CC2530: After 5 seconds, board won't enter PM2
Part Number: CC2530
Other Parts Discussed in Thread: CC2531EMK, CC2531
I've been facing this problem where after 5 seconds of scanning for a hub from -DREJOIN_SCAN=5000, the device doesn't enter PM2. The board is supposed to consume 1.2microamps when it enters PM2, but instead it is consuming 8ma of current. The code below shows that the CC2530 makes sure that everything is ready before it enters PM2, but however a task, or tasks, is preventing the board from doing so. What is this task and why is it turned on? Why won't the CC2530 enter PM2 after 5 seconds?
next = osal_next_timeout();
OSAL_SET_CPU_INTO_SLEEP( next );
 * INCLUDES
#include "ZComDef.h"
#include "OSAL.h"
#include "AF.h"
#include "ZDApp.h"
#include "ZDObject.h"
#include "MT_SYS.h"
#include "nwk_util.h"
#include "zcl.h"
#include "zcl_general.h"
#include "zcl_ha.h"
#include "zcl_ezmode.h"
#include "zcl_diagnostic.h"
#include "zcl_samplelight.h"
#include "onboard.h"
/* HAL */
#include "hal_lcd.h"
//#include "hal_led.h"
#include "hal_key.h"
#if ( defined (ZGP_DEVICE_TARGET) || defined (ZGP_DEVICE_TARGETPLUS) \
      || defined (ZGP_DEVICE_COMBO) || defined (ZGP_DEVICE_COMBO_MIN) )
#include "zgp_translationtable.h"
  #if (SUPPORTED_S_FEATURE(SUPP_ZGP_FEATURE_TRANSLATION_TABLE))
    #define ZGP_AUTO_TT
  #endif
#endif
#if (defined HAL_BOARD_ZLIGHT) || (defined HAL_PWM)
#include "math.h"
#include "hal_timer.h"
#endif
#include "NLMEDE.h"
 * MACROS
 * CONSTANTS
#define LEVEL_MAX                 0xFE
#define LEVEL_MIN                 0x0
#define GAMMA_VALUE               2
#define PWM_FULL_DUTY_CYCLE       1000
#elif (defined HAL_PWM)
#endif
 * TYPEDEFS
 * GLOBAL VARIABLES
byte zclSampleLight_TaskID;
uint8 zclSampleLightSeqNum;
 * GLOBAL FUNCTIONS
 * LOCAL VARIABLES
afAddrType_t zclSampleLight_DstAddr;
#ifdef ZCL_EZMODE
static void zclSampleLight_ProcessZDOMsgs( zdoIncomingMsg_t *pMsg );
static void zclSampleLight_EZModeCB( zlcEZMode_State_t state, zclEZMode_CBData_t *pData );
// register EZ-Mode with task information (timeout events, callback, etc...)
static const zclEZMode_RegisterData_t zclSampleLight_RegisterEZModeData =
  &zclSampleLight_TaskID,
  SAMPLELIGHT_EZMODE_NEXTSTATE_EVT,
  SAMPLELIGHT_EZMODE_TIMEOUT_EVT,
  &zclSampleLightSeqNum,
#else
uint16 bindingInClusters[] =
  ZCL_CLUSTER_ID_GEN_ON_OFF
#ifdef ZCL_LEVEL_CTRL
  , ZCL_CLUSTER_ID_GEN_LEVEL_CONTROL
#endif
#define ZCLSAMPLELIGHT_BINDINGLIST (sizeof(bindingInClusters) / sizeof(bindingInClusters[0]))
#endif  // ZCL_EZMODE
// Test Endpoint to allow SYS_APP_MSGs
static endPointDesc_t sampleLight_TestEp =
  SAMPLELIGHT_ENDPOINT,
  (SimpleDescriptionFormat_t *)NULL,  // No Simple description for this test endpoint
  (afNetworkLatencyReq_t)0            // No Network Latency req
uint8 giLightScreenMode = LIGHT_MAINMODE;   // display the main screen mode first
uint8 gPermitDuration = 0;    // permit joining default to disabled
devStates_t zclSampleLight_NwkState = DEV_INIT;
#if ZCL_LEVEL_CTRL
uint8 zclSampleLight_WithOnOff;       // set to TRUE if state machine should set light on/off
uint8 zclSampleLight_NewLevel;        // new level when done moving
bool  zclSampleLight_NewLevelUp;      // is direction to new level up or down?
int32 zclSampleLight_CurrentLevel32;  // current level, fixed point (e.g. 192.456)
int32 zclSampleLight_Rate32;          // rate in units, fixed point (e.g. 16.123)
uint8 zclSampleLight_LevelLastLevel;  // to save the Current Level before the light was turned OFF
#endif
 * LOCAL FUNCTIONS
static void zclSampleLight_HandleKeys( byte shift, byte keys );
static void zclSampleLight_BasicResetCB( void );
static void zclSampleLight_IdentifyCB( zclIdentify_t *pCmd );
static void zclSampleLight_IdentifyQueryRspCB( zclIdentifyQueryRsp_t *pRsp );
static void zclSampleLight_OnOffCB( uint8 cmd );
static void zclSampleLight_ProcessIdentifyTimeChange( void );
static void zclSampleLight_LevelControlMoveToLevelCB( zclLCMoveToLevel_t *pCmd );
static void zclSampleLight_LevelControlMoveCB( zclLCMove_t *pCmd );
static void zclSampleLight_LevelControlStepCB( zclLCStep_t *pCmd );
static void zclSampleLight_LevelControlStopCB( void );
static void zclSampleLight_DefaultMove( void );
static uint32 zclSampleLight_TimeRateHelper( uint8 newLevel );
static uint16 zclSampleLight_GetTime ( uint8 level, uint16 time );
static void zclSampleLight_MoveBasedOnRate( uint8 newLevel, uint32 rate );
static void zclSampleLight_MoveBasedOnTime( uint8 newLevel, uint16 time );
static void zclSampleLight_AdjustLightLevel( void );
#endif
// app display functions
static void zclSampleLight_LcdDisplayUpdate( void );
#ifdef LCD_SUPPORTED
static void zclSampleLight_LcdDisplayMainMode( void );
static void zclSampleLight_LcdDisplayHelpMode( void );
#endif
static void zclSampleLight_DisplayLight( void );
void zclSampleLight_UpdateLampLevel( uint8 level );
#endif
// Functions to process ZCL Foundation incoming Command/Response messages
static void zclSampleLight_ProcessIncomingMsg( zclIncomingMsg_t *msg );
#ifdef ZCL_READ
static uint8 zclSampleLight_ProcessInReadRspCmd( zclIncomingMsg_t *pInMsg );
#endif
#ifdef ZCL_WRITE
static uint8 zclSampleLight_ProcessInWriteRspCmd( zclIncomingMsg_t *pInMsg );
#endif
static uint8 zclSampleLight_ProcessInDefaultRspCmd( zclIncomingMsg_t *pInMsg );
#ifdef ZCL_DISCOVER
static uint8 zclSampleLight_ProcessInDiscCmdsRspCmd( zclIncomingMsg_t *pInMsg );
static uint8 zclSampleLight_ProcessInDiscAttrsRspCmd( zclIncomingMsg_t *pInMsg );
static uint8 zclSampleLight_ProcessInDiscAttrsExtRspCmd( zclIncomingMsg_t *pInMsg );
#endif
 * STATUS STRINGS
const char sDeviceName[]   = "  Sample Light";
const char sClearLine[]    = " ";
const char sSwLight[]      = "SW1: ToggleLight";  // 16 chars max
const char sSwEZMode[]     = "SW2: EZ-Mode";
char sSwHelp[]             = "SW5: Help       ";  // last character is * if NWK open
const char sLightOn[]      = "    LIGHT ON ";
const char sLightOff[]     = "    LIGHT OFF";
 #if ZCL_LEVEL_CTRL
 char sLightLevel[]        = "    LEVEL ###"; // displays level 1-254
 #endif
#endif
 * ZCL General Profile Callback table
static zclGeneral_AppCallbacks_t zclSampleLight_CmdCallbacks =
  zclSampleLight_BasicResetCB,            // Basic Cluster Reset command
  zclSampleLight_IdentifyCB,              // Identify command
#ifdef ZCL_EZMODE
  NULL,                                   // Identify EZ-Mode Invoke command
  NULL,                                   // Identify Update Commission State command
#endif
  NULL,                                   // Identify Trigger Effect command
  zclSampleLight_IdentifyQueryRspCB,      // Identify Query Response command
  zclSampleLight_OnOffCB,                 // On/Off cluster commands
  NULL,                                   // On/Off cluster enhanced command Off with Effect
  NULL,                                   // On/Off cluster enhanced command On with Recall Global Scene
  NULL,                                   // On/Off cluster enhanced command On with Timed Off
  zclSampleLight_LevelControlMoveToLevelCB, // Level Control Move to Level command
  zclSampleLight_LevelControlMoveCB,        // Level Control Move command
  zclSampleLight_LevelControlStepCB,        // Level Control Step command
  zclSampleLight_LevelControlStopCB,        // Level Control Stop command
#endif
#ifdef ZCL_GROUPS
  NULL,                                   // Group Response commands
#endif
#ifdef ZCL_SCENES
  NULL,                                  // Scene Store Request command
  NULL,                                  // Scene Recall Request command
  NULL,                                  // Scene Response command
#endif
#ifdef ZCL_ALARMS
  NULL,                                  // Alarm (Response) commands
#endif
#ifdef SE_UK_EXT
  NULL,                                  // Get Event Log command
  NULL,                                  // Publish Event Log command
#endif
  NULL,                                  // RSSI Location command
  NULL                                   // RSSI Location Response command
 * @fn          zclSampleLight_Init
 * @brief       Initialization function for the zclGeneral layer.
