AM335x GPMC interface to dual port SRAM
Other Parts Discussed in Thread: SYSCONFIG, SN74ALVCH16374, AM3359
We referenced the TI ICE dual port ram schematic to design our device with a 64K x 16 DPRAM (CY7C028V).
However, data can't be read/wrote properly via GPMC multiplexed address data 16bits function, and which still only read the AD0 to AD15's internal status( if pullup: 0xFFFF / pulldown: 0x0 in conf module pin register).
Any idea to the issue, please help.
void PINMUX_Config(void)
MUX_VAL(CONTROL_PADCONF_GPMC_AD0, (0x30 )) /* GPMC_AD0 */;
MUX_VAL(CONTROL_PADCONF_GPMC_AD1, (0x30 )) /* GPMC_AD1 */;
MUX_VAL(CONTROL_PADCONF_GPMC_AD2, (0x30 )) /* GPMC_AD2 */;
MUX_VAL(CONTROL_PADCONF_GPMC_AD3, (0x30 )) /* GPMC_AD3 */;
MUX_VAL(CONTROL_PADCONF_GPMC_AD4, (0x30 )) /* GPMC_AD4 */;
MUX_VAL(CONTROL_PADCONF_GPMC_AD5, (0x30 )) /* GPMC_AD5 */;
MUX_VAL(CONTROL_PADCONF_GPMC_AD6, (0x30 )) /* GPMC_AD6 */;
MUX_VAL(CONTROL_PADCONF_GPMC_AD7, (0x30 )) /* GPMC_AD7 */;
MUX_VAL(CONTROL_PADCONF_GPMC_AD8, (0x30 )) /* GPMC_AD8 */;
MUX_VAL(CONTROL_PADCONF_GPMC_AD9, (0x30 )) /* GPMC_AD9 */;
MUX_VAL(CONTROL_PADCONF_GPMC_AD10, (0x30 )) /* GPMC_AD10 */;
MUX_VAL(CONTROL_PADCONF_GPMC_AD11, (0x30 )) /* GPMC_AD11 */;
MUX_VAL(CONTROL_PADCONF_GPMC_AD12, (0x30 )) /* GPMC_AD12 */;
MUX_VAL(CONTROL_PADCONF_GPMC_AD13, (0x30 )) /* GPMC_AD13 */;
MUX_VAL(CONTROL_PADCONF_GPMC_AD14, (0x30 )) /* GPMC_AD14 */;
MUX_VAL(CONTROL_PADCONF_GPMC_AD15, (0x30 )) /* GPMC_AD15 */;
MUX_VAL(CONTROL_PADCONF_GPMC_CSN1, ( 0x0 )) /* GPMC_CSN1 */;
MUX_VAL(CONTROL_PADCONF_GPMC_ADVN_ALE, ( 0x0 )) /* GPMC_ADVN_ALE */;
MUX_VAL(CONTROL_PADCONF_GPMC_OEN_REN, ( 0x0 )) /* GPMC_OEN_REN */;
MUX_VAL(CONTROL_PADCONF_GPMC_WEN, ( 0x0 )) /* GPMC_WEN */;
void GPMC_DPRAM_Init(void)
int csNum = 1;
unsigned int temp;
//enable clock to GPMC module
HWREG(SOC_PRCM_REGS + CM_PER_GPMC_CLKCTRL ) |=
CM_PER_GPMC_CLKCTRL_MODULEMODE_ENABLE;
//check to see if enabled
while((HWREG(SOC_PRCM_REGS + CM_PER_GPMC_CLKCTRL) & CM_PER_GPMC_CLKCTRL_IDLEST) !=
(CM_PER_GPMC_CLKCTRL_IDLEST_FUNC << CM_PER_GPMC_CLKCTRL_IDLEST_SHIFT));
//reset the GPMC module
HWREG(SOC_GPMC_0_REGS + GPMC_SYSCONFIG ) |= GPMC_SYSCONFIG_SOFTRESET;
while((HWREG(SOC_GPMC_0_REGS + GPMC_SYSSTATUS) & GPMC_SYSSTATUS_RESETDONE) ==
GPMC_SYSSTATUS_RESETDONE_RSTONGOING);
//Configure to no idle
temp = HWREG(SOC_GPMC_0_REGS + GPMC_SYSCONFIG);
