CC2650: Change Manufactorer Code of Node Descriptor
Part Number: CC2650
I'm using the example of the Temperature Sensor trying to find out how to change the Manufactorer Code of the Node Descriptor.
I only found that it's set to 0x0000 in AF.h but it doesn't seem to change the node descriptor and also I don't intend to change the stack fies.
How should the node descriptor / manufacturer code be changed?
Thanks!