 * @param       none
 * @return      none
//uint16 adc_ain2 = 0;
#define DATA_PIN P0_5
#define forward P0_7
#define backward P0_6
#define pin P0_3
#define time 110
static int no = 0;
#define PERIODIC_EVT 0x4000
#define PERIODIC_EVT2 0x0001
void zclSampleLight_Init( byte task_id )
  zclSampleLight_TaskID = task_id;
  osal_start_timerEx( zclSampleLight_TaskID, PERIODIC_EVT, 10 );
  osal_start_timerEx( zclSampleLight_TaskID, PERIODIC_EVT2, 10 );
  // Set destination address to indirect
  zclSampleLight_DstAddr.addrMode = (afAddrMode_t)AddrNotPresent;
  zclSampleLight_DstAddr.endPoint = 0;
  zclSampleLight_DstAddr.addr.shortAddr = 0;
  // This app is part of the Home Automation Profile
  zclHA_Init( &zclSampleLight_SimpleDesc );
  // Register the ZCL General Cluster Library callback functions
  zclGeneral_RegisterCmdCallbacks( SAMPLELIGHT_ENDPOINT, &zclSampleLight_CmdCallbacks );
  // Register the application's attribute list
  zcl_registerAttrList( SAMPLELIGHT_ENDPOINT, zclSampleLight_NumAttributes, zclSampleLight_Attrs );
  // Register the Application to receive the unprocessed Foundation command/response messages
  zcl_registerForMsg( zclSampleLight_TaskID );
#ifdef ZCL_DISCOVER
  // Register the application's command list
  zcl_registerCmdList( SAMPLELIGHT_ENDPOINT, zclCmdsArraySize, zclSampleLight_Cmds );
#endif
  // Register for all key events - This app will handle all key events
  RegisterForKeys( zclSampleLight_TaskID );
  // Register for a test endpoint
  afRegister( &sampleLight_TestEp );
#ifdef ZCL_EZMODE
  // Register EZ-Mode
  zcl_RegisterEZMode( &zclSampleLight_RegisterEZModeData );
  // Register with the ZDO to receive Match Descriptor Responses
  ZDO_RegisterForZDOMsg(task_id, Match_Desc_rsp);
#endif
  HalTimer1Init( 0 );
  halTimer1SetChannelDuty( WHITE_LED, 0 );
  halTimer1SetChannelDuty( RED_LED, 0 );
  halTimer1SetChannelDuty( BLUE_LED, 0 );
  halTimer1SetChannelDuty( GREEN_LED, 0 );
  // find if we are already on a network from NV_RESTORE
  uint8 state;
  NLME_GetRequest( nwkNwkState, 0, &state );
  if ( state < NWK_ENDDEVICE )
    // Start EZMode on Start up to avoid button press
    osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_START_EZMODE_EVT, 500 );
#if ZCL_LEVEL_CTRL
  zclSampleLight_DefaultMove();
#endif
#endif // #if (defined HAL_BOARD_ZLIGHT) || (defined HAL_PWM)
#ifdef ZCL_DIAGNOSTIC
  // Register the application's callback function to read/write attribute data.
  // This is only required when the attribute data format is unknown to ZCL.
  zcl_registerReadWriteCB( SAMPLELIGHT_ENDPOINT, zclDiagnostic_ReadWriteAttrCB, NULL );
  if ( zclDiagnostic_InitStats() == ZSuccess )
    // Here the user could start the timer to save Diagnostics to NV
#endif
  HalLcdWriteString ( (char *)sDeviceName, HAL_LCD_LINE_3 );
#endif  // LCD_SUPPORTED
#ifdef ZGP_AUTO_TT
  zgpTranslationTable_RegisterEP ( &zclSampleLight_SimpleDesc );
#endif
    ZDApp_ChangeState(DEV_NWK_DISC);
    // Restart scan for rejoin
    ZDApp_StartJoiningCycle();
    osal_stop_timerEx( ZDAppTaskID, ZDO_REJOIN_BACKOFF );
    osal_start_timerEx( ZDAppTaskID, ZDO_REJOIN_BACKOFF, zgDefaultRejoinScan );
  /*P0SEL &= ~BV(3);
  P0DIR |= BV(3);
  pin = 1;*/
  P0DIR |= 0x20;
  //P1DIR |= 0x3f;
  P0SEL &= ~BV(7);
  P0DIR |= BV(7);
  P0SEL &= ~BV(6);
  P0DIR |= BV(6);
    DATA_PIN = 0;
    forward = 0;
    backward = 1;
    for(int i=0; i<time; i++){
      Onboard_wait(10000);
    forward = 0;
    backward = 0;
    DATA_PIN = 1;
    no = 1;
    zclSampleLight_OnOff = LIGHT_ON;
 * @fn          zclSample_event_loop
 * @brief       Event Loop Processor for zclGeneral.
 * @param       none
 * @return      none
#include <hal_adc.h>
#define KEYHOLD_EVT  0x0100    //define event for key hold
int KeyPressCnt=0;
uint16 adc_ain2=0;
#define HAL_ADC_REF_125V    0x00    /* Internal 1.25V Reference */
#define HAL_ADC_DEC_064     0x00    /* Decimate by 64 : 8-bit resolution */
#define HAL_ADC_DEC_128     0x10    /* Decimate by 128 : 10-bit resolution */
#define HAL_ADC_DEC_512     0x30    /* Decimate by 512 : 14-bit resolution */
#define HAL_ADC_CHN_VDD3    0x0f    /* Input channel: VDD/3 */
#define HAL_ADC_CHN_TEMP    0x0e    /* Temperature sensor */
uint16 value_bat;
uint32        next;
halIntState_t intState;
uint8 ret;
#define TURNOFF_MOTOR_EVT 0x0400
uint16 zclSampleLight_event_loop( uint8 task_id, uint16 events )
  if( events & TURNOFF_MOTOR_EVT )
    forward = 0;
    backward = 0;
    DATA_PIN = 1;
    return (events ^ TURNOFF_MOTOR_EVT);
  if ( events & KEYHOLD_EVT )
    if ( P2_0==1 )
      if (KeyPressCnt>30){
        KeyPressCnt=0;
        extern void ZDApp_ResetTimerStart( uint16 delay );
        zgWriteStartupOptions(ZG_STARTUP_SET, (ZCD_STARTOPT_DEFAULT_NETWORK_STATE | ZCD_STARTOPT_DEFAULT_CONFIG_STATE) );
        //ZDApp_LeaveReset( FALSE );
        //Onboard_soft_reset();
        //SystemResetSoft();
        ZDApp_ResetTimerStart(100);
        for(int i=0; i<100; i++){
        //ZDApp_ResetTimerStart(2000);
        //zclSampleLight_BasicResetCB();
      else{
        KeyPressCnt++;
        osal_start_timerEx( zclSampleLight_TaskID, KEYHOLD_EVT, 100);
        ret=osal_start_timerEx( zclSampleLight_TaskID, KEYHOLD_EVT, 100);
    return ( events ^ KEYHOLD_EVT );
  if ( events & ZDO_DEVICE_RESET )
#ifdef ZBA_FALLBACK_NWKKEY
    if ( devState == DEV_END_DEVICE_UNAUTH )
      ZDSecMgrFallbackNwkKey();
    else
#endif
      // Set the NV startup option to force a "new" join.
      zgWriteStartupOptions( ZG_STARTUP_SET, ZCD_STARTOPT_DEFAULT_NETWORK_STATE );
      // The device has been in the UNAUTH state, so reset
      // Note: there will be no return from this call
      SystemResetSoft();
  if( events & PERIODIC_EVT2 )
#ifdef ZCL_EZMODE
      // Invoke EZ-Mode
      zclEZMode_InvokeData_t ezModeData;
      // Invoke EZ-Mode
      ezModeData.endpoint = SAMPLELIGHT_ENDPOINT; // endpoint on which to invoke EZ-Mode
      if ( (zclSampleLight_NwkState == DEV_ZB_COORD) ||
          (zclSampleLight_NwkState == DEV_ROUTER)   ||
            (zclSampleLight_NwkState == DEV_END_DEVICE) )
        ezModeData.onNetwork = TRUE;      // node is already on the network
      else
        ezModeData.onNetwork = FALSE;     // node is not yet on the network
      ezModeData.initiator = FALSE;          // OnOffLight is a target
      ezModeData.numActiveOutClusters = 0;
      ezModeData.pActiveOutClusterIDs = NULL;
      ezModeData.numActiveInClusters = 0;
      zcl_InvokeEZMode( &ezModeData );
      // Hold off interrupts.
