AES sample code for CC26xx
    I am unable to access the AES link from processors.wiki.ti.com/.../CC2640_AES_Encryption
I saw a post where someone has mentioned that AES is going to be part of the new CC26xxware code. Where can I find sample code to use the AES module ?
I tried using the APIs mentione in tirtos_simplelink_2_11_01_09/packages/ti/drivers/crypto/CryptoCC26XX.h but it not working.
First I had to include sysbios/family/arm/cc26xx/Power.h in CryptoCC26XX.h to get rid of a compiler error. But even after that I received a linking error because
it was not able to resolve CryptoCC26XX_init
Vivek
  • Can someone please help me. I am trying this out in the SimpleBLPheripheral project. I realized that Crypto driver is missing in the drivers folder in this project.
    What is the procedure to add crypto driver to this project ?
    I just confirmed the wiki link is active. Please try again. Also, please see the documentation links to CC26xxWare and TI-RTOS listed in the SW Developer's guide.
    Best wishes
  • I was able to successfully build and test the crypto driver in IAR but I get a linker error in CCS(as mentioned above). Any idea what it missing in CCS config ? I want to get it working in CCS.
    PS: the RomAES128Encryption.zip link on processors.wiki.ti.com/.../CC2640_AES_Encryption gives a Access denied error.
  • Hi JXS,
    The wiki link still can not work. BTW, I get this sample code form local TI FAE, but "AES_ECB_EncryptData" can not work correctly. I use "UP" button to test AES function. My sample code is showing below
      Filename:       SimpleBLECentral_Central.c
      Revised:        $Date: 2015-02-04 11:49:57 -0800 (Wed, 04 Feb 2015) $
      Revision:       $Revision: 42307 $
      Description:    This file contains the Simple BLE Central sample application
                      for use with the CC2650 Bluetooth Low Energy Protocol Stack.
      Copyright 2013 - 2015 Texas Instruments Incorporated. All rights reserved.
      IMPORTANT: Your use of this Software is limited to those specific rights
      granted under the terms of a software license agreement between the user
      who downloaded the software, his/her employer (which must be your employer)
      and Texas Instruments Incorporated (the "License").  You may not use this
      Software unless you agree to abide by the terms of the License. The License
      limits your use, and you acknowledge, that the Software may not be modified,
      copied or distributed unless embedded on a Texas Instruments microcontroller
      or used solely and exclusively in conjunction with a Texas Instruments radio
      frequency transceiver, which is integrated into your product.  Other than for
      the foregoing purpose, you may not use, reproduce, copy, prepare derivative
      works of, modify, distribute, perform, display or sell this Software and/or
      its documentation for any purpose.
      YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
      PROVIDED �AS IS� WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
      INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
      NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
      TEXAS INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT,
      NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
      LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
      INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
      OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
      OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
      (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
      Should you have any questions regarding your right to use this Software,
      contact Texas Instruments Incorporated at www.TI.com.
     * INCLUDES
    #include <string.h>
    #include <xdc/std.h>
    #include <xdc/runtime/Error.h>
    #include <xdc/runtime/System.h>
    #include <ti/sysbios/BIOS.h>
    #include <ti/sysbios/knl/Task.h>
    #include <ti/sysbios/knl/Clock.h>
    #include <ti/sysbios/knl/Semaphore.h>
    #include <ti/sysbios/knl/Queue.h>
    #include <ICall.h>
    #include "bcomdef.h"
    #include "gatt.h"
    #include "ll.h"
    #include "hci.h"
    #include "gapgattserver.h"
    #include "gattservapp.h"
    #include "central.h"
    #include "gapbondmgr.h"
    #include "simpleGATTprofile.h"
    #include "osal_snv.h"
    #include "ICallBleAPIMSG.h"
    #include "util.h"
    #include "board_key.h"
    #include "board_lcd.h"
    #include "Board.h"
    #include <driverlib/trng.h>
    #include "simpleBLECentral.h"
    #include "RomEncryption.h"
    #include <ti/drivers/lcd/LCDDogm1286.h>
     * MACROS
     * CONSTANTS
    // Simple BLE Central Task Events
