I use the ezsdk and I rebuild the pvrsrvkm.ko,I do no change for the graphics-sdk_4.04.00.02,then I use the prebuilt rootfs
as nfs,syslog have some error:
Starting PVR
PVR: PVRCore_Init
PM: Adding info for platform:pvrsrvkm
PVR: PVRSRVDriverProbe(pDevice=bf21d140)
PVR: EnableSystemClocks: Enabling System Clocks
PVR: GPTIMER11 clock is 20MHz
PVR: OSUnMapPhysToLin: unmapping 4 bytes from fa048054
PVR: OSUnMapPhysToLin: unmapping 4 bytes from fa048038
PVR: PVRCore_Init: major device 250
PM: Adding info for No Bus:pvrsrvkm
PM: Adding info for No Bus:bccat0
/dev/mem opened.
Memory mapped at address 0x40383000.
Read at address 0x48180F04 (0x40383f04): 0x00000001
Write at address 0x48180F04 (0x40383f04): 0x00000000, readback 0x00000000
/dev/mem opened.
Memory mapped at address 0x40303000.
Read at address 0x48180900 (0x40303900): 0x00000102
Write at address 0x48180900 (0x40303900): 0x00000002, readback 0x00000002
/dev/mem opened.
Memory mapped at address 0x40322000.
Read at address 0x48180920 (0x40322920): 0x00040002
Write at address 0x48180920 (0x40322920): 0x00000002, readback 0x00000002
PVR: Installing MISR with cookie bf21e81c
PVR: Installing device LISR SGX ISR on IRQ 37 with cookie c7ac83c0
PVR: OSUnMapPhysToLin: unmapping 65536 bytes from d0ba0000
PVR_K:(Warning): SysFinalise: Version string: SGX revision = 1.2.5 [583, usr/local/ezsdk02/component-sources/graphics-sdk_4.04.00.02/GFX_Linux_KM/services4/system/ti81xx/sysconfig.c]
PVR_K: (FAIL) SGXInit: Mismatch in client-side and KM driver build options; extra options present in KM: (0x1). Please check sgx_options.h
PVR_K:(Error): PVRSRVFinaliseSystem: Failed PVRSRVDevInitCompatCheck call (device index: 0) [422, usr/local/ezsdk02/component-sources/graphics-sdk_4.04.00.02/GFX_Linux_KM/services4/srvkm/common/pvrsrv.c]
PVR_K:(Error): BridgedDispatchKM: Initialisation failed. Driver unusable. [3785, usr/local/ezsdk02/component-sources/graphics-sdk_4.04.00.02/GFX_Linux_KM/services4/srvkm/bridged/bridged_pvr_bridge.c]
Calibrating touchscreen (first time only)ts_open: No such file or directory
our board have no lcd,and with 256m ddr3 in both ddr0 and ddr1 channels ,my bootargs is
'console=ttyO0,115200n8 notifyk.vpssm3_sva=0xBF900000 root=/dev/nfs nfsroot=192.168.1.213:/home/enson/targetfs/,nolock rw mem=176M ip=dhcp earlyprintk debug'
Enson
