• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » C6000 Multicore DSP » Keystone Multicore Forum (C66, 66A, AM5) » How to modify mcsdk_video demo for running it on another 4XC6678 platform?
Share
C6000 Multicore DSP
  • Forums
  • Announcements
Options
  • Subscribe via RSS
Training Available
TI provides self-paced online training that introduces the primary components of the KeyStone II family of SoC devices.
  • KeyStone II SoC Overview >
  • KeyStone II Software Overview >
  • KeyStone II ARM Cortex-A15 Corepac Overview >
  • More Information >
  • Check out
    Multicore Mix blog
    • $core_v2_blog.Current.Name
      OpenMP - All aboard!
      Posted 14 minutes ago
      by Debbie Greenstreet
      With so many end products today relying on multicore DSPs for...
      A look back: Two years of Multicore Mix
      Posted 1 day ago
      by Lauren Reed1
      A big thank you to everyone who participated in our contest last...
      It’s our second anniversary, but you get the present!
      Posted 8 days ago
      by Lindsey Bare
      It’s hard to believe it’s already been two years...
    This question is not answered
    zhao sun
    Posted by zhao sun
    on Apr 02 2012 01:23 AM
    Intellectual910 points
          I have another evm here which consist of 4 C6678. There are 2 main differences between it with the C6678 EVM:
    1. The EVM uses EMAC0 to connect BCM54616 Ethernet PHY. So perhaps, I need do initialize of SGMII port 0 and
    change setting of port0 and port1.
    2. The reference clocks of DDR and SGMII is difference.
    I have the evm's patch of pdk_C6678_1_0_0_15. But I find that demo (transcoder and DSP)  has it's own hardware
    initialization function instead of calling pdk package. So I wonder how to do modification of transcoder demo and the
    DSP demo to make it work on my evm here.
    The patch to pdk_C6678_1_0_0_15 is attched here. Please help me check
    how to do modification to make mcsdk-video demo work on my evm.
    Thank you!
    7633.patch.rar
    Sunzhao
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • ArunMani
      Posted by ArunMani
      on Apr 02 2012 13:24 PM
      Genius9510 points
      They might be using the platform_lib in the MCSDK. Can you try that. This is platform specific code and you can modify the plafor lib and still preserve the API callas.
      Arun.
      If you need more help, please reply back. If this answers the question, please click  Verify Answer  , below.
      Report Abuse
      • Reply
    • zhao sun
      Posted by zhao sun
      on Apr 03 2012 02:27 AM
      Hi ArunMani,
          Thank you for the reply. But will you please describe it specifically? I add the platform_init function(from pdk)
      to the platformInit function of SIU to fo Platform specific initializations. the platform_init function will do DDR3_init
      and SGMII_init for my evm. But when I run the transcode demo in my platform, I got the message below. It seems
      that I can not add connection between my test board with the tftp server. So can you give me some suggestion
      on this issue? Thank you very much!
      [C66xx_0] Start reading...[C66xx_0] platform: port 0 is link up!
      [C66xx_0] 貐Core 0: Adding MAC entry
      [C66xx_0] Core 0: Adding IP entry - SRC=[192, 168, 100, 100]
      [C66xx_0] Core 0: Adding UDP entry
      [C66xx_0] Adding UDP port: 2048
      [C66xx_0] ERROR: nwal_addConn returned Error Code -3
      [C66xx_0] Core 0: Error adding UDP entry: 0x800
      [C66xx_0] Core 0: Adding MAC entry
      [C66xx_0] Core 0: Adding IP entry - SRC=[10, 218, 109, 120]
      [C66xx_0] Adding UDP port: 32768
      [C66xx_0] Core 0: Error adding UDP entry: 0x8000
      [C66xx_0] Using Existing MAC handle for Core: 0
      [C66xx_0] Using Existing IP handle for Core: 0
      [C66xx_0] Core 0: Error adding UDP entry: 0x8002
      [C66xx_0] server mac add is 00-22-19-59-31-29
      [C66xx_0]  server ip add is 192.168.1.115
      [C66xx_0]  local mac add is 08-24-BA-79-CC-9E
      [C66xx_0]  local ip add is 192.168.1.117
      [C66xx_0] Core 0: Adding IP entry - SRC=[192, 168, 1, 117]
      [C66xx_0]
      [C66xx_0] Starting TFTP Get for viperkillercuts_720p_53fr.264... Error receive from server!