    #define SBC_START_DISCOVERY_EVT               0x0001
    #define SBC_PAIRING_STATE_EVT                 0x0002
    #define SBC_PASSCODE_NEEDED_EVT               0x0004
    #define SBC_RSSI_READ_EVT                     0x0008
    #define SBC_KEY_CHANGE_EVT                    0x0010
    #define SBC_STATE_CHANGE_EVT                  0x0020
    // Maximum number of scan responses
    #define DEFAULT_MAX_SCAN_RES                  8
    // Scan duration in ms
    #define DEFAULT_SCAN_DURATION                 4000
    // Discovey mode (limited, general, all)
    #define DEFAULT_DISCOVERY_MODE                DEVDISC_MODE_ALL
    // TRUE to use active scan
    #define DEFAULT_DISCOVERY_ACTIVE_SCAN         TRUE
    // TRUE to use white list during discovery
    #define DEFAULT_DISCOVERY_WHITE_LIST          FALSE
    // TRUE to use high scan duty cycle when creating link
    #define DEFAULT_LINK_HIGH_DUTY_CYCLE          FALSE
    // TRUE to use white list when creating link
    #define DEFAULT_LINK_WHITE_LIST               FALSE
    // Default RSSI polling period in ms
    #define DEFAULT_RSSI_PERIOD                   1000
    // Whether to enable automatic parameter update request when a connection is
    // formed
    #define DEFAULT_ENABLE_UPDATE_REQUEST         FALSE
    // Minimum connection interval (units of 1.25ms) if automatic parameter update
    // request is enabled
    #define DEFAULT_UPDATE_MIN_CONN_INTERVAL      400
    // Maximum connection interval (units of 1.25ms) if automatic parameter update
    #define DEFAULT_UPDATE_MAX_CONN_INTERVAL      800
    // Slave latency to use if automatic parameter update request is enabled
    #define DEFAULT_UPDATE_SLAVE_LATENCY          0
    // Supervision timeout value (units of 10ms) if automatic parameter update
    #define DEFAULT_UPDATE_CONN_TIMEOUT           600
    // Default passcode
    #define DEFAULT_PASSCODE                      19655
    // Default GAP pairing mode
    #define DEFAULT_PAIRING_MODE                  GAPBOND_PAIRING_MODE_WAIT_FOR_REQ
    // Default MITM mode (TRUE to require passcode or OOB when pairing)
    #define DEFAULT_MITM_MODE                     FALSE
    // Default bonding mode, TRUE to bond
    #define DEFAULT_BONDING_MODE                  TRUE
    // Default GAP bonding I/O capabilities
    #define DEFAULT_IO_CAPABILITIES               GAPBOND_IO_CAP_DISPLAY_ONLY
    // Default service discovery timer delay in ms
    #define DEFAULT_SVC_DISCOVERY_DELAY           1000
    // TRUE to filter discovery results on desired service UUID
    #define DEFAULT_DEV_DISC_BY_SVC_UUID          TRUE
    // Length of bd addr as a string
    #define B_ADDR_STR_LEN                        15
    // Task configuration
    #define SBC_TASK_PRIORITY                     1
    #ifndef SBC_TASK_STACK_SIZE
    #define SBC_TASK_STACK_SIZE                   864
    #endif
    // Application states
    enum
      BLE_STATE_IDLE,
      BLE_STATE_CONNECTING,
      BLE_STATE_CONNECTED,
      BLE_STATE_DISCONNECTING
    // Discovery states
    enum
      BLE_DISC_STATE_IDLE,                // Idle
      BLE_DISC_STATE_MTU,                 // Exchange ATT MTU size
      BLE_DISC_STATE_SVC,                 // Service discovery
      BLE_DISC_STATE_CHAR                 // Characteristic discovery
     * TYPEDEFS
    // App event passed from profiles.
    typedef struct
      uint8_t event;  // event type
      uint8_t status; // event status
      uint8_t *pData; // event data pointer
    } sbcEvt_t;
     * GLOBAL VARIABLES
     * EXTERNAL VARIABLES
     * LOCAL VARIABLES
    // Entity ID globally used to check for source and/or destination of messages
    static ICall_EntityID selfEntity;
    // Semaphore globally used to post events to the application thread
    static ICall_Semaphore sem;
    // Clock object used to signal timeout
    static Clock_Struct startDiscClock;
    // Queue object used for app messages
    static Queue_Struct appMsg;
    static Queue_Handle appMsgQueue;
    // Task pending events
    static uint16_t events = 0;
    Task_Struct sbcTask;
    Char sbcTaskStack[SBC_TASK_STACK_SIZE];
    // GAP GATT Attributes
    static const uint8_t attDeviceName[GAP_DEVICE_NAME_LEN] = "Simple BLE Central";
    // Number of scan results and scan result index
    static uint8_t scanRes;
    static uint8_t scanIdx;
    // Scan result list
    static gapDevRec_t devList[DEFAULT_MAX_SCAN_RES];
    // Scanning state
    static bool scanningStarted = FALSE;
    // RSSI polling state
    static bool rssiStarted = FALSE;
    // Connection handle of current connection
    static uint16_t connHandle = GAP_CONNHANDLE_INIT;
