TI8148 DVRRDK_03.50.00.05 demo not work for multiple channel
Other Parts Discussed in Thread: TVP5158
I have a TI DM8148 EVM & I am using DVRRDK_03.50.00.05 on it.
I run RDK demo for 4CH VCAP + VENC + VDEC + VDIS  - Progressive SD Encode + Decode.
It only works on channel 1(VIN1 Port). I mean it work when I give video source on VIN1 port.
If I give video source on channel 2(VIN2) to 4(VIN4), I didn't get any output.
How can I set this issue?
  • Can you share the logs of Print Detailed STatistics command "i" option in mcfw demo
  • root@dm814x:/opt/dvr_rdk/ti814x# ./run.sh
     Main Menu
     1: 4CH VCAP + VENC + VDEC + VDIS  - Progressive SD Encode + Decode
     2: 8CH <D1+CIF> VCAP + VENC + VDEC + VDIS  - Progressive SD Encode + Decode
     3: 16CH RT VCAP + VENC + VDEC + VDIS  - Progressive SD Encode + Decode
     4: 16CH NRT <D1+CIF> VCAP + VENC + VDEC + VDIS  - Progressive SD Encode + Decode
     5:               VDEC + VDIS  - SD/HD Decode ONLY
     e: Exit
     Enter Choice: 1
    --------------- CHANNEL DETAILS-------------
    Capture Channels => 4
    Enc Channels => Primary 4, Secondary 4
    Dec Channels => 4
    Disp Channels => 8
    ------------*** NameServer_add: duplicate entry found!
            Error [0xfffffffe] at Line no: 1055 in file /home/vaibhav/DVRRDK/DVRRDK_03.50.00.05/ti_tools/syslink/syslink_2_20_02_20/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/utils/hlos/knl/NameServer.c
     0: SYSTEM: System Common Init in progress !!!
     0: SYSTEM: IPC init in progress !!!
     11: SYSTEM: CPU [DSP] sy*** NameServer_add: duplicate entry found!
    slink proc ID is [0] !!!
     11: S*** NameServer_add: duplicate entry found!
    YSTEM: CPU [VIDEO-M3] syslink proc ID is [1] !!!*** NameServer_add: duplicate entry found!
     11: SYSTEM: CPU [VPSS-M3] sys*** NameServer_add: duplicate entry found!
    link proc ID is [2] !!!
     11: SYSTEM: CPU [HOST]*** NameServer_add: duplicate entry found!
     syslink proc ID is [3] !!!
     11*** NameServer_add: duplicate entry found!
    : SYSTEM: Creating MsgQ Heap [IP*** NameServer_add: duplicate entry found!
    C_MSGQ_MSG_HEAP_3] ...
     39: SYS*** NameServer_add: duplicate entry found!
    TEM: Creating MsgQ [HOST_MSGQ] ...
     41: SYSTEM:*** NameServer_add: duplicate entry found!
     Creating MsgQ [HOST_ACK_MSGQ] .*** NameServer_add: duplicate entry found!
     43: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
     44: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
     44: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
     45: SYSTEM: Notify register to [DSP] line 0, event 15 ...
     46: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
     46: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
     47: SYSTEM: IPC init DONE !!!
     48: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
     76: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
     102: SYSTEM: ListElem Shared Addr = 0x40a9d980
     103: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
     131: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
     157: SYSTEM: ListElem Shared Addr = 0x40abb480
     158: SYSTEM: Creating ListMP [HOST_IPC_OUT_19] in region 0 ...
     186: SYSTEM: Creating ListMP [HOST_IPC_IN_19] in region 0 ...
     212: SYSTEM: ListElem Shared Addr = 0x40ad8f80
     213: SYSTEM: Creating ListMP [HOST_IPC_OUT_20] in region 0 ...
     239: SYSTEM: Creating ListMP [HOST_IPC_IN_20] in region 0 ...
     265: SYSTEM: ListElem Shared Addr = 0x40afc800
     266: SYSTEM: Creating ListMP [HOST_IPC_OUT_21] in region 0 ...
     294: SYSTEM: Creating ListMP [HOST_IPC_IN_21] in region 0 ...
     321: SYSTEM: ListElem Shared Addr = 0x40b20080
     321: SYSTEM: System Common Init Done !!!
     [host] HDMI Ctrl :Initializing
     [host] HDMI Ctrl :Initialized
     Enable file write (YES - y / NO - n) : y
     File write ENABLED !!!
