CC2530: ERROR e104
Part Number: CC2530
Other Parts Discussed in Thread: Z-STACK, REMOTI
I got the following error when compiling the z-stack code on IAR Workbench, can someone suggest what changes I need to do to eliminate the error
Error[e104]: Failed to fit all segments into specified ranges. Problem discovered in segment XDATA_N. Unable to place 2 block(s) (0xc02 byte(s) total) in 0xbc3 byte(s) of memory. The problem occurred while processing the segment placement command "-P(XDATA)XDATA_N=_XDATA_START-_XDATA_END", where at the moment of placement the available memory ranges were "XDATA:133d-1eff"
Suhrith