    static uint8_t state = BLE_STATE_IDLE;
    // Discovery state
    static uint8_t discState = BLE_DISC_STATE_IDLE;
    // Discovered service start and end handle
    static uint16_t svcStartHdl = 0;
    static uint16_t svcEndHdl = 0;
    // Discovered characteristic handle
    static uint16_t charHdl = 0;
    // Value to write
    static uint8_t charVal = 0;
    // Value read/write toggle
    static bool doWrite = FALSE;
    // GATT read/write procedure state
    static bool procedureInProgress = FALSE;
    // Callback variables
    static uint8_t pairState;
    static uint8_t pairStatus;
    static uint8_t displayPasscode;
    // Maximim PDU size (default = 27 octets)
    static uint16 maxPduSize;
    #ifdef TI_DRIVERS_LCD_INCLUDED
      static int8_t rssiValue;
    #endif
    static uint8 aesKey[16] = {1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16};
    static uint8 aesData[5] = {0x0a, 0x0b, 0x0c, 0x0d, 0x0e};
    static uint8 encryptedData[5] = {0};
     * LOCAL FUNCTIONS
    static void SimpleBLECentral_init(void);
    static void SimpleBLECentral_taskFxn(UArg a0, UArg a1);
    static void SimpleBLECentral_processGATTMsg(gattMsgEvent_t *pMsg);
    static void SimpleBLECentral_handleKeys(uint8_t shift, uint8_t keys);
    static void SimpleBLECentral_processStackMsg(ICall_Hdr *pMsg);
    static void SimpleBLECentral_processAppMsg(sbcEvt_t *pMsg);
    static void SimpleBLECentral_processRoleEvent(gapCentralRoleEvent_t *pEvent);
    static void SimpleBLECentral_processGATTDiscEvent(gattMsgEvent_t *pMsg);
    static void SimpleBLECentral_startDiscovery(void);
    static bool SimpleBLECentral_findSvcUuid(uint16_t uuid, uint8_t *pData,
                                             uint8_t dataLen);
    static void SimpleBLECentral_addDeviceInfo(uint8_t *pAddr, uint8_t addrType);
    static void SimpleBLECentral_processPairState(uint8_t state, uint8_t status);
    static void SimpleBLECentral_processPasscode(uint16_t connectionHandle,
                                                 uint8_t uiOutputs);
    static void SimpleBLECentral_rssiCB(uint16_t connHandle, int8_t rssi);
    static uint8_t SimpleBLECentral_eventCB(gapCentralRoleEvent_t *pEvent);
    static void SimpleBLECentral_passcodeCB(uint8_t *deviceAddr, uint16_t connHandle,
                                            uint8_t uiInputs, uint8_t uiOutputs);
    static void SimpleBLECentral_pairStateCB(uint16_t connHandle, uint8_t state,
                                             uint8_t status);
    static uint8_t SimpleBLECentral_enqueueMsg(uint8_t event, uint8_t status,
                                               uint8_t *pData);
    void SimpleBLECentral_startDiscHandler(UArg a0);
    void SimpleBLECentral_keyChangeHandler(uint8 keysPressed);
     * PROFILE CALLBACKS
    // GAP Role Callbacks
    static gapCentralRoleCB_t SimpleBLECentral_roleCB =
      SimpleBLECentral_rssiCB,     // RSSI callback
      SimpleBLECentral_eventCB     // Event callback
    // Bond Manager Callbacks
    static gapBondCBs_t SimpleBLECentral_bondCB =
      SimpleBLECentral_passcodeCB, // Passcode callback
      SimpleBLECentral_pairStateCB // Pairing state callback
     * PUBLIC FUNCTIONS
     * @fn      SimpleBLEPeripheral_createTask
     * @brief   Task creation function for the Simple BLE Peripheral.
     * @param   none
     * @return  none
    void SimpleBLECentral_createTask(void)
      Task_Params taskParams;
      // Configure task
      Task_Params_init(&taskParams);
      taskParams.stack = sbcTaskStack;
      taskParams.stackSize = SBC_TASK_STACK_SIZE;
      taskParams.priority = SBC_TASK_PRIORITY;
      Task_construct(&sbcTask, SimpleBLECentral_taskFxn, &taskParams, NULL);
     * @fn      SimpleBLECentral_Init
     * @brief   Initialization function for the Simple BLE Central App Task.
     *          This is called during initialization and should contain
     *          any application specific initialization (ie. hardware
     *          initialization/setup, table initialization, power up
     *          notification).
     * @param   none
     * @return  none
      // N0 STACK API CALLS CAN OCCUR BEFORE THIS CALL TO ICall_registerApp
      // Register the current thread as an ICall dispatcher application
      // so that the application can send and receive messages.
      ICall_registerApp(&selfEntity, &sem);
      // Hard code the DB Address till CC2650 board gets its own IEEE address
      //uint8 bdAddress[B_ADDR_LEN] = { 0x11, 0x11, 0x11, 0x11, 0x11, 0x11 };
      //HCI_EXT_SetBDADDRCmd(bdAddress);
      // Set device's Sleep Clock Accuracy
      //HCI_EXT_SetSCACmd(40);
      // Create an RTOS queue for message from profile to be sent to app.
