LAUNCHXL-CC26X2R1: about ZCL command "COMMAND_ON_DURATION"
Part Number: LAUNCHXL-CC26X2R1
Hi Team,
My customer is using the "zclGeneral_SendOnOff_CmdOnDuration" in zcl_general.h,and he finds the command "COMMAND_ON_DURATION" as following:
 *  Send an On Off Command - COMMAND_ONOFF_ONDURATION
 *  Use like:
 *      ZStatus_t zclGeneral_SendOnOff_CmdOnDuration( uint16_t srcEP, afAddrType_t *dstAddr, uint16_t onDuration, uint8_t disableDefaultRsp, uint8_t seqNum );
#define zclGeneral_SendOnOff_CmdOnDuration(a,b,c,d,e) zcl_SendCommand( (a), (b), ZCL_CLUSTER_ID_GENERAL_ON_OFF, COMMAND_ON_DURATION, TRUE, ZCL_FRAME_CLIENT_SERVER_DIR, (d), 0, (e), 2, (c) )
But it can not be found the definition of this command  anywhere,it seems to be an outdated command.
Could you help to check it?
kevin
