Other Parts Discussed in Thread: Z-STACK
I want to transmit a constant value from my end device to my coordinator node continuously. how can I do that? (not discrete)
I use Z-stack3.0.1, IAR compiler and temperature + thermostat sample app.
If you want to transmit the same value, once the device gets a response from the coordinator, it can send another data packet.
Also, you may want to consider using a device with its receiver always on (either a router or an end device with RFD_RCVC_ALWAYS_ON == TRUE).
Toby