      HAL_ENTER_CRITICAL_SECTION( intState );
      // Get next time-out
      // Re-enable interrupts.
      HAL_EXIT_CRITICAL_SECTION( intState );
      // Put the processor into sleep mode
#else // NOT EZ-Mode
      zAddrType_t dstAddr;
      HalLedSet ( HAL_LED_4, HAL_LED_MODE_OFF );
      // Initiate an End Device Bind Request, this bind request will
      // only use a cluster list that is important to binding.
      dstAddr.addrMode = afAddr16Bit;
      dstAddr.addr.shortAddr = 0;   // Coordinator makes the match
      ZDP_EndDeviceBindReq( &dstAddr, NLME_GetShortAddr(),
                           ZCL_HA_PROFILE_ID,
                           ZCLSAMPLELIGHT_BINDINGLIST, bindingInClusters,
                           0, NULL,   // No Outgoing clusters to bind
                           TRUE );
    osal_start_timerEx( zclSampleLight_TaskID, PERIODIC_EVT2, 5000 );
    return (events ^ PERIODIC_EVT2);
  if( events & PERIODIC_EVT )
    //Do things that need periodic processing here!
    /* Clear ADC interrupt flag */
    ADCIF = 0;
    ADCCON3 = (HAL_ADC_REF_125V| HAL_ADC_DEC_128 | HAL_ADC_CHN_VDD3);
    /* Wait for the conversion to finish */
    while ( !ADCIF );
    /* Get the result */
    value_bat = ADCL;
    value_bat |= ((uint16) ADCH) << 8;
    * value now contains measurement of Vdd/3
    * 0 indicates 0V and 32767 indicates 1.25V
    * voltage = (value*3*1.25)/32767 volts
    * we will multiply by this by 10 to allow units of 0.1 volts
    value_bat = value_bat >> 6; // divide first by 2^6
    value_bat = (uint16)(value_bat * 37.5);
    value_bat = value_bat >> 9; // ...and later by 2^9...to prevent overflow during multiplication
    if(value_bat<=25){
      P0_4=1;
    else if(value_bat>25){
      P0_4=0;
    osal_start_timerEx( zclSampleLight_TaskID, PERIODIC_EVT, 5000 );
    return (events ^ PERIODIC_EVT);
  afIncomingMSGPacket_t *MSGpkt;
  (void)task_id;  // Intentionally unreferenced parameter
    if ( events & SYS_EVENT_MSG )
      while ( (MSGpkt = (afIncomingMSGPacket_t *)osal_msg_receive( zclSampleLight_TaskID )) )
        switch ( MSGpkt->hdr.event )
  #ifdef ZCL_EZMODE
          case ZDO_CB_MSG:
            zclSampleLight_ProcessZDOMsgs( (zdoIncomingMsg_t *)MSGpkt );
            break;
  #endif
          case ZCL_INCOMING_MSG:
            // Incoming ZCL Foundation command/response messages
            zclSampleLight_ProcessIncomingMsg( (zclIncomingMsg_t *)MSGpkt );
            break;
          case KEY_CHANGE:
            zclSampleLight_HandleKeys( ((keyChange_t *)MSGpkt)->state, ((keyChange_t *)MSGpkt)->keys );
            break;
          case ZDO_STATE_CHANGE:
            zclSampleLight_NwkState = (devStates_t)(MSGpkt->hdr.status);
            // now on the network
              zclSampleLight_LcdDisplayUpdate();
  #ifdef ZCL_EZMODE
              zcl_EZModeAction( EZMODE_ACTION_NETWORK_STARTED, NULL );
            break;
          default:
            break;
        // Release the memory
        osal_msg_deallocate( (uint8 *)MSGpkt );
      // return unprocessed events
      return (events ^ SYS_EVENT_MSG);
  if ( events & SAMPLELIGHT_IDENTIFY_TIMEOUT_EVT )
    if ( zclSampleLight_IdentifyTime > 0 )
      zclSampleLight_IdentifyTime--;
    zclSampleLight_ProcessIdentifyTimeChange();
    return ( events ^ SAMPLELIGHT_IDENTIFY_TIMEOUT_EVT );
  if ( events & SAMPLELIGHT_MAIN_SCREEN_EVT )
    return ( events ^ SAMPLELIGHT_MAIN_SCREEN_EVT );
#ifdef ZCL_EZMODE
  // event to start EZMode on startup with a delay
  if ( events & SAMPLELIGHT_START_EZMODE_EVT )
    // Invoke EZ-Mode
    // Invoke EZ-Mode
    else
    return ( events ^ SAMPLELIGHT_START_EZMODE_EVT );
  // going on to next state
  if ( events & SAMPLELIGHT_EZMODE_NEXTSTATE_EVT )
    zcl_EZModeAction ( EZMODE_ACTION_PROCESS, NULL );   // going on to next state
    return ( events ^ SAMPLELIGHT_EZMODE_NEXTSTATE_EVT );
  // the overall EZMode timer expired, so we timed out
  if ( events & SAMPLELIGHT_EZMODE_TIMEOUT_EVT )
    zcl_EZModeAction ( EZMODE_ACTION_TIMED_OUT, NULL ); // EZ-Mode timed out
    return ( events ^ SAMPLELIGHT_EZMODE_TIMEOUT_EVT );
#endif // ZLC_EZMODE
  if ( events & SAMPLELIGHT_LEVEL_CTRL_EVT )
    zclSampleLight_AdjustLightLevel();
    return ( events ^ SAMPLELIGHT_LEVEL_CTRL_EVT );
#endif
  // Discard unknown events
  return 0;
 * @fn      zclSampleLight_HandleKeys
 * @brief   Handles all key events for this device.
 * @param   shift - true if in shift/alt.
 * @param   keys - bit field for key events. Valid entries:
 *                 HAL_KEY_SW_5
 *                 HAL_KEY_SW_4
 *                 HAL_KEY_SW_2
 *                 HAL_KEY_SW_1
 * @return  none
  if ( (keys & HAL_KEY_SW_2) /*|| (keys & HAL_KEY_SW_1)*/ )
    forward = 0;
    backward = 0;
    DATA_PIN = 1;
  if ( keys & HAL_KEY_SW_6 )
    /*ZDApp_ChangeState(DEV_NWK_DISC);
    osal_start_timerEx( ZDAppTaskID, ZDO_REJOIN_BACKOFF, zgDefaultRejoinScan );*/
    osal_stop_timerEx( zclSampleLight_TaskID, TURNOFF_MOTOR_EVT);
    osal_start_timerEx( zclSampleLight_TaskID, TURNOFF_MOTOR_EVT, 5000);
    ret=osal_start_timerEx( zclSampleLight_TaskID, TURNOFF_MOTOR_EVT, 5000);
    KeyPressCnt=0;
    // toggle local light immediately
    zclSampleLight_OnOff = zclSampleLight_OnOff ? LIGHT_OFF : LIGHT_ON;
  /*if ( keys & HAL_KEY_SW_3 )
    NLME_SendNetworkStatus( zclSampleLight_DstAddr.addr.shortAddr,
                       NLME_GetShortAddr(), NWKSTAT_NONTREE_LINK_FAILURE, FALSE );
  if ( keys & HAL_KEY_SW_4 )
    if ( ( zclSampleLight_NwkState == DEV_ZB_COORD ) ||
          ( zclSampleLight_NwkState == DEV_ROUTER ) )
      zAddrType_t tmpAddr;
      tmpAddr.addrMode = Addr16Bit;
      tmpAddr.addr.shortAddr = NLME_GetShortAddr();
      // toggle permit join
      gPermitDuration = gPermitDuration ? 0 : 0xff;
      // Trust Center significance is always true
      ZDP_MgmtPermitJoinReq( &tmpAddr, gPermitDuration, TRUE, FALSE );
  // Shift F5 does a Basic Reset (factory defaults)
  if ( shift && ( keys & HAL_KEY_SW_5 ) )
  else if ( keys & HAL_KEY_SW_5 )
    giLightScreenMode = giLightScreenMode ? LIGHT_MAINMODE : LIGHT_HELPMODE;
  // update the display, including the light
 * @fn      zclSampleLight_LcdDisplayUpdate
 * @brief   Called to update the LCD display.