temp &= ~GPMC_SYSCONFIG_IDLEMODE;
temp |= GPMC_SYSCONFIG_IDLEMODE_NOIDLE << GPMC_SYSCONFIG_IDLEMODE_SHIFT;
HWREG(SOC_GPMC_0_REGS + GPMC_SYSCONFIG) = temp;
HWREG(SOC_GPMC_0_REGS + GPMC_IRQENABLE) = 0x0;
HWREG(SOC_GPMC_0_REGS + GPMC_TIMEOUT_CONTROL) = 0x0;
HWREG(SOC_GPMC_0_REGS + GPMC_CONFIG) = 0x2;
HWREG(SOC_GPMC_0_REGS + GPMC_CONFIG1(csNum )) = 0x00001200;
HWREG(SOC_GPMC_0_REGS + GPMC_CONFIG2(csNum )) = 0x00070800;
HWREG(SOC_GPMC_0_REGS + GPMC_CONFIG3(csNum )) = 0x00020200;
HWREG(SOC_GPMC_0_REGS + GPMC_CONFIG4(csNum )) = 0x07000800;
HWREG(SOC_GPMC_0_REGS + GPMC_CONFIG5(csNum )) = 0x00070708;
HWREG(SOC_GPMC_0_REGS + GPMC_CONFIG6(csNum )) = 0x00000180;
HWREG(SOC_GPMC_0_REGS + GPMC_CONFIG7(csNum )) = 0x00000F49; //address space starts at 0x09000000
  • HWREG(SOC_GPMC_0_REGS + GPMC_CONFIG) = 0x2;
    LIMITEDADDRESS (Bit 1=1) in GPMC_CONFIG sets the GPMC so that A26-A11 are not modified during an external memory access. Could this be the problem?
  • Hello Biser,
    Thank you for the reply.
    The result was the same (only read internal pin status of AD0 -AD15) while modifying LIMITEDADDRESS (Bit 1=0) in GPMC_CONFIG.
    Is there any further information or example for AM335x access SRAM via GPMC?
    Many thanks,
    Elvis
  • Have you checked what's the situation on the other port of the SRAM? Maybe the other side is preventing the AM335X side from being read/written?
  • Hello Biser,
    Thank you for your reply.
    We checked the hardware layout  of flip-flop(SN74ALVCH16374), which was reversed in all D and Q pins.
    Current, the GPMC is able to access the SRAM in bootloader(MLO) layer only.
    The GPMC ( config ) registers maintain the same settings both in bootloader and APP state, but the GPMC not work ( the SRAM not accessible ) while in the APP layer.
    Is that any suggestion how to address the issue?
    Elvis
  • Hi Elvis,
    What software are you using on the AM335X?
  • Hi Biser,
    The AM3359 is running based on Starterware.
    The GPMC is not able to access the SRAM while execute the MMUConfigAndEnable(); function.
    Any possible effect between the GPMC and the MMUConfigAndEnable(); function?
    Elvis
  • I'm sorry, I cannot help with Starterware. You can try the Starterware forum: http://e2e.ti.com/support/embedded/starterware/default.aspx.
