• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » DLP & MEMS » DLP LightCrafter Development Platform » Trigger pins
Share
DLP & MEMS
  • Forums
Options
  • Subscribe via RSS
Trigger pins
Trigger pins
This question is not answered
Nghia Huynh
Posted by Nghia Huynh
on Apr 27 2012 13:16 PM
Prodigy80 points
According to pg 31 of the User Guide:
Table 4-1. Trigger Connector Pins
DESCRIPTION PIN SUPPLY RANGE
Trigger Supply 1 3.3 V
Trigger Input 2 3.3 V
Trigger Output 3 3.3 V
Ground 4
3.3 V
Are these 4 pins physically like this:
If I have a circuit look something like this: Pin1------------switch-------------Pin2
Would closing the switch issue a trigger signal?
In the software, under the "Pattern Sequence" tab, "Input trigger" is set to "External (Positive)." Shorting pin 1 and 2 produces no result but shorting pin 2 and 3 causes the pattern to change. Could someone help me explain why?
Also, "Exposure time" is set to 0 which according to the user guide would cause a pattern to be displayed until the next trigger signal is received. However, after shorting pin 2 and 3 briefly to change to a pattern, (at this point, pin2 and 3 are no longer shorted) that pattern only stay displayed for a few seconds and then the screen goes dark. Could someone help me explain this as well?
Thank you
LightCrafter
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Divya
    Posted by Divya
    on May 09 2012 14:42 PM
    Expert3680 points
    Hi Tommy,
    I apologize for delayed response. The physical placement of the pins is correct in the above mentioned image.
    If you are providing an active high external trigger ( "External (Positve)" input trigger setting in the GUI) at 3.3V, then you need to connect the trigger generator (or pulse generator) between Pin 2 and GND (Pin 4).
    This enables the display of pattern when each trigger signal is issued. If you are attempting something different, please let me know.
    Divya
    www.ti.com/mems
    Report Abuse
    • Reply
  • Nghia Huynh
    on May 16 2012 15:46 PM
    Prodigy80 points
    Hi Divya,
    I am thinking about one of these options:
    So if the pulse generator outputs a voltage square wave with amplitude = 10V, freq = 0.5 Hz, then the pattern would switch every 2 seconds. Is that correct?
    By the way, I measured the voltage difference between these pins (directly on the LightCrafter, without the circuit above):
    - V1 - V4 = 0 V
    - V2 - V4 = 3.3 V
    - V1 - V2 = 0 V
    Could you help me explain why this is the case? I thought V1 - V4 = 3.3V
    Thank you,
    Tommy
    LightCrafter
    Report Abuse
    • Reply
  • Divya
    Posted by Divya
    on May 22 2012 15:16 PM
    Expert3680 points
    Hi Tommy,
    Sorry for the delayed response.
    First, I recommend not to apply 10V amplitude to the pulse generator. In the figure below (Lightcrafter System Board Schematic), R285 is not connected on the board by default. So, you are able to measure 3.3V between Pins 2 and 4. You need to connect a 0 ohm (R285) resistor, to use the set-up with the amplifier. Else, supplying a positive trigger (pin2 and GND) with 3.3V amplitude would suffice your needs.
    You can change the voltage levels to either 5V or 1.8V by removing R282 and installing R281(for 5V) or R283(for 1.8V). Please note that 3.3V is recommended for proper operation.
    www.ti.com/mems
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
