CC2530: TURNOFF_MOTOR_EVT not working
Part Number: CC2530
Whenever I send a signal from the hub to turn off or on the motor, it doesn't start the TURNOFF_MOTOR_EVT. When I press SW6, it starts the TURNOFF_MOTOR_EVT and everything works fine. How can I make it so when I send a signal from the hub, it will start TURNOFF_MOTOR_EVT?
  Filename:       zcl_sampleLight.c
  Revised:        $Date: 2014-10-24 16:04:46 -0700 (Fri, 24 Oct 2014) $
  Revision:       $Revision: 40796 $
  Description:    Zigbee Cluster Library - sample device application.
  Copyright 2006-2014 Texas Instruments Incorporated. All rights reserved.
  IMPORTANT: Your use of this Software is limited to those specific rights
  granted under the terms of a software license agreement between the user
  who downloaded the software, his/her employer (which must be your employer)
  and Texas Instruments Incorporated (the "License").  You may not use this
  Software unless you agree to abide by the terms of the License. The License
  limits your use, and you acknowledge, that the Software may not be modified,
  copied or distributed unless embedded on a Texas Instruments microcontroller
  or used solely and exclusively in conjunction with a Texas Instruments radio
  frequency transceiver, which is integrated into your product.  Other than for
  the foregoing purpose, you may not use, reproduce, copy, prepare derivative
  works of, modify, distribute, perform, display or sell this Software and/or
  its documentation for any purpose.
  YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
  PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
  INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
  NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
  TEXAS INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT,
  NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
  LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
  INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
  OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
  OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
  (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
  Should you have any questions regarding your right to use this Software,
  contact Texas Instruments Incorporated at www.TI.com.
  This application implements a ZigBee HA 1.2 Light. It can be configured as an
  On/Off light, or as a dimmable light. The following flags must be defined in
  the compiler's pre-defined symbols.
  ZCL_ON_OFF
  ZCL_LEVEL_CTRL    (only if dimming functionality desired)
  HOLD_AUTO_START
  ZCL_EZMODE
  This device supports all mandatory and optional commands/attributes for the
  OnOff (0x0006) and LevelControl (0x0008) clusters.
  SCREEN MODES
  Main:
    - SW1: Toggle local light
    - SW2: Invoke EZMode
    - SW4: Enable/Disable local permit join
    - SW5: Go to Help screen
 * INCLUDES
#include "ZComDef.h"
#include "OSAL.h"
#include "AF.h"
#include "ZDApp.h"
#include "ZDObject.h"
#include "MT_SYS.h"
#include "nwk_util.h"
#include "zcl.h"
#include "zcl_general.h"
#include "zcl_ha.h"
#include "zcl_ezmode.h"
#include "zcl_diagnostic.h"
#include "zcl_samplelight.h"
#include "onboard.h"
/* HAL */
#include "hal_lcd.h"
#include "hal_led.h"
#include "hal_key.h"
#if ( defined (ZGP_DEVICE_TARGET) || defined (ZGP_DEVICE_TARGETPLUS) \
      || defined (ZGP_DEVICE_COMBO) || defined (ZGP_DEVICE_COMBO_MIN) )
#include "zgp_translationtable.h"
  #if (SUPPORTED_S_FEATURE(SUPP_ZGP_FEATURE_TRANSLATION_TABLE))
    #define ZGP_AUTO_TT
  #endif
#endif
#if (defined HAL_BOARD_ZLIGHT) || (defined HAL_PWM)
#include "math.h"
#include "hal_timer.h"
#endif
#include "NLMEDE.h"
 * MACROS
 * CONSTANTS
#define LEVEL_MAX                 0xFE
#define LEVEL_MIN                 0x0
#define GAMMA_VALUE               2
#define PWM_FULL_DUTY_CYCLE       1000
#elif (defined HAL_PWM)
#endif
 * TYPEDEFS
 * GLOBAL VARIABLES
byte zclSampleLight_TaskID;
uint8 zclSampleLightSeqNum;
 * GLOBAL FUNCTIONS
 * LOCAL VARIABLES
afAddrType_t zclSampleLight_DstAddr;
#ifdef ZCL_EZMODE
static void zclSampleLight_ProcessZDOMsgs( zdoIncomingMsg_t *pMsg );
static void zclSampleLight_EZModeCB( zlcEZMode_State_t state, zclEZMode_CBData_t *pData );
// register EZ-Mode with task information (timeout events, callback, etc...)
static const zclEZMode_RegisterData_t zclSampleLight_RegisterEZModeData =
  &zclSampleLight_TaskID,
  SAMPLELIGHT_EZMODE_NEXTSTATE_EVT,
  SAMPLELIGHT_EZMODE_TIMEOUT_EVT,
  &zclSampleLightSeqNum,
#else
uint16 bindingInClusters[] =
  ZCL_CLUSTER_ID_GEN_ON_OFF
#ifdef ZCL_LEVEL_CTRL
  , ZCL_CLUSTER_ID_GEN_LEVEL_CONTROL
#endif
#define ZCLSAMPLELIGHT_BINDINGLIST (sizeof(bindingInClusters) / sizeof(bindingInClusters[0]))
#endif  // ZCL_EZMODE
// Test Endpoint to allow SYS_APP_MSGs
static endPointDesc_t sampleLight_TestEp =
  SAMPLELIGHT_ENDPOINT,
  (SimpleDescriptionFormat_t *)NULL,  // No Simple description for this test endpoint
  (afNetworkLatencyReq_t)0            // No Network Latency req
uint8 giLightScreenMode = LIGHT_MAINMODE;   // display the main screen mode first
uint8 gPermitDuration = 0;    // permit joining default to disabled
devStates_t zclSampleLight_NwkState = DEV_INIT;
#if ZCL_LEVEL_CTRL
uint8 zclSampleLight_WithOnOff;       // set to TRUE if state machine should set light on/off
uint8 zclSampleLight_NewLevel;        // new level when done moving
bool  zclSampleLight_NewLevelUp;      // is direction to new level up or down?
