I am trying to get the \mcsdk\pdk_C6678_1_0_0_17\packages\ti\drv\exampleProjects\SRIO_MulticoreLoopbackexampleProject to work. It seems odd but my cache/shared variables seems to not be updating. Any suggestions as to what might cause this?
It was using the ti/csl/csl_cacheAux.h functions. I changed it to use the ti/sysbios/family/c66/Cache.h functions becuase these were working in my SRIOchipTochip example. However, neither set of functions allow the isSRIOInitialized variable to be updated for the non-initializing cores to see. While core1 is able to just move forward core 0, 2 and 3 are stuck waiting for isSRIOInitialized to equal 1.
Attached is the .c file for you reference. Please advise.
Brandy
 *   @file  multicoreLoopback.c
 *   @brief
 *      This is an example application which showcases how the SRIO Driver
 *      API can be used in a multiple core environment.
 *      The test suite sends/receives data as follows:-
 *      CORE 1 --> CORE 2 --> CORE 3 --> CORE 0 --> CORE 1
 *      At each step the received data is validated (Payload and Received
 *      Identifiers).
 *      The goal of the test suite is to showcase that the SRIO Driver API
 *      are multi-core safe.
 *  \par
 *  NOTE:
 *      (C) Copyright 2009 Texas Instruments, Inc.
 *  Redistribution and use in source and binary forms, with or without
 *  modification, are permitted provided that the following conditions
 *  are met:
 *    Redistributions of source code must retain the above copyright
 *    Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the
 *    distribution.
 *    Neither the name of Texas Instruments Incorporated nor the names of
 *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
 *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
 *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
 *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
 *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
 *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
 *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
 *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
 *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 *  \par
#include <xdc/std.h>
#include <string.h>
#include <xdc/runtime/IHeap.h>
#include <xdc/runtime/System.h>
#include <xdc/runtime/Memory.h>
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Task.h>
#include <ti/sysbios/heaps/HeapBuf.h>
#include <ti/sysbios/heaps/HeapMem.h>
#include <ti/sysbios/family/c64p/Hwi.h>
#include <ti/sysbios/family/c64p/EventCombiner.h>
#include <ti/sysbios/family/c66/Cache.h>
/* IPC includes */
#include <ti/ipc/GateMP.h>
#include <ti/ipc/Ipc.h>
#include <ti/ipc/ListMP.h>
#include <ti/ipc/SharedRegion.h>
#include <ti/ipc/MultiProc.h>
#include <xdc/cfg/global.h>
/* SRIO Driver Include File. */
#include <ti/drv/srio/srio_drv.h>
/* CPPI/QMSS Include Files. */
#include <ti/drv/cppi/cppi_drv.h>
#include <ti/drv/qmss/qmss_drv.h>
#include <ti/drv/qmss/qmss_firmware.h>
/* CSL Include Files */
#include <ti/csl/csl_chip.h>
#include <ti/csl/csl_cacheAux.h>
#include <ti/csl/csl_psc.h>
#include <ti/csl/csl_pscAux.h>
#include <ti/csl/csl_semAux.h>
 ************************** LOCAL Definitions *************************
#define NUM_HOST_DESC               32
#define SIZE_HOST_DESC              48
#define SRIO_MAX_MTU				256
/* Defines the core number responsible for system initialization. */
#define CORE_SYS_INIT               1
/* Number of cores for which the test is being executed. */
#define NUM_CORES                   4
/* SRIO Application Hardware Semaphore. */
#define SRIO_APP_HW_SEM             5
 ************************** Global Variables **************************
/* Memory used for the descriptors. */
#pragma DATA_ALIGN (host_region, 16)
Uint8   host_region[NUM_HOST_DESC * SIZE_HOST_DESC];
Qmss_InitCfg   qmssInitConfig;
/* Global Varialble which keeps track of the core number executing the
 * application. */
