Sometimes a Zigbee node can support more than one endpoint with different function. So "ZCL handler external function" is better to can be proceed by different endpoint. I have fix zcl_port file to support this application.
/****************************************************************************** Filename: zcl_port.c Revised: $Date: 2015-02-12 12:55:11 -0800 (Thu, 12 Feb 2015) $ Revision: $Revision: 42532 $ Description: This file contains the ZCL porting layer. Copyright (c) 2019, Texas Instruments Incorporated All rights reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met: * Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer. * Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution. * Neither the name of Texas Instruments Incorporated nor the names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission. THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. ******************************************************************************/ /********************************************************************* * INCLUDES */ #include <xdc/std.h> #include <xdc/runtime/Error.h> #include <xdc/runtime/System.h> #include <ti/sysbios/BIOS.h> #include <ti/sysbios/knl/Clock.h> #include <ti/sysbios/knl/Semaphore.h> #include <ti/drivers/Power.h> #include <ti/drivers/power/PowerCC26XX.h> #include <string.h> #include <inc/hw_ints.h> #include "zstackapi.h" #include "zcl.h" #include "zcl_general.h" #include "zcl_port.h" #include "bdb_reporting.h" #include "rom_jt_154.h" #include "zglobals.h" /********************************************************************* * MACROS */ /********************************************************************* * CONSTANTS */ #define EXT_ADDR_LEN 8 /********************************************************************* * TYPEDEFS */ typedef struct { uint8_t entity; endPointDesc_t *pEpDesc; #if defined (ZCL_SCENES) zclGeneral_Scene_t scene; #endif } zclPort_entityEPDesc_t; #if defined (ZCL_SCENES) // Scene NV types typedef struct zclGenSceneNVItem { uint8_t endpoint; zclGeneral_Scene_t scene; }zclGenSceneNVItem_t; #endif // multiple endpoint for ZCL handler external, added by luoyiming 2020-02-08 typedef struct { void *next; uint8_t endpoint; zclport_pFnZclHandleExternal pfn; } zclHandleExternalList_t; /********************************************************************* * GLOBAL VARIABLES */ /********************************************************************* * EXTERNAL VARIABLES */ /********************************************************************* * EXTERNAL FUNCTIONS */ /********************************************************************* * LOCAL VARIABLES */ static NVINTF_nvFuncts_t *pfnZclPortNV = NULL; #if defined (ZCL_SCENES) static uint16_t zclSceneNVID = ZCL_PORT_SCENE_TABLE_NV_ID; #endif #if defined (ZCL_GROUPS) static aps_Group_t foundGrp; #endif static zclPort_entityEPDesc_t entityEPDescs[MAX_SUPPORTED_ENDPOINTS] = {0}; static zstack_sysNwkInfoReadRsp_t nwkInfo = { 0xFFFE, { 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF }, zstack_DevState_HOLD, 0xFFFF, { 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF }, 0xFFFE, { 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF }, { 0, 0, 0 }, 0 }; #if defined (ZCL_SCENES) static uint8_t lastFindSceneEndpoint = 0xFF; #endif // Function pointer for applications to ZCL Handle External // added multiple endpoint processing by luoyiming at 2020-02-08 zclHandleExternalList_t *zclHandleExternalList = NULL; /********************************************************************* * LOCAL FUNCTIONS */ static void convertTxOptions(zstack_TransOptions_t *pOptions, uint8_t options); endPointDesc_t *zcl_afFindEndPointDesc(uint8_t EndPoint); // fixed by luoyiming 2020-02-08 uint8_t zclPortFindEntity(uint8_t EndPoint); /********************************************************************* * PUBLIC FUNCTIONS *********************************************************************/ /********************************************************************* * API Functions *********************************************************************/ /** * Register an AF Endpoint. This is needed by the ZCL code * to find an AF endpoint descriptor. * * Public function defined in zcl_port.h */ bool zclport_registerEndpoint(uint8_t entity, endPointDesc_t *pEpDesc) { int x; // don't register same endpoint repeatedly, fixed by luoyiming 2020-02-08 if ( zcl_afFindEndPointDesc( pEpDesc->endPoint ) ) { return(false); } for(x = 0; x < MAX_SUPPORTED_ENDPOINTS; x++) { if(entityEPDescs[x].pEpDesc == NULL) { zstack_afRegisterReq_t regReq = {0}; zstack_SimpleDescriptor_t simpleDesc; // Save information to local table entityEPDescs[x].entity = entity; entityEPDescs[x].pEpDesc = pEpDesc; // Register an endpoint with the stack thread simpleDesc.endpoint = pEpDesc->endPoint; simpleDesc.profileID = pEpDesc->simpleDesc->AppProfId; simpleDesc.deviceID = pEpDesc->simpleDesc->AppDeviceId; simpleDesc.deviceVer = pEpDesc->simpleDesc->AppDevVer; simpleDesc.n_inputClusters = pEpDesc->simpleDesc->AppNumInClusters; simpleDesc.pInputClusters = pEpDesc->simpleDesc->pAppInClusterList; simpleDesc.n_outputClusters = pEpDesc->simpleDesc->AppNumOutClusters; simpleDesc.pOutputClusters = pEpDesc->simpleDesc->pAppOutClusterList; regReq.endpoint = pEpDesc->endPoint; regReq.pSimpleDesc = &simpleDesc; regReq.latencyReq = zstack_NetworkLatency_NO_LATENCY_REQS; (void)Zstackapi_AfRegisterReq(entity, ®Req); return(true); } } return(false); } /** * Call to register the functions pointers for the NV driver. * * Public function defined in zcl_port.h */ void zclport_registerNV(NVINTF_nvFuncts_t *pfnNV, uint16_t sceneNVID) { pfnZclPortNV = pfnNV; #if defined (ZCL_SCENES) zclSceneNVID = sceneNVID; #endif } /** * Call to register a function pointer to handle zcl_HandleExternal() messages. * Added multiple endpoint processing by luoyiming at 2020-02-08. * * Public function defined in zcl_port.h */ bool zclport_registerZclHandleExternal( uint8_t endpoint, zclport_pFnZclHandleExternal pfn ) { zclHandleExternalList_t *find = zclHandleExternalList; zclHandleExternalList_t *tail = NULL; // If endpoint is valid, added by luoyiming 2020-02-08 if ( zcl_afFindEndPointDesc( endpoint ) == NULL ) { return false; } // match if there be same endpoint and find tail item, fixed by luoyiming 2020-02-08 while ( find ) { if ( find->endpoint == endpoint ) { find->pfn = pfn; return true; } if ( find->next == NULL ) { tail = find; } find = find->next; } // add new item, fixed by luoyiming 2020-02-08 zclHandleExternalList_t *newItem = zcl_mem_alloc( sizeof(zclHandleExternalList_t) ); if ( newItem ) { newItem->next = NULL; newItem->endpoint = endpoint; newItem->pfn = pfn; if ( zclHandleExternalList == NULL ) { zclHandleExternalList = newItem; } else { tail->next = newItem; } return true; } return false; } /** * Call to get Device Information. * * Public function defined in zcl_port.h */ zstack_sysNwkInfoReadRsp_t *zclport_getDeviceInfo(uint8_t entity) { Zstackapi_sysNwkInfoReadReq(entity, &nwkInfo); return(&nwkInfo); } /** * Determines if the device is already part of a network by asking the * stack thread. * * Public function defined in zcl_port.h */ bool zclport_isAlreadyPartOfNetwork(uint8_t entity) { zstack_sysConfigReadReq_t readReq = {0}; zstack_sysConfigReadRsp_t readRsp = {0}; // Ask if the device is already part of a network readReq.devPartOfNetwork = true; (void)Zstackapi_sysConfigReadReq(entity, &readReq, &readRsp); return(readRsp.devPartOfNetwork); } /** * If the NV item does not already exist, it is created and * initialized with the data passed to the function, if any. * * Public function defined in zcl_port.h */ uint8_t zclport_initializeNVItem(uint16_t id, uint16_t subId, uint16_t len, void *buf) { if(pfnZclPortNV && pfnZclPortNV->createItem) { uint32_t nvLen = 