 * @param   none
 * @return  none
  if ( giLightScreenMode == LIGHT_HELPMODE )
    zclSampleLight_LcdDisplayHelpMode();
  else
    zclSampleLight_LcdDisplayMainMode();
#endif
  zclReportCmd_t rptcmd;
  rptcmd.numAttr = 1;
  rptcmd.attrList[0].attrID = ATTRID_ON_OFF;
  rptcmd.attrList[0].dataType = ZCL_DATATYPE_BOOLEAN;
  rptcmd.attrList[0].attrData = (uint8*)&zclSampleLight_OnOff;
  zclSampleLight_DstAddr.addrMode = (afAddrMode_t)Addr16Bit;
  zclSampleLight_DstAddr.endPoint=1;
  zcl_SendReportCmd(SAMPLELIGHT_ENDPOINT,&zclSampleLight_DstAddr, ZCL_CLUSTER_ID_GEN_ON_OFF, &rptcmd, ZCL_FRAME_CLIENT_SERVER_DIR, false, 0 );
  zclSampleLight_DisplayLight();
 * @fn      zclSampleLight_UpdateLampLevel
 * @brief   Update lamp level output with gamma compensation
 * @param   level
 * @return  none
  uint16 gammaCorrectedLevel;
  // gamma correct the level
  gammaCorrectedLevel = (uint16) ( pow( ( (float)level / LEVEL_MAX ), (float)GAMMA_VALUE ) * (float)LEVEL_MAX);
  halTimer1SetChannelDuty(WHITE_LED, (uint16)(((uint32)gammaCorrectedLevel*PWM_FULL_DUTY_CYCLE)/LEVEL_MAX) );
#endif
 * @fn      zclSampleLight_DisplayLight
 * @brief   Displays current state of light on LED and also on main display if supported.
 * @param   none
 * @return  none
  // set the LED1 based on light (on or off)
  if ( zclSampleLight_OnOff == LIGHT_ON & no == 0 )
    DATA_PIN = 0;
    forward = 0;
    backward = 1;
    /*for(int i=0; i<time; i++){
    forward = 0;
    backward = 0;
    DATA_PIN = 1;*/
    no = 1;
  else if ( zclSampleLight_OnOff == LIGHT_OFF & no == 1 )
    DATA_PIN = 0;
    forward = 1;
    backward = 0;
    forward = 0;
    backward = 0;
    DATA_PIN = 1;*/
    no = 0;
  if (giLightScreenMode == LIGHT_MAINMODE)
    // display current light level
    if ( ( zclSampleLight_LevelCurrentLevel == ATTR_LEVEL_MIN_LEVEL ) &&
         ( zclSampleLight_OnOff == LIGHT_OFF ) )
      HalLcdWriteString( (char *)sLightOff, HAL_LCD_LINE_2 );
    else if ( ( zclSampleLight_LevelCurrentLevel >= ATTR_LEVEL_MAX_LEVEL ) ||
              ( zclSampleLight_LevelCurrentLevel == zclSampleLight_LevelOnLevel ) ||
               ( ( zclSampleLight_LevelOnLevel == ATTR_LEVEL_ON_LEVEL_NO_EFFECT ) &&
                 ( zclSampleLight_LevelCurrentLevel == zclSampleLight_LevelLastLevel ) ) )
      HalLcdWriteString( (char *)sLightOn, HAL_LCD_LINE_2 );
    else    // "    LEVEL ###"
      zclHA_uint8toa( zclSampleLight_LevelCurrentLevel, &sLightLevel[10] );
      HalLcdWriteString( (char *)sLightLevel, HAL_LCD_LINE_2 );
#else
    if ( zclSampleLight_OnOff )
    else
#endif // ZCL_LEVEL_CTRL
 * @fn      zclSampleLight_LcdDisplayMainMode
 * @brief   Called to display the main screen on the LCD.
 * @param   none
 * @return  none
  // display line 1 to indicate NWK status
  if ( zclSampleLight_NwkState == DEV_ZB_COORD )
    zclHA_LcdStatusLine1( ZCL_HA_STATUSLINE_ZC );
  else if ( zclSampleLight_NwkState == DEV_ROUTER )
    zclHA_LcdStatusLine1( ZCL_HA_STATUSLINE_ZR );
  else if ( zclSampleLight_NwkState == DEV_END_DEVICE )
    zclHA_LcdStatusLine1( ZCL_HA_STATUSLINE_ZED );
  // end of line 3 displays permit join status (*)
  if ( gPermitDuration )
    sSwHelp[15] = '*';
  else
    sSwHelp[15] = ' ';
  HalLcdWriteString( (char *)sSwHelp, HAL_LCD_LINE_3 );
 * @fn      zclSampleLight_LcdDisplayHelpMode
 * @brief   Called to display the SW options on the LCD.
 * @param   none
 * @return  none
  HalLcdWriteString( (char *)sSwLight, HAL_LCD_LINE_1 );
  HalLcdWriteString( (char *)sSwEZMode, HAL_LCD_LINE_2 );
 * @fn      zclSampleLight_ProcessIdentifyTimeChange
 * @brief   Called to process any change to the IdentifyTime attribute.
 * @param   none
 * @return  none
    osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_IDENTIFY_TIMEOUT_EVT, 1000 );
    //HalLedBlink ( HAL_LED_4, 0xFF, HAL_LED_DEFAULT_DUTY_CYCLE, HAL_LED_DEFAULT_FLASH_TIME );
  else
#ifdef ZCL_EZMODE
    if ( zclSampleLight_IdentifyCommissionState & EZMODE_COMMISSION_OPERATIONAL )
      //HalLedSet ( HAL_LED_4, HAL_LED_MODE_ON );
    else
      //HalLedSet ( HAL_LED_4, HAL_LED_MODE_OFF );
#endif
    osal_stop_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_IDENTIFY_TIMEOUT_EVT );
 * @fn      zclSampleLight_BasicResetCB
 * @brief   Callback from the ZCL General Cluster Library
 *          to set all the Basic Cluster attributes to default values.
 * @param   none
 * @return  none
  NLME_LeaveReq_t leaveReq;
  // Set every field to 0
  osal_memset( &leaveReq, 0, sizeof( NLME_LeaveReq_t ) );
  // This will enable the device to rejoin the network after reset.
  leaveReq.rejoin = TRUE;
  // Leave the network, and reset afterwards
  if ( NLME_LeaveReq( &leaveReq ) != ZSuccess )
    // Couldn't send out leave; prepare to reset anyway
 * @fn      zclSampleLight_IdentifyCB
 * @brief   Callback from the ZCL General Cluster Library when
 *          it received an Identity Command for this application.
 * @param   srcAddr - source address and endpoint of the response message
 * @param   identifyTime - the number of seconds to identify yourself
 * @return  none
  zclSampleLight_IdentifyTime = pCmd->identifyTime;
 * @fn      zclSampleLight_IdentifyQueryRspCB
 *          it received an Identity Query Response Command for this application.
 * @param   srcAddr - requestor's address
 * @param   timeout - number of seconds to identify yourself (valid for query response)
 * @return  none
  (void)pRsp;
#ifdef ZCL_EZMODE
    zclEZMode_ActionData_t data;
    data.pIdentifyQueryRsp = pRsp;
    zcl_EZModeAction ( EZMODE_ACTION_IDENTIFY_QUERY_RSP, &data );
#endif
 * @fn      zclSampleLight_OnOffCB
 *          it received an On/Off Command for this application.
 * @param   cmd - COMMAND_ON, COMMAND_OFF or COMMAND_TOGGLE
 * @return  none
  afIncomingMSGPacket_t *pPtr = zcl_getRawAFMsg();
  zclSampleLight_DstAddr.addr.shortAddr = pPtr->srcAddr.addr.shortAddr;
  // Turn on the light
  if ( cmd == COMMAND_ON )
  // Turn off the light
  else if ( cmd == COMMAND_OFF )
    zclSampleLight_OnOff = LIGHT_OFF;
  // Toggle the light
  else if ( cmd == COMMAND_TOGGLE )
    if ( zclSampleLight_OnOff == LIGHT_OFF )
    else
#if ZCL_LEVEL_CTRL
  zclSampleLight_DefaultMove( );
#endif
  zclSampleLight_LcdDisplayUpdate( );
 * @fn      zclSampleLight_TimeRateHelper
 * @brief   Calculate time based on rate, and startup level state machine
 * @param   newLevel - new level for current level
 * @return  diff (directly), zclSampleLight_CurrentLevel32 and zclSampleLight_NewLevel, zclSampleLight_NewLevelUp
  uint32 diff;
  uint32 newLevel32;
  // remember current and new level
  zclSampleLight_NewLevel = newLevel;
  zclSampleLight_CurrentLevel32 = (uint32)1000 * zclSampleLight_LevelCurrentLevel;
  // calculate diff
  newLevel32 = (uint32)1000 * newLevel;
  if ( zclSampleLight_LevelCurrentLevel > newLevel )
    diff = zclSampleLight_CurrentLevel32 - newLevel32;
    zclSampleLight_NewLevelUp = FALSE;  // moving down
  else
    diff = newLevel32 - zclSampleLight_CurrentLevel32;
    zclSampleLight_NewLevelUp = TRUE;   // moving up
  return ( diff );
 * @fn      zclSampleLight_MoveBasedOnRate
 * @param   rate16   - fixed point rate (e.g. 16.123)
 * @return  none
  uint32 diff;
  // determine how much time (in 10ths of seconds) based on the difference and rate
  zclSampleLight_Rate32 = rate;
  diff = zclSampleLight_TimeRateHelper( newLevel );
  zclSampleLight_LevelRemainingTime = diff / rate;
  if ( !zclSampleLight_LevelRemainingTime )
    zclSampleLight_LevelRemainingTime = 1;
  osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_LEVEL_CTRL_EVT, 100 );
 * @fn      zclSampleLight_MoveBasedOnTime
 * @brief   Calculate rate based on time, and startup level state machine
 * @param   time      - in 10ths of seconds
 * @return  none
  uint16 diff;
  // determine rate (in units) based on difference and time
  zclSampleLight_LevelRemainingTime = zclSampleLight_GetTime( newLevel, time );
  zclSampleLight_Rate32 = diff / time;
 * @fn      zclSampleLight_GetTime
 * @brief   Determine amount of time that MoveXXX will take to complete.
