Other Parts Discussed in Thread: Z-STACK,
The End device is transmitting nwk address request.
I am testing the coordinator on existing router & end device.
Although the end device is sending a nwk address request, coordinator does not nwk address respond.
The attached file questionFor_NwkAddrRsp.cubx.(Ubiqua tool)
Stack : Z-Stack Home 1.2.2a.44539
Project : TI SampleThermostat(Coordinator), Silicon labs(Router, End device)
PAN Configuration and Test Procedure :
1. Coordinator On & Pan configuration
2. Router On & binding to Coordinator
3. End device On & binding to Coordinator
4. The End device sends the Temp & Humidity data to the Coordinator at 10 seconds intervals.
5. Coordinator Off
6. The End device is intended to send sensor data to the Coordinator via Router.(Coordinator Off)
7. End device is sending a nwk address request
8. Coordinator On(NV_RESTORE defined)
9. The code is sending the response.(attached file : QuestionFor_NwkAddrRsp.png)
10. However, the packet on ubquia appears to be broadcast by the Coordinator.
What should I add to the project for response?