      appMsgQueue = Util_constructQueue(&appMsg);
      // Setup discovery delay as a one-shot timer
      Util_constructClock(&startDiscClock, SimpleBLECentral_startDiscHandler,
                          DEFAULT_SVC_DISCOVERY_DELAY, 0, false, 0);
      Board_initKeys(SimpleBLECentral_keyChangeHandler);
      Board_openLCD();
      // Setup Central Profile
        uint8_t scanRes = DEFAULT_MAX_SCAN_RES;
        GAPCentralRole_SetParameter(GAPCENTRALROLE_MAX_SCAN_RES, sizeof(uint8_t),
                                    &scanRes);
      // Setup GAP
      GAP_SetParamValue(TGAP_GEN_DISC_SCAN, DEFAULT_SCAN_DURATION);
      GAP_SetParamValue(TGAP_LIM_DISC_SCAN, DEFAULT_SCAN_DURATION);
      GGS_SetParameter(GGS_DEVICE_NAME_ATT, GAP_DEVICE_NAME_LEN,
                       (void *)attDeviceName);
      // Setup the GAP Bond Manager
        uint32_t passkey = DEFAULT_PASSCODE;
        uint8_t pairMode = DEFAULT_PAIRING_MODE;
        uint8_t mitm = DEFAULT_MITM_MODE;
        uint8_t ioCap = DEFAULT_IO_CAPABILITIES;
        uint8_t bonding = DEFAULT_BONDING_MODE;
        GAPBondMgr_SetParameter(GAPBOND_DEFAULT_PASSCODE, sizeof(uint32_t),
                                &passkey);
        GAPBondMgr_SetParameter(GAPBOND_PAIRING_MODE, sizeof(uint8_t), &pairMode);
        GAPBondMgr_SetParameter(GAPBOND_MITM_PROTECTION, sizeof(uint8_t), &mitm);
        GAPBondMgr_SetParameter(GAPBOND_IO_CAPABILITIES, sizeof(uint8_t), &ioCap);
        GAPBondMgr_SetParameter(GAPBOND_BONDING_ENABLED, sizeof(uint8_t), &bonding);
      // Initialize GATT Client
      VOID GATT_InitClient();
      // Register to receive incoming ATT Indications/Notifications
      GATT_RegisterForInd(selfEntity);
      // Initialize GATT attributes
      GGS_AddService(GATT_ALL_SERVICES);         // GAP
      GATTServApp_AddService(GATT_ALL_SERVICES); // GATT attributes
      // Start the Device
      VOID GAPCentralRole_StartDevice(&SimpleBLECentral_roleCB);
      // Register with bond manager after starting device
      GAPBondMgr_Register(&SimpleBLECentral_bondCB);
      LCD_WRITE_STRING("BLE Central", LCD_PAGE0);
     * @fn      SimpleBLECentral_taskFxn
     * @brief   Application task entry point for the Simple BLE Central.
     * @param   none
     * @return  events not processed
      // Initialize application
      SimpleBLECentral_init();
      // Application main loop
      for (;;)
        // Waits for a signal to the semaphore associated with the calling thread.
        // Note that the semaphore associated with a thread is signaled when a
        // message is queued to the message receive queue of the thread or when
        // ICall_signal() function is called onto the semaphore.
        ICall_Errno errno = ICall_wait(ICALL_TIMEOUT_FOREVER);
        if (errno == ICALL_ERRNO_SUCCESS)
          ICall_EntityID dest;
          ICall_ServiceEnum src;
          ICall_HciExtEvt *pMsg = NULL;
          if (ICall_fetchServiceMsg(&src, &dest,
                                    (void **)&pMsg) == ICALL_ERRNO_SUCCESS)
            if ((src == ICALL_SERVICE_CLASS_BLE) && (dest == selfEntity))
              // Process inter-task message
              SimpleBLECentral_processStackMsg((ICall_Hdr *)pMsg);
            if (pMsg)
              ICall_freeMsg(pMsg);
        // If RTOS queue is not empty, process app message
        if (!Queue_empty(appMsgQueue))
          sbcEvt_t *pMsg = (sbcEvt_t *)Util_dequeueMsg(appMsgQueue);
          if (pMsg)
            // Process message
            SimpleBLECentral_processAppMsg(pMsg);
            // Free the space from the message
            ICall_free(pMsg);
        if (events & SBC_START_DISCOVERY_EVT)
          events &= ~SBC_START_DISCOVERY_EVT;
          SimpleBLECentral_startDiscovery();
        if (events & SBC_PAIRING_STATE_EVT)
          events &= ~SBC_PAIRING_STATE_EVT;
          SimpleBLECentral_processPairState(pairState, pairStatus);
        if (events & SBC_RSSI_READ_EVT)
          events &= ~SBC_RSSI_READ_EVT;
          LCD_WRITE_STRING_VALUE("RSSI -dB:", (uint32_t)(-rssiValue), 10, LCD_PAGE4);
        if (events & SBC_PASSCODE_NEEDED_EVT)
          events &= ~SBC_PASSCODE_NEEDED_EVT;
          SimpleBLECentral_processPasscode(connHandle, displayPasscode);
     * @fn      SimpleBLECentral_processStackMsg
     * @brief   Process an incoming task message.
     * @param   pMsg - message to process
     * @return  none
      switch (pMsg->event)
        case GAP_MSG_EVENT:
          SimpleBLECentral_processRoleEvent((gapCentralRoleEvent_t *)pMsg);
          break;
        case GATT_MSG_EVENT:
          SimpleBLECentral_processGATTMsg((gattMsgEvent_t *)pMsg);
          break;
        default:
          break;
     * @fn      SimpleBLECentral_processAppMsg
     * @brief   Central application event processing function.
