I think this must be a very simple question, but I am new to the uTCA concept and also to the C6678 EVM.
I have followed this older post: http://e2e.ti.com/support/dsp/c6000_multi-core_dsps/f/639/t/115240.aspx?PageIndex=4
It directs me to update my MSP430 to this newest code and then, I am assuming, I should be able to connect via SRIO to the MCH. Seems quite simple.
However, I get the distinct feeling that when I programmed it the NVRAM did not get programmed correctly. When I ask the chassis what FRU's are registered, I values that seem like they are defaults or even bad values that the MSP430 source code says should have been overwritten.
When I programmed it, I merely built the code and the loaded it via CCSv5 and the MSP-FET 430 UIF programmer. Is there a script or something that I was supposed to run to update the NVRAM. I feel like this was a bit simple and incorrect.
Thanks for you help! Please see below for some sample fru data.
Here is a sample of what my fru info was and my link info:
The FRU name comes up FRU Unknown - odd. But I can use FRU ID #11 to control the EVM's LEDs. So I know this is the right address.
(0x20, FRU# 00)     (0xf0, 0x01)     VT UTCA SHELF     M4 (Active)
(0x82, FRU# 00)     (0xc2, 0x01)     VT UTCA CARRIER   M4 (Active)
(0x82, FRU# 01)     (0xf2, 0x61)     SH FRU DEV1       M4 (Active)
(0x82, FRU# 02)     (0xf2, 0x62)     SH FRU DEV2       M4 (Active)
(0x82, FRU# 03)     (0xc2, 0x61)     VT UTCA MCMC      M4 (Active)
(0x82, FRU# 04)     (0xc2, 0x62)     VT UTCA MCMC      M4 (Active)
(0x82, FRU# 05)     (0xc1, 0x61)     VT AMC719         M4 (Active)
(0x82, FRU# 11)     (0x00, 0x00)     FRU Unknown       M4 (Active)
(0x82, FRU# 40)     (0x1e, 0x61)     VT VT095          M4 (Active)
(0x82, FRU# 41)     (0x1e, 0x62)     VT VT095          M4 (Active)
(0x82, FRU# 50)     (0x0a, 0x61)     VT UTC010         M4 (Active)
(0x82, FRU# 79)     (0xf3, 0x60)     TELCO ALARM       M4 (Active)
I can also use FRU ID#11 to get the AMC Point to Point results. These look like they should be correct - the SRIO is showing available. However the GUID is 0x1BAD1BAD... this is my first hint that something did not go right :)
AMC Point-To-Point Results
OEM Guid Count 01
      GUID[00]
0x1bad1bad00000000000000000bad0bad
Record Type :AMC
Channels Defined :3
AMC Channel Descriptor #0
Lane 0 = Port0
Lane 1 = Port1
Lane 2 = Port31
Lane 3 = Port31
AMC Channel Descriptor #1
Lane 0 = Port8
Lane 1 = Port9
Lane 2 = Port10
Lane 3 = Port11
AMC Channel Descriptor #2
Lane 0 = Port4
Lane 1 = Port5
Lane 2 = Port31
Lane 3 = Port31
AMC Link Descriptor #0
      Channel
ID          0
Lane Mask 0x1
Link Type AMC.2 Ethernet (0x5)
      Link Type
Ext.      1000BASE-BX (SerDES Gigabit)
Ethernet (0x0)
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #1
      Channel
ID          0
Lane Mask 0x2
      Link Type
Ethernet (0x0)
Group ID 0
Asymmetric Match 0
AMC Link Descriptor #2
      Channel
ID          1
Lane Mask 0xf
Link Type AMC.4 Serial RapidIO (0x6)
      Link Type
Ext.      No Extension Specified (0x3)
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #3
      Channel
ID          1
Lane Mask 0xf
      Link Type
Ext.      3.125 Gbaud transmission rate
(2.5 Gbps) (0x2)
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #4
      Channel
ID          1
Lane Mask 0xf
      Link Type
Ext.      2.5 Gbaud transmission rate
(2.0 Gbps) (0x1)
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #5
      Channel
ID          1
Lane Mask 0xf
      Link Type
Ext.      1.25 Gbaud transmission rate
(1.0 Gbps) (0x0)
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #6
      Channel
ID          1
Lane Mask 0x3
      Link Type
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #7
      Channel
ID          1
Lane Mask 0x3
      Link Type
(2.5 Gbps) (0x2)
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #8
      Channel
ID          1
Lane Mask 0x3
      Link Type
(2.0 Gbps) (0x1)
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #9
      Channel
ID          1
Lane Mask 0x3
      Link Type
(1.0 Gbps) (0x0)
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #10
      Channel
ID          1
Lane Mask 0xc
      Link Type
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #11
      Channel
ID          1
Lane Mask 0xc
      Link Type
(2.5 Gbps) (0x2)
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #12
      Channel
ID          1
Lane Mask 0xc
      Link Type
(2.0 Gbps) (0x1)
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #13
      Channel
ID          1
Lane Mask 0xc
      Link Type
(1.0 Gbps) (0x0)
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #14
      Channel
ID          1
Lane Mask 0x1
      Link Type
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #15
      Channel
ID          1
Lane Mask 0x1
      Link Type
(2.5 Gbps) (0x2)
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #16
      Channel
ID          1
Lane Mask 0x1
      Link Type
(2.0 Gbps) (0x1)
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #17
      Channel
ID          1
Lane Mask 0x1
      Link Type
(1.0 Gbps) (0x0)
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #18
      Channel
ID          1
Lane Mask 0x2
      Link Type
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #19
      Channel
ID          1
Lane Mask 0x2
      Link Type Ext.      3.125 Gbaud transmission rate (2.5 Gbps)
(0x2)
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #20
      Channel
ID          1
Lane Mask 0x2
      Link Type
(2.0 Gbps) (0x1)
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #21
      Channel
ID          1
Lane Mask 0x2
      Link Type
(1.0 Gbps) (0x0)
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #22
      Channel
ID          1
Lane Mask 0x4
      Link Type
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #23
      Channel
ID          1
Lane Mask 0x4
      Link Type
(2.5 Gbps) (0x2)
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #24
      Channel
ID          1
Lane Mask 0x4
      Link Type
(2.0 Gbps) (0x1)
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #25
      Channel
ID          1
Lane Mask 0x4
      Link Type
(1.0 Gbps) (0x0)
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #26
      Channel
ID          1
Lane Mask 0x8
      Link Type
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #27
      Channel
ID          1
Lane Mask 0x8
      Link Type
(2.5 Gbps) (0x2)
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #28
Channel ID 1
Lane Mask 0x8
      Link Type
(2.0 Gbps) (0x1)
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #29
      Channel
ID          1
Lane Mask 0x8
      Link Type
(1.0 Gbps) (0x0)
Group ID 0
      Asymmetric
Match    0
AMC Link Descriptor #30
      Channel
ID          2
Lane Mask 0x3
Link Type AMC.1 PCI Express (0x2)
      Link Type
Ext.      Gen 2-capable (0x2)
Group ID 0
      Asymmetric
Match    1
AMC Link Descriptor #31
      Channel
ID          2
Lane Mask 0x3
      Link Type
Ext.      Gen 1-capable (0x0)
Group ID 0
      Asymmetric
Match    1
AMC Link Descriptor #32
      Channel
ID          2
Lane Mask 0x1
      Link Type
Group ID 0
      Asymmetric
Match    1
AMC Link Descriptor #33
      Channel
ID          2
Lane Mask 0x1
      Link Type
Group ID 0
      Asymmetric
Match    1