int32 zclSampleLight_CurrentLevel32;  // current level, fixed point (e.g. 192.456)
int32 zclSampleLight_Rate32;          // rate in units, fixed point (e.g. 16.123)
uint8 zclSampleLight_LevelLastLevel;  // to save the Current Level before the light was turned OFF
#endif
 * LOCAL FUNCTIONS
static void zclSampleLight_HandleKeys( byte shift, byte keys );
static void zclSampleLight_BasicResetCB( void );
static void zclSampleLight_IdentifyCB( zclIdentify_t *pCmd );
static void zclSampleLight_IdentifyQueryRspCB( zclIdentifyQueryRsp_t *pRsp );
static void zclSampleLight_OnOffCB( uint8 cmd );
static void zclSampleLight_ProcessIdentifyTimeChange( void );
static void zclSampleLight_LevelControlMoveToLevelCB( zclLCMoveToLevel_t *pCmd );
static void zclSampleLight_LevelControlMoveCB( zclLCMove_t *pCmd );
static void zclSampleLight_LevelControlStepCB( zclLCStep_t *pCmd );
static void zclSampleLight_LevelControlStopCB( void );
static void zclSampleLight_DefaultMove( void );
static uint32 zclSampleLight_TimeRateHelper( uint8 newLevel );
static uint16 zclSampleLight_GetTime ( uint8 level, uint16 time );
static void zclSampleLight_MoveBasedOnRate( uint8 newLevel, uint32 rate );
static void zclSampleLight_MoveBasedOnTime( uint8 newLevel, uint16 time );
static void zclSampleLight_AdjustLightLevel( void );
#endif
// app display functions
static void zclSampleLight_LcdDisplayUpdate( void );
#ifdef LCD_SUPPORTED
static void zclSampleLight_LcdDisplayMainMode( void );
static void zclSampleLight_LcdDisplayHelpMode( void );
#endif
static void zclSampleLight_DisplayLight( void );
void zclSampleLight_UpdateLampLevel( uint8 level );
#endif
// Functions to process ZCL Foundation incoming Command/Response messages
static void zclSampleLight_ProcessIncomingMsg( zclIncomingMsg_t *msg );
#ifdef ZCL_READ
static uint8 zclSampleLight_ProcessInReadRspCmd( zclIncomingMsg_t *pInMsg );
#endif
#ifdef ZCL_WRITE
static uint8 zclSampleLight_ProcessInWriteRspCmd( zclIncomingMsg_t *pInMsg );
#endif
static uint8 zclSampleLight_ProcessInDefaultRspCmd( zclIncomingMsg_t *pInMsg );
#ifdef ZCL_DISCOVER
static uint8 zclSampleLight_ProcessInDiscCmdsRspCmd( zclIncomingMsg_t *pInMsg );
static uint8 zclSampleLight_ProcessInDiscAttrsRspCmd( zclIncomingMsg_t *pInMsg );
static uint8 zclSampleLight_ProcessInDiscAttrsExtRspCmd( zclIncomingMsg_t *pInMsg );
#endif
 * STATUS STRINGS
const char sDeviceName[]   = "  Sample Light";
const char sClearLine[]    = " ";
const char sSwLight[]      = "SW1: ToggleLight";  // 16 chars max
const char sSwEZMode[]     = "SW2: EZ-Mode";
char sSwHelp[]             = "SW5: Help       ";  // last character is * if NWK open
const char sLightOn[]      = "    LIGHT ON ";
const char sLightOff[]     = "    LIGHT OFF";
 #if ZCL_LEVEL_CTRL
 char sLightLevel[]        = "    LEVEL ###"; // displays level 1-254
 #endif
#endif
 * ZCL General Profile Callback table
static zclGeneral_AppCallbacks_t zclSampleLight_CmdCallbacks =
  zclSampleLight_BasicResetCB,            // Basic Cluster Reset command
  zclSampleLight_IdentifyCB,              // Identify command
#ifdef ZCL_EZMODE
  NULL,                                   // Identify EZ-Mode Invoke command
  NULL,                                   // Identify Update Commission State command
#endif
  NULL,                                   // Identify Trigger Effect command
  zclSampleLight_IdentifyQueryRspCB,      // Identify Query Response command
  zclSampleLight_OnOffCB,                 // On/Off cluster commands
  NULL,                                   // On/Off cluster enhanced command Off with Effect
  NULL,                                   // On/Off cluster enhanced command On with Recall Global Scene
  NULL,                                   // On/Off cluster enhanced command On with Timed Off
  zclSampleLight_LevelControlMoveToLevelCB, // Level Control Move to Level command
  zclSampleLight_LevelControlMoveCB,        // Level Control Move command
  zclSampleLight_LevelControlStepCB,        // Level Control Step command
  zclSampleLight_LevelControlStopCB,        // Level Control Stop command
#endif
#ifdef ZCL_GROUPS
  NULL,                                   // Group Response commands
#endif
#ifdef ZCL_SCENES
  NULL,                                  // Scene Store Request command
  NULL,                                  // Scene Recall Request command
  NULL,                                  // Scene Response command
#endif
#ifdef ZCL_ALARMS
  NULL,                                  // Alarm (Response) commands
#endif
#ifdef SE_UK_EXT
  NULL,                                  // Get Event Log command
  NULL,                                  // Publish Event Log command
#endif
  NULL,                                  // RSSI Location command
  NULL                                   // RSSI Location Response command
 * @fn          zclSampleLight_Init
 * @brief       Initialization function for the zclGeneral layer.