     Enter file write path : /home/vaibhav/
     Selected file write path [/home/vaibhav/]
     [host] Partition Free Size for Path[/home/vaibhav//VBITS_HDR_0_LAYER_0.bin] = [0xA6939900]
     [host] Max File size per channel:0x1BC3442A
     [host] MCFW_IPCBITS:VcapVencVdecVdis_ipcBitsSendFxn:Entered...
     AUDIO: Do you enable Audio <Y/N>: n
     [FBDEV]
     [FBDEV] FB: Starting !!!
     [FBDEV] FB: Opened device [/dev/fb0] (fd=406) !!!
     [FBDEV]
     [FBDEV] Fix Screen Info
     [FBDEV] ---------------
     [FBDEV] Line Length - 2560
     [FBDEV] Physical Address = 84c00000
     [FBDEV] Buffer Length = 9437184
     [FBDEV]
     [FBDEV]
     [FBDEV] Var Screen Info
     [FBDEV] Xres - 1280
     [FBDEV] Yres - 720
     [FBDEV] Xres Virtual - 1280
     [FBDEV] Yres Virtual - 720
     [FBDEV] Bits Per Pixel - 16
     [FBDEV] Pixel Clk - 6734
     [FBDEV] Rotation - 0
     [FBDEV]
     [FBDEV]
     [FBDEV] Reg Params Info
     [FBDEV] region 0, postion 0 x 0, prioirty 1
     [FBDEV] first 1, last 1
     [FBDEV] sc en 0, sten en 0
     [FBDEV] tran en 0, type 0, key 0
     [FBDEV] blend 0, alpha 0
     [FBDEV] bb en 0, alpha 0
     [FBDEV]
     [FBDEV]
     [FBDEV] ### BUF SIZE = 1843200 Bytes !!!
     [FBDEV]
     [FBDEV] FB: Opened device [/dev/fb2] (fd2=407) !!!
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV] Xres - 720
     [FBDEV] Yres - 480
     [FBDEV] Xres Virtual - 720
     [FBDEV] Yres Virtual - 480
     [FBDEV] Pixel Clk - 18518
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV] ### BUF SIZE = 691200 Bytes !!!
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV] Xres - 1280
     [FBDEV] Yres - 720
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV] Xres - 1280
     [FBDEV] Yres - 720
     [FBDEV]
     [FBDEV]
     [FBDEV] sc en 1, sten en 0
     [FBDEV] tran en 1, type 0, key 16777215
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV] Xres - 1280
     [FBDEV] Yres - 720
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV] grpx_fb_draw ...
     [FBDEV] grpx_fb_draw ... Done !!!
     [FBDEV] FB: Start DONE !!!
     [FBDEV]
    ********* Entered usecase 4CH <814x> Enc/Dec OSD Enabled SCD Enabled
     25252: MCFW  : CPU Revision [ES2.1] !!!
     25252: MCFW  : Detected [UNKNOWN] Board !!!
     25252: MCFW  : Base Board Revision [REV A] !!!
     VCAP: DEVICE-0 (0x58): Device not found !!!
     [m3vpss ]  70731: CAPTURE: Create in progress !!!
     [m3vpss ]  70764: CAPTURE: VIP0 PortA capture mode is [ 8-bit, Pixel-mux Embedded Sync] !!!
     [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 58 (58)
     [m3vpss ]  UTILS: DMA: 0 of 4: Allocated PaRAM = 58 (0x49004740)
     [m3vpss ]  UTILS: DMA: 1 of 4: Allocated PaRAM = 64 (0x49004800)
     [m3vpss ]  UTILS: DMA: 2 of 4: Allocated PaRAM = 65 (0x49004820)
     [m3vpss ]  UTILS: DMA: 3 of 4: Allocated PaRAM = 66 (0x49004840)
     [m3vpss ] CAPTURE::HEAPID:0    USED:328
     [m3vpss ] CAPTURE::HEAPID:4    USED:17713152
     [m3vpss ]  70840: CAPTURE: Create Done !!!
     [m3vpss ]  70840: DEI    : Create in progress !!!
     [m3vpss ]  70961: DEI     : Loading Up-scaling Co-effs
     [m3vpss ]  70961: DEI     : Co-effs Loading ... DONE !!!
     [m3vpss ] DEI:HEAPID:0 USED:64
     [m3vpss ] DEI:HEAPID:1 USED:9600
     [m3vpss ] DEI:HEAPID:4 USED:21626880
     [m3vpss ]  70962: DEI    : Create Done !!!
     [m3vpss ]  70968: DUP   : Create Done !!!
     [m3vpss ]  70968: NSF: Create in progress !!!
     [m3video]  71017: IPC_IN_M3   : Create in progress !!!