  • void PINMUX_Config(void)
        //Address Lines
        /* GPMC_A1 */
        HWREG(SOC_CONTROL_REGS + conf_lcd_data1_offset) =
        ( 1 << CONTROL_CONF_GPMC_A1_CONF_GPMC_A1_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_A1_CONF_GPMC_A1_PUDEN_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_A1_CONF_GPMC_A1_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_A1_CONF_GPMC_A1_RXACTIVE_SHIFT);
        /* GPMC_A2 */
        HWREG(SOC_CONTROL_REGS + conf_lcd_data2_offset) =
        ( 1 << CONTROL_CONF_GPMC_A2_CONF_GPMC_A2_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_A2_CONF_GPMC_A2_PUDEN_SHIFT)|
        ( 0 << CONTROL_CONF_GPMC_A2_CONF_GPMC_A2_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_A2_CONF_GPMC_A2_RXACTIVE_SHIFT) ;
        /* GPMC_A3 */
        HWREG(SOC_CONTROL_REGS + conf_lcd_data3_offset) =
        ( 1 << CONTROL_CONF_GPMC_A3_CONF_GPMC_A3_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_A3_CONF_GPMC_A3_PUDEN_SHIFT)|
        ( 0 << CONTROL_CONF_GPMC_A3_CONF_GPMC_A3_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_A3_CONF_GPMC_A3_RXACTIVE_SHIFT) ;
        /* GPMC_A4 */
        HWREG(SOC_CONTROL_REGS + conf_lcd_data4_offset) =
        ( 1 << CONTROL_CONF_GPMC_A4_CONF_GPMC_A4_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_A4_CONF_GPMC_A4_PUDEN_SHIFT)|
        ( 0 << CONTROL_CONF_GPMC_A4_CONF_GPMC_A4_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_A4_CONF_GPMC_A4_RXACTIVE_SHIFT) ;
        /* GPMC_A5 */
        HWREG(SOC_CONTROL_REGS + conf_lcd_data5_offset) =
        ( 1 << CONTROL_CONF_GPMC_A5_CONF_GPMC_A5_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_A5_CONF_GPMC_A5_PUDEN_SHIFT)|
        ( 0 << CONTROL_CONF_GPMC_A5_CONF_GPMC_A5_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_A5_CONF_GPMC_A5_RXACTIVE_SHIFT) ;
        /* GPMC_A6 */
        HWREG(SOC_CONTROL_REGS + conf_lcd_data6_offset) =
        ( 1 << CONTROL_CONF_GPMC_A6_CONF_GPMC_A6_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_A6_CONF_GPMC_A6_PUDEN_SHIFT)|
        ( 0 << CONTROL_CONF_GPMC_A6_CONF_GPMC_A6_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_A6_CONF_GPMC_A6_RXACTIVE_SHIFT) ;
        /* GPMC_AD7 */
        HWREG(SOC_CONTROL_REGS + conf_lcd_data7_offset) =
        ( 1 << CONTROL_CONF_GPMC_A7_CONF_GPMC_A7_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_A7_CONF_GPMC_A7_PUDEN_SHIFT)|
        ( 0 << CONTROL_CONF_GPMC_A7_CONF_GPMC_A7_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_A7_CONF_GPMC_A7_RXACTIVE_SHIFT) ;
        /* GPMC_A8 */
        HWREG(SOC_CONTROL_REGS + vsync_offset) =
        ( 1 << CONTROL_CONF_GPMC_A8_CONF_GPMC_A8_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_A8_CONF_GPMC_A8_PUDEN_SHIFT)|
        ( 0 << CONTROL_CONF_GPMC_A8_CONF_GPMC_A8_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_A8_CONF_GPMC_A8_RXACTIVE_SHIFT) ;
        /* GPMC_A9 */
        HWREG(SOC_CONTROL_REGS + hsync_offset) =
        ( 1 << CONTROL_CONF_GPMC_A9_CONF_GPMC_A9_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_A9_CONF_GPMC_A9_PUDEN_SHIFT)|
        ( 0 << CONTROL_CONF_GPMC_A9_CONF_GPMC_A9_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_A9_CONF_GPMC_A9_RXACTIVE_SHIFT) ;
        /* GPMC_A10 */
        HWREG(SOC_CONTROL_REGS + pclk_offset) =
        ( 1 << CONTROL_CONF_GPMC_A10_CONF_GPMC_A10_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_A10_CONF_GPMC_A10_PUDEN_SHIFT)|
        ( 0 << CONTROL_CONF_GPMC_A10_CONF_GPMC_A10_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_A10_CONF_GPMC_A10_RXACTIVE_SHIFT) ;
        /* GPMC_A11 */
        HWREG(SOC_CONTROL_REGS + ac_bias_en_offset) =
