Texas Instruments
  • Samples Cart - Add Samples Samples & Purchase Cart
  • Contact Us
  • TI Worldwide: United States
  • my.TI Login
  • Products
  • Applications
  • Design Support
  • Sample & Buy
  • All Searches
TI Home » TI E2E Community » Support Forums » ARM® & DSP Microprocessors » DaVinci™ Video Processors » DM37x DaVinci Video Processor Forum » DM3725 Boundary Scan
  • Join
  • Sign In with my.TI Login
TI E2E™ Community
  • Home
  • Support Forums
  • Videos
  • Blogs
  • Groups
  • More ...
  • Go
  • Advanced Search
Share
Details
Rate This
  • 5 Replies
  • 3 Subscribers
  • 388 Views
  • Posted5 months ago
Options
  • Subscribe via RSS
Tags
  • 1080p
  • 1273
  • 3730
  • 4k resolution
  • 720P
  • AM3703
  • AM3730
  • AM37xx
  • AM-LAANDOC
  • android
  • Android Source build
  • Angstrom
  • ASP
  • Audio
  • beagle Board
  • beagle Board XM
  • beagleboard
  • Beagleboard-xm
  • beagleboard-xm camera
  • BEAGLEBONE
  • BIOS 5.40
  • bluetooth
  • BlueZ
  • Boot mode
  • Boot pin settings
Forum - Title
Welcome to the DaVinci™ Video Processors Section of the TI E2E Support Community. Ask questions, share knowledge, explore ideas, and help solve problems with fellow engineers. To post a question, click on the forum tab then "New Post".
  • Get this RSS feed
  • Home
  • Announcements
  • Forums
New Post
This question is not answered
Jim Carrillo
Posted by Jim Carrillo
on Dec 13, 2011 3:52 PM
Intellectual1010 points
I'm transitioning this conversation from email to the forum, so my apologies for the formatting below:
Initial customer question:
“We are trying to use boundary scan to test the pop memory on the top of the DM3725. We have difficulty to find the top pin definitions (interface with DDRAM) on attached DM3725 Boundary Scan file. Did we use the right file? This is urgent for our factory. I appreciate any one of you can provide a quick feedback.”
Initial response from TI:
“The boundary scan is usually covered by the BSDL files we make available via our product folders on ti.com (I assume that is where the attached file originated from).  However, in many cases the BSDL file we provide does not include DDR interfaces (LPDDR in DM37x case) since this test is dependent on board design (trace lengths) and memory size chosen which is likely different between TI EVM and customer’s proprietary boards.”
Follow-up from customer:
"This is a pop and no board design (trace length) involved such that it should not be the reason to not provide DDR interface in BSDL, right?"
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Jim Carrillo
    on Dec 13, 2011 3:57 PM
    AM37xx_CBP BSDL.DOCX
    Here is the file that was attached to the original question:
    Report Abuse
    • Reply
  • Jeff Culverhouse
    Posted by Jeff Culverhouse
    on Dec 13, 2011 4:38 PM
    Expert6120 points
    Hello Jim,
    we do not currently support BSDL on the top balls.  Since the DDR are only located on the top there is no way to do BSDL with them.  If you need to do the GPMC balls then you will have to use the bottom balls and map them to the top.
    As far as I know most of the PoP memories do not support BSDL anyway, so I am not sure how you would check it anyway.
    Please click the Verify Answer button on this post if it answers your question.
    Jeff
    Report Abuse
    • Reply
  • Jim Carrillo
    on Dec 14, 2011 9:47 AM
    Thanks Jeff - Jim
    Report Abuse
    • Reply
  • Terry Walton
    Posted by Terry Walton
    on Dec 28, 2011 7:56 PM
    Prodigy60 points
    Jeff,
    Does the OMAP3530 CBP package respond to the OMAP3530 SVF File: OMAP35x_Pre-Init_Sequence.svf file?
    Do you have a manufacturer IDCODE and a IDCODE OPCODE for the OMAP3530 in CBP package?
    Can I use the same codes found at: http://processors.wiki.ti.com/index.php/Boundary_Scan_on_OMAP35x ?
    Report Abuse
    • Reply
  • Jeff Culverhouse
    on Jan 4, 2012 10:44 AM
    Expert6120 points
    Hello Terry,
    yes, that svf file will work with all of the OMAP35x devices.  The IDCODE is the same.  You will just need to make sure you get the correct BSDL file for the CBB package in OMAP3530.
    Jeff
    Report Abuse
    • Reply
Share
ALL CONTENT AND MATERIALS ON THIS SITE ARE PROVIDED "AS IS". TI AND ITS RESPECTIVE SUPPLIERS AND PROVIDERS OF CONTENT MAKE NO REPRESENTATIONS ABOUT THE SUITABILITY OF THESE MATERIALS FOR ANY PURPOSE AND DISCLAIM ALL WARRANTIES AND CONDITIONS WITH REGARD TO THESE MATERIALS, INCLUDING BUT NOT LIMITED TO ALL IMPLIED WARRANTIES AND CONDITIONS OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, TITLE AND NON-INFRINGEMENT OF ANY THIRD PARTY INTELLECTUAL PROPERTY RIGHT. TI AND ITS RESPECTIVE SUPPLIERS AND PROVIDERS OF CONTENT MAKE NO REPRESENTATIONS ABOUT THE SUITABILITY OF THESE MATERIALS FOR ANY PURPOSE AND DISCLAIM ALL WARRANTIES AND CONDITIONS WITH RESPECT TO THESE MATERIALS. NO LICENSE, EITHER EXPRESS OR IMPLIED, BY ESTOPPEL OR OTHERWISE, IS GRANTED BY TI. USE OF THE INFORMATION ON THIS SITE MAY REQUIRE A LICENSE FROM A THIRD PARTY, OR A LICENSE FROM TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Products | Applications | Design Support | Sample & Buy RSS
TI Worldwide | About TI | Contact Us | Investor Relations | Press Center | Corporate Citizenship | Careers | Tags | my.TI Login | All Searches | Site Map
© Copyright 1995- Texas Instruments Incorporated. All rights reserved. Trademarks | Privacy Policy | Terms of Use
