviceName, HAL_LCD_LINE_3 );
#endif  // LCD_SUPPORTED
#ifdef ZGP_AUTO_TT
  zgpTranslationTable_RegisterEP ( &zclSampleLight_SimpleDesc );
#endif
  P2SEL &= ~BV(0);
  P2DIR |= BV(0);
  P2_0=0;
  zclSampleLight_OnOff = LIGHT_ON;
  P0DIR |= 0x20;
  P1DIR |= 0x3f;
    /*DATA_PIN = 0;
    forward = 0;
    backward = 1;
    for(int i=0; i<time; i++){
      Onboard_wait(10000);
    forward = 0;
    backward = 0;
    DATA_PIN = 1;*/
    no = 1;
    ZDApp_ChangeState(DEV_NWK_DISC);
    // Restart scan for rejoin
    ZDApp_StartJoiningCycle();
    osal_stop_timerEx( ZDAppTaskID, ZDO_REJOIN_BACKOFF );
    osal_start_timerEx( ZDAppTaskID, ZDO_REJOIN_BACKOFF, zgDefaultRejoinScan );
 * @fn          zclSample_event_loop
 * @brief       Event Loop Processor for zclGeneral.
 * @param       none
 * @return      none
#include <hal_adc.h>
#define KEYHOLD_EVT  0x0100    //define event for key hold
int KeyPressCnt=0;
uint16 adc_ain2=0;
#define HAL_ADC_REF_125V    0x00    /* Internal 1.25V Reference */
#define HAL_ADC_DEC_064     0x00    /* Decimate by 64 : 8-bit resolution */
#define HAL_ADC_DEC_128     0x10    /* Decimate by 128 : 10-bit resolution */
#define HAL_ADC_DEC_512     0x30    /* Decimate by 512 : 14-bit resolution */
#define HAL_ADC_CHN_VDD3    0x0f    /* Input channel: VDD/3 */
#define HAL_ADC_CHN_TEMP    0x0e    /* Temperature sensor */
uint16 value_bat;
uint32        next;
halIntState_t intState;
#include <OSAL_PwrMgr.h>
uint16 zclSampleLight_event_loop( uint8 task_id, uint16 events )
  if( events & PERIODIC_EVT2 )
    //CODE HERE
    zclSampleLight_BasicResetCB();
#else
#ifdef ZCL_EZMODE
      // Invoke EZ-Mode
      zclEZMode_InvokeData_t ezModeData;
      // Invoke EZ-Mode
      ezModeData.endpoint = SAMPLELIGHT_ENDPOINT; // endpoint on which to invoke EZ-Mode
      if ( (zclSampleLight_NwkState == DEV_ZB_COORD) ||
          (zclSampleLight_NwkState == DEV_ROUTER)   ||
            (zclSampleLight_NwkState == DEV_END_DEVICE) )
        ezModeData.onNetwork = TRUE;      // node is already on the network
      else
        ezModeData.onNetwork = FALSE;     // node is not yet on the network
      ezModeData.initiator = FALSE;          // OnOffLight is a target
      ezModeData.numActiveOutClusters = 0;
      ezModeData.pActiveOutClusterIDs = NULL;
      ezModeData.numActiveInClusters = 0;
      zcl_InvokeEZMode( &ezModeData );
      // Hold off interrupts.
      HAL_ENTER_CRITICAL_SECTION( intState );
      // Get next time-out
      next = osal_next_timeout();
      // Re-enable interrupts.
      HAL_EXIT_CRITICAL_SECTION( intState );
      // Put the processor into sleep mode
      OSAL_SET_CPU_INTO_SLEEP( 7200000 );
#else // NOT EZ-Mode
      zAddrType_t dstAddr;
      HalLedSet ( HAL_LED_4, HAL_LED_MODE_OFF );
      // Initiate an End Device Bind Request, this bind request will
      // only use a cluster list that is important to binding.
      dstAddr.addrMode = afAddr16Bit;
      dstAddr.addr.shortAddr = 0;   // Coordinator makes the match
      ZDP_EndDeviceBindReq( &dstAddr, NLME_GetShortAddr(),
                           ZCL_HA_PROFILE_ID,
                           ZCLSAMPLELIGHT_BINDINGLIST, bindingInClusters,
                           0, NULL,   // No Outgoing clusters to bind
                           TRUE );
#endif // HAL_BOARD_ZLIGHT
    osal_start_timerEx( zclSampleLight_TaskID, PERIODIC_EVT2, 5000 );
    return (events ^ PERIODIC_EVT2);
  if( events & PERIODIC_EVT )
    //Do things that need periodic processing here!
