• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » C6000 Multicore DSP » Keystone Multicore Forum (C66, 66A, AM5) » C6678 Memory performance
Share
C6000 Multicore DSP
  • Forums
  • Announcements
Options
  • Subscribe via RSS
Training Available
TI provides self-paced online training that introduces the primary components of the KeyStone II family of SoC devices.
  • KeyStone II SoC Overview >
  • KeyStone II Software Overview >
  • KeyStone II ARM Cortex-A15 Corepac Overview >
  • More Information >
  • Check out
    Multicore Mix blog
    • $core_v2_blog.Current.Name
      Geeks UNITE for Geek Pride Day
      Posted 1 day ago
      by Lauren Reed1
      Happy Geek Pride Day from the Processors team! We wanted to celebrate...
      OpenMP - All aboard!
      Posted 3 days ago
      by Debbie Greenstreet
      With so many end products today relying on multicore DSPs for...
      A look back: Two years of Multicore Mix
      Posted 4 days ago
      by Lauren Reed1
      A big thank you to everyone who participated in our contest last...
    This question is answered
    Ya D
    Posted by Ya D
    on Sep 19 2011 02:22 AM
    Intellectual485 points
    I am looking for information about memory performance in the C6678 DSP.
    More specifically, when L1 and L2 are SRAM only, what is the throughput for each of them ?
    Also, what is the throughput of the shared memory when accessed by all cores simultaneously
    (that is, how many cores can read from the shared memory together) ?
    Same for the DDR3. Does DDR3 access interfere with shared memory access (or anything else)?
    I looked in the documentations and could not find anything related.
    Thank you.
    KeyStone C6778
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Chad Courtney
      Posted by Chad Courtney
      on Sep 19 2011 10:04 AM
      Mastermind22595 points
      Ya,
      There is a performance application note that will be released soon, that will address these and more questions regarding memory and peripheral performance.
      Chad
      Please click the Verify Answer button on this post if it answers your question.
      Report Abuse
      • Reply
    • Ya D
      Posted by Ya D
      on Sep 19 2011 13:36 PM
      Thank you.
      Do you know when? ( its a little bit urgent)
      Is there any way to get quick answers soon?
      Thank you again.
      Report Abuse
      • Reply
    • Chad Courtney
      on Sep 19 2011 14:04 PM
      I expect it will be out next week.  I'll have someone try to follow up with some data points.  That said, you'll want to be more specific as to what the source and destination are specifically and what the transfer mechanism is (EDMA, IDMA, CorePacs, Peripherals)
      Chad
      Report Abuse
      • Reply
    • Ya D
      Posted by Ya D
      on Sep 19 2011 14:14 PM
      Thank you.
      I am using EDMA for DDR to L2 and shared memory.
      The CorePacs operate directly on L2 and shared memory.
      But I am also interested (for comparasion only) about access directly to DDR from the core.
      Report Abuse
      • Reply
    • Derek Brown
      Posted by Derek Brown
      on Sep 20 2011 09:17 AM
      Verified Answer
      Verified by Ya D
      Intellectual1880 points
      Ya,
      Hopefully, the below information will be adequate until the performance application note is published.
      All throughput figures listed below assume that the DSP is operating at 1 GHz (1000 Mhz).
      Raw Memory Throughput:
      • L1D SRAM: L1D operates at DSP/1 frequency, so it can be accessed every cycle. L1D is accessed through a 256 bit interface, so the maximum throughput of L1D is 32,000 megabytes per second. ((256 bit buswidth)/(8 bits/byte)*(1000M)=32000MB/s)
      • L2 SRAM: L2 operates at DSP/2 frequency, so it can be accessed every other cycle. L2 is accessed through a 256 bit interface, so the maximum throughput of L2 is 16,000 megabytes per second. ((256 bit buswidth)/(8 bits/byte)*(1000M/2)=16000MB/s)
      • MSMC SRAM: MSMC operates at DSP/2 frequency, so it can be accessed every other cycle. MSMC has 4 memory banks, each of which is accessed through a 256 bit interface. All 4 banks can be accessed simultaneously by separate cores or other system masters. If the data in MSMC SRAM is allocated so that each of the 4 banks are being fulling utilized simultaneously, the maximum throughput of the shared memory is 64,000 megabytes per second. ((256 bit buswidth)/(8 bits/byte)*(1000M/2)*(4 banks)=64000MB/s). Up to 4 masters can access MSMC simultaneously.