0; NVINTF_itemID_t nvId; nvId.systemID = NVINTF_SYSID_APP; nvId.itemID = (uint16_t)id; nvId.subID = (uint16_t)subId; if(pfnZclPortNV->getItemLen) { nvLen = pfnZclPortNV->getItemLen(nvId); } if(nvLen == len) { // Already exists and length is good return(SUCCESS); } if(pfnZclPortNV->createItem(nvId, len, buf) == NVINTF_FAILURE) { // Operation failed return(NV_OPER_FAILED); } } // NV was created return(NV_ITEM_UNINIT); } /** * Write a data item to NV. Function can write an entire item to NV or * an element of an item by indexing into the item with an offset. * * Public function defined in zcl_port.h */ uint8_t zclport_writeNV(uint16_t id, uint16_t subId, uint16_t len, void *buf) { uint8_t rtrn = SUCCESS; if(pfnZclPortNV && pfnZclPortNV->writeItem) { uint32_t nvLen = 0; NVINTF_itemID_t nvId; nvId.systemID = NVINTF_SYSID_APP; nvId.itemID = (uint16_t)id; nvId.subID = (uint16_t)subId; if(pfnZclPortNV->getItemLen) { nvLen = pfnZclPortNV->getItemLen(nvId); } if(nvLen > 0) { if(pfnZclPortNV->writeItem(nvId, len, buf) == NVINTF_FAILURE) { rtrn = NV_OPER_FAILED; } } else { rtrn = NV_ITEM_UNINIT; } } return rtrn; } /** * Read data from NV. This function can be used to read an entire item * from NV or an element of an item by indexing into the item with an * offset. Read data is copied into buf. * * Public function defined in zcl_port.h */ uint8_t zclport_readNV(uint16_t id, uint16_t subId, uint16_t ndx, uint16_t len, void *buf) { uint8_t ret = SUCCESS; if(pfnZclPortNV && pfnZclPortNV->readItem) { NVINTF_itemID_t nvId; nvId.systemID = NVINTF_SYSID_APP; nvId.itemID = (uint16_t)id; nvId.subID = (uint16_t)subId; if(pfnZclPortNV->readItem(nvId, ndx, len, buf) == NVINTF_FAILURE) { ret = NV_OPER_FAILED; } } return(ret); } /******************************************************************** * @fn zclport_deleteNV * * @brief Delete item from NV. This function will fail if the length * parameter does not match the length of the item in NV. * * @param id - Valid NV item Id. * @param subId - Valid NV item sub Id. * @param len - Length of item to delete. * * @return SUCCESS if item was deleted, * NV_ITEM_UNINIT if item did not exist in NV, * NV_BAD_ITEM_LEN if length parameter not correct, * NV_OPER_FAILED if attempted deletion failed. */ uint8_t zclport_deleteNV(uint16_t id, uint16_t subId, uint16_t len) { uint8_t ret = SUCCESS; if (pfnZclPortNV && pfnZclPortNV->deleteItem) { uint32_t nvLen = 0; NVINTF_itemID_t nvId; nvId.systemID = NVINTF_SYSID_APP; nvId.itemID = (uint16_t)id; nvId.subID = (uint16_t)subId; if(pfnZclPortNV->getItemLen) { nvLen = pfnZclPortNV->getItemLen(nvId); } if(nvLen == 0) { ret = NV_ITEM_UNINIT; } else if(nvLen != len) { ret = NV_BAD_ITEM_LEN; } else if(pfnZclPortNV->deleteItem(nvId) == NVINTF_FAILURE) { ret = NV_OPER_FAILED; } } return(ret); } /********************************************************************* * @fn zcl_HandleExternal * * @brief Callback function to handle messages externally * * @param pInMsg - incoming message to process * * @return TRUE */ uint8_t zcl_HandleExternal(zclIncoming_t *pInMsg) { #ifdef BDB_REPORTING zclIncomingMsg_t *pCmd; pCmd = (zclIncomingMsg_t *)OsalPort_msgAllocate( sizeof ( zclIncomingMsg_t ) ); if ( pCmd != NULL ) { // fill in the message pCmd->hdr.event = ZCL_INCOMING_MSG; pCmd->zclHdr = pInMsg->hdr; pCmd->clusterId = pInMsg->msg->clusterId; pCmd->srcAddr = pInMsg->msg->srcAddr; pCmd->endPoint = pInMsg->msg->endPoint; pCmd->attrCmd = pInMsg->attrCmd; if(pCmd->zclHdr.commandID == ZCL_CMD_CONFIG_REPORT) { zstack_bdbProcessInConfigReportReq_t Req = {0}; Req.pZclIncommingMsg = pCmd; Zstackapi_bdbProcessInConfigReportCmd(zclPortFindEntity(pCmd->endPoint),&Req); OsalPort_msgDeallocate((uint8_t*)pCmd); return TRUE; } if(pCmd->zclHdr.commandID == ZCL_CMD_READ_REPORT_CFG) { zstack_bdbProcessInReadReportCfgReq_t Req = {0}; Req.pZclIncommingMsg = pCmd; Zstackapi_bdbProcessInReadReportCfgCmd(zclPortFindEntity(pCmd->endPoint),&Req); OsalPort_msgDeallocate((uint8_t*)pCmd); return