    /* Clear ADC interrupt flag */
    ADCIF = 0;
    ADCCON3 = (HAL_ADC_REF_125V| HAL_ADC_DEC_128 | HAL_ADC_CHN_VDD3);
    /* Wait for the conversion to finish */
    while ( !ADCIF );
    /* Get the result */
    value_bat = ADCL;
    value_bat |= ((uint16) ADCH) << 8;
    * value now contains measurement of Vdd/3
    * 0 indicates 0V and 32767 indicates 1.25V
    * voltage = (value*3*1.25)/32767 volts
    * we will multiply by this by 10 to allow units of 0.1 volts
    value_bat = value_bat >> 6; // divide first by 2^6
    value_bat = (uint16)(value_bat * 37.5);
    value_bat = value_bat >> 9; // ...and later by 2^9...to prevent overflow during multiplication
    if(value_bat<=25){
      P0_4=1;
    else if(value_bat>25){
      P0_4=0;
    osal_start_timerEx( zclSampleLight_TaskID, PERIODIC_EVT, 5000 );
    return (events ^ PERIODIC_EVT);
  if ( events & KEYHOLD_EVT )
   if ( P2_0==1 )
   if (KeyPressCnt>25){
   extern void ZDApp_ResetTimerStart( uint16 delay );
   zgWriteStartupOptions(ZG_STARTUP_SET, (ZCD_STARTOPT_DEFAULT_NETWORK_STATE | ZCD_STARTOPT_DEFAULT_CONFIG_STATE) );
   ZDApp_ResetTimerStart(2000);
   else{
     KeyPressCnt++;
     osal_start_timerEx( zclSampleLight_TaskID, KEYHOLD_EVT, 100);
   return ( events ^ KEYHOLD_EVT );
  afIncomingMSGPacket_t *MSGpkt;
  (void)task_id;  // Intentionally unreferenced parameter
    if ( events & SYS_EVENT_MSG )
      while ( (MSGpkt = (afIncomingMSGPacket_t *)osal_msg_receive( zclSampleLight_TaskID )) )
        switch ( MSGpkt->hdr.event )
  #ifdef ZCL_EZMODE
          case ZDO_CB_MSG:
            zclSampleLight_ProcessZDOMsgs( (zdoIncomingMsg_t *)MSGpkt );
            break;
  #endif
          case ZCL_INCOMING_MSG:
            // Incoming ZCL Foundation command/response messages
            zclSampleLight_ProcessIncomingMsg( (zclIncomingMsg_t *)MSGpkt );
            break;
          case KEY_CHANGE:
            zclSampleLight_HandleKeys( ((keyChange_t *)MSGpkt)->state, ((keyChange_t *)MSGpkt)->keys );
            break;
          case ZDO_STATE_CHANGE:
            zclSampleLight_NwkState = (devStates_t)(MSGpkt->hdr.status);
            // now on the network
              zclSampleLight_LcdDisplayUpdate();
  #ifdef ZCL_EZMODE
              zcl_EZModeAction( EZMODE_ACTION_NETWORK_STARTED, NULL );
            break;
          default:
            break;
        // Release the memory
        osal_msg_deallocate( (uint8 *)MSGpkt );
      // return unprocessed events
      return (events ^ SYS_EVENT_MSG);
  if ( events & SAMPLELIGHT_IDENTIFY_TIMEOUT_EVT )
    if ( zclSampleLight_IdentifyTime > 0 )
      zclSampleLight_IdentifyTime--;
    zclSampleLight_ProcessIdentifyTimeChange();
    return ( events ^ SAMPLELIGHT_IDENTIFY_TIMEOUT_EVT );
  if ( events & SAMPLELIGHT_MAIN_SCREEN_EVT )
    return ( events ^ SAMPLELIGHT_MAIN_SCREEN_EVT );
#ifdef ZCL_EZMODE
  // event to start EZMode on startup with a delay
  if ( events & SAMPLELIGHT_START_EZMODE_EVT )
    // Invoke EZ-Mode
    // Invoke EZ-Mode
    else
    return ( events ^ SAMPLELIGHT_START_EZMODE_EVT );
  // going on to next state
  if ( events & SAMPLELIGHT_EZMODE_NEXTSTATE_EVT )
    zcl_EZModeAction ( EZMODE_ACTION_PROCESS, NULL );   // going on to next state
    return ( events ^ SAMPLELIGHT_EZMODE_NEXTSTATE_EVT );
  // the overall EZMode timer expired, so we timed out
  if ( events & SAMPLELIGHT_EZMODE_TIMEOUT_EVT )
    zcl_EZModeAction ( EZMODE_ACTION_TIMED_OUT, NULL ); // EZ-Mode timed out
    return ( events ^ SAMPLELIGHT_EZMODE_TIMEOUT_EVT );
#endif // ZLC_EZMODE
  if ( events & SAMPLELIGHT_LEVEL_CTRL_EVT )
    zclSampleLight_AdjustLightLevel();
    return ( events ^ SAMPLELIGHT_LEVEL_CTRL_EVT );
#endif
  // Discard unknown events
  return 0;
 * @fn      zclSampleLight_HandleKeys
 * @brief   Handles all key events for this device.
 * @param   shift - true if in shift/alt.
 * @param   keys - bit field for key events. Valid entries:
 *                 HAL_KEY_SW_5
 *                 HAL_KEY_SW_4
 *                 HAL_KEY_SW_2
 *                 HAL_KEY_SW_1
 * @return  none
  if ( keys & HAL_KEY_SW_6)
    KeyPressCnt=0;
    // toggle local light immediately
    zclSampleLight_OnOff = zclSampleLight_OnOff ? LIGHT_OFF : LIGHT_ON;
    zclSampleLight_LevelCurrentLevel = zclSampleLight_OnOff ? zclSampleLight_LevelOnLevel : ATTR_LEVEL_MIN_LEVEL;
#endif
    for(int i=0; i<10; i++){
  /*if ( keys & HAL_KEY_SW_3 )
    NLME_SendNetworkStatus( zclSampleLight_DstAddr.addr.shortAddr,
                       NLME_GetShortAddr(), NWKSTAT_NONTREE_LINK_FAILURE, FALSE );
  if ( keys & HAL_KEY_SW_4 )
    if ( ( zclSampleLight_NwkState == DEV_ZB_COORD ) ||
          ( zclSampleLight_NwkState == DEV_ROUTER ) )
      zAddrType_t tmpAddr;
      tmpAddr.addrMode = Addr16Bit;
      tmpAddr.addr.shortAddr = NLME_GetShortAddr();
      // toggle permit join
      gPermitDuration = gPermitDuration ? 0 : 0xff;
      // Trust Center significance is always true
      ZDP_MgmtPermitJoinReq( &tmpAddr, gPermitDuration, TRUE, FALSE );
  // Shift F5 does a Basic Reset (factory defaults)
  if ( shift && ( keys & HAL_KEY_SW_5 ) )
  else if ( keys & HAL_KEY_SW_5 )
    giLightScreenMode = giLightScreenMode ? LIGHT_MAINMODE : LIGHT_HELPMODE;
  // update the display, including the light
 * @fn      zclSampleLight_LcdDisplayUpdate
 * @brief   Called to update the LCD display.