      • DDR3: DDR3 data is accessed through a 64-bit interface. Assuming that DDR3-1333 is operating at the maximum rate, the theoretical maximum throughput 10,664 megabytes per second. ((64bits)/(8bit/byte)*(1333M)=10664MB/s). Only one master can access the DDR3 at a time.
      Maximum Throughputs for C66x core and DMA masters:
      • C66x Core: (128 bit buswidth)/(8bit/byte)*(1000M)=16000MB/s
      • IDMA: (256 bit buswidth)/(8bit/byte)*(1000M/2)=16000MB/s
      • EDMA0: (256 bit buswidth)/(8bit/byte)*(1000M/2)=16000MB/s
      • EDMA1: (128 bit buswidth)/(8bit/byte)*(1000M/3)=5333MB/s
      • EDMA2: (128 bit buswidth)/(8bit/byte)*(1000M/3)=5333MB/s
      DDR3 Accesses using EDMA:
      If you use EDMA0 to access DDR3, then you should be able to get data at a maximum rate of 10664 megabytes per second, excluding any idle time required for setting up the EDMA transaction. If using EDMA1 or EDMA2 to access DDR3, then the maximim rate that you can get data from DDR3 is 5333 megabytes per second, exculding any idle time required for setting up the EDMA trasaction.
      C66x Core Accessed to DDR3:
      Assuming that L1D, L2, and MSMC are all configured as SRAM (caching disabled) then single reads to DDR3 will stall the DSP 89 cycles. Burst reads to DDR3 will stall the DSP 43.2 cycles. Writes to DDR3 will not stall the DSP since the data will be written to DDR3 by the DDR3 controller; however, it will take some time for the data to actually arrive in DDR3.
      Derek
      Derek
      If you need more help, please reply back. If this answers the question, please click  Verify Answer , below.
      C6678 Throughput Memory Access
      Report Abuse
      • Reply
    • Ya D
      Posted by Ya D
      on Sep 20 2011 09:36 AM
      Thank you very much.
      This is exactly what I need.
      Report Abuse
      • Reply
    • Ya D
      Posted by Ya D
      on Sep 25 2011 02:14 AM
      One last question,
      You said that direct access to DDR3 stalls the DSP for 89 cycles. What causes the stall? DDR3 latency? How do you get this number?
      Thank you
      Report Abuse
      • Reply
    • Derek Brown
      on Sep 27 2011 14:53 PM
      Ya,
      Yes, this delay is primarily caused by DDR3 latency. There is also some delay in the bus for accessing DDR3, since the bus that is used to access DDR3 operates at a slower rate than the DSP.
      I will get back with you on how these numbers are being measured.
      Derek
      Derek
      C66x DDR3
      Report Abuse
      • Reply
    • Ya D
      Posted by Ya D
      on Nov 15 2011 04:05 AM
      any updates?
      Is the performance document published yet?
      I could not find it anywhere.
      Thanks.
      Report Abuse
      • Reply
    • Chad Courtney
      on Nov 15 2011 13:25 PM
      Ya,
      We had a number of internal reviews with many changes for clarification and haven't published it yet.  We are really close and it should be out in the next few weeks.
      Chad
      Report Abuse
      • Reply
    • Ivan Krechetov
      Posted by Ivan Krechetov
      on Apr 13 2012 17:32 PM
      Prodigy210 points
      I have a problem with IDMA1 (L2<->L1) performance (only approx. 3,3Gb/s), pls. look thread http://e2e.ti.com/support/dsp/c6000_multi-core_dsps/f/639/t/182014.aspx#656195
      Ivan
      Report Abuse
      • Reply
    • Chad Courtney
      on Apr 16 2012 14:46 PM
      Ivan,
      I have someone who's digging into this and will be replying on the other thread.
      Chad
      Report Abuse
      • Reply
    • Teun van Kuppeveld
      Posted by Teun van Kuppeveld
      on Apr 17 2012 09:27 AM
      Prodigy50 points
      Dear Chad,
      Is the document published at this moment?
      Teun
      Report Abuse
      • Reply
    • Chad Courtney
      on Apr 17 2012 10:04 AM
      Teun,
      It's documented in the Keystone Throughput Performance Guide http://www.ti.com/lit/an/sprabk5/sprabk5.pdf
      Chad
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