UInt32          coreNum = 0xFFFF;
#pragma DATA_ALIGN   (isSRIOInitialized, 128)
#pragma DATA_SECTION (isSRIOInitialized, ".srioSharedMem");
volatile Uint32     isSRIOInitialized    = 0;
#pragma DATA_ALIGN   (isSRIOSocketsCreated, 128)
#pragma DATA_SECTION (isSRIOSocketsCreated, ".srioSharedMem");
volatile Uint32     isSRIOSocketsCreated = 0;
/* Memory used for the accumulator list. */
#pragma DATA_ALIGN (gHiPriAccumList, 16)
UInt32              gHiPriAccumList[32];
/* These are the device identifiers used used in the TEST Application */
const uint32_t DEVICE_ID1_16BIT    = 0xBEEF;
const uint32_t DEVICE_ID1_8BIT     = 0xAB;
const uint32_t DEVICE_ID2_16BIT    = 0x4560;
const uint32_t DEVICE_ID2_8BIT     = 0xCD;
const uint32_t DEVICE_ID3_16BIT    = 0x1234;
const uint32_t DEVICE_ID3_8BIT     = 0x12;
const uint32_t DEVICE_ID4_16BIT    = 0x5678;
const uint32_t DEVICE_ID4_8BIT     = 0x56;
 ************************* Extern Definitions *************************
extern UInt32 malloc_counter;
extern UInt32 free_counter;
extern int32_t SrioDevice_init (void);
extern Void* Osal_srioDataBufferMalloc(UInt32 numBytes);
/* QMSS device specific configuration */
extern Qmss_GlobalConfigParams  qmssGblCfgParams;
/* CPPI device specific configuration */
extern Cppi_GlobalConfigParams  cppiGblCfgParams;
/* OSAL Data Buffer Memory Initialization. */
extern int32_t Osal_dataBufferInitMemory(uint32_t dataBufferSize);
 ************************ SRIO TEST FUNCTIONS *************************
 *  @b Description
 *  @n
 *      Utility function which converts a local address to global.
 *  @param[in]  addr
 *      Local address to be converted
 *  @retval
 *      Global Address
static UInt32 l2_global_address (Uint32 addr)
	UInt32 corenum;
	/* Get the core number. */
	corenum = CSL_chipReadReg(CSL_CHIP_DNUM);
	/* Compute the global address. */
	return (addr + (0x10000000 + (corenum*0x1000000)));
 *  @b Description
 *  @n
 *      Utility function that is required by the IPC module to set the proc Id.
 *      The proc Id is set via this function instead of hard coding it in the .cfg file
 *  @retval
 *      Not Applicable.
Void myStartupFxn (Void)
	MultiProc_setLocalId (CSL_chipReadReg (CSL_CHIP_DNUM));
 *  @b Description
 *  @n
 *      This function enables the power/clock domains for SRIO.
 *  @retval
 *      Not Applicable.
static Int32 enable_srio (void)
#ifndef SIMULATOR_SUPPORT
    /* SRIO power domain is turned OFF by default. It needs to be turned on before doing any
     * SRIO device register access. This not required for the simulator. */
    /* Set SRIO Power domain to ON */
    CSL_PSC_enablePowerDomain (CSL_PSC_PD_SRIO);
    /* Enable the clocks too for SRIO */
    CSL_PSC_setModuleNextState (CSL_PSC_LPSC_SRIO, PSC_MODSTATE_ENABLE);
    /* Start the state transition */
    CSL_PSC_startStateTransition (CSL_PSC_PD_SRIO);
    /* Wait until the state transition process is completed. */
    while (!CSL_PSC_isStateTransitionDone (CSL_PSC_PD_SRIO));
    /* Return SRIO PSC status */
    if ((CSL_PSC_getPowerDomainState(CSL_PSC_PD_SRIO) == PSC_PDSTATE_ON) &&
        (CSL_PSC_getModuleState (CSL_PSC_LPSC_SRIO) == PSC_MODSTATE_ENABLE))
        /* SRIO ON. Ready for use */
        return 0;
    else
        /* SRIO Power on failed. Return error */
        return -1;
#else
    /* PSC is not supported on simulator. Return success always */
    return 0;
#endif
 *  @b Description
 *  @n
 *      System Initialization Code. This is added here only for illustrative
 *      purposes and needs to be invoked once during initialization at
 *      system startup.
 *  @retval
 *      Success     -   0
 *  @retval
 *      Error       -   <0
static Int32 system_init (Void)
    Int32               result;
    Qmss_MemRegInfo     memRegInfo;
    /* Initialize the QMSS Configuration block. */
    memset (&qmssInitConfig, 0, sizeof (Qmss_InitCfg));
    /* Set up the linking RAM. Use the internal Linking RAM.