      [C66xx_0]
      [C66xx_0] Creating Decoder Algorithm Instance...Num. buffs requested = 23
      [C66xx_0] algAlloc req. Buffer 0: space = 17, size = 4840
      [C66xx_0] algAlloc req. Buffer 1: space = 0, size = 8840
      [C66xx_0] algAlloc req. Buffer 2: space = 0, size = 78184
      [C66xx_0] algAlloc req. Buffer 3: space = 0, size = 8992
      [C66xx_0] algAlloc req. Buffer 4: space = 17, size = 8664
      [C66xx_0] algAlloc req. Buffer 5: space = 17, size = 176
      [C66xx_0] algAlloc req. Buffer 6: space = 17, size = 144
      [C66xx_0] algAlloc req. Buffer 7: space = 17, size = 4420
      [C66xx_0] algAlloc req. Buffer 8: space = 17, size = 24
      [C66xx_0] algAlloc req. Buffer 9: space = 17, size = 1860480
      [C66xx_0] algAlloc req. Buffer 10: space = 17, size = 15079680
      [C66xx_0] algAlloc req. Buffer 11: space = 17, size = 1966080
      [C66xx_0] algAlloc req. Buffer 12: space = 17, size = 136
      [C66xx_0] algAlloc req. Buffer 13: space = 17, size = 144
      [C66xx_0] algAlloc req. Buffer 14: space = 17, size = 8840
      [C66xx_0] algAlloc req. Buffer 15: space = 17, size = 544
      [C66xx_0] algAlloc req. Buffer 16: space = 17, size = 540
      [C66xx_0] algAlloc req. Buffer 17: space = 17, size = 264
      [C66xx_0] algAlloc req. Buffer 18: space = 17, size = 12672
      [C66xx_0] algAlloc req. Buffer 19: space = 17, size = 74880
      [C66xx_0] algAlloc req. Buffer 20: space = 17, size = 110592
      [C66xx_0] algAlloc req. Buffer 21: space = 17, size = 8160
      [C66xx_0] algAlloc req. Buffer 22: space = 17, size = 116
      [C66xx_0]
      [C66xx_0] Algorithm Instance Creation Done...
      [C66xx_0] Num. buffs requested = 13
      [C66xx_0] algAlloc req. Buffer 0: space = 17, size = 1664
      [C66xx_0] algAlloc req. Buffer 1: space = 0, size = 261376
      [C66xx_0] algAlloc req. Buffer 2: space = 17, size = 327680
      [C66xx_0] algAlloc req. Buffer 3: space = 17, size = 4480
      [C66xx_0] algAlloc req. Buffer 4: space = 17, size = 3968
      [C66xx_0] algAlloc req. Buffer 5: space = 17, size = 6144
      [C66xx_0] algAlloc req. Buffer 6: space = 17, size = 3712
      [C66xx_0] algAlloc req. Buffer 7: space = 17, size = 65536
      [C66xx_0] algAlloc req. Buffer 8: space = 17, size = 3840
      [C66xx_0] algAlloc req. Buffer 9: space = 17, size = 3247104
      [C66xx_0] algAlloc req. Buffer 10: space = 17, size = 244864
      [C66xx_0] algAlloc req. Buffer 11: space = 17, size = 65920
      [C66xx_0] algAlloc req. Buffer 12: space = 17, size = 14464
      [C66xx_0]
      [C66xx_0] Encoder Algorithm Instance Creation Done...
      [C66xx_0]
      [C66xx_0]  Bitstream Ended...
      [C66xx_0] TFTP Get stopped.
      [C66xx_0] TFTP Statistics-------------------+
      [C66xx_0] |  RX Bytes          :          0 |
      [C66xx_0] |  TX Bytes          :          0 |
      [C66xx_0] |  Valid Packets     :          0 |
      [C66xx_0] |  Duplicate Packets :          0 |
      [C66xx_0] |  Error Packets     :          0 |
      [C66xx_0] +---------------------------------+
      [C66xx_0]
      [C66xx_0] TFTP Put stopped.
      [C66xx_0]
      [C66xx_0]  --------------  SUMMARY --------------------
      [C66xx_0]   Total number of Frames              = 1
      [C66xx_0]   Decoder Bit Rate at 30 frames/Sec           = 0 Kbps
      [C66xx_0]   Encoder Bit Rate at 30 frames/Sec           = 0 Kbps
      [C66xx_0]  --------------    END   --------------------
      [C66xx_0]
      [C66xx_0]  End of execution
      [C66xx_0] End of Program
      Sunzhao
      Report Abuse
      • Reply
    • Hongmei Gou
      Posted by Hongmei Gou
      on Apr 05 2012 16:29 PM
      Intellectual2930 points
      Hi Sunzhao,
      Can you please provide some details about your EVM? Is it a Quad-Shannon board from Advantech?
