C66x Problem service MSI-interrupt in EP-mode
Need help!!!
Problem:
TDMXEVM6678 on AMC adapter  plug to PCIe slot in PC.
TDMXEVM6678 memory configuration L1P=32K,L1D=32K,L2-SRAM
PC enable MSI-interrupt   by write MSI_0_SET_REG :  PCI_ADDR[BAR0 + 0x108] = 1
PC periodic generate MSI-interrupt   by write to MSI_IRQ register:  PCI_ADDR[BAR0 + 0x54] = 0
On TDMXEVM6678 run application  HWI-routine hwi_msi_func call only one time
I think Interrupt request not clear, but I don't  know to do any more?
File app.cfg
  var Hwi = xdc.useModule('ti.sysbios.hal.Hwi');
  var hwi_msiParams = new Hwi.Params();
  hwi_msiParams.instance.name = "HWI_INT4";
  hwi_msiParams.eventId = 17; // MSI-interrupt event from DataSheet
  hwi_msiParams.priority = 4;
  hwi_msiParams.enableInt = false;
  hwi_msiParams.arg = 1;
  Program.global.HWI_INT4 = Hwi.create(4, "&hwi_msi_func", hwi_msiParams);
  Hwi.common$.namedInstance = false;
File: main.c
#include <ti/csl/cslr_pciess_app.h>
Void main()
    Hwi_enableInterrupt(4);
    BIOS_start();     /* enable interrupts and start SYS/BIOS */
uint32v count = 0 ;
void hwi_msi_func(int arg)
  CSL_Pciess_appRegs* baseAddr = priv->handle ;
  CSL_Pciess_appMsix_irqRegs* msi_ptr = baseAddr->MSIX_IRQ ;
  Uint32 val = baseAddr->MSI_IRQ ;
  Uint32 status;
  status =  msi_ptr[0].MSI_IRQ_STATUS ;
  msi_ptr[0].MSI_IRQ_STATUS = status[0] ; // clear interrupt request
  // for check  isr calls count by PC side
  ++count ;
  baseAddr->GPR[0] = count;
  • Problem is solved, I find secret added. Need write also IRQ_EOI register in HWI rotine
    uint32v count = 0 ;
      Uint32 status;
      msi_ptr[0].MSI_IRQ_STATUS = status ; // clear interrupt request
       // !!!!!!!! secret added !!!
       baseAddr->IRQ_EOI = 4 ; // say PCIe "interrupt is servised"
      ++count ;