 * @param   level = new level to move to
 *          time  = 0xffff=default, or 0x0000-n amount of time in tenths of seconds.
 * @return  none
static uint16 zclSampleLight_GetTime( uint8 level, uint16 time )
  // there is a hiearchy of the amount of time to use for transistioning
  // check each one in turn. If none of defaults are set, then use fastest
  // time possible.
  if ( time == 0xFFFF )
    // use On or Off Transition Time if set (not 0xffff)
    if ( zclSampleLight_OnOff == LIGHT_ON )
      time = zclSampleLight_LevelOffTransitionTime;
    else
      time = zclSampleLight_LevelOnTransitionTime;
    // else use OnOffTransitionTime if set (not 0xffff)
      time = zclSampleLight_LevelOnOffTransitionTime;
    // else as fast as possible
      time = 1;
  if ( !time )
    time = 1; // as fast as possible
  return ( time );
 * @fn      zclSampleLight_DefaultMove
 * @brief   We were turned on/off. Use default time to move to on or off.
 * @param   zclSampleLight_OnOff - must be set prior to calling this function.
 * @return  none
  uint8  newLevel;
  uint32 rate;      // fixed point decimal (3 places, eg. 16.345)
  uint16 time;
  // if moving to on position, move to on level
    if ( zclSampleLight_LevelOnLevel == ATTR_LEVEL_ON_LEVEL_NO_EFFECT )
      // The last Level (before going OFF) should be used)
      newLevel = zclSampleLight_LevelLastLevel;
    else
      newLevel = zclSampleLight_LevelOnLevel;
  else
    newLevel = ATTR_LEVEL_MIN_LEVEL;
      // Save the current Level before going OFF to use it when the light turns ON
      // it should be back to this level
      zclSampleLight_LevelLastLevel = zclSampleLight_LevelCurrentLevel;
    time = 1;
  // calculate rate based on time (int 10ths) for full transition (1-254)
  rate = 255000 / time;    // units per tick, fixed point, 3 decimal places (e.g. 8500 = 8.5 units per tick)
  // start up state machine.
  zclSampleLight_WithOnOff = TRUE;
  zclSampleLight_MoveBasedOnRate( newLevel, rate );
 * @fn      zclSampleLight_AdjustLightLevel
 * @brief   Called each 10th of a second while state machine running
 * @param   none
 * @return  none
  // one tick (10th of a second) less
  if ( zclSampleLight_LevelRemainingTime )
    --zclSampleLight_LevelRemainingTime;
  // no time left, done
  if ( zclSampleLight_LevelRemainingTime == 0)
    zclSampleLight_LevelCurrentLevel = zclSampleLight_NewLevel;
  // still time left, keep increment/decrementing
  else
    if ( zclSampleLight_NewLevelUp )
      zclSampleLight_CurrentLevel32 += zclSampleLight_Rate32;
    else
      zclSampleLight_CurrentLevel32 -= zclSampleLight_Rate32;
    zclSampleLight_LevelCurrentLevel = (uint8)( zclSampleLight_CurrentLevel32 / 1000 );
  zclSampleLight_UpdateLampLevel(zclSampleLight_LevelCurrentLevel);
#endif
  // also affect on/off
  if ( zclSampleLight_WithOnOff )
    if ( zclSampleLight_LevelCurrentLevel > ATTR_LEVEL_MIN_LEVEL )
      ENABLE_LAMP;
#endif
    else
      DISABLE_LAMP;
#endif
  // display light level as we go
  zclSampleLight_DisplayLight( );
  // keep ticking away
 * @fn      zclSampleLight_LevelControlMoveToLevelCB
 *          it received a LevelControlMoveToLevel Command for this application.
 * @param   pCmd - ZigBee command parameters
 * @return  none
  zclSampleLight_WithOnOff = pCmd->withOnOff;
  zclSampleLight_MoveBasedOnTime( pCmd->level, pCmd->transitionTime );
 * @fn      zclSampleLight_LevelControlMoveCB
 *          it received a LevelControlMove Command for this application.
 * @return  none
  uint8 newLevel;
  uint32 rate;
  // convert rate from units per second to units per tick (10ths of seconds)
  // and move at that right up or down
  if ( pCmd->moveMode == LEVEL_MOVE_UP )
    newLevel = ATTR_LEVEL_MAX_LEVEL;  // fully on
  else
    newLevel = ATTR_LEVEL_MIN_LEVEL; // fully off
  rate = (uint32)100 * pCmd->rate;
 * @fn      zclSampleLight_LevelControlStepCB
 * @return  none
  uint8 newLevel;
  // determine new level, but don't exceed boundaries
  if ( pCmd->stepMode == LEVEL_MOVE_UP )
    if ( (uint16)zclSampleLight_LevelCurrentLevel + pCmd->amount > ATTR_LEVEL_MAX_LEVEL )
    else
      newLevel = zclSampleLight_LevelCurrentLevel + pCmd->amount;
  else
    if ( pCmd->amount >= zclSampleLight_LevelCurrentLevel )
    else
      newLevel = zclSampleLight_LevelCurrentLevel - pCmd->amount;
  // move to the new level
  zclSampleLight_MoveBasedOnTime( newLevel, pCmd->transitionTime );
 * @fn      zclSampleLight_LevelControlStopCB
 *          it received an Level Control Stop Command for this application.
 * @return  none
  // stop immediately
  osal_stop_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_LEVEL_CTRL_EVT );
  zclSampleLight_LevelRemainingTime = 0;
#endif
 *  Functions for processing ZCL Foundation incoming Command/Response messages
 * @fn      zclSampleLight_ProcessIncomingMsg
 * @brief   Process ZCL Foundation incoming message
 * @param   pInMsg - pointer to the received message
 * @return  none
static void zclSampleLight_ProcessIncomingMsg( zclIncomingMsg_t *pInMsg )
  switch ( pInMsg->zclHdr.commandID )
#ifdef ZCL_READ
    case ZCL_CMD_READ_RSP:
      zclSampleLight_ProcessInReadRspCmd( pInMsg );
      break;
#endif
#ifdef ZCL_WRITE
    case ZCL_CMD_WRITE_RSP:
      zclSampleLight_ProcessInWriteRspCmd( pInMsg );
      break;
#endif
#ifdef ZCL_REPORT
    // Attribute Reporting implementation should be added here
    case ZCL_CMD_CONFIG_REPORT:
      // zclSampleLight_ProcessInConfigReportCmd( pInMsg );
      break;
    case ZCL_CMD_CONFIG_REPORT_RSP:
      // zclSampleLight_ProcessInConfigReportRspCmd( pInMsg );
      break;
    case ZCL_CMD_READ_REPORT_CFG:
      // zclSampleLight_ProcessInReadReportCfgCmd( pInMsg );
      break;
    case ZCL_CMD_READ_REPORT_CFG_RSP:
      // zclSampleLight_ProcessInReadReportCfgRspCmd( pInMsg );
      break;
    case ZCL_CMD_REPORT:
      // zclSampleLight_ProcessInReportCmd( pInMsg );
      break;
#endif
    case ZCL_CMD_DEFAULT_RSP:
      zclSampleLight_ProcessInDefaultRspCmd( pInMsg );
      break;
#ifdef ZCL_DISCOVER
    case ZCL_CMD_DISCOVER_CMDS_RECEIVED_RSP:
      zclSampleLight_ProcessInDiscCmdsRspCmd( pInMsg );
      break;
    case ZCL_CMD_DISCOVER_CMDS_GEN_RSP:
      break;
    case ZCL_CMD_DISCOVER_ATTRS_RSP:
      zclSampleLight_ProcessInDiscAttrsRspCmd( pInMsg );
      break;
    case ZCL_CMD_DISCOVER_ATTRS_EXT_RSP:
      zclSampleLight_ProcessInDiscAttrsExtRspCmd( pInMsg );
      break;
#endif
    default:
      break;
  if ( pInMsg->attrCmd )
    osal_mem_free( pInMsg->attrCmd );
#ifdef ZCL_READ
 * @fn      zclSampleLight_ProcessInReadRspCmd
 * @brief   Process the "Profile" Read Response Command
 * @param   pInMsg - incoming message to process
 * @return  none
  zclReadRspCmd_t *readRspCmd;
  uint8 i;
  readRspCmd = (zclReadRspCmd_t *)pInMsg->attrCmd;
  for (i = 0; i < readRspCmd->numAttr; i++)
    // Notify the originator of the results of the original read attributes
    // attempt and, for each successfull request, the value of the requested
    // attribute
  return ( TRUE );
#endif // ZCL_READ
#ifdef ZCL_WRITE
 * @fn      zclSampleLight_ProcessInWriteRspCmd
 * @brief   Process the "Profile" Write Response Command
 * @return  none
  zclWriteRspCmd_t *writeRspCmd;
  uint8 i;
  writeRspCmd = (zclWriteRspCmd_t *)pInMsg->attrCmd;
  for ( i = 0; i < writeRspCmd->numAttr; i++ )
    // Notify the device of the results of the its original write attributes
    // command.
