DMVA2 IPNC + CCSv4.2.3 + JTAG USB560M
Hi all, does any of you figure out why can I be receiving this problem while trying to load nandwriter_ipnc_dmva1_xxx.out :
ARM9: File Loader: Data verification failed at address 0x8E000002 Please verify target memory and memory map.
ARM9: Unable to terminate memory download: NULL buffer pointer at 0x320
Error found during data verification.
Ensure the linker command file matches the memory map
I have set up the connection as Blackhawk USB560-M Emulator with EVMDM365 and loaded the gel_ipnc_dmvax_1.0.0.gel. Also JTAG TCLK Frecuency (Mhz)  = Automatic with faster 35.0MHz limit.
Does anyone know why can this error be solved?
Thank you guys!
