Other Parts Discussed in Thread: CC1352P,
Hi Team,
We have a customer experiencing an error while doing the example for creating a simple LED toggling task using Sensor Controller Studio below:
As Document mentioned.The task tester should return Syntax error or unknown identifier(s)in the execution code.
but the customer is getting error in [Initialization code]. So she cannot proceed to the next step.
And...
When she added the Data structure member it shows Error: 2 : Syntax Error or unknown identifier(s).
The customer tried to simulate again (as per the second response). The customer have cleared the Bug which got before. Now, she got another bug while connecting the device.
Error: System CPU startup code failed. This may be due to incorrect target chip selection:
Let us know what is the probable cause of error.
The customer is just trying to do a tutorial for Blinking an LED using LAUNCHXL-CC1352P.
If you have an example for CCS for LED blinking using this EVM. This is a great help also.
Thanks!
Jonathan
