Hi ,I am using AIF2 on C6670 and runs well for the most of the time, at this monent I find a issue that I can't figure.
My environment is LTE 20MHZ, CPRI, FDD , loopback use one fiber connect Tx and Rx.
The rx data is corrent at first, then I pull out the fiber , the RM sync_status is changing from ST3 to ST0, rx reveive no data. Then I plug in the fiber, RM sync_status changes to ST3 and rx can receive data, but the data is not corrent !
Is this phenomenon normal ? If it is normal should I reset some part of the AIF2 so My rx will be corrent again?
Thanks for your reply.