 * @param   none
 * @return  none
  if ( giLightScreenMode == LIGHT_HELPMODE )
    zclSampleLight_LcdDisplayHelpMode();
  else
    zclSampleLight_LcdDisplayMainMode();
#endif
  zclReportCmd_t rptcmd;
  rptcmd.numAttr = 1;
  rptcmd.attrList[0].attrID = ATTRID_ON_OFF;
  rptcmd.attrList[0].dataType = ZCL_DATATYPE_BOOLEAN;
  rptcmd.attrList[0].attrData = (uint8*)&zclSampleLight_OnOff;
  zclSampleLight_DstAddr.addrMode = (afAddrMode_t)Addr16Bit;
  zclSampleLight_DstAddr.endPoint=1;
  zcl_SendReportCmd(SAMPLELIGHT_ENDPOINT,&zclSampleLight_DstAddr, ZCL_CLUSTER_ID_GEN_ON_OFF, &rptcmd, ZCL_FRAME_CLIENT_SERVER_DIR, false, 0 );
  zclSampleLight_DisplayLight();
 * @fn      zclSampleLight_UpdateLampLevel
 * @brief   Update lamp level output with gamma compensation
 * @param   level
 * @return  none
  uint16 gammaCorrectedLevel;
  // gamma correct the level
  gammaCorrectedLevel = (uint16) ( pow( ( (float)level / LEVEL_MAX ), (float)GAMMA_VALUE ) * (float)LEVEL_MAX);
  halTimer1SetChannelDuty(WHITE_LED, (uint16)(((uint32)gammaCorrectedLevel*PWM_FULL_DUTY_CYCLE)/LEVEL_MAX) );
#endif
 * @fn      zclSampleLight_DisplayLight
 * @brief   Displays current state of light on LED and also on main display if supported.
 * @param   none
 * @return  none
  // set the LED1 based on light (on or off)
  if ( zclSampleLight_OnOff == LIGHT_ON & no == 0 )
    DATA_PIN = 0;
    forward = 0;
    backward = 1;
    forward = 0;
    backward = 0;
    DATA_PIN = 1;
    no = 1;
  else if ( zclSampleLight_OnOff == LIGHT_OFF & no == 1 )
    DATA_PIN = 0;
    forward = 1;
    backward = 0;
    forward = 0;
    backward = 0;
    DATA_PIN = 1;
    no = 0;
  if (giLightScreenMode == LIGHT_MAINMODE)
    // display current light level
    if ( ( zclSampleLight_LevelCurrentLevel == ATTR_LEVEL_MIN_LEVEL ) &&
         ( zclSampleLight_OnOff == LIGHT_OFF ) )
      HalLcdWriteString( (char *)sLightOff, HAL_LCD_LINE_2 );
    else if ( ( zclSampleLight_LevelCurrentLevel >= ATTR_LEVEL_MAX_LEVEL ) ||
              ( zclSampleLight_LevelCurrentLevel == zclSampleLight_LevelOnLevel ) ||
               ( ( zclSampleLight_LevelOnLevel == ATTR_LEVEL_ON_LEVEL_NO_EFFECT ) &&
                 ( zclSampleLight_LevelCurrentLevel == zclSampleLight_LevelLastLevel ) ) )
      HalLcdWriteString( (char *)sLightOn, HAL_LCD_LINE_2 );
    else    // "    LEVEL ###"
      zclHA_uint8toa( zclSampleLight_LevelCurrentLevel, &sLightLevel[10] );
      HalLcdWriteString( (char *)sLightLevel, HAL_LCD_LINE_2 );
#else
    if ( zclSampleLight_OnOff )
    else
#endif // ZCL_LEVEL_CTRL
 * @fn      zclSampleLight_LcdDisplayMainMode
 * @brief   Called to display the main screen on the LCD.
 * @param   none
 * @return  none
  // display line 1 to indicate NWK status
  if ( zclSampleLight_NwkState == DEV_ZB_COORD )
    zclHA_LcdStatusLine1( ZCL_HA_STATUSLINE_ZC );
  else if ( zclSampleLight_NwkState == DEV_ROUTER )
    zclHA_LcdStatusLine1( ZCL_HA_STATUSLINE_ZR );
  else if ( zclSampleLight_NwkState == DEV_END_DEVICE )
    zclHA_LcdStatusLine1( ZCL_HA_STATUSLINE_ZED );
  // end of line 3 displays permit join status (*)
  if ( gPermitDuration )
    sSwHelp[15] = '*';
  else
    sSwHelp[15] = ' ';
  HalLcdWriteString( (char *)sSwHelp, HAL_LCD_LINE_3 );
 * @fn      zclSampleLight_LcdDisplayHelpMode
 * @brief   Called to display the SW options on the LCD.
 * @param   none
 * @return  none
  HalLcdWriteString( (char *)sSwLight, HAL_LCD_LINE_1 );
  HalLcdWriteString( (char *)sSwEZMode, HAL_LCD_LINE_2 );
 * @fn      zclSampleLight_ProcessIdentifyTimeChange
 * @brief   Called to process any change to the IdentifyTime attribute.
 * @param   none
 * @return  none
    osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_IDENTIFY_TIMEOUT_EVT, 1000 );
    //HalLedBlink ( HAL_LED_4, 0xFF, HAL_LED_DEFAULT_DUTY_CYCLE, HAL_LED_DEFAULT_FLASH_TIME );
  else
#ifdef ZCL_EZMODE
    if ( zclSampleLight_IdentifyCommissionState & EZMODE_COMMISSION_OPERATIONAL )
      //HalLedSet ( HAL_LED_4, HAL_LED_MODE_ON );
    else
      //HalLedSet ( HAL_LED_4, HAL_LED_MODE_OFF );
#endif
    osal_stop_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_IDENTIFY_TIMEOUT_EVT );
 * @fn      zclSampleLight_BasicResetCB
 * @brief   Callback from the ZCL General Cluster Library
 *          to set all the Basic Cluster attributes to default values.
 * @param   none
 * @return  none
  NLME_LeaveReq_t leaveReq;
  // Set every field to 0
  osal_memset( &leaveReq, 0, sizeof( NLME_LeaveReq_t ) );
  // This will enable the device to rejoin the network after reset.
  leaveReq.rejoin = TRUE;
  // Set the NV startup option to force a "new" join.
  zgWriteStartupOptions( ZG_STARTUP_SET, ZCD_STARTOPT_DEFAULT_NETWORK_STATE );
  // Leave the network, and reset afterwards
  if ( NLME_LeaveReq( &leaveReq ) != ZSuccess )
    // Couldn't send out leave; prepare to reset anyway
    ZDApp_LeaveReset( FALSE );
 * @fn      zclSampleLight_IdentifyCB
 * @brief   Callback from the ZCL General Cluster Library when
 *          it received an Identity Command for this application.