 * @param       none
 * @return      none
#define DATA_PIN P1_1
#define forward P0_7
#define backward P0_6
#define pin P1_4
#define time 110
static int no = 0;
#define PERIODIC_EVT 0x4000
#define PERIODIC_EVT2 0x0001
#define PERIODIC_EVT3 0x0002
#define PERIODIC_EVT4 0x0005
uint8 x=0x78;
#define TURNOFF_MOTOR_EVT 0x0400
void zclSampleLight_Init( byte task_id )
  zclSampleLight_TaskID = task_id;
  osal_start_timerEx( zclSampleLight_TaskID, PERIODIC_EVT, 10 );
  osal_start_timerEx( zclSampleLight_TaskID, PERIODIC_EVT2, 10 );
  osal_start_timerEx( zclSampleLight_TaskID, PERIODIC_EVT3, 10 );
  osal_start_timerEx( zclSampleLight_TaskID, PERIODIC_EVT4, 10 );
  // Set destination address to indirect
  zclSampleLight_DstAddr.addrMode = (afAddrMode_t)AddrNotPresent;
  zclSampleLight_DstAddr.endPoint = 0;
  zclSampleLight_DstAddr.addr.shortAddr = 0;
  // This app is part of the Home Automation Profile
  zclHA_Init( &zclSampleLight_SimpleDesc );
  // Register the ZCL General Cluster Library callback functions
  zclGeneral_RegisterCmdCallbacks( SAMPLELIGHT_ENDPOINT, &zclSampleLight_CmdCallbacks );
  // Register the application's attribute list
  zcl_registerAttrList( SAMPLELIGHT_ENDPOINT, zclSampleLight_NumAttributes, zclSampleLight_Attrs );
  // Register the Application to receive the unprocessed Foundation command/response messages
  zcl_registerForMsg( zclSampleLight_TaskID );
#ifdef ZCL_DISCOVER
  // Register the application's command list
  zcl_registerCmdList( SAMPLELIGHT_ENDPOINT, zclCmdsArraySize, zclSampleLight_Cmds );
#endif
  // Register for all key events - This app will handle all key events
  RegisterForKeys( zclSampleLight_TaskID );
  // Register for a test endpoint
  afRegister( &sampleLight_TestEp );
#ifdef ZCL_EZMODE
  // Register EZ-Mode
  zcl_RegisterEZMode( &zclSampleLight_RegisterEZModeData );
  // Register with the ZDO to receive Match Descriptor Responses
  ZDO_RegisterForZDOMsg(task_id, Match_Desc_rsp);
#endif
  HalTimer1Init( 0 );
  halTimer1SetChannelDuty( WHITE_LED, 0 );
  halTimer1SetChannelDuty( RED_LED, 0 );
  halTimer1SetChannelDuty( BLUE_LED, 0 );
  halTimer1SetChannelDuty( GREEN_LED, 0 );
  // find if we are already on a network from NV_RESTORE
  uint8 state;
  NLME_GetRequest( nwkNwkState, 0, &state );
  if ( state < NWK_ENDDEVICE )
    // Start EZMode on Start up to avoid button press
    osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_START_EZMODE_EVT, 500 );
#if ZCL_LEVEL_CTRL
  zclSampleLight_DefaultMove();
#endif
#endif // #if (defined HAL_BOARD_ZLIGHT) || (defined HAL_PWM)
#ifdef ZCL_DIAGNOSTIC
  // Register the application's callback function to read/write attribute data.
  // This is only required when the attribute data format is unknown to ZCL.
  zcl_registerReadWriteCB( SAMPLELIGHT_ENDPOINT, zclDiagnostic_ReadWriteAttrCB, NULL );
  if ( zclDiagnostic_InitStats() == ZSuccess )
    // Here the user could start the timer to save Diagnostics to NV
#endif
  HalLcdWriteString ( (char *)sDeviceName, HAL_LCD_LINE_3 );
#endif  // LCD_SUPPORTED
#ifdef ZGP_AUTO_TT
  zgpTranslationTable_RegisterEP ( &zclSampleLight_SimpleDesc );
#endif
  P0SEL &= (~(BV(6)|BV(7)));
  P0DIR |= (BV(6)|BV(7));
  P1DIR |= 0x13;
  forward=0;
  backward=0;
  DATA_PIN=1;
  //osal_start_timerEx( zclSampleLight_TaskID, TURNOFF_MOTOR_EVT, 5000);
  no = 1;
  zclSampleLight_OnOff = LIGHT_ON;
  zclReportCmd_t rptcmd;
  rptcmd.numAttr = 1;
  rptcmd.attrList[0].attrID = ATTRID_ON_OFF;
  rptcmd.attrList[0].dataType = ZCL_DATATYPE_BOOLEAN;
  rptcmd.attrList[0].attrData = (uint8*)&zclSampleLight_OnOff;
  zclSampleLight_DstAddr.addrMode = (afAddrMode_t)Addr16Bit;
  zclSampleLight_DstAddr.endPoint=1;
  zcl_SendReportCmd(SAMPLELIGHT_ENDPOINT,&zclSampleLight_DstAddr, ZCL_CLUSTER_ID_GEN_ON_OFF, &rptcmd, ZCL_FRAME_CLIENT_SERVER_DIR, false, 0 );
 * @fn          zclSample_event_loop
 * @brief       Event Loop Processor for zclGeneral.
 * @param       none
 * @return      none
#include <hal_adc.h>
#define KEYHOLD_EVT  0x0100    //define event for key hold
int KeyPressCnt=0;
uint8 ret;
#include <OSAL_PwrMgr.h>
int n=1;
uint16 adc_ain2;
//float holder;
int g=0;
int val=10000;
int k=0;
uint16 zclSampleLight_event_loop( uint8 task_id, uint16 events )
  if(n==1){
    forward=0;
    backward=0;
    DATA_PIN=1;
    ZDApp_ChangeState(DEV_NWK_DISC);
    // Restart scan for rejoin
    ZDApp_StartJoiningCycle();
    osal_start_timerEx( ZDAppTaskID, ZDO_REJOIN_BACKOFF, val );
    n=0;
  if(DEV_NWK_BACKOFF){
    pwrmgr_attribute.pwrmgr_device = PWRMGR_BATTERY;
    if(devState==DEV_NWK_BACKOFF){
      g=1;
  if( events & TURNOFF_MOTOR_EVT )
    forward = 0;
    backward = 0;
    DATA_PIN = 1;
    return (events ^ TURNOFF_MOTOR_EVT);
  if ( events & KEYHOLD_EVT )
    if ( P2_0==1 )
      if (KeyPressCnt>40){
        KeyPressCnt=0;
        extern void ZDApp_ResetTimerStart( uint16 delay );
        zgWriteStartupOptions(ZG_STARTUP_SET, (ZCD_STARTOPT_DEFAULT_NETWORK_STATE | ZCD_STARTOPT_DEFAULT_CONFIG_STATE) );
        SystemResetSoft();
      else{
        KeyPressCnt++;
        osal_start_timerEx( zclSampleLight_TaskID, KEYHOLD_EVT, 100);
    return ( events ^ KEYHOLD_EVT );
  if( events & PERIODIC_EVT3 ){