  return ( TRUE );
#endif // ZCL_WRITE
 * @fn      zclSampleLight_ProcessInDefaultRspCmd
 * @brief   Process the "Profile" Default Response Command
 * @return  none
  // zclDefaultRspCmd_t *defaultRspCmd = (zclDefaultRspCmd_t *)pInMsg->attrCmd;
  // Device is notified of the Default Response command.
  (void)pInMsg;
  return ( TRUE );
#ifdef ZCL_DISCOVER
 * @fn      zclSampleLight_ProcessInDiscCmdsRspCmd
 * @brief   Process the Discover Commands Response Command
 * @return  none
  zclDiscoverCmdsCmdRsp_t *discoverRspCmd;
  uint8 i;
  discoverRspCmd = (zclDiscoverCmdsCmdRsp_t *)pInMsg->attrCmd;
  for ( i = 0; i < discoverRspCmd->numCmd; i++ )
    // Device is notified of the result of its attribute discovery command.
  return ( TRUE );
 * @fn      zclSampleLight_ProcessInDiscAttrsRspCmd
 * @brief   Process the "Profile" Discover Attributes Response Command
 * @return  none
  zclDiscoverAttrsRspCmd_t *discoverRspCmd;
  uint8 i;
  discoverRspCmd = (zclDiscoverAttrsRspCmd_t *)pInMsg->attrCmd;
  for ( i = 0; i < discoverRspCmd->numAttr; i++ )
  return ( TRUE );
 * @fn      zclSampleLight_ProcessInDiscAttrsExtRspCmd
 * @brief   Process the "Profile" Discover Attributes Extended Response Command
 * @return  none
  zclDiscoverAttrsExtRsp_t *discoverRspCmd;
  uint8 i;
  discoverRspCmd = (zclDiscoverAttrsExtRsp_t *)pInMsg->attrCmd;
  return ( TRUE );
#endif // ZCL_DISCOVER
#if ZCL_EZMODE
 * @fn      zclSampleLight_ProcessZDOMsgs
 * @brief   Called when this node receives a ZDO/ZDP response.
 * @param   none
 * @return  status
  ZDO_MatchDescRsp_t *pMatchDescRsp;
  // Let EZ-Mode know of the Simple Descriptor Response
  if ( pMsg->clusterID == Match_Desc_rsp )
    pMatchDescRsp = ZDO_ParseEPListRsp( pMsg );
    data.pMatchDescRsp = pMatchDescRsp;
    zcl_EZModeAction( EZMODE_ACTION_MATCH_DESC_RSP, &data );
    osal_mem_free( pMatchDescRsp );
 * @fn      zclSampleLight_EZModeCB
 * @brief   The Application is informed of events. This can be used to show on the UI what is
*           going on during EZ-Mode steering/finding/binding.
 * @param   state - an
 * @return  none
  char *pStr;
  uint8 err;
#endif
  // time to go into identify mode
  if ( state == EZMODE_STATE_IDENTIFYING )
    HalLcdWriteString( "EZMode", HAL_LCD_LINE_2 );
#endif
    zclSampleLight_IdentifyTime = ( EZMODE_TIME / 1000 );  // convert to seconds
  // autoclosing, show what happened (success, cancelled, etc...)
  if( state == EZMODE_STATE_AUTOCLOSE )
    pStr = NULL;
    err = pData->sAutoClose.err;
    if ( err == EZMODE_ERR_SUCCESS )
      pStr = "EZMode: Success";
    else if ( err == EZMODE_ERR_NOMATCH )
      pStr = "EZMode: NoMatch"; // not a match made in heaven
    if ( pStr )
      if ( giLightScreenMode == LIGHT_MAINMODE )
        HalLcdWriteString ( pStr, HAL_LCD_LINE_2 );
#endif
  // finished, either show DstAddr/EP, or nothing (depending on success or not)
  if( state == EZMODE_STATE_FINISH )
    // turn off identify mode
    zclSampleLight_IdentifyTime = 0;
    // if successful, inform user which nwkaddr/ep we bound to
    pStr = NULL;
    err = pData->sFinish.err;
    if( err == EZMODE_ERR_SUCCESS )
      // already stated on autoclose
    else if ( err == EZMODE_ERR_CANCELLED )
      pStr = "EZMode: Cancel";
    else if ( err == EZMODE_ERR_BAD_PARAMETER )
      pStr = "EZMode: BadParm";
    else if ( err == EZMODE_ERR_TIMEDOUT )
      pStr = "EZMode: TimeOut";
    if ( pStr )
#endif
    // show main UI screen 3 seconds after binding
    osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_MAIN_SCREEN_EVT, 3000 );
  • "next = osal_next_timeout();" and "OSAL_SET_CPU_INTO_SLEEP( next );" should be handled in osal_pwrmgr_powerconserve which is called by osal_run_system. You should call them directly in your application. If you intend to stop ez-mode, you should not use the following lines:
    if(zclEZModeState != EZMODE_STATE_READY)
    zcl_SetEZModeError ( EZMODE_ERR_CANCELLED );
    // needed to shut down timers, turn off joining, etc...
    zcl_SetEZModeState ( EZMODE_STATE_FINISH );
  • 1) I tried your code, but it didn't fix the problem. What else do you suggest?
    2) When you say "You should call them directly in your application", how should I implement it in my application?
  • 1. Can you elaborate what you intend to achieve?
    2. It's a typo. I mean to say "It should not...". I have revise my previous post.
  • After, 5 seconds of scanning for a hub, I want the CC2530 to enter PM2 and only consume 1.2microamps and not 8ma.
  • Do you use EZ-Mode to scan for a hub?
  • Yes. It is an end device, so it has to.
  • In general case, EZ-mode won't be finished in 5 seconds so it set a timeout of 3 minutes which is defined by EZMODE_TIME. If you change EZMODE_TIME to 15 seconds and trigger EZ-mode, do you see power consumption drops to PM2 after 15 seconds?
  • Unfortunately no.
  • What's the power consumption do you see?
  • 8ma consumption
  • Try to add the following red line in zcl_EZModeAction() and test again.
        case EZMODE_ACTION_TIMED_OUT:
          // timed out
            zcl_SetEZModeError( EZMODE_ERR_TIMEDOUT );
            zcl_SetEZModeState( EZMODE_STATE_FINISH );
            osal_pwrmgr_powerconserve();  // Put the processor/system into sleep
  • That did not fix the problem either.
  • I commented all of the below code from the event loop related to EZ-mode, and the power consumption was still 8ma. Why is this so?
    #ifdef ZCL_EZMODE
    // Invoke EZ-Mode
    // Invoke EZ-Mode
    else
    ZCL_HA_PROFILE_ID,
    TRUE );
  • I suggest you to use sniffer to check if your device still keeps sends beacon requests.
  • It don't have my sniffer device with me right now and I don't believe the CC2530 is scanning for the hub after 20 seconds because the oscilloscope shows that the CC2530 doesn't send out any more beacon requests. Are there any other possibilities that you think may cause this problem? So besides the ez-mode, what other tasks might keep the CC2530 awake?
  • I see you keep restart PERIODIC_EVT2 every 5 seconds and it means PERIODIC_EVT2 would toggle EZ-mode every 5 seconds. I think this would make your device keeps in EZ-mode and cause your power consumption problem. I suggest you to buy CC2531EMK and Ubiqua Packet Analyzer to do sniffer task otherwise you cannot be sure on this beacon requests things.
  • For testing, I changed it so EZ-mode is only activated when I press HAL_KEY_SW_6, but the CC2530 still consumes 8ma. In the meantime, since I don't have the CC2531 with me currently, besides EZ-mode, what OTHER problems may cause this issue?
  • Actually, you call zcl_InvokeEZMode in PERIODIC_EVT2 which comes every 5 seconds so your code would toggle EZ-mode in PERIODIC_EVT2. Maybe try to stop PERIODIC_EVT2 event to see if the problem is solved.