 * @param   srcAddr - source address and endpoint of the response message
 * @param   identifyTime - the number of seconds to identify yourself
 * @return  none
  zclSampleLight_IdentifyTime = pCmd->identifyTime;
 * @fn      zclSampleLight_IdentifyQueryRspCB
 *          it received an Identity Query Response Command for this application.
 * @param   srcAddr - requestor's address
 * @param   timeout - number of seconds to identify yourself (valid for query response)
 * @return  none
  (void)pRsp;
#ifdef ZCL_EZMODE
    zclEZMode_ActionData_t data;
    data.pIdentifyQueryRsp = pRsp;
    zcl_EZModeAction ( EZMODE_ACTION_IDENTIFY_QUERY_RSP, &data );
#endif
 * @fn      zclSampleLight_OnOffCB
 *          it received an On/Off Command for this application.
 * @param   cmd - COMMAND_ON, COMMAND_OFF or COMMAND_TOGGLE
 * @return  none
  afIncomingMSGPacket_t *pPtr = zcl_getRawAFMsg();
  zclSampleLight_DstAddr.addr.shortAddr = pPtr->srcAddr.addr.shortAddr;
  // Turn on the light
  if ( cmd == COMMAND_ON )
  // Turn off the light
  else if ( cmd == COMMAND_OFF )
    zclSampleLight_OnOff = LIGHT_OFF;
  // Toggle the light
  else if ( cmd == COMMAND_TOGGLE )
    if ( zclSampleLight_OnOff == LIGHT_OFF )
    else
#if ZCL_LEVEL_CTRL
  zclSampleLight_DefaultMove( );
#endif
  zclSampleLight_LcdDisplayUpdate( );
 * @fn      zclSampleLight_TimeRateHelper
 * @brief   Calculate time based on rate, and startup level state machine
 * @param   newLevel - new level for current level
 * @return  diff (directly), zclSampleLight_CurrentLevel32 and zclSampleLight_NewLevel, zclSampleLight_NewLevelUp
  uint32 diff;
  uint32 newLevel32;
  // remember current and new level
  zclSampleLight_NewLevel = newLevel;
  zclSampleLight_CurrentLevel32 = (uint32)1000 * zclSampleLight_LevelCurrentLevel;
  // calculate diff
  newLevel32 = (uint32)1000 * newLevel;
  if ( zclSampleLight_LevelCurrentLevel > newLevel )
    diff = zclSampleLight_CurrentLevel32 - newLevel32;
    zclSampleLight_NewLevelUp = FALSE;  // moving down
  else
    diff = newLevel32 - zclSampleLight_CurrentLevel32;
    zclSampleLight_NewLevelUp = TRUE;   // moving up
  return ( diff );
 * @fn      zclSampleLight_MoveBasedOnRate
 * @param   rate16   - fixed point rate (e.g. 16.123)
 * @return  none
  uint32 diff;
  // determine how much time (in 10ths of seconds) based on the difference and rate
  zclSampleLight_Rate32 = rate;
  diff = zclSampleLight_TimeRateHelper( newLevel );
  zclSampleLight_LevelRemainingTime = diff / rate;
  if ( !zclSampleLight_LevelRemainingTime )
    zclSampleLight_LevelRemainingTime = 1;
  osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_LEVEL_CTRL_EVT, 100 );
 * @fn      zclSampleLight_MoveBasedOnTime
 * @brief   Calculate rate based on time, and startup level state machine
 * @param   time      - in 10ths of seconds
 * @return  none
  uint16 diff;
  // determine rate (in units) based on difference and time
  zclSampleLight_LevelRemainingTime = zclSampleLight_GetTime( newLevel, time );
  zclSampleLight_Rate32 = diff / time;
 * @fn      zclSampleLight_GetTime
 * @brief   Determine amount of time that MoveXXX will take to complete.
 * @param   level = new level to move to
 *          time  = 0xffff=default, or 0x0000-n amount of time in tenths of seconds.
 * @return  none
static uint16 zclSampleLight_GetTime( uint8 level, uint16 time )
  // there is a hiearchy of the amount of time to use for transistioning
  // check each one in turn. If none of defaults are set, then use fastest
  // time possible.
  if ( time == 0xFFFF )
    // use On or Off Transition Time if set (not 0xffff)
    if ( zclSampleLight_OnOff == LIGHT_ON )
      time = zclSampleLight_LevelOffTransitionTime;
    else
      time = zclSampleLight_LevelOnTransitionTime;
    // else use OnOffTransitionTime if set (not 0xffff)
      time = zclSampleLight_LevelOnOffTransitionTime;
    // else as fast as possible
      time = 1;
  if ( !time )
    time = 1; // as fast as possible
  return ( time );
 * @fn      zclSampleLight_DefaultMove
 * @brief   We were turned on/off. Use default time to move to on or off.
 * @param   zclSampleLight_OnOff - must be set prior to calling this function.