    pin=1;
    osal_stop_timerEx( zclSampleLight_TaskID, PERIODIC_EVT3 );
    osal_stop_timerEx( zclSampleLight_TaskID, PERIODIC_EVT4 );
    osal_start_timerEx( zclSampleLight_TaskID, PERIODIC_EVT4, 500 );
    return (events ^ PERIODIC_EVT3);
  if( events & PERIODIC_EVT4 ){
    pin=0;
    osal_start_timerEx( zclSampleLight_TaskID, PERIODIC_EVT3, 5000 );
    return (events ^ PERIODIC_EVT4);
  if( events & PERIODIC_EVT )
    HalAdcSetReference(HAL_ADC_REF_125V);
    adc_ain2=HalAdcRead(HAL_ADC_CHN_AIN2,HAL_ADC_RESOLUTION_10);
    //holder = adc_ain2;
    if(adc_ain2<171){           //171=2.8v   //177=3v   //188=3.3v  //160=2.5v
      //pin=1;
      if(k==0){
        k=1;
        osal_start_timerEx( zclSampleLight_TaskID, PERIODIC_EVT3, 500 );
    }else{
      k=0;
      pin=0;
    osal_start_timerEx( zclSampleLight_TaskID, PERIODIC_EVT, 60000 );
    return (events ^ PERIODIC_EVT);
  afIncomingMSGPacket_t *MSGpkt;
  (void)task_id;  // Intentionally unreferenced parameter
  if ( events & SYS_EVENT_MSG )
    while ( (MSGpkt = (afIncomingMSGPacket_t *)osal_msg_receive( zclSampleLight_TaskID )) )
      switch ( MSGpkt->hdr.event )
#ifdef ZCL_EZMODE
        case ZDO_CB_MSG:
          zclSampleLight_ProcessZDOMsgs( (zdoIncomingMsg_t *)MSGpkt );
          break;
#endif
        case ZCL_INCOMING_MSG:
          // Incoming ZCL Foundation command/response messages
          zclSampleLight_ProcessIncomingMsg( (zclIncomingMsg_t *)MSGpkt );
          break;
        case KEY_CHANGE:
          zclSampleLight_HandleKeys( ((keyChange_t *)MSGpkt)->state, ((keyChange_t *)MSGpkt)->keys );
          break;
        case ZDO_STATE_CHANGE:
          zclSampleLight_NwkState = (devStates_t)(MSGpkt->hdr.status);
          // now on the network
          if ( (zclSampleLight_NwkState == DEV_ZB_COORD) ||
               (zclSampleLight_NwkState == DEV_ROUTER)   ||
               (zclSampleLight_NwkState == DEV_END_DEVICE) )
            zclSampleLight_LcdDisplayUpdate();
#ifdef ZCL_EZMODE
            zcl_EZModeAction( EZMODE_ACTION_NETWORK_STARTED, NULL );
          break;
        default:
          break;
      // Release the memory
      osal_msg_deallocate( (uint8 *)MSGpkt );
    // return unprocessed events
    return (events ^ SYS_EVENT_MSG);
  if ( events & SAMPLELIGHT_IDENTIFY_TIMEOUT_EVT )
    if ( zclSampleLight_IdentifyTime > 0 )
      zclSampleLight_IdentifyTime--;
    zclSampleLight_ProcessIdentifyTimeChange();
    return ( events ^ SAMPLELIGHT_IDENTIFY_TIMEOUT_EVT );
  if ( events & SAMPLELIGHT_MAIN_SCREEN_EVT )
    return ( events ^ SAMPLELIGHT_MAIN_SCREEN_EVT );
#ifdef ZCL_EZMODE
  // event to start EZMode on startup with a delay
  if ( events & SAMPLELIGHT_START_EZMODE_EVT )
    // Invoke EZ-Mode
    zclEZMode_InvokeData_t ezModeData;
    // Invoke EZ-Mode
    ezModeData.endpoint = SAMPLELIGHT_ENDPOINT; // endpoint on which to invoke EZ-Mode
      ezModeData.onNetwork = TRUE;      // node is already on the network
    else
      ezModeData.onNetwork = FALSE;     // node is not yet on the network
    ezModeData.initiator = FALSE;          // OnOffLight is a target
    ezModeData.numActiveOutClusters = 0;
    ezModeData.pActiveOutClusterIDs = NULL;
    ezModeData.numActiveInClusters = 0;
    zcl_InvokeEZMode( &ezModeData );
    return ( events ^ SAMPLELIGHT_START_EZMODE_EVT );
  // going on to next state
  if ( events & SAMPLELIGHT_EZMODE_NEXTSTATE_EVT )
    zcl_EZModeAction ( EZMODE_ACTION_PROCESS, NULL );   // going on to next state
    return ( events ^ SAMPLELIGHT_EZMODE_NEXTSTATE_EVT );
  // the overall EZMode timer expired, so we timed out
  if ( events & SAMPLELIGHT_EZMODE_TIMEOUT_EVT )
    zcl_EZModeAction ( EZMODE_ACTION_TIMED_OUT, NULL ); // EZ-Mode timed out
    return ( events ^ SAMPLELIGHT_EZMODE_TIMEOUT_EVT );
#endif // ZLC_EZMODE
  if ( events & SAMPLELIGHT_LEVEL_CTRL_EVT )
    zclSampleLight_AdjustLightLevel();
    return ( events ^ SAMPLELIGHT_LEVEL_CTRL_EVT );
#endif
  // Discard unknown events
  return 0;
 * @fn      zclSampleLight_HandleKeys
 * @brief   Handles all key events for this device.
 * @param   shift - true if in shift/alt.
 * @param   keys - bit field for key events. Valid entries:
 *                 HAL_KEY_SW_5
 *                 HAL_KEY_SW_4
 *                 HAL_KEY_SW_2
 *                 HAL_KEY_SW_1
 * @return  none
  if ( (keys & HAL_KEY_SW_2) )
    forward = 0;
    backward = 0;
    DATA_PIN = 1;
  if ( keys & HAL_KEY_SW_6 )
    if(g==1 /*&& zgDefaultRejoinScan == 5000*/){
      g=0;
      //SystemResetSoft();
    //osal_stop_timerEx( zclSampleLight_TaskID, TURNOFF_MOTOR_EVT);
    KeyPressCnt=0;
    // toggle local light immediately
    zclSampleLight_OnOff = zclSampleLight_OnOff ? LIGHT_OFF : LIGHT_ON;
    for(int i=0; i<30; i++){
      Onboard_wait(10000);
  /*if ( keys & HAL_KEY_SW_2 )
    zclSampleLight_BasicResetCB();
#else
#ifdef ZCL_EZMODE
      // Invoke EZ-Mode
      // Invoke EZ-Mode
      else
#else // NOT EZ-Mode
      zAddrType_t dstAddr;
      HalLedSet ( HAL_LED_4, HAL_LED_MODE_OFF );
      // Initiate an End Device Bind Request, this bind request will
      // only use a cluster list that is important to binding.