     * LLD will configure the internal linking RAM address and maximum internal linking RAM size if
     * a value of zero is specified. Linking RAM1 is not used */
    qmssInitConfig.linkingRAM0Base = 0;
    qmssInitConfig.linkingRAM0Size = 0;
    qmssInitConfig.linkingRAM1Base = 0;
    qmssInitConfig.maxDescNum      = NUM_HOST_DESC;
#ifdef xdc_target__bigEndian
    System_printf("Using Big Endian QMSS\n");
    qmssInitConfig.pdspFirmware[0].pdspId   = Qmss_PdspId_PDSP1;
    qmssInitConfig.pdspFirmware[0].firmware = &acc48_be;
    qmssInitConfig.pdspFirmware[0].size     = sizeof (acc48_be);
#else
    System_printf("Using Little Endian QMSS\n");
    qmssInitConfig.pdspFirmware[0].firmware = &acc48_le;
    qmssInitConfig.pdspFirmware[0].size     = sizeof (acc48_le);
#endif
    /* Initialize Queue Manager Sub System */
    result = Qmss_init (&qmssInitConfig, &qmssGblCfgParams);
    if (result != QMSS_SOK)
        System_printf ("Error initializing Queue Manager SubSystem error code : %d\n", result);
        return -1;
    /* Start the QMSS. */
    if (Qmss_start() != QMSS_SOK)
        System_printf ("Error: Unable to start the QMSS\n");
        return -1;
    /* Memory Region 0 Configuration */
    memRegInfo.descBase         = (UInt32 *)l2_global_address((UInt32)host_region);
    memRegInfo.descSize         = SIZE_HOST_DESC;
    memRegInfo.descNum          = NUM_HOST_DESC;
    memRegInfo.manageDescFlag   = Qmss_ManageDesc_MANAGE_DESCRIPTOR;
    memRegInfo.memRegion        = Qmss_MemRegion_MEMORY_REGION_NOT_SPECIFIED;
    /* Initialize and inset the memory region. */
    result = Qmss_insertMemoryRegion (&memRegInfo);
    if (result < QMSS_SOK)
        System_printf ("Error inserting memory region: %d\n", result);
        return -1;
    /* Initialize CPPI CPDMA */
    result = Cppi_init (&cppiGblCfgParams);
    if (result != CPPI_SOK)
        return -1;
    /* CPPI and Queue Manager are initialized. */
    System_printf ("Debug: Queue Manager and CPPI are initialized.\n");
    System_printf ("Debug: Host Region 0x%x\n", host_region);
    return 0;
 *  @b Description
 *  @n
 *      The function tests multicore
 *  @param[in]  hSrioDrv
 *      Handle to the SRIO driver
 *  @retval
 *      Success     - 0
 *  @retval
 *      Error       - <0
static Int32 test_multicore (Srio_DrvHandle hSrioDrv)
    Srio_SockHandle         srioSocket;
    Srio_SockBindAddrInfo   bindInfo;
    UInt8*                  txData;
    Srio_SockAddrInfo       to;
    Srio_SockAddrInfo       from;
    UInt16                  idx;
    Int32                   num_bytes;
    UInt8*                  ptr_rxDataPayload;
    Int32                   sendToCore;
    Int32                   recvFromCore;
    Srio_DrvBuffer          hDrvBuffer;
    UInt32                  allocatedLen;
    UInt16                  coreDeviceID[NUM_CORES];
    System_printf ("**********************************************\n");
    System_printf ("******** Multicore Testing (Core %d) *********\n", coreNum);
    /* Open SRIO Socket in Blocking Mode */
    srioSocket =  Srio_sockOpen (hSrioDrv, Srio_SocketType_TYPE11, TRUE);
    if (srioSocket == NULL)
        System_printf ("Error: Unable to open socket1\n");
        return -1;
    /* Initialize the core Device IDs: Each core has a seperate device ID. */
    coreDeviceID[0] = DEVICE_ID1_16BIT;
    coreDeviceID[1] = DEVICE_ID2_16BIT;
    coreDeviceID[2] = DEVICE_ID3_16BIT;
    coreDeviceID[3] = DEVICE_ID4_16BIT;
    /* Initialize the core bindings; we use the same mailbox & letter identifiers. */
    bindInfo.type11.tt       = TRUE;
    bindInfo.type11.id       = coreDeviceID[coreNum];
    bindInfo.type11.letter   = 2;
    bindInfo.type11.mbox     = 3;
    bindInfo.type11.segMap   = 0x0;
    /* Bind the SRIO socket */
    if (Srio_sockBind (srioSocket, &bindInfo) < 0)
        System_printf ("Error: socket1 bind failed\n");
        return -1;
    /* Get a transmit buffer from the SRIO Driver. */
    hDrvBuffer = Srio_allocTransmitBuffer(hSrioDrv, &txData, &allocatedLen);
    if (hDrvBuffer == NULL)
        System_printf ("Error: Producer Memory Allocation failed.\n");
        return -1;
    /* Create the transmit data payload. */
    for (idx = 0; idx < 100; idx++)
        txData[idx] = 0xA0 | coreNum;
    /* The global variable is a shared resource which is being accessed from multiple cores.