        ( 1 << CONTROL_CONF_GPMC_A11_CONF_GPMC_A11_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_A11_CONF_GPMC_A11_PUDEN_SHIFT)|
        ( 0 << CONTROL_CONF_GPMC_A11_CONF_GPMC_A11_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_A11_CONF_GPMC_A11_RXACTIVE_SHIFT) ;
        /* GPMC_A12 */
        HWREG(SOC_CONTROL_REGS + lcd_data8_offset) =
        ( 1 << CONTROL_CONF_GPMC_A12_CONF_GPMC_A12_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_A12_CONF_GPMC_A12_PUDEN_SHIFT)|
        ( 0 << CONTROL_CONF_GPMC_A12_CONF_GPMC_A12_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_A12_CONF_GPMC_A12_RXACTIVE_SHIFT) ;
        /* GPMC_A13 */
        HWREG(SOC_CONTROL_REGS + lcd_data9_offset) =
        ( 1 << CONTROL_CONF_GPMC_A13_CONF_GPMC_A13_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_A13_CONF_GPMC_A13_PUDEN_SHIFT)|
        ( 0 << CONTROL_CONF_GPMC_A13_CONF_GPMC_A13_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_A13_CONF_GPMC_A13_RXACTIVE_SHIFT) ;
        /* GPMC_A14 */
        HWREG(SOC_CONTROL_REGS + lcd_data10_offset) =
        ( 1 << CONTROL_CONF_GPMC_A14_CONF_GPMC_A14_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_A14_CONF_GPMC_A14_PUDEN_SHIFT)|
        ( 0 << CONTROL_CONF_GPMC_A14_CONF_GPMC_A14_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_A14_CONF_GPMC_A14_RXACTIVE_SHIFT) ;
        /* GPMC_A15 */
        HWREG(SOC_CONTROL_REGS + lcd_data11_offset) =
        ( 1 << CONTROL_CONF_GPMC_A15_CONF_GPMC_A15_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_A15_CONF_GPMC_A15_PUDEN_SHIFT)|
        ( 0 << CONTROL_CONF_GPMC_A15_CONF_GPMC_A15_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_A15_CONF_GPMC_A15_RXACTIVE_SHIFT) ;
        /* GPMC_A16 */
        HWREG(SOC_CONTROL_REGS + conf_gpmc_a0_offset) =
        ( 4 << CONTROL_CONF_GPMC_A16_CONF_GPMC_A16_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_A16_CONF_GPMC_A16_PUDEN_SHIFT)|
        ( 0 << CONTROL_CONF_GPMC_A16_CONF_GPMC_A16_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_A16_CONF_GPMC_A16_RXACTIVE_SHIFT);
        //Data Lines
        /* GPMC_AD0 */
        HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(0)) =
        ( 0 << CONTROL_CONF_GPMC_AD0_CONF_GPMC_AD0_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_AD0_CONF_GPMC_AD0_PUDEN_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD0_CONF_GPMC_AD0_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD0_CONF_GPMC_AD0_RXACTIVE_SHIFT);
        /* GPMC_AD1 */
        HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(1)) =
        ( 0 << CONTROL_CONF_GPMC_AD1_CONF_GPMC_AD1_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_AD1_CONF_GPMC_AD1_PUDEN_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD1_CONF_GPMC_AD1_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD1_CONF_GPMC_AD1_RXACTIVE_SHIFT);
        /* GPMC_AD2 */
        HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(2)) =
        ( 0 << CONTROL_CONF_GPMC_AD2_CONF_GPMC_AD2_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_AD2_CONF_GPMC_AD2_PUDEN_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD2_CONF_GPMC_AD2_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD2_CONF_GPMC_AD2_RXACTIVE_SHIFT);
        /* GPMC_AD3 */
        HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(3)) =
        ( 0 << CONTROL_CONF_GPMC_AD3_CONF_GPMC_AD3_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_AD3_CONF_GPMC_AD3_PUDEN_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD3_CONF_GPMC_AD3_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD3_CONF_GPMC_AD3_RXACTIVE_SHIFT);
        /* GPMC_AD4 */
        HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(4)) =