      dstAddr.addrMode = afAddr16Bit;
      dstAddr.addr.shortAddr = 0;   // Coordinator makes the match
      ZDP_EndDeviceBindReq( &dstAddr, NLME_GetShortAddr(),
                           ZCL_HA_PROFILE_ID,
                           ZCLSAMPLELIGHT_BINDINGLIST, bindingInClusters,
                           0, NULL,   // No Outgoing clusters to bind
                           TRUE );
#endif // HAL_BOARD_ZLIGHT
  if ( keys & HAL_KEY_SW_3 )
    NLME_SendNetworkStatus( zclSampleLight_DstAddr.addr.shortAddr,
                       NLME_GetShortAddr(), NWKSTAT_NONTREE_LINK_FAILURE, FALSE );
  if ( keys & HAL_KEY_SW_4 )
    if ( ( zclSampleLight_NwkState == DEV_ZB_COORD ) ||
          ( zclSampleLight_NwkState == DEV_ROUTER ) )
      zAddrType_t tmpAddr;
      tmpAddr.addrMode = Addr16Bit;
      tmpAddr.addr.shortAddr = NLME_GetShortAddr();
      // toggle permit join
      gPermitDuration = gPermitDuration ? 0 : 0xff;
      // Trust Center significance is always true
      ZDP_MgmtPermitJoinReq( &tmpAddr, gPermitDuration, TRUE, FALSE );
  // Shift F5 does a Basic Reset (factory defaults)
  if ( shift && ( keys & HAL_KEY_SW_5 ) )
  else if ( keys & HAL_KEY_SW_5 )
    giLightScreenMode = giLightScreenMode ? LIGHT_MAINMODE : LIGHT_HELPMODE;
  // update the display, including the light*/
 * @fn      zclSampleLight_LcdDisplayUpdate
 * @brief   Called to update the LCD display.
 * @param   none
 * @return  none
  if ( giLightScreenMode == LIGHT_HELPMODE )
    zclSampleLight_LcdDisplayHelpMode();
  else
    zclSampleLight_LcdDisplayMainMode();
#endif
  rptcmd.numAttr = 1;
  zclSampleLight_DisplayLight();
 * @fn      zclSampleLight_UpdateLampLevel
 * @brief   Update lamp level output with gamma compensation
 * @param   level
 * @return  none
  uint16 gammaCorrectedLevel;
  // gamma correct the level
  gammaCorrectedLevel = (uint16) ( pow( ( (float)level / LEVEL_MAX ), (float)GAMMA_VALUE ) * (float)LEVEL_MAX);
  halTimer1SetChannelDuty(WHITE_LED, (uint16)(((uint32)gammaCorrectedLevel*PWM_FULL_DUTY_CYCLE)/LEVEL_MAX) );
#endif
 * @fn      zclSampleLight_DisplayLight
 * @brief   Displays current state of light on LED and also on main display if supported.
 * @param   none
 * @return  none
  if ( zclSampleLight_OnOff == LIGHT_ON & no == 0 )
    DATA_PIN = 0;
    forward = 0;
    backward = 1;
    no = 1;
  else if ( zclSampleLight_OnOff == LIGHT_OFF & no == 1 )
    DATA_PIN = 0;
    forward = 1;
    backward = 0;
    no = 0;
  if (giLightScreenMode == LIGHT_MAINMODE)
    // display current light level
    if ( ( zclSampleLight_LevelCurrentLevel == ATTR_LEVEL_MIN_LEVEL ) &&
         ( zclSampleLight_OnOff == LIGHT_OFF ) )
      HalLcdWriteString( (char *)sLightOff, HAL_LCD_LINE_2 );
    else if ( ( zclSampleLight_LevelCurrentLevel >= ATTR_LEVEL_MAX_LEVEL ) ||
              ( zclSampleLight_LevelCurrentLevel == zclSampleLight_LevelOnLevel ) ||
               ( ( zclSampleLight_LevelOnLevel == ATTR_LEVEL_ON_LEVEL_NO_EFFECT ) &&
                 ( zclSampleLight_LevelCurrentLevel == zclSampleLight_LevelLastLevel ) ) )
      HalLcdWriteString( (char *)sLightOn, HAL_LCD_LINE_2 );
    else    // "    LEVEL ###"
      zclHA_uint8toa( zclSampleLight_LevelCurrentLevel, &sLightLevel[10] );
      HalLcdWriteString( (char *)sLightLevel, HAL_LCD_LINE_2 );
#else
    if ( zclSampleLight_OnOff )
    else
#endif // ZCL_LEVEL_CTRL
 * @fn      zclSampleLight_LcdDisplayMainMode
 * @brief   Called to display the main screen on the LCD.
 * @param   none
 * @return  none
  // display line 1 to indicate NWK status
  if ( zclSampleLight_NwkState == DEV_ZB_COORD )
    zclHA_LcdStatusLine1( ZCL_HA_STATUSLINE_ZC );
  else if ( zclSampleLight_NwkState == DEV_ROUTER )
    zclHA_LcdStatusLine1( ZCL_HA_STATUSLINE_ZR );
  else if ( zclSampleLight_NwkState == DEV_END_DEVICE )
    zclHA_LcdStatusLine1( ZCL_HA_STATUSLINE_ZED );
  // end of line 3 displays permit join status (*)
  if ( gPermitDuration )
    sSwHelp[15] = '*';
  else
    sSwHelp[15] = ' ';
  HalLcdWriteString( (char *)sSwHelp, HAL_LCD_LINE_3 );
 * @fn      zclSampleLight_LcdDisplayHelpMode
 * @brief   Called to display the SW options on the LCD.
 * @param   none
 * @return  none
  HalLcdWriteString( (char *)sSwLight, HAL_LCD_LINE_1 );
  HalLcdWriteString( (char *)sSwEZMode, HAL_LCD_LINE_2 );
 * @fn      zclSampleLight_ProcessIdentifyTimeChange
 * @brief   Called to process any change to the IdentifyTime attribute.