     * So here we need to protect it and ensure that there is only 1 core which is accessing
     * it at a time. We use a Hardware Semaphore to protect this. */
    while ((CSL_semAcquireDirect (SRIO_APP_HW_SEM)) == 0);
    /* Invalidate the cache and make sure you get the latest from the memory. */
    CACHE_invL1d ((void *) &isSRIOSocketsCreated, 128, CACHE_WAIT);
    /* The core has created the sockets:*/
    isSRIOSocketsCreated++;
    /* The SRIO Socket has been created. Writeback the contents to the cache. */
    CACHE_wbL1d ((void *) &isSRIOSocketsCreated, 128, CACHE_WAIT);
    /* Release the hardware semaphore. */
    CSL_semReleaseSemaphore (SRIO_APP_HW_SEM);
    /* We can proceed with the data transmission & reception tests only after all the
     * cores have created and bound their SRIO sockets. This is a simple counter running
     * in shared memory which allows us to SYNC up the socket creation. Wait till all the
     * cores have created the sockets */
    while (isSRIOSocketsCreated != NUM_CORES)
    System_printf ("------------------------------------------------------\n");
    /* Is this the starting core? */
    if (coreNum == 1)
        /* Starting Core: This is a special case because unlike the other cores; this initiates
         * the whole test cycle by sending the first packet. */
        sendToCore   = coreNum + 1;
        recvFromCore = coreNum - 1;
        if (recvFromCore < 0)
            recvFromCore = NUM_CORES-1;
        /* Send the data out. */
        to.type11.tt       = TRUE;
        to.type11.id       = coreDeviceID[sendToCore];
        to.type11.letter   = 2;
        to.type11.mbox     = 3;
        /* Send the data out from the producer core to the consumer core. */
        if (Srio_sockSend (srioSocket, hDrvBuffer, 100, &to) < 0)
            System_printf ("Error: SRIO Socket send failed\n");
            return -1;
        /* Debug Message */
        System_printf ("Debug(Core %d): Successfully sent data to ID:0x%x\n", coreNum, to.type11.id);
        /* CORE0: Wait for data to arrive from NUM_CORES-1 */
        System_printf ("Debug(Core %d): Waiting for data to arrive 0x%x\n", coreNum, bindInfo.type11.id);
        /* Receive the data. */
        num_bytes = Srio_sockRecv (srioSocket, (Srio_DrvBuffer*)&ptr_rxDataPayload, &from);
        if (num_bytes > 0)
            /* Make sure that the data was received from the producer core */
            if (from.type11.id != coreDeviceID[recvFromCore])
                System_printf ("Error: Invalid source id 0x%x Expected 0x%x\n", from.type11.id, coreDeviceID[recvFromCore]);
                return -1;
            /* Received and Transmitted packet length match. Payload verification */
                if (ptr_rxDataPayload[idx] != (0xA0 | recvFromCore))
                    System_printf ("Error: Receive Data Payload verification failed @ index %d\n", idx);
                    return -1;
            System_printf ("Debug(Core %d): Successfully received %d bytes\n", coreNum, num_bytes);
            /* Cleanup the received data payload. */
            Srio_freeRxDrvBuffer(srioSocket, (Srio_DrvBuffer)ptr_rxDataPayload);
        else
            /* Error: In receiving data */
            System_printf ("Error: Unable to receive data %d\n", num_bytes);
            return -1;
    else
        /* Any other core besides the starting core will initally wait for data to arrive */
        sendToCore   = (coreNum + 1) % NUM_CORES;
        if (num_bytes > 0)
                return -1;
                    return -1;
        else
            return -1;
        /* CoreX: Sends outs the packet to CoreX+1. */
        to.type11.mbox     = 3;
            return -1;
        System_printf ("Debug(Core %d): Successfully sent data to ID:0x%x\n", coreNum, coreDeviceID[sendToCore]);
    /* Close the sockets */
    Srio_sockClose (srioSocket);
    /* We are done with the test. */
    System_printf ("Debug(Core %d): Multicore Test Passed\n", coreNum);
    return 0;
 *  @b Description
 *  @n
 *      This is the Multicore Test task
 *  @retval
 *      Not Applicable.