 * @return  none
  uint8  newLevel;
  uint32 rate;      // fixed point decimal (3 places, eg. 16.345)
  uint16 time;
  // if moving to on position, move to on level
    if ( zclSampleLight_LevelOnLevel == ATTR_LEVEL_ON_LEVEL_NO_EFFECT )
      // The last Level (before going OFF) should be used)
      newLevel = zclSampleLight_LevelLastLevel;
    else
      newLevel = zclSampleLight_LevelOnLevel;
  else
    newLevel = ATTR_LEVEL_MIN_LEVEL;
      // Save the current Level before going OFF to use it when the light turns ON
      // it should be back to this level
      zclSampleLight_LevelLastLevel = zclSampleLight_LevelCurrentLevel;
    time = 1;
  // calculate rate based on time (int 10ths) for full transition (1-254)
  rate = 255000 / time;    // units per tick, fixed point, 3 decimal places (e.g. 8500 = 8.5 units per tick)
  // start up state machine.
  zclSampleLight_WithOnOff = TRUE;
  zclSampleLight_MoveBasedOnRate( newLevel, rate );
 * @fn      zclSampleLight_AdjustLightLevel
 * @brief   Called each 10th of a second while state machine running
 * @param   none
 * @return  none
  // one tick (10th of a second) less
  if ( zclSampleLight_LevelRemainingTime )
    --zclSampleLight_LevelRemainingTime;
  // no time left, done
  if ( zclSampleLight_LevelRemainingTime == 0)
    zclSampleLight_LevelCurrentLevel = zclSampleLight_NewLevel;
  // still time left, keep increment/decrementing
  else
    if ( zclSampleLight_NewLevelUp )
      zclSampleLight_CurrentLevel32 += zclSampleLight_Rate32;
    else
      zclSampleLight_CurrentLevel32 -= zclSampleLight_Rate32;
    zclSampleLight_LevelCurrentLevel = (uint8)( zclSampleLight_CurrentLevel32 / 1000 );
  zclSampleLight_UpdateLampLevel(zclSampleLight_LevelCurrentLevel);
#endif
  // also affect on/off
  if ( zclSampleLight_WithOnOff )
    if ( zclSampleLight_LevelCurrentLevel > ATTR_LEVEL_MIN_LEVEL )
      ENABLE_LAMP;
#endif
    else
      DISABLE_LAMP;
#endif
  // display light level as we go
  zclSampleLight_DisplayLight( );
  // keep ticking away
 * @fn      zclSampleLight_LevelControlMoveToLevelCB
 *          it received a LevelControlMoveToLevel Command for this application.
 * @param   pCmd - ZigBee command parameters
 * @return  none
  zclSampleLight_WithOnOff = pCmd->withOnOff;
  zclSampleLight_MoveBasedOnTime( pCmd->level, pCmd->transitionTime );
 * @fn      zclSampleLight_LevelControlMoveCB
 *          it received a LevelControlMove Command for this application.
 * @return  none
  uint8 newLevel;
  uint32 rate;
  // convert rate from units per second to units per tick (10ths of seconds)
  // and move at that right up or down
  if ( pCmd->moveMode == LEVEL_MOVE_UP )
    newLevel = ATTR_LEVEL_MAX_LEVEL;  // fully on
  else
    newLevel = ATTR_LEVEL_MIN_LEVEL; // fully off
  rate = (uint32)100 * pCmd->rate;
 * @fn      zclSampleLight_LevelControlStepCB
 * @return  none
  uint8 newLevel;
  // determine new level, but don't exceed boundaries
  if ( pCmd->stepMode == LEVEL_MOVE_UP )
    if ( (uint16)zclSampleLight_LevelCurrentLevel + pCmd->amount > ATTR_LEVEL_MAX_LEVEL )
    else
      newLevel = zclSampleLight_LevelCurrentLevel + pCmd->amount;
  else
    if ( pCmd->amount >= zclSampleLight_LevelCurrentLevel )
    else
      newLevel = zclSampleLight_LevelCurrentLevel - pCmd->amount;
  // move to the new level
  zclSampleLight_MoveBasedOnTime( newLevel, pCmd->transitionTime );
 * @fn      zclSampleLight_LevelControlStopCB
 *          it received an Level Control Stop Command for this application.
 * @return  none
  // stop immediately
  osal_stop_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_LEVEL_CTRL_EVT );
  zclSampleLight_LevelRemainingTime = 0;
#endif
 *  Functions for processing ZCL Foundation incoming Command/Response messages
 * @fn      zclSampleLight_ProcessIncomingMsg
 * @brief   Process ZCL Foundation incoming message
 * @param   pInMsg - pointer to the received message
 * @return  none
static void zclSampleLight_ProcessIncomingMsg( zclIncomingMsg_t *pInMsg )
  switch ( pInMsg->zclHdr.commandID )
#ifdef ZCL_READ
    case ZCL_CMD_READ_RSP:
      zclSampleLight_ProcessInReadRspCmd( pInMsg );
      break;
#endif
#ifdef ZCL_WRITE
    case ZCL_CMD_WRITE_RSP:
      zclSampleLight_ProcessInWriteRspCmd( pInMsg );
      break;
#endif
#ifdef ZCL_REPORT
    // Attribute Reporting implementation should be added here
    case ZCL_CMD_CONFIG_REPORT:
      // zclSampleLight_ProcessInConfigReportCmd( pInMsg );
      break;
    case ZCL_CMD_CONFIG_REPORT_RSP:
      // zclSampleLight_ProcessInConfigReportRspCmd( pInMsg );
      break;
    case ZCL_CMD_READ_REPORT_CFG:
      // zclSampleLight_ProcessInReadReportCfgCmd( pInMsg );
      break;
    case ZCL_CMD_READ_REPORT_CFG_RSP:
      // zclSampleLight_ProcessInReadReportCfgRspCmd( pInMsg );
      break;
    case ZCL_CMD_REPORT:
      // zclSampleLight_ProcessInReportCmd( pInMsg );
      break;
#endif
    case ZCL_CMD_DEFAULT_RSP:
      zclSampleLight_ProcessInDefaultRspCmd( pInMsg );
      break;
#ifdef ZCL_DISCOVER
    case ZCL_CMD_DISCOVER_CMDS_RECEIVED_RSP:
      zclSampleLight_ProcessInDiscCmdsRspCmd( pInMsg );
      break;
    case ZCL_CMD_DISCOVER_CMDS_GEN_RSP:
      break;
    case ZCL_CMD_DISCOVER_ATTRS_RSP:
      zclSampleLight_ProcessInDiscAttrsRspCmd( pInMsg );
      break;
    case ZCL_CMD_DISCOVER_ATTRS_EXT_RSP:
      zclSampleLight_ProcessInDiscAttrsExtRspCmd( pInMsg );
      break;
#endif
    default:
      break;
  if ( pInMsg->attrCmd )
    osal_mem_free( pInMsg->attrCmd );
#ifdef ZCL_READ
 * @fn      zclSampleLight_ProcessInReadRspCmd
 * @brief   Process the "Profile" Read Response Command
 * @param   pInMsg - incoming message to process
 * @return  none
  zclReadRspCmd_t *readRspCmd;
  uint8 i;
  readRspCmd = (zclReadRspCmd_t *)pInMsg->attrCmd;
  for (i = 0; i < readRspCmd->numAttr; i++)
    // Notify the originator of the results of the original read attributes
    // attempt and, for each successfull request, the value of the requested
    // attribute
  return ( TRUE );
#endif // ZCL_READ
#ifdef ZCL_WRITE
 * @fn      zclSampleLight_ProcessInWriteRspCmd
 * @brief   Process the "Profile" Write Response Command
 * @return  none
  zclWriteRspCmd_t *writeRspCmd;
  uint8 i;
  writeRspCmd = (zclWriteRspCmd_t *)pInMsg->attrCmd;
  for ( i = 0; i < writeRspCmd->numAttr; i++ )
    // Notify the device of the results of the its original write attributes
    // command.