     * @param   pMsg - pointer to event structure
     * @return  none
        case SBC_STATE_CHANGE_EVT:
          SimpleBLECentral_processStackMsg((ICall_Hdr *)pMsg->pData);
          // Free the stack message
          ICall_freeMsg(pMsg->pData);
          break;
        case SBC_KEY_CHANGE_EVT:
          SimpleBLECentral_handleKeys(0, pMsg->status);
          break;
        default:
          // Do nothing.
          break;
     * @fn      SimpleBLECentral_processRoleEvent
     * @brief   Central role event processing function.
     * @param   pEvent - pointer to event structure
     * @return  none
      switch (pEvent->gap.opcode)
        case GAP_DEVICE_INIT_DONE_EVENT:
            maxPduSize = pEvent->initDone.dataPktLen;
            LCD_WRITE_STRING(Util_convertBdAddr2Str(pEvent->initDone.devAddr),
                             LCD_PAGE1);
            LCD_WRITE_STRING("Initialized", LCD_PAGE2);
          break;
        case GAP_DEVICE_INFO_EVENT:
            // if filtering device discovery results based on service UUID
            if (DEFAULT_DEV_DISC_BY_SVC_UUID == TRUE)
              if (SimpleBLECentral_findSvcUuid(SIMPLEPROFILE_SERV_UUID,
                                               pEvent->deviceInfo.pEvtData,
                                               pEvent->deviceInfo.dataLen))
                SimpleBLECentral_addDeviceInfo(pEvent->deviceInfo.addr,
                                               pEvent->deviceInfo.addrType);
          break;
        case GAP_DEVICE_DISCOVERY_EVENT:
            // discovery complete
            // if not filtering device discovery results based on service UUID
            if (DEFAULT_DEV_DISC_BY_SVC_UUID == FALSE)
              // Copy results
              scanRes = pEvent->discCmpl.numDevs;
              memcpy(devList, pEvent->discCmpl.pDevList,
                     (sizeof(gapDevRec_t) * scanRes));
            LCD_WRITE_STRING_VALUE("Devices Found", scanRes, 10, LCD_PAGE2);
            if (scanRes > 0)
              LCD_WRITE_STRING("<- To Select", LCD_PAGE3);
            // initialize scan index to last device
            scanIdx = scanRes;
          break;
        case GAP_LINK_ESTABLISHED_EVENT:
            if (pEvent->gap.hdr.status == SUCCESS)
              state = BLE_STATE_CONNECTED;
              connHandle = pEvent->linkCmpl.connectionHandle;
              procedureInProgress = TRUE;
              // If service discovery not performed initiate service discovery
              if (charHdl == 0)
                Util_startClock(&startDiscClock);
              LCD_WRITE_STRING("Connected", LCD_PAGE2);
              LCD_WRITE_STRING(Util_convertBdAddr2Str(pEvent->linkCmpl.devAddr),
                               LCD_PAGE3);
            else
              LCD_WRITE_STRING("Connect Failed", LCD_PAGE2);
              LCD_WRITE_STRING_VALUE("Reason:", pEvent->gap.hdr.status, 10,
                                     LCD_PAGE3);
          break;
        case GAP_LINK_TERMINATED_EVENT:
            charHdl = 0;
            LCD_WRITE_STRING("Disconnected", LCD_PAGE2);
            LCD_WRITE_STRING_VALUE("Reason:", pEvent->linkTerminate.reason,
                                    10, LCD_PAGE3);
            LCD_WRITE_STRING("", LCD_PAGE4);
          break;
        case GAP_LINK_PARAM_UPDATE_EVENT:
            LCD_WRITE_STRING_VALUE("Param Update:", pEvent->linkUpdate.status,
                                    10, LCD_PAGE2);
          break;
        default:
          break;
     * @fn      SimpleBLECentral_handleKeys
     * @brief   Handles all key events for this device.
     * @param   shift - true if in shift/alt.