static Void multicoreTestTask(UArg arg0, UArg arg1)
    Srio_DrvConfig  cfg;
    Srio_DrvHandle  hSrioDriver;
    UInt8           isAllocated;
    /* Initialize the OSAL Data Buffer */
    if (Osal_dataBufferInitMemory(SRIO_MAX_MTU) < 0)
    	return;
    /* Initialize the SRIO Driver Configuration. */
    memset ((Void *)&cfg, 0, sizeof(Srio_DrvConfig));
    /* Setup the SRIO Driver Managed Configuration. */
    cfg.bAppManagedConfig                   = FALSE;
    /* Driver Managed: Receive Configuration */
    cfg.u.drvManagedCfg.bIsRxCfgValid             = 1;
    cfg.u.drvManagedCfg.rxCfg.rxMemRegion         = Qmss_MemRegion_MEMORY_REGION0;
    cfg.u.drvManagedCfg.rxCfg.numRxBuffers        = 4;
    cfg.u.drvManagedCfg.rxCfg.rxMTU               = SRIO_MAX_MTU;
    /* Accumulator Configuration. */
	    int32_t coreToQueueSelector[4];
        /* This is the table which maps the core to a specific receive queue. */
	    coreToQueueSelector[0] = 704;
	    coreToQueueSelector[1] = 705;
	    coreToQueueSelector[2] = 706;
	    coreToQueueSelector[3] = 707;
	    /* Since we are programming the accumulator we want this queue to be a HIGH PRIORITY Queue */
	    cfg.u.drvManagedCfg.rxCfg.rxCompletionQueue = Qmss_queueOpen (Qmss_QueueType_HIGH_PRIORITY_QUEUE,
        coreToQueueSelector[coreNum],
        &isAllocated);
		if (cfg.u.drvManagedCfg.rxCfg.rxCompletionQueue < 0)
			System_printf ("Error: Unable to open the SRIO Receive Completion Queue\n");
			return;
		/* Accumulator Configuration is VALID. */
		cfg.u.drvManagedCfg.rxCfg.bIsAccumlatorCfgValid = 1;
	    cfg.u.drvManagedCfg.rxCfg.accCfg.channel             = coreNum;
	    cfg.u.drvManagedCfg.rxCfg.accCfg.command             = Qmss_AccCmd_ENABLE_CHANNEL;
	    cfg.u.drvManagedCfg.rxCfg.accCfg.queueEnMask         = 0;
	    cfg.u.drvManagedCfg.rxCfg.accCfg.queMgrIndex         = coreToQueueSelector[coreNum];
	    cfg.u.drvManagedCfg.rxCfg.accCfg.maxPageEntries      = 2;
	    cfg.u.drvManagedCfg.rxCfg.accCfg.timerLoadCount      = 0;
	    cfg.u.drvManagedCfg.rxCfg.accCfg.interruptPacingMode = Qmss_AccPacingMode_LAST_INTERRUPT;
	    cfg.u.drvManagedCfg.rxCfg.accCfg.listEntrySize       = Qmss_AccEntrySize_REG_D;
	    cfg.u.drvManagedCfg.rxCfg.accCfg.listCountMode       = Qmss_AccCountMode_ENTRY_COUNT;
	    cfg.u.drvManagedCfg.rxCfg.accCfg.multiQueueMode      = Qmss_AccQueueMode_SINGLE_QUEUE;
        /* Initialize the accumulator list memory */
        memset ((Void *)&gHiPriAccumList[0], 0, sizeof(gHiPriAccumList));
        cfg.u.drvManagedCfg.rxCfg.accCfg.listAddress = l2_global_address((UInt32)&gHiPriAccumList[0]);
    /* Driver Managed: Transmit Configuration */
    cfg.u.drvManagedCfg.bIsTxCfgValid             = 1;
    cfg.u.drvManagedCfg.txCfg.txMemRegion         = Qmss_MemRegion_MEMORY_REGION0;
    cfg.u.drvManagedCfg.txCfg.numTxBuffers        = 4;
    cfg.u.drvManagedCfg.txCfg.txMTU               = SRIO_MAX_MTU;
    /* Start the SRIO Driver */
    hSrioDriver = Srio_start(&cfg);
    if (hSrioDriver == NULL)
        System_printf ("Error: SRIO Driver Start Failed\n");
        return;
    /* SRIO Driver is operational at this time. */
    System_printf ("Debug: SRIO Driver has been started Instance Handle 0x%p\n", hSrioDriver);
    /* Hook up the SRIO interrupts with the core. */
    EventCombiner_dispatchPlug (48, (EventCombiner_FuncPtr)Srio_rxCompletionIsr, (UArg)hSrioDriver, TRUE);
	EventCombiner_enableEvent(48);
    /* Map the event id to hardware interrupt 8. */
    Hwi_eventMap(8, 48);
    /* Enable interrupt 8. */
    Hwi_enableInterrupt(8);
    System_printf ("Debug: SRIO Driver ISR has been registered\n");
    /* Run the Multicore Test */
    if (test_multicore (hSrioDriver) < 0)