      Hongmei
      Report Abuse
      • Reply
    • zhao sun
      Posted by zhao sun
      on Apr 05 2012 21:25 PM
      Hi Hongmei,
          Yes, It is DSPC-8681 PCIe card from advantech here. The web site of this card is below:
      http://www.advantech.com/products/DSPC-8681/mod_A9314996-0022-4927-9AA4-6B1060D4E5E8.aspx
      We need to run transcoder video demo and the multi-channel dsp video demo on it now. But the tftp
      server can not be connected. Can you give me some suggestion about doing that?
      Thank you!
      Sunzhao
      Report Abuse
      • Reply
    • Sam Nelson
      Posted by Sam Nelson
      on Apr 10 2012 14:08 PM
      Prodigy700 points
      Hello Sunzhao,
      I am Sam and let me try to  help you with this.
      To make the transcoder demo work with the quad shannon card, you need to initialise:  GMII, GMAC & Serdes on the Ethernet subsystem (Which is already done by the ROM boot loader if you are using Ethernet boot on the C6678EVM).
      1055.dsp_init_binaries.zip
      I am attaching a init.out & init.hex , which incorporates the required initialization for Ethernet.
      If you load and run this init.out  ( init.out if you are loading through CCS or use init.hex  you using Advantech loader ) on core 0 of each DSP ,  before you load the transcoder demo code it should work for you.
      With this you don't need to add any code into the demo application.
      1602.dsp_init.zip
      I am also attaching here a sample project, where the Ethernet subsystem initialization is incorporated into the init.hex. ( Modified from Advantech sample code). It assumes the platform library in pdk_C6678_1_0_0_15 is patched with the Advantech platform patch.  This can be used as reference if you want to incorporate the initialisation code into your application code.  You may need to update the PDK directories on the file dsp_init\evmc6678l\macros.ini before you import the CCS project.
      Let me know if you have questions.
      with regards,
      Sam
      Report Abuse
      • Reply
    • zhao sun
      Posted by zhao sun
      on Apr 11 2012 01:55 AM
      Hi Sam,
         Thank you very much for you reply. I did try to the transcoder demo under your
      directions in 2 ways below. But it still didn't work:
      1. 2-stage running:
         1> Load the init.out with the emulator through CCSv5 to the quad shannon card and
      run it.
         2> Pause the program manually because it will run into an endless while loop (wait and
      start).
         3> Load my videoTranscode.out with emulator to the card.(without selecting CPU reset
      or system reset)
         4> Run the program then and I get the output message below:
      [C66xx_0]
      [C66xx_0] Starting TFTP Get for airshow_p1280x720_4Mbps.264... Error receive from server!
      [C66xx_0]
      2. Merge your sample code into main file of the transcoder project, and re-compile it. Then load the
      output binary to the card and run it. The same error message occurs. The attached file is My main file
      after merging. You may search the key word "Merge_code" to see what I have modified to the code.
      4520.main.rar
      Opening the error log switch in dsiunwal, I still got error message below:
      [C66xx_0]
      [C66xx_0]
      I can make sure that
      1. My tftp serve is OK, because I can do file downloading from another computer
      with it.
      2. The network is OK, because I can run other web related demos on the card.
      3. The card and my tftp server are both connected to a GiGa bits switch .
      4. The pdk version is 1_0_0_15. And it has already patched with advantech's patch.
      So can you give me some suggestion about this issue or What's wrong with my operation?
      And also will you please to provide the transcoder demo binary file you compiled for me to
      test if something wrong with my test environment?
      Thanks a lot!
      Sunzhao
      Report Abuse
      • Reply
    • zhao sun
      Posted by zhao sun
      on Apr 16 2012 03:26 AM
      Hi Sam,
          Will you please help me check this issue? Thanks a lot!
      Sunzhao
      Report Abuse
      • Reply
    • Vivek Chengalvala
      Posted by Vivek Chengalvala
      on Apr 30 2012 17:34 PM
      Intellectual1100 points
      Sunzhao,
      Can you run the webserver demo, reset the DSP and run the transcode demo? By reset, I mean just resetting through CCS and not powercycling the board. In your first log, it appears that the PHY is not properly configured and thus not allowing the TFTP packets to go out of the board. If we run the webserver demo that should configure PHY to be in the correct state. Please try this and let us know if it works. Then we will think about the next steps about how to get the PHY configuration into your code.
      Vivek
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