        ( 0 << CONTROL_CONF_GPMC_AD4_CONF_GPMC_AD4_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_AD4_CONF_GPMC_AD4_PUDEN_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD4_CONF_GPMC_AD4_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD4_CONF_GPMC_AD4_RXACTIVE_SHIFT);
        /* GPMC_AD5 */
        HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(5)) =
        ( 0 << CONTROL_CONF_GPMC_AD5_CONF_GPMC_AD5_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_AD5_CONF_GPMC_AD5_PUDEN_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD5_CONF_GPMC_AD5_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD5_CONF_GPMC_AD5_RXACTIVE_SHIFT);
        /* GPMC_AD6 */
        HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(6)) =
        ( 0 << CONTROL_CONF_GPMC_AD6_CONF_GPMC_AD6_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_AD6_CONF_GPMC_AD6_PUDEN_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD6_CONF_GPMC_AD6_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD6_CONF_GPMC_AD6_RXACTIVE_SHIFT);
        /* GPMC_AD7 */
        HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(7)) =
        ( 0 << CONTROL_CONF_GPMC_AD7_CONF_GPMC_AD7_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_AD7_CONF_GPMC_AD7_PUDEN_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD7_CONF_GPMC_AD7_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD7_CONF_GPMC_AD7_RXACTIVE_SHIFT);
        /* GPMC_AD8 */
        HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(8)) =
        ( 0 << CONTROL_CONF_GPMC_AD8_CONF_GPMC_AD8_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_AD8_CONF_GPMC_AD8_PUDEN_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD8_CONF_GPMC_AD8_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD8_CONF_GPMC_AD8_RXACTIVE_SHIFT);
        /* GPMC_AD9*/
        HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(9)) =
        ( 0 << CONTROL_CONF_GPMC_AD9_CONF_GPMC_AD9_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_AD9_CONF_GPMC_AD9_PUDEN_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD9_CONF_GPMC_AD9_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD9_CONF_GPMC_AD9_RXACTIVE_SHIFT);
        /* GPMC_AD10*/
        HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(10)) =
        ( 0 << CONTROL_CONF_GPMC_AD10_CONF_GPMC_AD10_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_AD10_CONF_GPMC_AD10_PUDEN_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD10_CONF_GPMC_AD10_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD10_CONF_GPMC_AD10_RXACTIVE_SHIFT);
        /* GPMC_AD11*/
        HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(11)) =
        ( 0 << CONTROL_CONF_GPMC_AD11_CONF_GPMC_AD11_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_AD11_CONF_GPMC_AD11_PUDEN_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD11_CONF_GPMC_AD11_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD11_CONF_GPMC_AD11_RXACTIVE_SHIFT);
        /* GPMC_AD12*/
        HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(12)) =
        ( 0 << CONTROL_CONF_GPMC_AD12_CONF_GPMC_AD12_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_AD12_CONF_GPMC_AD12_PUDEN_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD12_CONF_GPMC_AD12_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD12_CONF_GPMC_AD12_RXACTIVE_SHIFT);
        /* GPMC_AD13*/
        HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(13)) =
        ( 0 << CONTROL_CONF_GPMC_AD13_CONF_GPMC_AD13_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_AD13_CONF_GPMC_AD13_PUDEN_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD13_CONF_GPMC_AD13_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD13_CONF_GPMC_AD13_RXACTIVE_SHIFT);
