Other Parts Discussed in Thread: CC31XXEMUBOOST, CC3100BOOST, CC3200, CC3100
When attempting to set an authentication username for the HTTP Server, a six character value will cause strange behavior. I can authenticate once, but then authentication with the same credentials fails. After a reset, the credentials will be read out the same as they were set, and you will be able to authenticate once again, with further attempts to get a webpage failing. I am using the CC3100BOOST on the CC31XXEMUBOOST.
Usernames that cause the above behavior:
Opto22
22Opto
OptoCA
chrisg
Usernames that function properly:
Opto22O
Opto22G
chris
admin
OuTpUtOf1