     [m3video]  71018: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
     [m3video]  71018: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
     [m3vpss ] NSF::HEAPID:0        USED:128
     [m3vpss ] NSF::HEAPID:1        USED:9152
     [m3vpss ] NSF::HEAPID:4        USED:8110080
     [m3vpss ]  71014: NSF: Create Done !!!
     [m3vpss ]  71016: MERGE   : Create Done !!!
     [m3vpss ]  71016: IPC_OUT_M3   : Create in progress !!!
     [m3vpss ]  71017: IPC_OUT_M3   : Create Done !!!
     [m3video]  71021: IPC_IN_M3   : Create Done !!!
     [m3video]  71022: ALG : Create in progress !!!
     [m3video]  71032: ALG : Prev Link ID = 10000002 !!!
     [m3video]  71033: OSD: Opening algorithm ... !!!
     [m3video]  71046: OSD: Opening algorithm ... DONE !!!
     [m3video]  UTILS: DMA: Allocated CH (TCC) = 51 (51)
     [m3video]  UTILS: DMA: 0 of 8: Allocated PaRAM = 51 (0x49004660)
     [m3video]  UTILS: DMA: 1 of 8: Allocated PaRAM = 479 (0x49007BE0)
     [m3video]  UTILS: DMA: 2 of 8: Allocated PaRAM = 480 (0x49007C00)
     [m3video]  UTILS: DMA: 3 of 8: Allocated PaRAM = 481 (0x49007C20)
     [m3video]  UTILS: DMA: 4 of 8: Allocated PaRAM = 482 (0x49007C40)
     [m3video]  UTILS: DMA: 5 of 8: Allocated PaRAM = 483 (0x49007C60)
     [m3video]  UTILS: DMA: 6 of 8: Allocated PaRAM = 484 (0x49007C80)
     [m3video]  UTILS: DMA: 7 of 8: Allocated PaRAM = 485 (0x49007CA0)
     [m3video]  71064: SCD: Opening algorithm ... !!!
     [m3video]  71064: SCD: Opening algorithm ... DONE !!!
     [m3video]  UTILS: DMA: Allocated CH (TCC) = 56 (56)
     [m3video]  UTILS: DMA: 0 of 1: Allocated PaRAM = 56 (0x49004700)
     [m3video] ALGLINK:HEAPID:0     USED:30672
     [m3video] ALGLINK:HEAPID:3     USED:6294656
     [m3video]  71083: ALG : Create Done !!!
     [m3video]  71087: ENCODE: Create in progress ... !!!
     [m3video] ENCLINK:INFO: !!!Number of output buffers for ch[8] set to [1]
     [m3video]  71119: ENCODE: Creating CH0 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED  ], bitrate = 2000 Kbps ...
     [m3video] ENCLINK_H264:HEAPID:0        USED:13888
     [m3video] ENCLINK_H264:HEAPID:3        USED:2244608
     [m3video]  71133: ENCODE: Creating CH1 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED  ], bitrate = 2000 Kbps ...
     [m3video] ENCLINK_H264:HEAPID:0        USED:11912
     [m3video] ENCLINK_H264:HEAPID:3        USED:1511424
     [m3video]  71143: ENCODE: Creating CH2 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED  ], bitrate = 2000 Kbps ...
     [host] IpcBitsInLink_tskMain:Entered
     [host]  25709: IPC_BITS_IN   : Create in progress !!!
     [host]  25709: IPC_BITS_IN   : ListMPOpen start !!!
     [host]  25709: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_24] ...
     25711: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_24] ...
     [host]  25712: IPC_BITS_IN   : ListMPOpen done !!!
     [host]  25714: IPC_BITS_IN   : System_linkGetInfo done !!!
     [host]  25714: IPC_BITS_IN   : Create Done !!!
    ========bitsProducerLinkInfo============
    numQ 1, numCh 12
    Ch [0] Width 704, Height 480
    Ch [1] Width 704, Height 480
    Ch [2] Width 704, Height 480
    Ch [3] Width 704, Height 480
    Ch [4] Width 352, Height 240
    Ch [5] Width 352, Height 240
    Ch [6] Width 352, Height 240
    Ch [7] Width 352, Height 240
    Ch [8] Width 704, Height 480
    Ch [9] Width 704, Height 480
    Ch [10] Width 704, Height 480
    Ch [11] Width 704, Height 480
    Reducing bitsProducerLinkInfo.numCh to 4
     [host]  25714: IPC_BITS_OUT   : Create in progress !!!