  return ( TRUE );
#endif // ZCL_WRITE
 * @fn      zclSampleLight_ProcessInDefaultRspCmd
 * @brief   Process the "Profile" Default Response Command
 * @return  none
  // zclDefaultRspCmd_t *defaultRspCmd = (zclDefaultRspCmd_t *)pInMsg->attrCmd;
  // Device is notified of the Default Response command.
  (void)pInMsg;
  return ( TRUE );
#ifdef ZCL_DISCOVER
 * @fn      zclSampleLight_ProcessInDiscCmdsRspCmd
 * @brief   Process the Discover Commands Response Command
 * @return  none
  zclDiscoverCmdsCmdRsp_t *discoverRspCmd;
  uint8 i;
  discoverRspCmd = (zclDiscoverCmdsCmdRsp_t *)pInMsg->attrCmd;
  for ( i = 0; i < discoverRspCmd->numCmd; i++ )
    // Device is notified of the result of its attribute discovery command.
  return ( TRUE );
 * @fn      zclSampleLight_ProcessInDiscAttrsRspCmd
 * @brief   Process the "Profile" Discover Attributes Response Command
 * @return  none
  zclDiscoverAttrsRspCmd_t *discoverRspCmd;
  uint8 i;
  discoverRspCmd = (zclDiscoverAttrsRspCmd_t *)pInMsg->attrCmd;
  for ( i = 0; i < discoverRspCmd->numAttr; i++ )
  return ( TRUE );
 * @fn      zclSampleLight_ProcessInDiscAttrsExtRspCmd
 * @brief   Process the "Profile" Discover Attributes Extended Response Command
 * @return  none
  zclDiscoverAttrsExtRsp_t *discoverRspCmd;
  uint8 i;
  discoverRspCmd = (zclDiscoverAttrsExtRsp_t *)pInMsg->attrCmd;
  return ( TRUE );
#endif // ZCL_DISCOVER
#if ZCL_EZMODE
 * @fn      zclSampleLight_ProcessZDOMsgs
 * @brief   Called when this node receives a ZDO/ZDP response.
 * @param   none
 * @return  status
  ZDO_MatchDescRsp_t *pMatchDescRsp;
  // Let EZ-Mode know of the Simple Descriptor Response
  if ( pMsg->clusterID == Match_Desc_rsp )
    pMatchDescRsp = ZDO_ParseEPListRsp( pMsg );
    data.pMatchDescRsp = pMatchDescRsp;
    zcl_EZModeAction( EZMODE_ACTION_MATCH_DESC_RSP, &data );
    osal_mem_free( pMatchDescRsp );
 * @fn      zclSampleLight_EZModeCB
 * @brief   The Application is informed of events. This can be used to show on the UI what is
*           going on during EZ-Mode steering/finding/binding.
 * @param   state - an
 * @return  none
  char *pStr;
  uint8 err;
#endif
  // time to go into identify mode
  if ( state == EZMODE_STATE_IDENTIFYING )
    HalLcdWriteString( "EZMode", HAL_LCD_LINE_2 );
#endif
    zclSampleLight_IdentifyTime = ( EZMODE_TIME / 1000 );  // convert to seconds
  // autoclosing, show what happened (success, cancelled, etc...)
  if( state == EZMODE_STATE_AUTOCLOSE )
    pStr = NULL;
    err = pData->sAutoClose.err;
    if ( err == EZMODE_ERR_SUCCESS )
      pStr = "EZMode: Success";
    else if ( err == EZMODE_ERR_NOMATCH )
      pStr = "EZMode: NoMatch"; // not a match made in heaven
    if ( pStr )
      if ( giLightScreenMode == LIGHT_MAINMODE )
        HalLcdWriteString ( pStr, HAL_LCD_LINE_2 );
#endif
  // finished, either show DstAddr/EP, or nothing (depending on success or not)
  if( state == EZMODE_STATE_FINISH )
    // turn off identify mode
    zclSampleLight_IdentifyTime = 0;
    // if successful, inform user which nwkaddr/ep we bound to
    pStr = NULL;
    err = pData->sFinish.err;
    if( err == EZMODE_ERR_SUCCESS )
      // already stated on autoclose
    else if ( err == EZMODE_ERR_CANCELLED )
      pStr = "EZMode: Cancel";
    else if ( err == EZMODE_ERR_BAD_PARAMETER )
      pStr = "EZMode: BadParm";
    else if ( err == EZMODE_ERR_TIMEDOUT )
      pStr = "EZMode: TimeOut";
    if ( pStr )
#endif
    // show main UI screen 3 seconds after binding
    osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_MAIN_SCREEN_EVT, 3000 );
Image result for button circuit with arduino
  • If CC2530 doesn't respond until I release the button, it means you use wrong edge trigger. You should use RISING edge instead of FALLING edge in your hal_key.c.
  • It works now. However, in the factory reset code, the breakpoint in the below picture isn't always hit when I hold the button which means that the program doesn't know that the button is being pressed. Why is this and how can it be fixed so that everytime I press the button, the breakpoint will be hit? The breakpoint is supposed to be hit everytime I press the button according to the program.
