Other Parts Discussed in Thread: CC2530, CC2630, Z-STACK, CC2650,
Hi everyone,
I just received LAUNCHHXL-CC2650 kit. I am new to working with this launchpad. So, I start digging into its architecture &functionality. My goal is to make it as a Zigbee End device (CC2630) which will communicate with the coordinator (CC2530). I've followed some basic steps to start with this, which are described below:
IDE Used: IAR EWARM 7.40.2
Z-stack: Z-stack_Home_1.2.2a
I have followed these wiki instructions. I did everything that is written there but when I am compiling the Program (SampleSwitch), I am getting the errors
Building configuration: SampleSwitch - CC2650LP
Updating build tree...
Performing Pre-Build Action
Board.c
Warning[Pe047]: incompatible redefinition of macro "Board_SPI0_MISO" (declared at line 107 of C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.h 97
"C:/ti/tirtos_simplelink_2_11_01_09/packages/ti/boards/SensorTag/CC26XXST_0120/Board.h")
Warning[Pe047]: incompatible redefinition of macro "Board_SPI0_MOSI" (declared at line 108 of C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.h 98
Warning[Pe047]: incompatible redefinition of macro "Board_SPI0_CLK" (declared at line 106 of C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.h 99
Warning[Pe047]: incompatible redefinition of macro "Board_I2C0_SCL0" (declared at line 96 of C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.h 107
Warning[Pe047]: incompatible redefinition of macro "Board_SPI_FLASH_CS" (declared at line 101 of C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.h 111
Error[Pe1445]: invalid redefinition of enum "CC2650_I2CName" (declared at line 156 of C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.h 162
Error[Pe101]: "CC2650_I2C0" has already been declared in the current scope (at line 157 of C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.h 163
Error[Pe101]: "CC2650_I2CCOUNT" has already been declared in the current scope (at line 158 of C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.h 165
Error[Pe256]: invalid redeclaration of type name "CC2650_I2CName" (declared at line 159 of C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.h 166
Error[Pe1445]: invalid redefinition of enum "CC2650_CryptoName" (declared at line 67 of "C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\ C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.h 172
HomeAutomation\SampleSwitch_LP\CC26xx\..\..\..\common\CC26xx\LaunchPad\Board.h")
Error[Pe101]: "CC2650_CRYPTO0" has already been declared in the current scope (at line 69 of "C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\ C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.h 173
Error[Pe101]: "CC2650_CRYPTOCOUNT" has already been declared in the current scope (at line 69 of "C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\ C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.h 175
zstack\HomeAutomation\SampleSwitch_LP\CC26xx\..\..\..\common\CC26xx\LaunchPad\Board.h")
Error[Pe256]: invalid redeclaration of type name "CC2650_CryptoName" (declared at line 70 of "C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\ C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.h 176
Error[Pe1445]: invalid redefinition of enum "CC2650_SPIName" (declared at line 165 of C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.h 183
Error[Pe101]: "CC2650_SPI0" has already been declared in the current scope (at line 166 of C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.h 184
Error[Pe101]: "CC2650_SPICOUNT" has already been declared in the current scope (at line 167 of C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.h 187
Error[Pe256]: invalid redeclaration of type name "CC2650_SPIName" (declared at line 168 of C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.h 188
Error[Pe1445]: invalid redefinition of enum "CC2650_UARTName" (declared at line 174 of C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.h 194
Error[Pe101]: "CC2650_UART0" has already been declared in the current scope (at line 175 of C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.h 195
Error[Pe101]: "CC2650_UARTCOUNT" has already been declared in the current scope (at line 176 of C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.h 197
Error[Pe256]: invalid redeclaration of type name "CC2650_UARTName" (declared at line 177 of C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.h 198
Error[Pe1445]: invalid redefinition of enum "CC2650_UdmaName" (declared at line 183 of C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.h 204
Error[Pe101]: "CC2650_UDMA0" has already been declared in the current scope (at line 184 of C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.h 205
Error[Pe101]: "CC2650_UDMACOUNT" has already been declared in the current scope (at line 185 of C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.h 207
Error[Pe256]: invalid redeclaration of type name "CC2650_UdmaName" (declared at line 186 of C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.h 208
Error[Pe136]: struct "UARTCC26XX_HWAttrs" has no field "intPriority" C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.c 98
Error[Pe136]: struct "UDMACC26XX_HWAttrs" has no field "intPriority" C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.c 140
Error[Pe136]: struct "SPICC26XX_HWAttrs" has no field "intPriority" C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.c 176
Error[Pe146]: too many initializer values C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.c 186
Error[Pe136]: struct "I2CCC26XX_HWAttrs" has no field "intPriority" C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.c 242
Error[Pe136]: struct "CryptoCC26XX_HWAttrs" has no field "intPriority" C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\LaunchPad\CC2650LP\Board.c 283
Error while running C/C++ Compiler
Total number of errors: 26
Total number of warnings: 5
But When I am compiling the unchanged SampleSwitch Program, I am successfully able to compile. Please guide me to successful compiling it and I am not able to erase the flash through IAR IDE, it is showing me an error:
then I tried updating the firmware and changing the serial number then I was getting another error of wrong routing. Please guide me with the proper approach on how can I resolve this issue?
Priya