    ###Bit buff of size from the SR # 1 : 6635520
     [host] IPC_BITSOUT:BitBuffer Alloc.PoolID:0,Size:0x654000
     [host] IPCBITSOUTLINK:Translated Addr Virt:0x4129d280 To Phy:0x88519280
     [host]  25715: IPC_BITS_OUT   : Create Done !!!
     [m3video]  71152: ENCODE: Creating CH3 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED  ], bitrate = 2000 Kbps ...
     [m3video]  71162: ENCODE: Creating CH4 of 352 x 240, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video] ENCLINK_H264:HEAPID:3        USED:503808
     [m3video]  71166: ENCODE: Creating CH5 of 352 x 240, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  71170: ENCODE: Creating CH6 of 352 x 240, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  71175: ENCODE: Creating CH7 of 352 x 240, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  71179: ENCODE: Creating CH8 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED  ], bitrate = 100 Kbps ...
     [m3video] ENCLINK_JPEG:HEAPID:0        USED:2064
     [m3vpss ]  71315: IPC_IN_M3   : Create in progress !!!
     [m3video]  71180: ENCODE: Creating CH9 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED  ], bitrate = 100 Kbps ...
     [m3vpss ]  71315: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
     [m3vpss ]  71316: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
     [m3vpss ]  71317: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
     [m3vpss ]  71319: IPC_IN_M3   : Create Done !!!
     [m3video]  71180: ENCODE: Creating CH10 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED  ], bitrate = 100 Kbps ...
     [m3vpss ]  71320: MERGE   : Create Done !!!
     [m3vpss ]  71326: DUP   : Create Done !!!
     [m3vpss ]  71326: SWMS: Create in progress !!!
     [m3video]  71181: ENCODE: Creating CH11 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED  ], bitrate = 100 Kbps ...
     [m3video]  71182: ENCODE: All CH Create ... DONE !!!
     [m3video] ENCLINK:HEAPID:0     USED:105568
     [m3video] ENCLINK:HEAPID:2     USED:5345792
     [m3video] ENCLINK:HEAPID:3     USED:8794112
     [m3video]  71183: ENCODE: Create ... DONE !!!
     [m3video]  71183: IPC_BITS_OUT   : Create in progress !!!
     [m3video]  71186: IPC_BITS_OUT   : Create Done !!!
     [m3video]  71193: IPC_BITS_IN   : Create in progress !!!
     [m3video]  71193: SYSTEM: Opening ListMP [HOST_IPC_OUT_24] ...
     [m3video]  71194: SYSTEM: Opening ListMP [HOST_IPC_IN_24] ...
     [m3video]  71195: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
     [m3video]  71197: IPC_BITS_IN   : Create Done !!!
     [m3video]  71197: DECODE: Create in progress ... !!!
     [m3video] DECLINK_H264:HEAPID:0        USED:2368
     [m3video] DECLINK_H264:HEAPID:3        USED:1249280
     [m3video]  71226: DECODE: Creating CH0 of 704 x 480 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3video]  71254: DECODE: Creating CH1 of 704 x 480 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3video]  71282: DECODE: Creating CH2 of 704 x 480 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3video]  71309: DECODE: Creating CH3 of 704 x 480 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3video]  71311: DECODE: All CH Create ... DONE !!!
     [m3video] DECLINK:HEAPID:0     USED:9512
     [m3video] DECLINK:HEAPID:3     USED:19447808
     [m3video]  71313: DECODE: Create ... DONE !!!
     [m3video]  71314: IPC_OUT_M3   : Create in progress !!!
     [m3video]  71315: IPC_OUT_M3   : Create Done !!!
     [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 59 (59)
     [m3vpss ]  UTILS: DMA: 0 of 1: Allocated PaRAM = 59 (0x49004760)
     [m3vpss ] SWMS: instance 0, sc id 7, start win 0 end win 17
     [m3vpss ]  71514: SWMS    : VipScReq is TRUE!!!
     [m3vpss ]  71519: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3vpss ]  71519: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3vpss ]  71519: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]  71519: SWMS    : OutFrames List -> 2 !!!!!!!
     [m3vpss ] AVSYNC:WARNING!! Application wrongly configureddisplayID[-1]. Reseting to correct displayID[0]
     [m3vpss ]  71520: SWMS    : ******* Configuring clock 15 secs...
     [m3vpss ]  71520: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3vpss ]  71521: SWMS0    : Loading Horizontal Co-effs (10/16)x ...
