I had 6lbr working (as in I could get to [bbbb::100] from Chrome on my Windows PC, but something happened. I tried to rebuild from scratch, but it still isn't working. I think it might be to do with my NAT64? I am posting my nvm.dat file below. Please help!
debian@beaglebone:~$ sudo /usr/lib/6lbr/bin/nvm_tool --print /etc/6lbr/nvm.dat
Reading nvm file '/etc/6lbr/nvm.dat'
Channel : 25
PAN ID : abcd
WSN network prefix : fd00::
WSN network prefix length : 64
WSN IP address : fd00::100
WSN accept RA : False
WSN IP address autoconf : True
WSN 6LoWPAN context 0 : fd00::
DNS server : ::
Eth network prefix : bbbb::
Eth network prefix length : 64
Eth IP address : bbbb::100
Eth default router : ::
Eth IP address autoconf : False
RA daemon : True
RA router lifetime : 0
RA maximum interval : 600
RA minimum interval : 200
RA minimum delay : 3
RA PIO enabled : True
RA prefix valid lifetime : 86400
RA prefix preferred lifetime : 14400
RA RIO enabled : True
RA RIO lifetime : 1800
RPL instance ID : 30
RPL DODAG ID manual : False
RPL DODAG ID : ::
RPL DODAG ID global : True
RPL Preference : 0
RPL version ID : : 247
RPL DIO interval doubling : 8
RPL DIO minimum interval : 12
RPL DIO redundancy : 10
RPL default lifetime : 30
RPL maximum rank increase : 1792
RPL minimum rank increment : 256
RPL lifetime unit : 256
RPL Non Storing : False
RPL DAO ACK : True
RPL DAO ACK local repair : False
DIO triggers route refresh : False
RPL DAO Check Path Sequence : False
MAC layer : 1
Multicast engine : 0
Security layer : 0
Security level : 6
Network key : 0:1:2:3:4:5:6:7:8:9:a:b:c:d:e:f
Noncoresec anti-replay enabled (Legacy) : False
Noncoresec anti-replay workaround (Legacy) : False
Filter unknown nodes : False
Disable NUD : True
NAT 64 Enabled : False
NAT 64 DHCP Enabled : False
NAT 64 static port mapping Enabled : False
NAT 64 RFC-6052 prefix : False
NAT 64 address : 172.16.0.2
NAT 64 netmask : 255.255.255.0
NAT 64 gateway : 172.16.0.1
First CoAP port : 20000
First HTTP port : 25000
Local address rewrite : True
Smart Multi BR : False
Webserver configuration page disabled : False
Webserver enabled : True
Webserver port : 80
UDP Server enabled : True
UDP Server port : 3000
CoAP server enabled : True
DNS Proxy enabled : True
NVM Proxy port : 4000