     * @param   keys - bit field for key events. Valid entries:
     *                 HAL_KEY_SW_2
     *                 HAL_KEY_SW_1
     * @return  none
      (void)shift;  // Intentionally unreferenced parameter
      if (keys & KEY_LEFT)
        // Display discovery results
        if (!scanningStarted && scanRes > 0)
          // Increment index of current result (with wraparound)
          scanIdx++;
          if (scanIdx >= scanRes)
            scanIdx = 0;
          LCD_WRITE_STRING_VALUE("Device", (scanIdx + 1), 10, LCD_PAGE2);
          LCD_WRITE_STRING(Util_convertBdAddr2Str(devList[scanIdx].addr), LCD_PAGE3);
        return;
      if (keys & KEY_UP)
        AES_ECB_EncryptData(aesData, 5, aesKey);
        memcpy(encryptedData, aesData, 5);
        // Start or stop discovery
        if (state != BLE_STATE_CONNECTED)
          if (!scanningStarted)
            scanningStarted = TRUE;
            scanRes = 0;
            LCD_WRITE_STRING("Discovering...", LCD_PAGE2);
            LCD_WRITE_STRING("", LCD_PAGE3);
            GAPCentralRole_StartDiscovery(DEFAULT_DISCOVERY_MODE,
                                          DEFAULT_DISCOVERY_ACTIVE_SCAN,
                                          DEFAULT_DISCOVERY_WHITE_LIST);
          else
            GAPCentralRole_CancelDiscovery();
        else if (state == BLE_STATE_CONNECTED &&
                 charHdl != 0                 &&
                 procedureInProgress == FALSE)
          uint8_t status;
          // Do a read or write as long as no other read or write is in progress
          if (doWrite)
            // Do a write
            attWriteReq_t req;
            req.pValue = GATT_bm_alloc(connHandle, ATT_WRITE_REQ, 1, NULL);
            if ( req.pValue != NULL )
              req.handle = charHdl;
              req.len = 1;
              req.pValue[0] = charVal;
              req.sig = 0;
              req.cmd = 0;
              status = GATT_WriteCharValue(connHandle, &req, selfEntity);
              if ( status != SUCCESS )
                GATT_bm_free((gattMsg_t *)&req, ATT_WRITE_REQ);
          else
            // Do a read
            attReadReq_t req;
            status = GATT_ReadCharValue(connHandle, &req, selfEntity);
          if (status == SUCCESS)
            doWrite = !doWrite;
        return;
      if (keys & KEY_RIGHT)
        // Connection update
        if (state == BLE_STATE_CONNECTED)
          GAPCentralRole_UpdateLink(connHandle,
                                    DEFAULT_UPDATE_MIN_CONN_INTERVAL,
                                    DEFAULT_UPDATE_MAX_CONN_INTERVAL,
                                    DEFAULT_UPDATE_SLAVE_LATENCY,
                                    DEFAULT_UPDATE_CONN_TIMEOUT);
        return;
      if (keys & KEY_SELECT)
        uint8_t addrType;
        uint8_t *peerAddr;
        // Connect or disconnect
        if (state == BLE_STATE_IDLE)
          // if there is a scan result
          if (scanRes > 0)
            // connect to current device in scan result
            peerAddr = devList[scanIdx].addr;
            addrType = devList[scanIdx].addrType;
            state = BLE_STATE_CONNECTING;
            GAPCentralRole_EstablishLink(DEFAULT_LINK_HIGH_DUTY_CYCLE,
                                         DEFAULT_LINK_WHITE_LIST,
                                         addrType, peerAddr);
            LCD_WRITE_STRING("Connecting", LCD_PAGE2);
            LCD_WRITE_STRING(Util_convertBdAddr2Str(peerAddr), LCD_PAGE3);
        else if (state == BLE_STATE_CONNECTING ||
          // disconnect
          state = BLE_STATE_DISCONNECTING;
          GAPCentralRole_TerminateLink(connHandle);
          LCD_WRITE_STRING("Disconnecting", LCD_PAGE2);
        return;
      if (keys & KEY_DOWN)
        // Start or cancel RSSI polling
          if (!rssiStarted)
            rssiStarted = TRUE;
            GAPCentralRole_StartRssi(connHandle, DEFAULT_RSSI_PERIOD);
          else
            GAPCentralRole_CancelRssi(connHandle);
            LCD_WRITE_STRING("RSSI Cancelled", LCD_PAGE4);
        return;
     * @fn      SimpleBLECentral_processGATTMsg
     * @brief   Process GATT messages
     * @return  none
        if ((pMsg->method == ATT_READ_RSP)   ||
            ((pMsg->method == ATT_ERROR_RSP) &&
             (pMsg->msg.errorRsp.reqOpcode == ATT_READ_REQ)))
          if (pMsg->method == ATT_ERROR_RSP)
            LCD_WRITE_STRING_VALUE("Read Error", pMsg->msg.errorRsp.errCode, 10,
                                   LCD_PAGE4);
          else
            // After a successful read, display the read value
            LCD_WRITE_STRING_VALUE("Read rsp:", pMsg->msg.readRsp.pValue[0], 10,
                                   LCD_PAGE4);
        else if ((pMsg->method == ATT_WRITE_RSP)  ||
                  (pMsg->msg.errorRsp.reqOpcode == ATT_WRITE_REQ)))
          if (pMsg->method == ATT_ERROR_RSP == ATT_ERROR_RSP)
            LCD_WRITE_STRING_VALUE("Write Error", pMsg->msg.errorRsp.errCode, 10,
                                   LCD_PAGE4);
          else
            // After a succesful write, display the value that was written and
            // increment value
            LCD_WRITE_STRING_VALUE("Write sent:", charVal++, 10, LCD_PAGE4);
        else if (discState != BLE_DISC_STATE_IDLE)
          SimpleBLECentral_processGATTDiscEvent(pMsg);
      } // else - in case a GATT message came after a connection has dropped, ignore it.