 * @param   none
 * @return  none
    osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_IDENTIFY_TIMEOUT_EVT, 1000 );
    HalLedBlink ( HAL_LED_4, 0xFF, HAL_LED_DEFAULT_DUTY_CYCLE, HAL_LED_DEFAULT_FLASH_TIME );
  else
#ifdef ZCL_EZMODE
    if ( zclSampleLight_IdentifyCommissionState & EZMODE_COMMISSION_OPERATIONAL )
      HalLedSet ( HAL_LED_4, HAL_LED_MODE_ON );
    else
#endif
    osal_stop_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_IDENTIFY_TIMEOUT_EVT );
 * @fn      zclSampleLight_BasicResetCB
 * @brief   Callback from the ZCL General Cluster Library
 *          to set all the Basic Cluster attributes to default values.
 * @param   none
 * @return  none
  NLME_LeaveReq_t leaveReq;
  // Set every field to 0
  osal_memset( &leaveReq, 0, sizeof( NLME_LeaveReq_t ) );
  // This will enable the device to rejoin the network after reset.
  leaveReq.rejoin = TRUE;
  // Set the NV startup option to force a "new" join.
  zgWriteStartupOptions( ZG_STARTUP_SET, ZCD_STARTOPT_DEFAULT_NETWORK_STATE );
  // Leave the network, and reset afterwards
  if ( NLME_LeaveReq( &leaveReq ) != ZSuccess )
    // Couldn't send out leave; prepare to reset anyway
    ZDApp_LeaveReset( FALSE );
 * @fn      zclSampleLight_IdentifyCB
 * @brief   Callback from the ZCL General Cluster Library when
 *          it received an Identity Command for this application.
 * @param   srcAddr - source address and endpoint of the response message
 * @param   identifyTime - the number of seconds to identify yourself
 * @return  none
  zclSampleLight_IdentifyTime = pCmd->identifyTime;
 * @fn      zclSampleLight_IdentifyQueryRspCB
 *          it received an Identity Query Response Command for this application.
 * @param   srcAddr - requestor's address
 * @param   timeout - number of seconds to identify yourself (valid for query response)
 * @return  none
  (void)pRsp;
#ifdef ZCL_EZMODE
    zclEZMode_ActionData_t data;
    data.pIdentifyQueryRsp = pRsp;
    zcl_EZModeAction ( EZMODE_ACTION_IDENTIFY_QUERY_RSP, &data );
#endif
 * @fn      zclSampleLight_OnOffCB
 *          it received an On/Off Command for this application.
 * @param   cmd - COMMAND_ON, COMMAND_OFF or COMMAND_TOGGLE
 * @return  none
  afIncomingMSGPacket_t *pPtr = zcl_getRawAFMsg();
  zclSampleLight_DstAddr.addr.shortAddr = pPtr->srcAddr.addr.shortAddr;
  // Turn on the light
  if ( cmd == COMMAND_ON )
  // Turn off the light
  else if ( cmd == COMMAND_OFF )
    zclSampleLight_OnOff = LIGHT_OFF;
  // Toggle the light
  else if ( cmd == COMMAND_TOGGLE )
    if ( zclSampleLight_OnOff == LIGHT_OFF )
    else
#if ZCL_LEVEL_CTRL
  zclSampleLight_DefaultMove( );
#endif
  zclSampleLight_LcdDisplayUpdate( );
 * @fn      zclSampleLight_TimeRateHelper
 * @brief   Calculate time based on rate, and startup level state machine
 * @param   newLevel - new level for current level
 * @return  diff (directly), zclSampleLight_CurrentLevel32 and zclSampleLight_NewLevel, zclSampleLight_NewLevelUp
  uint32 diff;
  uint32 newLevel32;
  // remember current and new level
  zclSampleLight_NewLevel = newLevel;
  zclSampleLight_CurrentLevel32 = (uint32)1000 * zclSampleLight_LevelCurrentLevel;
  // calculate diff
  newLevel32 = (uint32)1000 * newLevel;
  if ( zclSampleLight_LevelCurrentLevel > newLevel )
    diff = zclSampleLight_CurrentLevel32 - newLevel32;
    zclSampleLight_NewLevelUp = FALSE;  // moving down
  else
    diff = newLevel32 - zclSampleLight_CurrentLevel32;
    zclSampleLight_NewLevelUp = TRUE;   // moving up
  return ( diff );
 * @fn      zclSampleLight_MoveBasedOnRate
 * @param   rate16   - fixed point rate (e.g. 16.123)
 * @return  none
  uint32 diff;
  // determine how much time (in 10ths of seconds) based on the difference and rate
  zclSampleLight_Rate32 = rate;
  diff = zclSampleLight_TimeRateHelper( newLevel );
  zclSampleLight_LevelRemainingTime = diff / rate;
  if ( !zclSampleLight_LevelRemainingTime )
    zclSampleLight_LevelRemainingTime = 1;
  osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_LEVEL_CTRL_EVT, 100 );
 * @fn      zclSampleLight_MoveBasedOnTime
 * @brief   Calculate rate based on time, and startup level state machine
 * @param   time      - in 10ths of seconds
 * @return  none
  uint16 diff;
  // determine rate (in units) based on difference and time
  zclSampleLight_LevelRemainingTime = zclSampleLight_GetTime( newLevel, time );
  zclSampleLight_Rate32 = diff / time;
 * @fn      zclSampleLight_GetTime
 * @brief   Determine amount of time that MoveXXX will take to complete.
 * @param   level = new level to move to
 *          time  = 0xffff=default, or 0x0000-n amount of time in tenths of seconds.
 * @return  none
static uint16 zclSampleLight_GetTime( uint8 level, uint16 time )
  // there is a hiearchy of the amount of time to use for transistioning
  // check each one in turn. If none of defaults are set, then use fastest
  // time possible.
  if ( time == 0xFFFF )
    // use On or Off Transition Time if set (not 0xffff)
    if ( zclSampleLight_OnOff == LIGHT_ON )
      time = zclSampleLight_LevelOffTransitionTime;
    else
      time = zclSampleLight_LevelOnTransitionTime;
    // else use OnOffTransitionTime if set (not 0xffff)
      time = zclSampleLight_LevelOnOffTransitionTime;
    // else as fast as possible
      time = 1;
  if ( !time )
    time = 1; // as fast as possible
  return ( time );
 * @fn      zclSampleLight_DefaultMove
 * @brief   We were turned on/off. Use default time to move to on or off.
 * @param   zclSampleLight_OnOff - must be set prior to calling this function.