  • I did. I moved code to HandlKeys so that only HAL_KEY_SW_6 toggles EZ-mode. I got rid of the PERIODIC_EVT2 for now, but the problem still exists. Why do you believe only ez-mode causes the problem? Does nothing else cause this problem?
  • To prove my idea, you can enable HOLD_AUTO_START and EZ-mode to power on device (don't trigger EZ-mode after device is powered on) to check what the power consumption is.
  • That is the setup I've been using to do the testing.
  • So, you still see 8 mA even if you don't trigger SW6 to start EZ-mode after device is powered on?
  • Yes. In the compiler options, I even tried disabling ez-mode and hold auto start, but the current consumption is still 8ma.
  • If you debug with IAR and pause application, what device state do you see when this power consumption issuse happens?
  • How do I check the device state?
  • Pause application and check devState value in ZDApp.c
  • So I set a few breakpoints in the here is what happened. At startup, continueJoining = TRUE is hit and it the value of devState is DEV_NWK_DISC. After about 8-10 seconds, the breakpoint continueJoining = FALSE is hit and the value is DEV_NWK_BACKOFF.
    Problems:
    1) I set the SCAN value to 20 seconds and not 10 seconds, so why does it stop continueJoining?
    2) If it stops continueJoining, then why is the power consumption still high at 8ma?
  • 1.How do you set scan to 20 seconds?
    2. Do you have any task in your application that keeps system busy?
  • I've noticed that by adding the below code into the event loop, the next variable does make the CC2530 go to sleep for 1-5ns, and then it stays at 8ma. So when the CC2530 drops to 8ma, after 5sec, it goes to PM2, then wakes up immediately. This cycle continues forever. That means every 5 seconds, a task is ended, but then it continues again later on. So what might this task be that works for 5 seconds and then turns off?
  • Do you have while-loop or for-loop in your application that would do a blocking task for a while?
  • No. I checked and there isn't.
  • After doing more testing, I found out that the CC2530 does enter PM2. However, when I press HAL_KEY_SW_6, then the CC2530 wakes up and stays at 8ma. Why is this so?
     * INCLUDES
    #include "OSAL.h"
    #include "AF.h"
    #include "ZDApp.h"
    #include "MT_SYS.h"
    #include "zcl.h"
    #include "zcl_ha.h"
    /* HAL */
        #define ZGP_AUTO_TT
      #endif
    #endif
    #include "math.h"
    #endif
    #include "NLMEDE.h"
     * MACROS
     * CONSTANTS
    #endif
     * TYPEDEFS
     * GLOBAL VARIABLES
     * GLOBAL FUNCTIONS
     * LOCAL VARIABLES
    #ifdef ZCL_EZMODE
    #else
    #endif
    #if ZCL_LEVEL_CTRL
    #endif
     * LOCAL FUNCTIONS
    #endif
    #endif
    #endif
    #ifdef ZCL_READ
    #endif
    #ifdef ZCL_WRITE
    #endif
    #ifdef ZCL_DISCOVER
    #endif
     * STATUS STRINGS
     #if ZCL_LEVEL_CTRL
     #endif
    #endif
    #ifdef ZCL_EZMODE
    #endif
    #endif
    #ifdef ZCL_GROUPS
    #endif
    #ifdef ZCL_SCENES
    #endif
    #ifdef ZCL_ALARMS
    #endif
    #ifdef SE_UK_EXT
    #endif
     * @param       none
     * @return      none
    #define pin P0_3
    #define time 110
    static int no = 0;
    uint32        next;
    #ifdef ZCL_DISCOVER
    #endif
    #ifdef ZCL_EZMODE
      // Register EZ-Mode
    #endif
      HalTimer1Init( 0 );
      uint8 state;
    #if ZCL_LEVEL_CTRL
    #endif
    #endif
    #ifdef ZGP_AUTO_TT
    #endif
      /*P0SEL &= ~BV(3);
      P0DIR |= BV(3);
      pin = 1;*/
      P0DIR |= 0x20;
      //P1DIR |= 0x3f;
      P0SEL &= ~BV(7);
      P0DIR |= BV(7);
      P0SEL &= ~BV(6);
      P0DIR |= BV(6);
        DATA_PIN = 0;
        forward = 0;
        backward = 1;
        forward = 0;
        backward = 0;
        DATA_PIN = 1;
        no = 1;
     * @param       none
     * @return      none
    int KeyPressCnt=0;
    uint16 adc_ain2=0;
    uint16 value_bat;
    uint8 ret;
        forward = 0;
        backward = 0;
        DATA_PIN = 1;
        if ( P2_0==1 )
            KeyPressCnt=0;
          else{
            KeyPressCnt++;
        else
    #endif
          SystemResetSoft();
    #ifdef ZCL_EZMODE
          // Invoke EZ-Mode
          // Invoke EZ-Mode
          else
                               ZCL_HA_PROFILE_ID,
                               TRUE );
        ADCIF = 0;
        while ( !ADCIF );
        value_bat = ADCL;
        if(value_bat<=25){
          P0_4=1;
          P0_4=0;
        osal_start_timerEx( zclSampleLight_TaskID, PERIODIC_EVT, 720000 );
      #ifdef ZCL_EZMODE
              case ZDO_CB_MSG:
                break;
      #endif
                break;
              case KEY_CHANGE:
                break;
      #ifdef ZCL_EZMODE
                break;
              default:
                break;
    #ifdef ZCL_EZMODE
        // Invoke EZ-Mode
        // Invoke EZ-Mode
        else
    #endif
      return 0;
     *                 HAL_KEY_SW_5
     *                 HAL_KEY_SW_4
     *                 HAL_KEY_SW_2
     *                 HAL_KEY_SW_1
     * @return  none
        forward = 0;
        backward = 0;
        DATA_PIN = 1;
        osal_start_timerEx( zclSampleLight_TaskID, TURNOFF_MOTOR_EVT, 1000);
        KeyPressCnt=0;
     * @param   none
     * @return  none
      else
    #endif
      rptcmd.numAttr = 1;
     * @param   level
     * @return  none
    #endif
     * @param   none
     * @return  none
        DATA_PIN = 0;
        forward = 0;
        backward = 1;
        forward = 0;
        backward = 0;
        DATA_PIN = 1;*/
        no = 1;
        DATA_PIN = 0;
        forward = 1;
        backward = 0;
        forward = 0;
        backward = 0;
        DATA_PIN = 1;*/
        no = 0;
    #else
        else
     * @param   none
     * @return  none
        sSwHelp[15] = '*';
      else
        sSwHelp[15] = ' ';
     * @param   none
     * @return  none
     * @param   none
     * @return  none
      else
    #ifdef ZCL_EZMODE
        else
    #endif
     * @param   none
     * @return  none
     * @return  none
     * @return  none
      (void)pRsp;
    #ifdef ZCL_EZMODE
    #endif
     * @return  none
      // Toggle the light
        else
    #if ZCL_LEVEL_CTRL
    #endif
      uint32 diff;
      uint32 newLevel32;
      // calculate diff
      else
      return ( diff );
     * @return  none
      uint32 diff;
     * @return  none
      uint16 diff;
     * @return  none
      // time possible.
        else
          time = 1;
      if ( !time )
      return ( time );
     * @return  none
      uint8  newLevel;
      uint16 time;
        else
      else
        time = 1;
     * @param   none
     * @return  none
      else
        else
    #endif
          ENABLE_LAMP;
    #endif
        else
          DISABLE_LAMP;
    #endif
     * @return  none
     * @return  none
      uint8 newLevel;
      uint32 rate;
      else
     * @return  none
      uint8 newLevel;
        else
      else
        else
     * @return  none
      // stop immediately
    #endif
     * @return  none
    #ifdef ZCL_READ
          break;
    #endif
    #ifdef ZCL_WRITE
          break;
    #endif
    #ifdef ZCL_REPORT
          break;
          break;
          break;
          break;
          break;
    #endif
          break;
    #ifdef ZCL_DISCOVER
          break;
          break;
          break;
          break;
    #endif
        default:
          break;
    #ifdef ZCL_READ
     * @return  none
      uint8 i;
        // attribute
      return ( TRUE );
    #endif // ZCL_READ
    #ifdef ZCL_WRITE
     * @return  none
      uint8 i;
        // command.
      return ( TRUE );
    #endif // ZCL_WRITE
     * @return  none
      (void)pInMsg;
      return ( TRUE );
    #ifdef ZCL_DISCOVER
     * @return  none
      uint8 i;
      return ( TRUE );
     * @return  none
      uint8 i;
      return ( TRUE );
     * @return  none
      uint8 i;
      return ( TRUE );
    #if ZCL_EZMODE
     * @param   none
     * @return  status
     * @param   state - an
     * @return  none
      char *pStr;
      uint8 err;
    #endif
    #endif
        pStr = NULL;
        if ( pStr )
    #endif
        pStr = NULL;
        if ( pStr )
    #endif
  • Comment out the line "osal_start_timerEx( zclSampleLight_TaskID, KEYHOLD_EVT, 100);" in your zclSampleLight_HandleKeys() to see if power consumption drops.