        /* GPMC_AD14*/
        HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(14)) =
        ( 0 << CONTROL_CONF_GPMC_AD14_CONF_GPMC_AD14_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_AD14_CONF_GPMC_AD14_PUDEN_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD14_CONF_GPMC_AD14_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD14_CONF_GPMC_AD14_RXACTIVE_SHIFT);
        /* GPMC_AD15 */
        HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_AD(15)) =
        ( 0 << CONTROL_CONF_GPMC_AD15_CONF_GPMC_AD15_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_AD15_CONF_GPMC_AD15_PUDEN_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD15_CONF_GPMC_AD15_PUTYPESEL_SHIFT) |
        ( 1 << CONTROL_CONF_GPMC_AD15_CONF_GPMC_AD15_RXACTIVE_SHIFT);
        //PUTYPESEL bit to be verified
        /* GPMC_WAIT0 */
        HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_WAIT0) =
        ( 0 << CONTROL_CONF_GPMC_WAIT0_CONF_GPMC_WAIT0_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_WAIT0_CONF_GPMC_WAIT0_PUDEN_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_WAIT0_CONF_GPMC_WAIT0_PUTYPESEL_SHIFT)|
        ( 0 << CONTROL_CONF_GPMC_WAIT0_CONF_GPMC_WAIT0_RXACTIVE_SHIFT);
        /* GPMC_CS3 */
        HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_CSN(3)) =
        ( 0 << CONTROL_CONF_GPMC_CSN3_CONF_GPMC_CSN3_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_CSN3_CONF_GPMC_CSN3_PUDEN_SHIFT)|
        ( 0 << CONTROL_CONF_GPMC_CSN3_CONF_GPMC_CSN3_PUTYPESEL_SHIFT)|
        ( 0 << CONTROL_CONF_GPMC_CSN3_CONF_GPMC_CSN3_RXACTIVE_SHIFT);
        /* GPMC_BE0N_CLE */
        HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_BE0N_CLE) =
        ( 0 << CONTROL_CONF_GPMC_BE0N_CLE_CONF_GPMC_BE0N_CLE_MMODE_SHIFT ) |
        ( 0 << CONTROL_CONF_GPMC_BE0N_CLE_CONF_GPMC_BE0N_CLE_PUDEN_SHIFT )  |
        ( 0 << CONTROL_CONF_GPMC_BE0N_CLE_CONF_GPMC_BE0N_CLE_PUTYPESEL_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_BE0N_CLE_CONF_GPMC_BE0N_CLE_RXACTIVE_SHIFT);
        /* GPMC_OEN_REN */
        HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_OEN_REN) =
        ( 0 << CONTROL_CONF_GPMC_OEN_REN_CONF_GPMC_OEN_REN_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_OEN_REN_CONF_GPMC_OEN_REN_PUDEN_SHIFT)  |
        ( 0 << CONTROL_CONF_GPMC_OEN_REN_CONF_GPMC_OEN_REN_PUTYPESEL_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_OEN_REN_CONF_GPMC_OEN_REN_RXACTIVE_SHIFT);
        /* GPMC_WEN */
        HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_WEN) =
        ( 0 << CONTROL_CONF_GPMC_WEN_CONF_GPMC_WEN_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_WEN_CONF_GPMC_WEN_PUDEN_SHIFT)  |
        ( 0 << CONTROL_CONF_GPMC_WEN_CONF_GPMC_WEN_PUTYPESEL_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_WEN_CONF_GPMC_WEN_RXACTIVE_SHIFT);
        /* GPMC_BE1N_CLE */
        HWREG(SOC_CONTROL_REGS + CONTROL_CONF_GPMC_BE1N) =
        ( 0 << CONTROL_CONF_GPMC_BE1N_CONF_GPMC_BE1N_MMODE_SHIFT ) |
        ( 0 << CONTROL_CONF_GPMC_BE1N_CONF_GPMC_BE1N_PUDEN_SHIFT )  |
        ( 0 << CONTROL_CONF_GPMC_BE1N_CONF_GPMC_BE1N_PUTYPESEL_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_BE1N_CONF_GPMC_BE1N_RXACTIVE_SHIFT);
        /* DPRAM INTR GPIO0_8*/
        HWREG(SOC_CONTROL_REGS + lcd_data12_offset) =
        ( 7 << CONTROL_CONF_GPMC_A16_CONF_GPMC_A16_MMODE_SHIFT) |
        ( 0 << CONTROL_CONF_GPMC_A16_CONF_GPMC_A16_RXACTIVE_SHIFT);
        /* DPRAM SEM GPIO0_9 */
        HWREG(SOC_CONTROL_REGS + lcd_data13_offset) =
        int csNum = 3;
        unsigned int temp;
        HWREG(SOC_GPMC_0_REGS + GPMC_CONFIG1(csNum )) = 0x00001000; ;
    void MMUConfigAndEnable(void)