      GATT_bm_free(&pMsg->msg, pMsg->method);
     * @fn      SimpleBLECentral_eventCB
     * @brief   Central event callback function.
     * @return  TRUE if safe to deallocate event message, FALSE otherwise.
      // Forward the role event to the application
      if (SimpleBLECentral_enqueueMsg(SBC_STATE_CHANGE_EVT,
                                      SUCCESS, (uint8_t *)pEvent))
        // App will process and free the event
        return FALSE;
      // Caller should free the event
      return TRUE;
     * @fn      SimpleBLECentral_rssiCB
     * @brief   RSSI callback.
     * @param   connHandle - connection handle
     * @param   rssi - RSSI
     * @return  none
      // Remember the latest RSSI value for display
      rssiValue = rssi;
    #endif
      events |= SBC_RSSI_READ_EVT;
      // Wake up the application thread when it waits for clock event
      Semaphore_post(sem);
     * @fn      SimpleBLECentral_pairStateCB
     * @brief   Pairing state callback.
     * @return  none
                                             uint8_t status)
      // Remember the new state and status
      pairState = state;
      pairStatus = status;
      events |= SBC_PAIRING_STATE_EVT;
     * @fn      SimpleBLECentral_passcodeCB
     * @brief   Passcode callback.
     * @return  none
      displayPasscode = uiOutputs;
      events |= SBC_PASSCODE_NEEDED_EVT;
     * @fn      SimpleBLECentral_processPairState
     * @brief   Process the new paring state.
     * @return  none
      if (state == GAPBOND_PAIRING_STATE_STARTED)
        LCD_WRITE_STRING("Pairing started", LCD_PAGE2);
      else if (state == GAPBOND_PAIRING_STATE_COMPLETE)
          LCD_WRITE_STRING("Pairing success", LCD_PAGE2);
        else
          LCD_WRITE_STRING_VALUE("Pairing fail:", status, 10, LCD_PAGE2);
      else if (state == GAPBOND_PAIRING_STATE_BONDED)
          LCD_WRITE_STRING("Bonding success", LCD_PAGE2);
     * @fn      SimpleBLECentral_processPasscode
     * @brief   Process the Passcode request.
     * @return  none
                                                 uint8_t uiOutputs)
      uint32_t  passcode;
      // Create random passcode
      passcode = Util_GetTRNG();
      passcode %= 1000000;
      // Display passcode to user
      if (uiOutputs != 0)
        LCD_WRITE_STRING_VALUE("Passcode:", passcode, 10, LCD_PAGE4);
      // Send passcode response
      GAPBondMgr_PasscodeRsp(connectionHandle, SUCCESS, passcode);
     * @fn      SimpleBLECentral_startDiscovery
     * @brief   Start service discovery.
     * @return  none
      attExchangeMTUReq_t req;
      // Initialize cached handles
      svcStartHdl = svcEndHdl = charHdl = 0;
      discState = BLE_DISC_STATE_MTU;
      // Discover GATT Server's Rx MTU size
      req.clientRxMTU = maxPduSize - L2CAP_HDR_SIZE;
      // ATT MTU size should be set to the minimum of the Client Rx MTU
      // and Server Rx MTU values
      VOID GATT_ExchangeMTU(connHandle, &req, selfEntity);
     * @fn      SimpleBLECentral_processGATTDiscEvent
     * @brief   Process GATT discovery event
     * @return  none
      if (pMsg->method == ATT_MTU_UPDATED_EVENT)
        // MTU size updated
        LCD_WRITE_STRING_VALUE("MTU Size:", pMsg->msg.mtuEvt.MTU, 10, LCD_PAGE4);
      else if (discState == BLE_DISC_STATE_MTU)
        // MTU size response received, discover simple BLE service
        if (pMsg->method == ATT_EXCHANGE_MTU_RSP)
          uint8_t uuid[ATT_BT_UUID_SIZE] = { LO_UINT16(SIMPLEPROFILE_SERV_UUID),
                                             HI_UINT16(SIMPLEPROFILE_SERV_UUID) };
          // Just in case we're using the default MTU size (23 octets)
          LCD_WRITE_STRING_VALUE("MTU Size:", ATT_MTU_SIZE, 10, LCD_PAGE4);
          discState = BLE_DISC_STATE_SVC;
          // Discovery simple BLE service
          VOID GATT_DiscPrimaryServiceByUUID(connHandle, uuid, ATT_BT_UUID_SIZE,
                                             selfEntity);
      else if (discState == BLE_DISC_STATE_SVC)
        // Service found, store handles
        if (pMsg->method == ATT_FIND_BY_TYPE_VALUE_RSP &&
            pMsg->msg.findByTypeValueRsp.numInfo > 0)
          svcStartHdl = ATT_ATTR_HANDLE(pMsg->msg.findByTypeValueRsp.pHandlesInfo, 0);
          svcEndHdl = ATT_GRP_END_HANDLE(pMsg->msg.findByTypeValueRsp.pHandlesInfo, 0);
        // If procedure complete
        if (((pMsg->method == ATT_FIND_BY_TYPE_VALUE_RSP) &&
             (pMsg->hdr.status == bleProcedureComplete))  ||
            (pMsg->method == ATT_ERROR_RSP))
          if (svcStartHdl != 0)
            attReadByTypeReq_t req;
            // Discover characteristic
            discState = BLE_DISC_STATE_CHAR;
            req.startHandle = svcStartHdl;
            req.endHandle = svcEndHdl;
            req.type.len = ATT_BT_UUID_SIZE;
            req.type.uuid[0] = LO_UINT16(SIMPLEPROFILE_CHAR1_UUID);
            req.type.uuid[1] = HI_UINT16(SIMPLEPROFILE_CHAR1_UUID);
            VOID GATT_ReadUsingCharUUID(connHandle, &req, selfEntity);
      else if (discState == BLE_DISC_STATE_CHAR)
        // Characteristic found, store handle
        if ((pMsg->method == ATT_READ_BY_TYPE_RSP) &&
            (pMsg->msg.readByTypeRsp.numPairs > 0))
          charHdl = BUILD_UINT16(pMsg->msg.readByTypeRsp.pDataList[0],
                                 pMsg->msg.readByTypeRsp.pDataList[1]);
          LCD_WRITE_STRING("Simple Svc Found", LCD_PAGE2);
     * @fn      SimpleBLECentral_findSvcUuid
     * @brief   Find a given UUID in an advertiser's service UUID list.