TRUE; } OsalPort_msgDeallocate((uint8_t*)pCmd); } #endif // zclHandleExternal for multiple endpoint, fixed by luoyiming 2020-02-08 zclHandleExternalList_t *find = zclHandleExternalList; // Did the application register to handle this message while ( find ) { if ( ( find->endpoint == pInMsg->msg->endPoint ) && ( find->pfn ) ) { // Let the application handle it return (find->pfn( pInMsg )); } find = find->next; } return(TRUE); } /********************************************************************* * @fn zcl_mem_alloc * * @brief Abstraction function to allocate memory * * @param size - size in bytes needed * * @return pointer to allocated buffer, NULL if nothing allocated. */ void *zcl_mem_alloc(uint16_t size) { return( (void *)OsalPort_malloc(size) ); } /********************************************************************* * @fn zcl_memset * * @brief Abstract function to memset * * @param dest - buffer to set * @param value - value to set into memory * @param len - length to set in memory * * @return pointer to buffer after set */ void *zcl_memset(void *dest, uint8_t value, int len) { return( (void *)memset(dest, value, len) ); } /********************************************************************* * @fn zcl_memcpy * * @brief Generic memory copy. * * Note: This function differs from the standard OsalPort_memcpy(), since * it returns the pointer to the next destination uint8_t. The * standard OsalPort_memcpy() returns the original destination address. * * @param dst - pointer to destination memory * @param src - pointer to source memory * @param len - length to copy * * @return pointer to buffer after set */ void *zcl_memcpy(void *dst, void *src, unsigned int len) { uint8_t *pDst = dst; uint8_t *pSrc = src; while(len--) { *pDst++ = *pSrc++; } return(pDst); } /********************************************************************* * @fn zcl_memcmp * * @brief * * Generic memory compare. * * * Note: This function differs from the standard memcmp(), since * it returns the TRUE to when memory is the same and FALSE when * the memory is different. * * @param src1 - source 1 address * @param src2 - source 2 address * @param len - number of bytes to compare * * @return TRUE - same, FALSE - different */ uint8_t zcl_memcmp(const void *src1, const void *src2, unsigned int len) { const uint8_t *pSrc1; const uint8_t *pSrc2; pSrc1 = src1; pSrc2 = src2; while ( len-- ) { if( *pSrc1++ != *pSrc2++ ) return FALSE; } return TRUE; } /********************************************************************* * @fn zcl_cpyExtAddr * * @brief Copy an extended address. * * @param dst - pointer to destination memory * @param src - pointer to source memory * * @return pointer to buffer after set */ void *zcl_cpyExtAddr(uint8_t *pDest, const uint8_t *pSrc) { return zcl_memcpy( (void *)pDest, (void *)pSrc, EXT_ADDR_LEN ); } /********************************************************************* * @fn zcl_mem_free * * @brief Abstract function to free allocated memory * * @param ptr - pointer to allocated memory */ void zcl_mem_free(void *ptr) { if(ptr != NULL) { OsalPort_free(ptr); } } /********************************************************************* * @fn zcl_buffer_uint32 * * @brief Abstract function to break a uin32 into a buffer * * @param buf - pointer to destination memory * @param val - value to break * * @return pointer to buffer after set */ uint8_t *zcl_buffer_uint32(uint8_t *buf, uint32_t val) { *buf++ = BREAK_UINT32(val, 0); *buf++ = BREAK_UINT32(val, 1); *buf++ = BREAK_UINT32(val, 2); *buf++ = BREAK_UINT32(val, 3); return buf; } /********************************************************************* * @fn zcl_build_uint32 * * @brief Abstract function to build a uint32_t from an array of bytes * * @param swapped - array of bytes * @param len - length of array * * @return uint32_t value */ uint32_t