CC2530: Association Request is not sent
Part Number: CC2530
CC2530 I am working with application based on TIMAC stack.
Trying to send Association Request explicitly from RFD/FFD device in order to join it to another one FFD device configured as a coordinator .
Association request is not sent out from MAC, dint see the association request log in sniffer.
and association confirm signal having the response status 0x92.
Could you please let us know what might be the problem.
Babu
  • Hi Babu,
    Can you please specify the example code you are starting from, take a snapshot or code excerpt of the API involved to attempt association, and provide a sniffer log?
    Ryan
  • Hi Ryan,
    Please find below association request parameter details,
    logical_channel = 11;
    Channel page = 0;
    coord_addr_mode = 02;
    coord_addr_short_Addr = 0x0000;
    coord_pan_id=0xcccc;
    capability=0x80;
    sec = 0x00;
    On Association confirm signal, getting the value
    short address: 0xFFFF
    status : 0x92
    Ramesh
  • As per spec, If the coordinator was not able to associate the device to its PAN, the Short Address field shall be set to
    0xffff. What could be the reason for not associate ?
  • SQLite format 3@  	-��
    �.j��
    #�.v�KtableNodesNodes	CREATE TABLE [Nodes] ([Id] Integer PRIMARY KEY AUTOINCREMENT, [X] REAL, [Y] REAL, [Label] TEXT){�EtableAddressesAddressesCREATE TABLE [Addresses] ([Id] Integer PRIMARY KEY AUTOINCREMENT, [Long] TEXT, [Short] TEXT)j�7tableKeysKeysCREATE TABLE [Keys] ([Id] Integer PRIMARY KEY AUTOINCREMENT, [Key] BLOB, [Type] TEXT)P++Ytablesqlite_sequencesqlite_sequenceCREATE TABLE sqlite_sequence(name,seq)�q�9tablePacketsPacketsCREATE TABLE [Packets] ([Id] Integer PRIMARY KEY AUTOINCREMENT, [Raw] BLOB, [Stack] INTEGER, [Channel] INTEGER, [Timestamp] REAL, [TimeDelta] REAL, [LQI] INTEGER, [RSSI] INTEGER, [Comment] TEXT, [DeviceId] INTEGER)��{tableDevicesDevicesCREATE TABLE [Devices] ([Id] Integer PRIMARY KEY, [Alias] TEXT, [Description] TEXT, [Stack] INTEGER, [Channel] INTEGER)[�	tableMetadataMetadataCREATE TABLE [Metadata] ([Key] Text PRIMARY KEY, [Value] TEXT)/Cindexsqlite_autoindex_Metadata_1Metadata
    	����~<��$	GGraphicViewIsActiveBackgroundTrue0!SSystemInfoMicrosoft Windows NT 6.3.9600.0 [8]Localeen-IN+SavedWithUbiqua/2.2.0161@!sComputerId651FEBF3421E59EFBF-710FACAA4E8076000BD96D746837A4EC!FileFormat2*KTimeZone(UTC+06:00) India Standard Time/SavedAt1530427912.445773'GSavedByBabu B <babub.subs@gmail.com>
    	t��t������!GGraphicViewIsActiveBackground	!SystemInfo
    Locale
    SavedWith!ComputerId!FileFormatTimeZoneSavedAt
    	SavedBy
    ��JOQUSB8285: Texas Instruments CC2531Texas Instruments CC2531 [USB8285]
    	���Z��C
    q
    +��Y��e
    N
    	�DF#
    	A�h����	���!q�K`��11 (0x0B), A��K�g@.!łU�6�DF#
    	A�g����	���!q�K`��11 (0x0B), A��{�`�@. :2*�w�DF#
    	A�f����	���!q�K`��11 (0x0B), A��w�Yq@. �V.	��DF#
    	A�e����	���!q�K`��11 (0x0B), A��s�>�@."����DF#
    	A�d����	���!q�K`��11 (0x0B), A��p:�3?����>y�CD#
    	������"�!q�K�����11 (0x0B), A��o�W�?odIU�g{�3 #
    	������11 (0x0B), A��o�3@+�~�M3���1 #
    	c������11 (0x0B), A��lU�X@�*c�P�DF#
    	A������	��!q�K`��11 (0x0B), A��jw��@. O*�~Z�DF#
    	A������	��!q�K`��11 (0x0B), A��f���@.���
    x�DF#
    	A������	��
    !q�K`��11 (0x0B), A��b�X@. 3�3�D
    F#
    	A������	��!q�K`��11 (0x0B), A��_+��@.W����DF#
    	A������	��!q�K`��11 (0x0B), A��[g��@. q�?9��DF#
    	A������	��
    !q�K`��11 (0x0B), A��W���@.:Wꢡ�D
    F#
    	A������	��	!q�K`��11 (0x0B), A��Sߪa@. ��Kj�D	F#
    	A������	��!q�K`��11 (0x0B), A��P��@.�*w���DF#
    	A������	��!q�K`��11 (0x0B), A��LW��@. Ï6iI�DF#
    	A������	��!q�K`��11 (0x0B), A��H��-@. 8L`�DF#
    	A������	��!q�K`��11 (0x0B), A��Dϐ*@.���~��DF#
    	A������	��!q�K`��11 (0x0B), A��A��@$�u�lv�CD#
    	������"�!q�K�����11 (0x0B), A��>k�?jT���R�3 #
    	������11 (0x0B), A��>k��@@�����DF#
    	A������	��!q�K`��11 (0x0B), A��=G��@/)�]�23�) #
    	�������11 (0x0B), A��9b|R�
    ���	NodesPackets
    ��0x0000
    Beacon_Request_Response_July01.cubx.tar.gzhttps://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/158/Beacon_5F00_Request_5F00_Response_5F00_July01.cubx.7z
  • Sniffer logs uploaded.
  • Hi Ryan,
    Found the reason for not sending the Association request out of MAC.
    Due to MAC is busy at particular moment , request is not sent to the coordinator.
    Issue is resolved with adding delay before sending ass'n request.
    Now I am facing one more issue.
    After sending the device announcement, getting the network status - address conflict from coordinator.
    any specific reason for this behavior ??
    Babu
  • Hi Ryan,
    After updating the  extended address, address conflict issue got resolved.
    Babu