        ** Define DDR memory region of AM335x. DDR can be configured as Normal
        ** memory with R/W access in user/privileged modes. The cache attributes
        ** specified here are,
        ** Inner - Write through, No Write Allocate
        ** Outer - Write Back, Write Allocate
        REGION regionDdr = {
                            MMU_PGTYPE_SECTION, START_ADDR_DDR, NUM_SECTIONS_DDR,
                            MMU_MEMTYPE_NORMAL_NON_SHAREABLE(MMU_CACHE_WT_NOWA,
                                                             MMU_CACHE_WB_WA),
                            MMU_REGION_NON_SECURE, MMU_AP_PRV_RW_USR_RW,
                            (unsigned int*)pageTable
        ** Define OCMC RAM region of AM335x. Same Attributes of DDR region given.
        REGION regionOcmc = {
                             MMU_PGTYPE_SECTION, START_ADDR_OCMC, NUM_SECTIONS_OCMC,
                                                              MMU_CACHE_WB_WA),
        ** Define Device Memory Region. The region between OCMC and DDR is
        ** configured as device memory, with R/W access in user/privileged modes.
        ** Also, the region is marked 'Execute Never'.
        REGION regionDev = {
                            MMU_PGTYPE_SECTION, START_ADDR_DEV, NUM_SECTIONS_DEV,
                            MMU_MEMTYPE_DEVICE_SHAREABLE,
                            MMU_AP_PRV_RW_USR_RW  | MMU_SECTION_EXEC_NEVER,
        /* Initialize the page table and MMU */
        MMUInit((unsigned int*)pageTable);
        /* Map the defined regions */
        MMUMemRegionMap(&regionDdr);
        MMUMemRegionMap(&regionOcmc);
        MMUMemRegionMap(&regionDev);
        /* Now Safe to enable MMU */
        MMUEnable((unsigned int*)pageTable);
    void main()
        unsigned int    error = 0;
        unsigned int    i;
        unsigned int *pmem;
           GPMC_DPRAM_Init();
        PINMUX_Config();
        while(1)
            pmem =  (unsigned int *) 0x09000000;
            // fill data
            for(i=0; i<0x2; i+=2)
                *pmem++ = 0x1234;   // After this instruction getting exception
            // verify data
            for(i=0; i<0x20; i+=1)
                if(*pmem++ != 0x12)
                    error++;
                else
                    error = error;
    **                              END OF FILE
    /**************** Memory Map Configuration On Target Connect ************************/
    OnTargetConnect()
        GEL_MapOff();
        GEL_MapReset();
        GEL_MapAddStr(0x00020000, 0, 0x0000C000, "R", 0);    // Boot ROM
        GEL_MapAddStr(0x08000000, 0, 0x00100000, "R|W", 0);  // 16MB GPMC External/NOR (on GP Daughtercard)
        GEL_MapAddStr(0x09000000, 0, 0x00080000, "R|W", 0);  // GPMC DPRAM
        GEL_MapAddStr(0x40020000, 0, 0x0000C000, "R", 0);    // Boot ROM (also at 0x20000)
        GEL_MapAddStr(0x402F0400, 0, 0x0000FC00, "R|W", 0);  // SRAM Internal
        GEL_MapAddStr(0x40300000, 0, 0x00010000, "R|W", 0);  // OCMC-RAM
        GEL_MapAddStr(0x44000000, 0, 0x00400000, "R|W", 0);  // L3F CFG Regs
        GEL_MapAddStr(0x44800000, 0, 0x00400000, "R|W", 0);  // L3S CFG Regs
        GEL_MapAddStr(0x44C00000, 0, 0x00400000, "R|W", 0);  // L4_WKUP
        GEL_MapAddStr(0x46000000, 0, 0x00400000, "R|W", 0);  // McASP0 Data
        GEL_MapAddStr(0x46400000, 0, 0x00400000, "R|W", 0);  // McASP1 Data
        GEL_MapAddStr(0x47400000, 0, 0x00005000, "R|W", 0);  // USB0/1
        GEL_MapAddStr(0x47810000, 0, 0x00010000, "R|W", 0);  // MMCHS2
        GEL_MapAddStr(0x48000000, 0, 0x01000000, "R|W", 0);  // L4 PER
        GEL_MapAddStr(0x49000000, 0, 0x00B00000, "R|W", 0);  // EDMA
        GEL_MapAddStr(0x4A000000, 0, 0x01000000, "R|W", 0);  // L4_FAST
        GEL_MapAddStr(0x4B160000, 0, 0x1000, "R|W", 0);  // DebugSS_DRM
        GEL_MapAddStr(0x4C000000, 0, 0x01000000, "R|W", 0);  // EMIF
        GEL_MapAddStr(0x50000000, 0, 0x01000000, "R|W", 0);  // GPMC Regs
        GEL_MapAddStr(0x56000000, 0, 0x01000000, "R|W", 0);  // SGX530
        GEL_MapAddStr(0x80000000, 0, 0x20000000, "R|W", 0);  // 512MB DDR2 external memory
        GEL_MapOn();
        AM335xStartState();
        AM335x_EVM_Initialization();
        DDR_DataTransferCheck();
        Disable_Watchdog();
    DPRAM.pdfDPRAM_1.pdfHello Elvis,
    Am working on same DPRAM interface with AM335x GPMC.
    Here am facing problem when i tried to access memory which i have mapped in .gel file i.e
    *pmem++ = 0x1234;
    After that instruction its throwing exception like "No source available for "0x4030fc10" . Here attached the schematics, source file and .gel file please have a look and let me know any other configuration is required.
    Please let me know if any other setting as per my HW configuration.
    Thanks & Regards,
    Sudheer A.