zcl_build_uint32(uint8_t *swapped, uint8_t len) { if(len == 2) { return( BUILD_UINT32(swapped[0], swapped[1], 0L, 0L) ); } else if(len == 3) { return( BUILD_UINT32(swapped[0], swapped[1], swapped[2], 0L) ); } else if(len == 4) { return( BUILD_UINT32(swapped[0], swapped[1], swapped[2], swapped[3]) ); } else { return( (uint32_t)swapped[0] ); } } /********************************************************************* * @fn zclPortFind * * @brief Find the endpoint descriptor from endpoint * * @param EndPoint - endpoint * * @return pointer to found endpoint descriptor, NULL if not found */ zclPort_entityEPDesc_t *zclPortFind(uint8_t EndPoint) { int x; for(x = 0; x < MAX_SUPPORTED_ENDPOINTS; x++) { if( entityEPDescs[x].pEpDesc && (EndPoint == entityEPDescs[x].pEpDesc->endPoint) ) { return(&entityEPDescs[x]); } } return( (zclPort_entityEPDesc_t *)NULL ); } /********************************************************************* * @fn zclPortFindEntity * * @brief Find the Task ID from endpoint * * @param EndPoint - endpoint * * @return Task ID */ uint8_t zclPortFindEntity(uint8_t EndPoint) { int x; for(x = 0; x < MAX_SUPPORTED_ENDPOINTS; x++) { if( (entityEPDescs[x].pEpDesc) && (EndPoint == entityEPDescs[x].pEpDesc->endPoint) ) { return(entityEPDescs[x].entity); } } return( (uint8_t)NULL ); } /********************************************************************* * @fn afFindEndPointDesc * * @brief Find the endpoint descriptor from endpoint * * @param EndPoint - endpoint * * @return pointer to found endpoint descriptor, NULL if not found */ endPointDesc_t *zcl_afFindEndPointDesc(uint8_t EndPoint) { int x; for(x = 0; x < MAX_SUPPORTED_ENDPOINTS; x++) { if( (entityEPDescs[x].pEpDesc) && (EndPoint == entityEPDescs[x].pEpDesc->endPoint) ) { return(entityEPDescs[x].pEpDesc); } } return( (endPointDesc_t *)NULL ); } /********************************************************************* * @fn zcl_AF_DataRequestExt * * @brief Common functionality for invoking APSDE_DataReq() for both * SendMulti and MSG-Send. * * NOTE: this is a conversion function * Luoyiming adds confirm callback * * input parameters * * @param *dstAddr - Full ZB destination address: Nwk Addr + End Point. * @param *srcEP - Origination (i.e. respond to or ack to) End Point Descr. * @param cID - A valid cluster ID as specified by the Profile. * @param bufLen - Number of bytes of data pointed to by next param. * @param *buf - A pointer to the data bytes to send. * @param *transID - A pointer to a byte which can be modified and which will * be used as the transaction sequence number of the msg. * @param options - Valid bit mask of Tx options. * @param radius - Normally set to AF_DEFAULT_RADIUS. * @param afCnfCB - Confirm callback,added by luoyiming. * @param param - param for confirm callback,added by luoyiming.. * * output parameters * * @param *transID - Incremented by one if the return value is success. * * @return afStatus_t - See previous definition of afStatus_... types. */ afStatus_t zcl_AF_DataRequestExt(afAddrType_t *dstAddr, endPointDesc_t *srcEP, uint16_t cID, uint16_t bufLen, uint8_t *buf, uint8_t *transID, uint8_t options, uint8_t radius, zstack_AfCnfCb_t* afCnfCB, void* cnfParam) { afStatus_t status; zstack_afDataReq_t req; memset(&req, 0, sizeof(zstack_afDataReq_t)); req.dstAddr.addrMode = (zstack_AFAddrMode)dstAddr->addrMode; if(req.dstAddr.addrMode == zstack_AFAddrMode_EXT) { OsalPort_memcpy(req.dstAddr.addr.extAddr, dstAddr->addr.extAddr, EXT_ADDR_LEN); } else if(req.dstAddr.addrMode != zstack_AFAddrMode_NONE) { req.dstAddr.addr.shortAddr = dstAddr->addr.shortAddr; } req.dstAddr.endpoint = dstAddr->endPoint; req.dstAddr.panID = dstAddr->panId; convertTxOptions(&(req.options), options); req.srcEndpoint = srcEP->endPoint; req.clusterID = cID; req.transID = transID; req.radius = radius; req.n_payload = bufLen; req.pPayload = buf; req.afCnfCB = afCnfCB; req.cnfParam = cnfParam; status = Zstackapi_AfDataReq(zclPortFindEntity(srcEP->endPoint), &req); return(status); } /****************************************************************************** * @fn convertTxOptions * * @brief Convert uint8_t txOptions into PB TransOptions data type * * @param pOptions - TransOptions pointer * @param options - txOptions * * @return none ******************************************************************************/ static void convertTxOptions(zstack_TransOptions_t *pOptions, uint8_t options) { if(options & AF_WILDCARD_PROFILEID) { pOptions->wildcardProfileID = TRUE; } if(options & AF_ACK_REQUEST) { pOptions->ackRequest = TRUE; } if(options & AF_LIMIT_CONCENTRATOR) { pOptions->limitConcentrator = TRUE; } if(options & AF_SUPRESS_ROUTE_DISC_NETWORK) { pOptions->suppressRouteDisc = TRUE; } if(options & AF_EN_SECURITY) { pOptions->apsSecurity = TRUE; } if(options & AF_SKIP_ROUTING) { pOptions->skipRouting = TRUE; } } #if defined (ZCL_GROUPS) /********************************************************************* * APS Interface messages *********************************************************************/ /********************************************************************* * @fn zclport_aps_RemoveGroup * * @brief Remove a group with endpoint and groupID * * @param endpoint - * @param groupID - ID to look forw group * * @return TRUE if removed, FALSE if not found */ uint8_t zclport_aps_RemoveGroup(uint8_t endpoint, uint16_t groupID) { uint8_t status; zstack_apsRemoveGroup_t req; req.endpoint = endpoint; req.groupID = groupID; status = Zstackapi_ApsRemoveGroupReq(zclPortFindEntity(endpoint), &req); return(status); } /********************************************************************* * @fn zclport_aps_RemoveAllGroup * * @brief Remove a groups with an endpoint * * @param endpoint - * @param groupID - ID to look for group * * @return none */ void zclport_aps_RemoveAllGroup(uint8_t endpoint) { zstack_apsRemoveAllGroups_t req; req.endpoint = endpoint; Zstackapi_ApsRemoveAllGroupsReq(zclPortFindEntity(endpoint), &req); } /********************************************************************* * @fn zclport_aps_FindAllGroupsForEndpoint * * @brief Find all the groups with endpoint * * @param endpoint - endpoint to look for * @param groupList - List to hold group IDs (should hold * APS_MAX_GROUPS entries) * * @return number of groups copied to groupList */ uint8_t zclport_aps_FindAllGroupsForEndpoint(uint8_t endpoint, uint16_t *groupList) { zstack_apsFindAllGroupsReq_t req; zstack_apsFindAllGroupsRsp_t rsp = {0}; req.endpoint = endpoint; if( (groupList) && (Zstackapi_ApsFindAllGroupsReq( zclPortFindEntity(endpoint), &req, &rsp) == zstack_ZStatusValues_ZSuccess) ) { uint8_t x; for(x = 0; x < rsp.numGroups; x++) { groupList[x] = rsp.pGroupList[x]; } if(rsp.pGroupList) { OsalPort_free(rsp.pGroupList); } } return( (uint8_t)rsp.numGroups ); } /********************************************************************* * @fn zclport_aps_FindGroup * * @brief Find a group with endpoint and groupID * * @param endpoint - * @param groupID - ID to look forw group * * @return a pointer to the group information, NULL if not found */ aps_Group_t *zclport_aps_FindGroup(uint8_t endpoint, uint16_t groupID) { aps_Group_t *pFound = (aps_Group_t *)NULL; zstack_apsFindGroupReq_t req; zstack_apsFindGroupRsp_t rsp; req.endpoint = endpoint; req.groupID = groupID; if(Zstackapi_ApsFindGroupReq(zclPortFindEntity(endpoint), &req, &rsp) == zstack_ZStatusValues_ZSuccess) { memset( &foundGrp, 0, sizeof(aps_Group_t) ); foundGrp.ID = rsp.groupID; if(rsp.pName) { if(rsp.n_name <= APS_GROUP_NAME_LEN) { OsalPort_memcpy(foundGrp.name, rsp.pName, rsp.n_name); } OsalPort_free(rsp.pName); } pFound = &foundGrp; } return(pFound); } /********************************************************************* * @fn zclport_aps_AddGroup * * @brief Add a group for an endpoint * * @param endpoint - * @param group - new group * * @return ZStatus_t */ ZStatus_t zclport_aps_AddGroup(uint8_t endpoint, aps_Group_t *group) { uint8_t status = zstack_ZStatusValues_ZFailure; zstack_apsAddGroup_t req; memset( &req, 0, sizeof(zstack_apsAddGroup_t) ); req.endpoint = endpoint; if(group) { uint8_t len; req.groupID = group->ID; len = strlen( (const char *)group->name ); if(len) { req.n_name = len; req.pName = group->name; } status = Zstackapi_ApsAddGroupReq(zclPortFindEntity(endpoint), &req); } return(status); } /********************************************************************* * @fn zclport_aps_CountAllGroups * * @brief Count the total number of groups * * @param none * * @return number of groups */ uint8_t zclport_aps_CountAllGroups(void) { // Slight cheat, don't know the endpoint - use first entity return( Zstackapi_ApsCountAllGroupsReq(entityEPDescs[0].entity) ); } #endif // defined(ZCL_GROUPS) #if defined (ZCL_SCENES) /********************************************************************* * @fn sceneRecEmpty * * @brief Checks for an empty record * * @param pNvItem - pointer to scene NV record * * @return true if all bytes where 0xFF, false otherwise */ static bool sceneRecEmpty(zclGenSceneNVItem_t *pNvItem) { uint8_t *pBuf = (uint8_t *)pNvItem; uint16_t x; for(x = 0; x < sizeof(zclGenSceneNVItem_t); x++) { if(*pBuf++ != 0xFF) { return(false); } } return(true); } /********************************************************************* * @fn zclGeneral_ScenesInit * * @brief Initialize the Scenes Table */ void zclGeneral_ScenesInit(void) { uint16_t x; zclGenSceneNVItem_t temp; memset(&temp, 0xFF, sizeof(zclGenSceneNVItem_t)); for(x = 0; x < ZCL_GEN_MAX_SCENES; x++) { zclport_initializeNVItem(zclSceneNVID, x, sizeof(zclGenSceneNVItem_t), &temp); } } /********************************************************************* * @fn zclGeneral_RemoveAllScenes * * @brief Remove all scenes for an endpoint and groupID * * @param endpoint - endpoint to filter with * @param groupID - group ID looking for */ void zclGeneral_RemoveAllScenes(uint8_t endpoint, uint16_t groupID) { uint16_t x; zclGenSceneNVItem_t nvItem; for(x = 0; x < ZCL_GEN_MAX_SCENES; x++) { if(zclport_readNV(zclSceneNVID, x, 0, sizeof(zclGenSceneNVItem_t), &nvItem) == SUCCESS) { if( (sceneRecEmpty(&nvItem) == false) && ( (nvItem.endpoint == endpoint) || (endpoint == 0xFF) ) && (nvItem.scene.groupID == groupID) ) { // Remove the item by setting it all to 0xFF memset( &nvItem, 0xFF, sizeof(zclGenSceneNVItem_t) ); zclport_writeNV(zclSceneNVID, x, sizeof(zclGenSceneNVItem_t), &nvItem); } } } } /********************************************************************* * @fn zclGeneral_RemoveScene * * @brief Remove a scene * * @param endpoint - endpoint to filter with * @param groupID - group ID looking for * @param sceneID - scene ID * * @return TRUE if removed, FALSE if not found */ uint8_t zclGeneral_RemoveScene(uint8_t endpoint, uint16_t groupID, uint8_t sceneID) { uint16_t x; zclGenSceneNVItem_t nvItem; for(x = 0; x < ZCL_GEN_MAX_SCENES; x++) { if(zclport_readNV(zclSceneNVID, x, 0, sizeof(zclGenSceneNVItem_t), &nvItem) == SUCCESS) { if( (sceneRecEmpty(&nvItem) == false) && ( (nvItem.endpoint == endpoint) || (endpoint == 0xFF) ) && (nvItem.scene.groupID == groupID) && (nvItem.scene.ID == sceneID) ) { // Remove the item by setting it all to 0xFF memset( &nvItem, 0xFF, sizeof(zclGenSceneNVItem_t) ); if(zclport_writeNV(zclSceneNVID, x, sizeof(zclGenSceneNVItem_t), &nvItem) == SUCCESS) { return(TRUE); } else { return(FALSE); } } } } return(FALSE); } /********************************************************************* * @fn zclGeneral_FindScene * * @brief Find a scene with endpoint and sceneID * * @param endpoint - endpoint filter to find scene * @param groupID - what group the scene belongs to * @param sceneID - ID to look for scene * * @return a pointer to the scene information, NULL if not found */ zclGeneral_Scene_t *zclGeneral_FindScene(uint8_t endpoint, uint16_t groupID, uint8_t sceneID) { uint16_t x; zclGenSceneNVItem_t nvItem; zclPort_entityEPDesc_t *pEPDesc = zclPortFind(endpoint); if(pEPDesc != NULL) { for(x = 0; x < ZCL_GEN_MAX_SCENES; x++) { if(zclport_readNV(zclSceneNVID, x, 0, sizeof(zclGenSceneNVItem_t), &nvItem) == SUCCESS) { if( (sceneRecEmpty(&nvItem) == false) && ( (nvItem.endpoint == endpoint) || (endpoint == 0xFF) ) && (nvItem.scene.groupID == groupID) && (nvItem.scene.ID == sceneID) ) { lastFindSceneEndpoint = endpoint; // Copy to a temp area OsalPort_memcpy( &(pEPDesc->scene), &(nvItem.scene), sizeof(zclGeneral_Scene_t) ); return( &(pEPDesc->scene) ); } } } } return( (zclGeneral_Scene_t *)NULL ); } /********************************************************************* * @fn zclGeneral_AddScene * * @brief Add a scene for an endpoint * * @param endpoint - * @param scene - new scene item * * @return ZStatus_t */ ZStatus_t zclGeneral_AddScene(uint8_t endpoint, zclGeneral_Scene_t *scene) { uint16_t x; zclGenSceneNVItem_t nvItem; // See if the item exists already for(x = 0; x < ZCL_GEN_MAX_SCENES; x++) { if(zclport_readNV(zclSceneNVID, x, 0, sizeof(zclGenSceneNVItem_t), &nvItem) == SUCCESS) { if( (sceneRecEmpty(&nvItem) == false) && (nvItem.endpoint == endpoint) && (nvItem.scene.groupID == scene->groupID) && (nvItem.scene.ID == scene->ID) ) { break; } } } // Find an empty slot if(x == ZCL_GEN_MAX_SCENES) { for(x = 0; x < ZCL_GEN_MAX_SCENES; x++) { if(zclport_readNV(zclSceneNVID, x, 0, sizeof(zclGenSceneNVItem_t), &nvItem) == SUCCESS) { if( sceneRecEmpty(&nvItem) ) { break; } } } } if(x == ZCL_GEN_MAX_SCENES) { return(ZFailure); } // Item found or empty slot found nvItem.endpoint = endpoint; OsalPort_memcpy( &(nvItem.scene), scene, sizeof(zclGeneral_Scene_t) ); if(zclport_writeNV(zclSceneNVID, x, sizeof(zclGenSceneNVItem_t), &nvItem) == SUCCESS) { return(ZSuccess); } else { return(ZFailure); } } /********************************************************************* * @fn zclGeneral_CountAllScenes * * @brief Count the number of scenes * * @return number of scenes found */ uint8_t zclGeneral_CountAllScenes(void) { uint16_t x; zclGenSceneNVItem_t nvItem; uint8_t cnt = 0; for(x = 0; x < ZCL_GEN_MAX_SCENES; x++) { if(zclport_readNV(zclSceneNVID, x, 0, sizeof(zclGenSceneNVItem_t), &nvItem) == SUCCESS) { if(sceneRecEmpty(&nvItem) == false) { cnt++; } } } return(cnt); } /********************************************************************* * @fn zclGeneral_FindAllScenesForGroup * * @brief Get all the scenes with groupID * * @param endpoint - endpoint to filter with * @param groupID - group ID looking for * * @return number of scenes found */ uint8_t zclGeneral_FindAllScenesForGroup(uint8_t endpoint, uint16_t groupID, uint8_t *sceneList) { uint16_t x; zclGenSceneNVItem_t nvItem; uint8_t cnt = 0; for(x = 0; x < ZCL_GEN_MAX_SCENES; x++) { if(zclport_readNV(zclSceneNVID, x, 0, sizeof(zclGenSceneNVItem_t), &nvItem) == SUCCESS) { if( (sceneRecEmpty(&nvItem) == false) && (nvItem.endpoint == endpoint) && (nvItem.scene.groupID == groupID) ) { sceneList[cnt++] = nvItem.scene.ID; } } } return(cnt); } /********************************************************************* * @fn zclGeneral_ScenesSave * * @brief Save the Scenes Table - Something has changed. * This function is only called if zclGeneral_FindScene() * was called and the found information was changed. */ void zclGeneral_ScenesSave(void) { if(lastFindSceneEndpoint != 0xFF) { zclPort_entityEPDesc_t *pEPDesc = zclPortFind(lastFindSceneEndpoint); if(pEPDesc) { zclGeneral_AddScene( lastFindSceneEndpoint, &(pEPDesc->scene) ); lastFindSceneEndpoint = 0xFF; } } } #endif // ZCL_SCENES /********************************************************************* *********************************************************************/
Ok, I see what you mean and have passed this on to the development team for further investigation.