 * @return  none
  uint8  newLevel;
  uint32 rate;      // fixed point decimal (3 places, eg. 16.345)
  uint16 time;
  // if moving to on position, move to on level
    if ( zclSampleLight_LevelOnLevel == ATTR_LEVEL_ON_LEVEL_NO_EFFECT )
      // The last Level (before going OFF) should be used)
      newLevel = zclSampleLight_LevelLastLevel;
    else
      newLevel = zclSampleLight_LevelOnLevel;
  else
    newLevel = ATTR_LEVEL_MIN_LEVEL;
      // Save the current Level before going OFF to use it when the light turns ON
      // it should be back to this level
      zclSampleLight_LevelLastLevel = zclSampleLight_LevelCurrentLevel;
    time = 1;
  // calculate rate based on time (int 10ths) for full transition (1-254)
  rate = 255000 / time;    // units per tick, fixed point, 3 decimal places (e.g. 8500 = 8.5 units per tick)
  // start up state machine.
  zclSampleLight_WithOnOff = TRUE;
  zclSampleLight_MoveBasedOnRate( newLevel, rate );
 * @fn      zclSampleLight_AdjustLightLevel
 * @brief   Called each 10th of a second while state machine running
 * @param   none
 * @return  none
  // one tick (10th of a second) less
  if ( zclSampleLight_LevelRemainingTime )
    --zclSampleLight_LevelRemainingTime;
  // no time left, done
  if ( zclSampleLight_LevelRemainingTime == 0)
    zclSampleLight_LevelCurrentLevel = zclSampleLight_NewLevel;
  // still time left, keep increment/decrementing
  else
    if ( zclSampleLight_NewLevelUp )
      zclSampleLight_CurrentLevel32 += zclSampleLight_Rate32;
    else
      zclSampleLight_CurrentLevel32 -= zclSampleLight_Rate32;
    zclSampleLight_LevelCurrentLevel = (uint8)( zclSampleLight_CurrentLevel32 / 1000 );
  zclSampleLight_UpdateLampLevel(zclSampleLight_LevelCurrentLevel);
#endif
  // also affect on/off
  if ( zclSampleLight_WithOnOff )
    if ( zclSampleLight_LevelCurrentLevel > ATTR_LEVEL_MIN_LEVEL )
      ENABLE_LAMP;
#endif
    else
      DISABLE_LAMP;
#endif
  // display light level as we go
  zclSampleLight_DisplayLight( );
  // keep ticking away
 * @fn      zclSampleLight_LevelControlMoveToLevelCB
 *          it received a LevelControlMoveToLevel Command for this application.
 * @param   pCmd - ZigBee command parameters
 * @return  none
  zclSampleLight_WithOnOff = pCmd->withOnOff;
  zclSampleLight_MoveBasedOnTime( pCmd->level, pCmd->transitionTime );
 * @fn      zclSampleLight_LevelControlMoveCB
 *          it received a LevelControlMove Command for this application.
 * @return  none
  uint8 newLevel;
  uint32 rate;
  // convert rate from units per second to units per tick (10ths of seconds)
  // and move at that right up or down
  if ( pCmd->moveMode == LEVEL_MOVE_UP )
    newLevel = ATTR_LEVEL_MAX_LEVEL;  // fully on
  else
    newLevel = ATTR_LEVEL_MIN_LEVEL; // fully off
  rate = (uint32)100 * pCmd->rate;
 * @fn      zclSampleLight_LevelControlStepCB
 * @return  none
  uint8 newLevel;
  // determine new level, but don't exceed boundaries
  if ( pCmd->stepMode == LEVEL_MOVE_UP )
    if ( (uint16)zclSampleLight_LevelCurrentLevel + pCmd->amount > ATTR_LEVEL_MAX_LEVEL )
    else
      newLevel = zclSampleLight_LevelCurrentLevel + pCmd->amount;
  else
    if ( pCmd->amount >= zclSampleLight_LevelCurrentLevel )
    else
      newLevel = zclSampleLight_LevelCurrentLevel - pCmd->amount;
  // move to the new level
  zclSampleLight_MoveBasedOnTime( newLevel, pCmd->transitionTime );
 * @fn      zclSampleLight_LevelControlStopCB
 *          it received an Level Control Stop Command for this application.
 * @return  none
  // stop immediately
  osal_stop_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_LEVEL_CTRL_EVT );
  zclSampleLight_LevelRemainingTime = 0;
#endif
 *  Functions for processing ZCL Foundation incoming Command/Response messages
 * @fn      zclSampleLight_ProcessIncomingMsg
 * @brief   Process ZCL Foundation incoming message
 * @param   pInMsg - pointer to the received message
 * @return  none
static void zclSampleLight_ProcessIncomingMsg( zclIncomingMsg_t *pInMsg )
  switch ( pInMsg->zclHdr.commandID )
#ifdef ZCL_READ
    case ZCL_CMD_READ_RSP:
      zclSampleLight_ProcessInReadRspCmd( pInMsg );
      break;
#endif
#ifdef ZCL_WRITE
    case ZCL_CMD_WRITE_RSP:
      zclSampleLight_ProcessInWriteRspCmd( pInMsg );
      break;
#endif
#ifdef ZCL_REPORT
    // Attribute Reporting implementation should be added here
    case ZCL_CMD_CONFIG_REPORT:
      // zclSampleLight_ProcessInConfigReportCmd( pInMsg );
      break;
    case ZCL_CMD_CONFIG_REPORT_RSP:
      // zclSampleLight_ProcessInConfigReportRspCmd( pInMsg );
      break;
    case ZCL_CMD_READ_REPORT_CFG:
      // zclSampleLight_ProcessInReadReportCfgCmd( pInMsg );
      break;
    case ZCL_CMD_READ_REPORT_CFG_RSP:
      // zclSampleLight_ProcessInReadReportCfgRspCmd( pInMsg );
      break;
    case ZCL_CMD_REPORT:
      // zclSampleLight_ProcessInReportCmd( pInMsg );
      break;
#endif
    case ZCL_CMD_DEFAULT_RSP:
      zclSampleLight_ProcessInDefaultRspCmd( pInMsg );
      break;
#ifdef ZCL_DISCOVER
    case ZCL_CMD_DISCOVER_CMDS_RECEIVED_RSP:
      zclSampleLight_ProcessInDiscCmdsRspCmd( pInMsg );
      break;
    case ZCL_CMD_DISCOVER_CMDS_GEN_RSP:
      break;
    case ZCL_CMD_DISCOVER_ATTRS_RSP:
      zclSampleLight_ProcessInDiscAttrsRspCmd( pInMsg );
      break;
    case ZCL_CMD_DISCOVER_ATTRS_EXT_RSP:
      zclSampleLight_ProcessInDiscAttrsExtRspCmd( pInMsg );
      break;
#endif
    default:
      break;
  if ( pInMsg->attrCmd )
    osal_mem_free( pInMsg->attrCmd );
#ifdef ZCL_READ
 * @fn      zclSampleLight_ProcessInReadRspCmd
 * @brief   Process the "Profile" Read Response Command
 * @param   pInMsg - incoming message to process
 * @return  none
  zclReadRspCmd_t *readRspCmd;
  uint8 i;
  readRspCmd = (zclReadRspCmd_t *)pInMsg->attrCmd;
  for (i = 0; i < readRspCmd->numAttr; i++)
    // Notify the originator of the results of the original read attributes
    // attempt and, for each successfull request, the value of the requested
    // attribute
  return ( TRUE );
#endif // ZCL_READ
#ifdef ZCL_WRITE
 * @fn      zclSampleLight_ProcessInWriteRspCmd
 * @brief   Process the "Profile" Write Response Command
 * @return  none
  zclWriteRspCmd_t *writeRspCmd;
  uint8 i;
  writeRspCmd = (zclWriteRspCmd_t *)pInMsg->attrCmd;
  for ( i = 0; i < writeRspCmd->numAttr; i++ )
    // Notify the device of the results of the its original write attributes
    // command.
