Part Number: CC1352P
Hello
I request a design review for CC1352P
Use only Zigbee mode.ForReview_ZBP-1000-V01_18.pdf
Best regards
Hello
- Why are X32K-Q1/X32K-Q2 connected to the RF pins through a not mounted resistor?
- Component sizes: It looks like you are using different component values in the RF paths than used in:
. Note that if you are doing a design that uses 0402 components you should follow a reference design that uses the same component size.
- Note that if you plan to power the PA from VDDR, the optimal 10 dBm BOM is different from the 20 dBm BOM. (