  • I think you should replace "if(P2_0==1)" with "if(P2_0==0)"
  • I already tried that, but that just means "if the button is released" and so the factory reset constantly happens without me pressing the button.
  • There is bug in your KEYHOLD_EVT. Try to use the following code to replace yours.
    if ( P2_0==1 )
    }else{
    KeyPressCnt++;
  • I tried the code and now the breakpoint is hit about 3-5 times consistently after I press the button only once. This is strange and also the problem is that the breakpoint on the factory reset is never hit when I hold the button for 5+ seconds. Why is this so and how can it be fixed so that the CC2530 factory resets after I hold the button for 5 seconds?
  • I make a mistake in my code. Please revise the red cod in the followings:
    if ( P2_0==0)
    }else{
    KeyPressCnt++;
  • Unfortunately that didn't fix the problem. What else do you suggest?
  • What problem do you see now?
  • Well the breakpoint in the image above still isn't hit when I hold the button down.
  • The breakpoint should hit when button is released.
  • It does not though. When I hold the button for 5+ seconds and then release, the CC2530 doesn't factory reset.
  • If you set a breakpoint on "if (KeyPressCnt>25)", what value of KeyPressCnt do you see?
  • Most of the time the breakpoint doesn't hit, but when it does, I usually get a value of 0, but occasionally if I'm lucky, I get a value greater than 25. So basically the problem is that, the code doesn't always know that the button is being pressed for 5 seconds even though ISR is always hit. What may be the problem as to why the factory reset code doesn't always know that the button is being pressed for 5 seconds?
  • Remove "KeyPressCnt=0;" in "if ( keys & HAL_KEY_SW_6){...}" and put it in "if (KeyPressCnt>25){...}"
  • The breakpoint is hit more and this improved the code, but the factory reset code still does not always know when the button is being pressed unlike the breakpoint at ISR. Is there any more to improve the code so that the factory reset always knows when the button is being pressed? Some of the times it doesn't know that the button is being held for 5 seconds.
  • When you see "Some of the times it doesn't know that the button is being held for 5 seconds", what value of KeyPressCnt do you see?
  • When it doesn't read the button, the breakpoint isn't ever hit. When it does hit, it reads the value of KeyPressCnt correctly. So the problem that needs to be fixed is that the factory reset needs to always know that the button is being pressed and held.
  • So,if you set another breakpoint in if ( keys & HAL_KEY_SW_6) and When you see "Some of the times it doesn't know that the button is being held for 5 seconds", does it hit?
  • That breakpoint always hits. Just not in the factory reset.
  • Does it go to KEYHOLD_EVT?
  • What do you mean? The breakpoint just hits and stops because it detects a rising edge button press. As soon as I press the button, the breakpoint is immediately hit and doesn't wait for me to hold the button. Only the factory reset code waits for me to hold the button. Perhaps it is the difference between P2_0 and HAL_KEY_SW_6 that may cause this problem?
  • When P2_0 is triggered, it should hit if ( keys & HAL_KEY_SW_6) in zclSampleLight_HandleKeys and call "osal_start_timerEx( zclSampleLight_TaskID, KEYHOLD_EVT, 100)" to schedule KEYHOLD_EVT to 100ms later. My question is when P2_0 is triggered, does it always hit "if ( P2_0==1 )" in if ( events & KEYHOLD_EVT ).
  • Not always, but most of the time it is. If I set a breakpoint on if (KeyPressCnt>25), then the breakpoint hits even less. Why is this so and how can it be fixed?
  • Can you attach your latest zcl_samplelight.c?
  • Here is the file:
     * INCLUDES
    #include "OSAL.h"
    #include "AF.h"
    #include "ZDApp.h"
    #include "MT_SYS.h"
    #include "zcl.h"
    #include "zcl_ha.h"
    /* HAL */
        #define ZGP_AUTO_TT
      #endif
    #endif
    #include "math.h"
    #endif
    #include "NLMEDE.h"
     * MACROS
     * CONSTANTS
    #endif
     * TYPEDEFS
     * GLOBAL VARIABLES
     * GLOBAL FUNCTIONS
     * LOCAL VARIABLES
    #ifdef ZCL_EZMODE
    #else
    #endif
    #if ZCL_LEVEL_CTRL
    #endif
     * LOCAL FUNCTIONS
    #endif
    #endif
    #endif
    #ifdef ZCL_READ
    #endif
    #ifdef ZCL_WRITE
    #endif
    #ifdef ZCL_DISCOVER
    #endif
     * STATUS STRINGS
     #if ZCL_LEVEL_CTRL
     #endif
    #endif
    #ifdef ZCL_EZMODE
    #endif
    #endif
    #ifdef ZCL_GROUPS
    #endif
    #ifdef ZCL_SCENES
    #endif
    #ifdef ZCL_ALARMS
    #endif
    #ifdef SE_UK_EXT
    #endif
     * @param       none
     * @return      none
    #define time 110
    static int no = 0;
    #ifdef ZCL_DISCOVER
    #endif
    #ifdef ZCL_EZMODE
      // Register EZ-Mode
    #endif
      HalTimer1Init( 0 );
      uint8 state;
    #if ZCL_LEVEL_CTRL
    #endif
    #endif
    #ifdef ZGP_AUTO_TT
    #endif
      P2SEL &= ~BV(0);
      P2DIR |= BV(0);
      P2_0=0;
      P0DIR |= 0x20;
      P1DIR |= 0x3f;
        DATA_PIN = 0;
        forward = 1;
        backward = 0;
        forward = 0;
        backward = 0;
        DATA_PIN = 1;
        no = 1;
     * @param       none
     * @return      none
    int KeyPressCnt=0;
    uint16 adc_ain2=0;
    uint16 value_bat;
    uint32        next;
        //CODE HERE
    #else
    #ifdef ZCL_EZMODE
          // Invoke EZ-Mode
          // Invoke EZ-Mode
          else
                               ZCL_HA_PROFILE_ID,
                               TRUE );
        ADCIF = 0;
        while ( !ADCIF );
        value_bat = ADCL;
        if(value_bat<=25){
          P0_4=1;
          P0_4=0;
        if ( P2_0==0 )
            KeyPressCnt=0;
        else{
          KeyPressCnt++;
      /*if ( events & KEYHOLD_EVT )
       if ( P2_0==1 )