     * @return  TRUE if service UUID found
                                             uint8_t dataLen)
      uint8_t adLen;
      uint8_t adType;
      uint8_t *pEnd;
      pEnd = pData + dataLen - 1;
      // While end of data not reached
      while (pData < pEnd)
        // Get length of next AD item
        adLen = *pData++;
        if (adLen > 0)
          adType = *pData;
          // If AD type is for 16-bit service UUID
          if ((adType == GAP_ADTYPE_16BIT_MORE) ||
              (adType == GAP_ADTYPE_16BIT_COMPLETE))
            pData++;
            adLen--;
            // For each UUID in list
            while (adLen >= 2 && pData < pEnd)
              // Check for match
              if ((pData[0] == LO_UINT16(uuid)) && (pData[1] == HI_UINT16(uuid)))
                // Match found
                return TRUE;
              // Go to next
              pData += 2;
              adLen -= 2;
            // Handle possible erroneous extra byte in UUID list
            if (adLen == 1)
              pData++;
          else
            // Go to next item
            pData += adLen;
      // Match not found
      return FALSE;
     * @fn      SimpleBLECentral_addDeviceInfo
     * @brief   Add a device to the device discovery result list
     * @return  none
      uint8_t i;
      // If result count not at max
      if (scanRes < DEFAULT_MAX_SCAN_RES)
        // Check if device is already in scan results
        for (i = 0; i < scanRes; i++)
          if (memcmp(pAddr, devList[i].addr , B_ADDR_LEN) == 0)
            return;
        // Add addr to scan result list
        memcpy(devList[scanRes].addr, pAddr, B_ADDR_LEN);
        devList[scanRes].addrType = addrType;
        // Increment scan result count
        scanRes++;
     * @fn      SimpleBLECentral_startDiscHandler
     * @brief   Clock handler function
     * @param   a0 - ignored
     * @return  none
      events |= SBC_START_DISCOVERY_EVT;
     * @fn      SimpleBLECentral_keyChangeHandler
     * @brief   Key event handler function
     * @return  none
    void SimpleBLECentral_keyChangeHandler(uint8 keys)
      SimpleBLECentral_enqueueMsg(SBC_KEY_CHANGE_EVT, keys, NULL);
     * @fn      SimpleBLECentral_enqueueMsg
     * @brief   Creates a message and puts the message in RTOS queue.
     * @param   event - message event.
     * @param   status - message status.
     * @param   pData - message data pointer.
     * @return  TRUE or FALSE
                                               uint8_t *pData)
      sbcEvt_t *pMsg = ICall_malloc(sizeof(sbcEvt_t));
      // Create dynamic pointer to message.
      if (pMsg)
        pMsg->event = event;
        pMsg->status = status;
        pMsg->pData = pData;
        // Enqueue the message.
        return Util_enqueueMsg(appMsgQueue, sem, (uint8_t *)pMsg);
      return FALSE;
    Attached the zip file from the AES encryption wiki: http://processors.wiki.ti.com/index.php/CC2640_AES_Encryption
  • AES-CCM code is not available in these files. Any idea where I can find code for it ? I am creating a new thread to track this e2e.ti.com/.../433086
    Please let me know if you have access to AES-CCM code.
  • Please note that I received this reply on the other thread from
    Hi Vivek,
    The ROM encryption library that was uploaded to the wiki is not recommended to use for now. Parts of the will be used in future versions of the BLE stack and since the library uses a global RAM scratch area this will cause thread safety issues when the BLE stack starts using this until we have a thread safe wrapper in place around the library. The final version of the crypto library (expected in August) will have support for AES ECB/CCM/CTR, ECC as well as SHA256 checksums.
    Svend
