• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » DLP & MEMS » DLP LightCrafter Development Platform » How to upgrade software’s on DLP® LightCrafter™
Share
DLP & MEMS
  • Forums
Options
  • Subscribe via RSS
  • Divya
    Posted by Divya
    on Jun 21 2012 17:46 PM
    Expert3680 points
    MSP430 and FPGA Firmware Upgrade:
    Connect the LightCrafter to the PC via USB cable. After establishing the connection through GUI, open the ‘Solution/ Upgrade’ tab and select the SW package from the drop down menu to be FPGA Firmware/ MSP430 Software. Browse the location of the downloaded software and click ‘Install’. And, wait until “Command SUCCESS” appears on the bottom left of the GUI screen.
    DM365 Software Upgrade:
    Download the DM365 Software.
    To copy the image, unzip with 7-zip. Free download of the 7-zip software is available here.
    Select the file in the compressed folder, right click, and select extract under 7-zip menu. It will unzip to a 4GB file.
    An SD card with 4GB size or greater can be used (Transcend 4GB class 10 micro SD card has been tested).
    For loading the image to the SD card, Image writer utility is required.
    For windows,
    Download Win32DiskImager from: link
    Insert the SD card and start Win32DiskImager
    Select the image file and choose the letter drive for the SD card
    Click on write.
    If an error message appears stating that there is not enough memory on the disk, disregard and continue. The actual card sizes vary and not all the card is populated with data.
    For Linux,
    Use DD command:
    Insert the sd card in your linux machine. Find out which device /dev/sda or /dev/sdb is detected by the OS. In our test case, it is typically detected as /dev/sdb
    On the command prompt execute “dd if=/path/to/dm365sw_3_0sd4gb.dd of=/dev/sdb"
    The card will be partitioned into two: a 44MB FAT32 formatted and a Linux partition of 40MB. The FAT32 partition contains the boot source for the DM365 boot loader. The Linux Partition includes the linux kernel and file system.
    Now, keep the switch shown in figure below pointed to the micro SD card and keep the micro SD card in. Power cycle the LightCrafter.
    LightCrafter will boot and run from the card (a little slower than NAND). If you need to use the earlier version, just move the DIP switch away from the SD Card and it will boot from NAND on the next power-up. To switch back to booting from SD card, move the DIP switch to point to the SD card. However, solutions stored are not compatible with both versions.
     After a projected pattern with Red, Green and Blue vertical bars is seen on the screen, run the GUI and the updated version numbers will be visible on the GUI.
    www.ti.com/mems
    firmware FPGA LightCrafterGUI Software
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
  • Peter Ferland
    Posted by Peter Ferland
    on Mar 22 2012 10:13 AM
    Prodigy110 points
    Divya,
    Thanks for the instructions, but it appears as though a 4GB card with a formatted capacity of less than the transcend uSD card you tested will not work with Win32 disk imager.  I'm going to buy an 8GB card that will certainly be large enough, but since you are only using 80MB (if even that) could you create a much smaller image?
    Also, the latest version I've found for the DM365 image is 2.5, I assume that 3.0 will be uploaded soon?
    Report Abuse
    • Reply
  • Divya
    Posted by Divya
    on Mar 22 2012 10:49 AM
    Expert3680 points
    Peter,
    The real capacity of the transcend card we tested appeared to be 3.85GB on the Linux system. Can you try using the Physdiskwrite image writing tool (link) for writing the image to SD card. The image should certainly fit in 8GB card. The latest versions of the DM365 (v3.0), FPGA (v2.4.39), GUI (v0.40) and MSP430 (v2.4) will be soon uploaded.
    Thanks for your patience.
    Divya
    www.ti.com/mems
    Report Abuse
    • Reply
  • Phillip Wilt
    Posted by Phillip Wilt
    on Jun 15 2012 19:43 PM
    Prodigy10 points
    what is the status of the newest firmwares listed in this post please?
    Report Abuse
    • Reply
  • Divya
    Posted by Divya
    Expert3680 points
    Hi Phillip,
    Welcome to DLP section of TI E2E Community!
    Sorry for the delayed response. The new firmware might take at least 2 more weeks before it is available on ti.com. Our intention was to fix the USB issue before releasing the upgrades.
    We think we found the cause for USB connection issues on the Lightcrafter and would be releasing the problem statement and the fix soon. The firmware needs to be DVT'ed once more.
    Divya
    www.ti.com/mems
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