       else{
         KeyPressCnt++;
      #ifdef ZCL_EZMODE
              case ZDO_CB_MSG:
                break;
      #endif
                break;
              case KEY_CHANGE:
                break;
      #ifdef ZCL_EZMODE
                break;
              default:
                break;
    #ifdef ZCL_EZMODE
        // Invoke EZ-Mode
        // Invoke EZ-Mode
        else
    #endif
      return 0;
     *                 HAL_KEY_SW_5
     *                 HAL_KEY_SW_4
     *                 HAL_KEY_SW_2
     *                 HAL_KEY_SW_1
     * @return  none
    #endif
        /*for(int i=0; i<10; i++){
     * @param   none
     * @return  none
      else
    #endif
      rptcmd.numAttr = 1;
     * @param   level
     * @return  none
    #endif
     * @param   none
     * @return  none
        DATA_PIN = 0;
        forward = 0;
        backward = 1;
        forward = 0;
        backward = 0;
        DATA_PIN = 1;
        no = 1;
        DATA_PIN = 0;
        forward = 1;
        backward = 0;
        forward = 0;
        backward = 0;
        DATA_PIN = 1;
        no = 0;
    #else
        else
     * @param   none
     * @return  none
        sSwHelp[15] = '*';
      else
        sSwHelp[15] = ' ';
     * @param   none
     * @return  none
     * @param   none
     * @return  none
      else
    #ifdef ZCL_EZMODE
        else
    #endif
     * @param   none
     * @return  none
     * @return  none
     * @return  none
      (void)pRsp;
    #ifdef ZCL_EZMODE
    #endif
     * @return  none
      // Toggle the light
        else
    #if ZCL_LEVEL_CTRL
    #endif
      uint32 diff;
      uint32 newLevel32;
      // calculate diff
      else
      return ( diff );
     * @return  none
      uint32 diff;
     * @return  none
      uint16 diff;
     * @return  none
      // time possible.
        else
          time = 1;
      if ( !time )
      return ( time );
     * @return  none
      uint8  newLevel;
      uint16 time;
        else
      else
        time = 1;
     * @param   none
     * @return  none
      else
        else
    #endif
          ENABLE_LAMP;
    #endif
        else
          DISABLE_LAMP;
    #endif
     * @return  none
     * @return  none
      uint8 newLevel;
      uint32 rate;
      else
     * @return  none
      uint8 newLevel;
        else
      else
        else
     * @return  none
      // stop immediately
    #endif
     * @return  none
    #ifdef ZCL_READ
          break;
    #endif
    #ifdef ZCL_WRITE
          break;
    #endif
    #ifdef ZCL_REPORT
          break;
          break;
          break;
          break;
          break;
    #endif
          break;
    #ifdef ZCL_DISCOVER
          break;
          break;
          break;
          break;
    #endif
        default:
          break;
    #ifdef ZCL_READ
     * @return  none
      uint8 i;
        // attribute
      return ( TRUE );
    #endif // ZCL_READ
    #ifdef ZCL_WRITE
     * @return  none
      uint8 i;
        // command.
      return ( TRUE );
    #endif // ZCL_WRITE
     * @return  none
      (void)pInMsg;
      return ( TRUE );
    #ifdef ZCL_DISCOVER
     * @return  none
      uint8 i;
      return ( TRUE );
     * @return  none
      uint8 i;
      return ( TRUE );
     * @return  none
      uint8 i;
      return ( TRUE );
    #if ZCL_EZMODE
     * @param   none
     * @return  status
     * @param   state - an
     * @return  none
      char *pStr;
      uint8 err;
    #endif
    #endif
        pStr = NULL;
        if ( pStr )
    #endif
        pStr = NULL;
        if ( pStr )
    #endif
  • If you set a breakpoint at "KeyPressCnt++;", do you see it keep hitting every time you Peer and hold the button?
  • When I hold the button after the first the first time the breakpoint hits, then it constantly hits until I release the button which is good. However, it doesn't always know when I press the button and hold it. For example, I press and hold the button and the breakpoint doesn't hit. Then I release the button. Then I press and hold the button and know the breakpoint has hit and continuously hits until I release the button. So the problem still remains that if ( P2_0==0 ) doesn't always register that the button is pressed. Once it figures out the button is pressed, it knows that the button is being held for 5 seconds.
  • I suggest you to check return value of osal_start_timerEx( zclSampleLight_TaskID, KEYHOLD_EVT, 100); to see if event is start correctly every time.
  • I changed the post to:
    Also how do I check the return value? Do I need to add a variable to the watch window?
  • uint8 ret; //Claim ret as global variable
    ret=osal_start_timerEx( zclSampleLight_TaskID, KEYHOLD_EVT, 100);
    Check ret in watch window.
  • This is the value I get for ret everytime the breakpoint hits: '\0' (0x00)
  • If the ret is 0x00, it means event create successfully. Then, program should go to "if ( events & KEYHOLD_EVT ){..}", doesn't it?
  • Yes, but the breakpoint at if(P2_0==0) isn't always hit when I press the button unlike the breakpoint at if(keys & HAL_KEY_SW_6) which is always hit. Should I do if(HAL_KEY_SW_6) in the factory reset code to fix the problem?
  • Can you attach a screen shot to show me the breakpoint at if(P2_0==0) you set?
  • I set a breakpoint on the line if(P2_0==0) as well as on KeyPress++. They only hit when the button is pressed, but the breakpoint doesn't always hit unlike the breakpoint in ISR.
  • Where is your screen shot? If you press and hold the button, does breakpoint keep hitting?
  • Thanks for your help. I found out I had to rearrange the if statements and redefine it to the below and so now it works reliably.
    if ( P2_0==1 )
    if (KeyPressCnt>10){
    KeyPressCnt=0;
    else{
    KeyPressCnt++;
  • You are welcome and it's good to know it works now.