  • It does not.
  • Try to comment out the following codes in zclSampleLight_HandleKeys to test again.
    forward = 0;
    backward = 0;
    DATA_PIN = 1;
  • I did that, but it didn't fix the problem unfortunately. What else do you suggest?
  • I suggest you to find the root cause of your problem first. Have you tested what I suggest to remove SW2 related code to see if power consumption drops?
  • Yes. Can you provide a list of all possible things that I can try to find the root cause of the problem?
  • What does YES mean? Does power consumption drop after you comment out SW2 related codes? I don't have a list. I just check your code and suggest you to remove what you add to application one-by-one to see if we can find some clues.
  • I removed the code you specified, but it did not fix the problem. What should I try next?
  • If you comment out everything in "if ( keys & HAL_KEY_SW_6 )...", does power consumption drops?
  • The power consumption does not drop.
  • Comment out "if ( events & KEYHOLD_EVT )..." in zclSampleLight_event_loop to see if power consumption drops.
  • I commented out all of the KeyHold code, battery monitor code, HAL_KEY_SW_6 code, and the consumption still does not drop. Also I commented out all of the EZ-mode code (FYI, ez-mode not entered unless SW6 is pressed) and the consumption is still 8ma. So I do not believe the consumption has to do with button holding/factory reset, SW6, SW2, battery monitor, or EZ-mode (ez-mode related to SW6/periodic event). What other possibilities do you think may cause the problem?
  • Can you attach your latest code after you comment out all of those you mentioned?
  • Here is the code:
     * INCLUDES
    #include "OSAL.h"
    #include "AF.h"
    #include "ZDApp.h"
    #include "MT_SYS.h"
    #include "zcl.h"
    #include "zcl_ha.h"
    /* HAL */
        #define ZGP_AUTO_TT
      #endif
    #endif
    #include "math.h"
    #endif
    #include "NLMEDE.h"
     * MACROS
     * CONSTANTS
    #endif
     * TYPEDEFS
     * GLOBAL VARIABLES
     * GLOBAL FUNCTIONS
     * LOCAL VARIABLES
    #ifdef ZCL_EZMODE
    #else
    #endif
    #if ZCL_LEVEL_CTRL
    #endif
     * LOCAL FUNCTIONS
    #endif
    #endif
    #endif
    #ifdef ZCL_READ
    #endif
    #ifdef ZCL_WRITE
    #endif
    #ifdef ZCL_DISCOVER
    #endif
     * STATUS STRINGS
     #if ZCL_LEVEL_CTRL
     #endif
    #endif
    #ifdef ZCL_EZMODE
    #endif
    #endif
    #ifdef ZCL_GROUPS
    #endif
    #ifdef ZCL_SCENES
    #endif
    #ifdef ZCL_ALARMS
    #endif
    #ifdef SE_UK_EXT
    #endif
     * @param       none
     * @return      none
    #define pin P0_3
    #define time 110
    static int no = 0;
    #ifdef ZCL_DISCOVER
    #endif
    #ifdef ZCL_EZMODE
      // Register EZ-Mode
    #endif
      HalTimer1Init( 0 );
      uint8 state;
    #if ZCL_LEVEL_CTRL
    #endif
    #endif
    #ifdef ZGP_AUTO_TT
    #endif
      /*P0SEL &= ~BV(3);
      P0DIR |= BV(3);
      pin = 1;*/
      P0DIR |= 0x20;
      //P1DIR |= 0x3f;
      P0SEL &= ~BV(7);
      P0DIR |= BV(7);
      P0SEL &= ~BV(6);
      P0DIR |= BV(6);
        DATA_PIN = 0;
        forward = 0;
        backward = 1;
        forward = 0;
        backward = 0;
        DATA_PIN = 1;
        no = 1;
     * @param       none
     * @return      none
    int KeyPressCnt=0;
    uint16 adc_ain2=0;
    uint16 value_bat;
    uint32        next;
    uint8 ret;
      /*if( events & TURNOFF_MOTOR_EVT )
        forward = 0;
        backward = 0;
        DATA_PIN = 1;
      /*if ( events & KEYHOLD_EVT )
        if ( P2_0==1 )
          if (KeyPressCnt>50){
            KeyPressCnt=0;
            //ZDApp_ResetTimerStart(100);
          else{
            KeyPressCnt++;
      /*if( events & PERIODIC_EVT2 )
    #ifdef ZCL_EZMODE
          // Invoke EZ-Mode
          // Invoke EZ-Mode
          else
        osal_start_timerEx( zclSampleLight_TaskID, PERIODIC_EVT2, 50000 );
        /*// Hold off interrupts.
          OSAL_SET_CPU_INTO_SLEEP( 50000 );*/
      #ifdef ZCL_EZMODE
              case ZDO_CB_MSG:
                break;
      #endif
                break;
              case KEY_CHANGE:
                break;
      #ifdef ZCL_EZMODE
                break;
              default:
                break;
    #ifdef ZCL_EZMODE
        // Invoke EZ-Mode
        // Invoke EZ-Mode
        else
    #endif
      return 0;
     *                 HAL_KEY_SW_5
     *                 HAL_KEY_SW_4
     *                 HAL_KEY_SW_2
     *                 HAL_KEY_SW_1
     * @return  none
      /*if ( (keys & HAL_KEY_SW_2) )
        forward = 0;
        backward = 0;
        DATA_PIN = 1;
        //osal_start_timerEx( zclSampleLight_TaskID, PERIODIC_EVT, 5000 );
        /*osal_stop_timerEx( zclSampleLight_TaskID, TURNOFF_MOTOR_EVT);
        KeyPressCnt=0;
        zclSampleLight_OnOff = zclSampleLight_OnOff ? LIGHT_OFF : LIGHT_ON;*/
     * @param   none
     * @return  none
      else
    #endif
      rptcmd.numAttr = 1;
     * @param   level
     * @return  none
    #endif
     * @param   none
     * @return  none
        DATA_PIN = 0;
        forward = 0;
        backward = 1;
        forward = 0;
        backward = 0;
        DATA_PIN = 1;*/
        no = 1;
        DATA_PIN = 0;
        forward = 1;
        backward = 0;
        forward = 0;
        backward = 0;
        DATA_PIN = 1;*/
        no = 0;
    #else
        else
     * @param   none
     * @return  none
        sSwHelp[15] = '*';
      else
        sSwHelp[15] = ' ';
     * @param   none
     * @return  none
     * @param   none
     * @return  none
      else
    #ifdef ZCL_EZMODE
        else
    #endif
     * @param   none
     * @return  none
     * @return  none
     * @return  none
      (void)pRsp;
    #ifdef ZCL_EZMODE
    #endif
     * @return  none
      // Toggle the light
        else
    #if ZCL_LEVEL_CTRL
    #endif
      uint32 diff;
      uint32 newLevel32;
      // calculate diff
      else
      return ( diff );
     * @return  none
      uint32 diff;
     * @return  none
      uint16 diff;
     * @return  none
      // time possible.
        else
          time = 1;
      if ( !time )
      return ( time );
     * @return  none
      uint8  newLevel;
      uint16 time;
        else
      else
        time = 1;
     * @param   none
     * @return  none
      else
        else
    #endif
          ENABLE_LAMP;
    #endif
        else
          DISABLE_LAMP;
    #endif
     * @return  none
     * @return  none
      uint8 newLevel;
      uint32 rate;
      else
     * @return  none
      uint8 newLevel;
        else
      else
        else
     * @return  none
      // stop immediately
    #endif
     * @return  none
    #ifdef ZCL_READ
          break;
    #endif
    #ifdef ZCL_WRITE
          break;
    #endif
    #ifdef ZCL_REPORT
          break;
          break;
          break;
          break;
          break;
    #endif
          break;
    #ifdef ZCL_DISCOVER
          break;
          break;
          break;
          break;
    #endif
        default:
          break;
    #ifdef ZCL_READ
     * @return  none
      uint8 i;
        // attribute
      return ( TRUE );
    #endif // ZCL_READ
    #ifdef ZCL_WRITE
     * @return  none
      uint8 i;
        // command.
      return ( TRUE );
    #endif // ZCL_WRITE
     * @return  none
      (void)pInMsg;
      return ( TRUE );
    #ifdef ZCL_DISCOVER
     * @return  none
      uint8 i;
      return ( TRUE );
     * @return  none
      uint8 i;
      return ( TRUE );
     * @return  none
      uint8 i;
      return ( TRUE );
    #if ZCL_EZMODE
     * @param   none
     * @return  status
     * @param   state - an
     * @return  none
      char *pStr;
      uint8 err;
    #endif
    #endif
        pStr = NULL;
        if ( pStr )
    #endif
        pStr = NULL;
        if ( pStr )
    #endif
  • Try to comment out "if( events & PERIODIC_EVT )..." in event loop.
  • I tried that, but it did not fix the problem.
  • Try to comment out everything inside your zclSampleLight_LcdDisplayUpdate().
  • That didn't fix the problem either.