        System_printf ("Error: Multicore Tests failed\n");
        return;
    /* Print out the Malloc & Free Counter */
    System_printf ("Debug(Core %d): Allocation Counter : %d\n", coreNum, malloc_counter);
    System_printf ("Debug(Core %d): Free Counter       : %d\n", coreNum, free_counter);
    /* Check if there is a memory leak? Since we dont implement the DEINIT API
     * there are 'cfg.numRxDesc' and 'cfg.numTxDesc' buffers always allocated for
     * the SRIO Driver. 1 allocation is there for the Driver Instance
     * Take this into account while we check for leaks? */
    if ((cfg.u.drvManagedCfg.rxCfg.numRxBuffers + cfg.u.drvManagedCfg.txCfg.numTxBuffers + free_counter + 1 ) !=
        malloc_counter)
        System_printf ("Error: Memory Leak Detected\n");
        Task_exit();
    /* Control comes here implies that all testing passed. */
    System_printf ("Debug(Core %d): Multicore Example successful.\n", coreNum);
    return;
 *  @b Description
 *  @n
 *      Entry point for the example
 *  @retval
 *      Not Applicable.
Void main(Void)
    Task_Params     taskParams;
	coreNum = CSL_chipReadReg (CSL_CHIP_DNUM);
    System_printf ("****************************************************\n");
    System_printf ("******  Multicore Loopback Testing (Core %d) *******\n", coreNum);
    /* Initialize the heap in shared memory. Using IPC module to do that */
    Ipc_start();
    /* Initialize the system only if the core was configured to do so. */
    if (coreNum == CORE_SYS_INIT)
        System_printf ("Debug(Core %d): System Initialization for CPPI & QMSS\n", coreNum);
        /* System Initialization */
        if (system_init() < 0)
            return;
        /* Power on SRIO peripheral before using it */
        if (enable_srio () < 0)
            System_printf ("Error: SRIO PSC Initialization Failed\n");
            return;
	    /* Device Specific SRIO Initializations: This should always be called before
         * initializing the SRIO Driver. */
    	if (SrioDevice_init() < 0)
        	return;
        /* Initialize the SRIO Driver */
        if (Srio_init () < 0)
            System_printf ("Error: SRIO Driver Initialization Failed\n");
            return;
        System_printf ("Debug(Core %d): SRIO Driver has been initialized\n", coreNum);
        /* Write to the SHARED memory location at this point in time. The other cores cannot execute
         * till the SRIO Driver is up and running. */
        isSRIOInitialized = 1;
        /* The SRIO IP block has been initialized. We need to writeback the cache here because it will
         * ensure that the rest of the cores which are waiting for SRIO to be initialized would now be
         * woken up. */
 //       CACHE_wbL1d ((void *) &isSRIOInitialized, 128, CACHE_WAIT);
        Cache_wb ((void *) &isSRIOInitialized, 4, Cache_Type_L1D, TRUE);
    else
        /* TODO: Testing this.... */
        System_printf ("Debug(Core %d): Waiting for SRIO to be initialized.\n", coreNum);
        /* All other cores loop around forever till the SRIO is up and running.
         * We need to invalidate the cache so that we always read this from the memory. */
//        while (isSRIOInitialized == 0)
//            CACHE_invL1d ((void *) &isSRIOInitialized, 128, CACHE_WAIT);
          Cache_inv ((void *) &isSRIOInitialized, 4, Cache_Type_L1D, TRUE);
        System_printf("Debug(Core %d): SRIO Initialized.\n",coreNum);
            return;
        System_printf ("Debug(Core %d): SRIO can now be used.\n", coreNum);
    /* Create the Multicore Test Task. */
    Task_Params_init(&taskParams);
    Task_create(multicoreTestTask, &taskParams, NULL);
    /* Start the BIOS */
    BIOS_start();
