Network Scalability of a Linear Zigbee Pro network
Other Parts Discussed in Thread: CC2530, CC2591
Hi All,
Is it possible to have a around 100  all router node network with up to 30 hops using CC2530 (running TI Zigbee Pro stack) for all the nodes including coordinator?
with the coordinator at one end and remaining 99 routers arranged in a line with around 20feet spacing betwwen them. Also taking into considerations LNA CC2591 with 4db o/p. Has anyone successfully inmplemeted or atleast tried implementing a similar network.
Concern is that memory in CC2530 should not be an issue and aslo will the last node(99th) will be able to communicate with the coordinator reliably within 30 hops
@TI employees : Is there any example of similar application working at some place?