  return ( TRUE );
#endif // ZCL_WRITE
 * @fn      zclSampleLight_ProcessInDefaultRspCmd
 * @brief   Process the "Profile" Default Response Command
 * @return  none
  // zclDefaultRspCmd_t *defaultRspCmd = (zclDefaultRspCmd_t *)pInMsg->attrCmd;
  // Device is notified of the Default Response command.
  (void)pInMsg;
  return ( TRUE );
#ifdef ZCL_DISCOVER
 * @fn      zclSampleLight_ProcessInDiscCmdsRspCmd
 * @brief   Process the Discover Commands Response Command
 * @return  none
  zclDiscoverCmdsCmdRsp_t *discoverRspCmd;
  uint8 i;
  discoverRspCmd = (zclDiscoverCmdsCmdRsp_t *)pInMsg->attrCmd;
  for ( i = 0; i < discoverRspCmd->numCmd; i++ )
    // Device is notified of the result of its attribute discovery command.
  return ( TRUE );
 * @fn      zclSampleLight_ProcessInDiscAttrsRspCmd
 * @brief   Process the "Profile" Discover Attributes Response Command
 * @return  none
  zclDiscoverAttrsRspCmd_t *discoverRspCmd;
  uint8 i;
  discoverRspCmd = (zclDiscoverAttrsRspCmd_t *)pInMsg->attrCmd;
  for ( i = 0; i < discoverRspCmd->numAttr; i++ )
  return ( TRUE );
 * @fn      zclSampleLight_ProcessInDiscAttrsExtRspCmd
 * @brief   Process the "Profile" Discover Attributes Extended Response Command
 * @return  none
  zclDiscoverAttrsExtRsp_t *discoverRspCmd;
  uint8 i;
  discoverRspCmd = (zclDiscoverAttrsExtRsp_t *)pInMsg->attrCmd;
  return ( TRUE );
#endif // ZCL_DISCOVER
#if ZCL_EZMODE
 * @fn      zclSampleLight_ProcessZDOMsgs
 * @brief   Called when this node receives a ZDO/ZDP response.
 * @param   none
 * @return  status
  ZDO_MatchDescRsp_t *pMatchDescRsp;
  // Let EZ-Mode know of the Simple Descriptor Response
  if ( pMsg->clusterID == Match_Desc_rsp )
    pMatchDescRsp = ZDO_ParseEPListRsp( pMsg );
    data.pMatchDescRsp = pMatchDescRsp;
    zcl_EZModeAction( EZMODE_ACTION_MATCH_DESC_RSP, &data );
    osal_mem_free( pMatchDescRsp );
 * @fn      zclSampleLight_EZModeCB
 * @brief   The Application is informed of events. This can be used to show on the UI what is
*           going on during EZ-Mode steering/finding/binding.
 * @param   state - an
 * @return  none
  char *pStr;
  uint8 err;
#endif
  // time to go into identify mode
  if ( state == EZMODE_STATE_IDENTIFYING )
    HalLcdWriteString( "EZMode", HAL_LCD_LINE_2 );
#endif
    zclSampleLight_IdentifyTime = ( EZMODE_TIME / 1000 );  // convert to seconds
  // autoclosing, show what happened (success, cancelled, etc...)
  if( state == EZMODE_STATE_AUTOCLOSE )
    pStr = NULL;
    err = pData->sAutoClose.err;
    if ( err == EZMODE_ERR_SUCCESS )
      pStr = "EZMode: Success";
    else if ( err == EZMODE_ERR_NOMATCH )
      pStr = "EZMode: NoMatch"; // not a match made in heaven
    if ( pStr )
      if ( giLightScreenMode == LIGHT_MAINMODE )
        HalLcdWriteString ( pStr, HAL_LCD_LINE_2 );
#endif
  // finished, either show DstAddr/EP, or nothing (depending on success or not)
  if( state == EZMODE_STATE_FINISH )
    // turn off identify mode
    zclSampleLight_IdentifyTime = 0;
    // if successful, inform user which nwkaddr/ep we bound to
    pStr = NULL;
    err = pData->sFinish.err;
    if( err == EZMODE_ERR_SUCCESS )
      // already stated on autoclose
    else if ( err == EZMODE_ERR_CANCELLED )
      pStr = "EZMode: Cancel";
    else if ( err == EZMODE_ERR_BAD_PARAMETER )
      pStr = "EZMode: BadParm";
    else if ( err == EZMODE_ERR_TIMEDOUT )
      pStr = "EZMode: TimeOut";
    if ( pStr )
#endif
    // show main UI screen 3 seconds after binding
    osal_start_timerEx( zclSampleLight_TaskID, SAMPLELIGHT_MAIN_SCREEN_EVT, 3000 );