     [m3vpss ]  71521: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]
     [m3vpss ]  *** [SWMS0] Mosaic Parameters ***
     [m3vpss ]
     [m3vpss ]  Output FPS: 60
     [m3vpss ]
     [m3vpss ]  Win | Ch  | Input      | Input          | Input         | Input       | Output     |  Output         | Output        | Output      | Low Cost | SWMS | Data  | Blank |
     [m3vpss ]  Num | Num | Start X, Y | Width x Height | Pitch Y / C   | Memory Type | Start X, Y |  Width x Height | Pitch Y / C   | Memory Type | ON / OFF | Inst | Format| Frame |
     [m3vpss ]  ----------------------------------------------------------------------------------------------------------------------------------------------------------------------
     [m3vpss ]    0 |   0 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |    0,    0 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]    1 |   1 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |  480,    0 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]    2 |   2 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |  960,    0 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]    3 |   3 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   | 1440,    0 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]    4 |   4 |    0,    0 |   704 x    240 |  1792 /  1792 | NON-TILED   |    0,  270 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  420SP |   OFF |
     [m3vpss ]    5 |   5 |    0,    0 |   704 x    240 |  1792 /  1792 | NON-TILED   |  480,  270 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  420SP |   OFF |
     [m3vpss ]    6 |   6 |    0,    0 |   704 x    240 |  1792 /  1792 | NON-TILED   |  960,  270 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  420SP |   OFF |
     [m3vpss ]    7 |   7 |    0,    0 |   704 x    240 |  1792 /  1792 | NON-TILED   | 1440,  270 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  420SP |   OFF |
     [m3vpss ]    8 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |    0,  540 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]    9 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  480,  540 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]   10 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  960,  540 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]   11 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   | 1440,  540 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]   12 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |    0,  810 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]   13 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  480,  810 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]   14 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  960,  810 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]   15 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   | 1440,  810 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]
     [m3vpss ] SWMS:HEAPID:0        USED:224
     [m3vpss ] SWMS:HEAPID:1        USED:20224
     [m3vpss ] SWMS:HEAPID:3        USED:4147200
     [m3vpss ] SWMS:HEAPID:4        USED:29030400
     [m3vpss ]  71528: SWMS: Create Done !!!
     [m3vpss ]  71528: SWMS: Create in progress !!!
     [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 60 (60)
     [m3vpss ]  UTILS: DMA: 0 of 1: Allocated PaRAM = 60 (0x49004780)
     [m3vpss ] SWMS: instance 0, sc id 5, start win 0 end win 17
     [m3vpss ]  71577: SWMS1    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3vpss ]  71577: SWMS1    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3vpss ]  71577: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ] AVSYNC:WARNING!! Application wrongly configureddisplayID[-1]. Reseting to correct displayID[2]
     [m3vpss ]  71578: SWMS    : ******* Configuring clock 15 secs...
     [m3vpss ]  71578: SWMS1    : Loading Vertical Co-effs (7/16)x ...
     [m3vpss ]  71578: SWMS1    : Loading Horizontal Co-effs (3/16)x ...
     [m3vpss ]  71578: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]
     [m3vpss ]  *** [SWMS1] Mosaic Parameters ***
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]    0 |   0 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |    0,    0 |   176 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]    1 |   1 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |  176,    0 |   176 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]    2 |   2 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |  352,    0 |   176 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]    3 |   3 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |  528,    0 |   192 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]    4 |   4 |    0,    0 |   704 x    240 |  1792 /  1792 | NON-TILED   |    0,  120 |   176 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  420SP |   OFF |
     [m3vpss ]    5 |   5 |    0,    0 |   704 x    240 |  1792 /  1792 | NON-TILED   |  176,  120 |   176 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  420SP |   OFF |
     [m3vpss ]    6 |   6 |    0,    0 |   704 x    240 |  1792 /  1792 | NON-TILED   |  352,  120 |   176 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  420SP |   OFF |
     [m3vpss ]    7 |   7 |    0,    0 |   704 x    240 |  1792 /  1792 | NON-TILED   |  528,  120 |   192 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  420SP |   OFF |
     [m3vpss ]    8 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |    0,  240 |   176 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]    9 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  176,  240 |   176 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]   10 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  352,  240 |   176 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]   11 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  528,  240 |   192 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]   12 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |    0,  360 |   176 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]   13 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  176,  360 |   176 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]   14 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  352,  360 |   176 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]   15 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  528,  360 |   192 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  422I  |   OFF |
     [m3vpss ]
     DEMO: No video detected at CH [0] !!!
     DEMO: No video detected at CH [1] !!!
     DEMO: No video detected at CH [2] !!!
     DEMO: No video detected at CH [3] !!!
     Run-Time Menu
     1: Capture Settings
     2: Encode  Settings
     3: Decode  Settings
     4: Display Settings
     5: Audio Capture <TVP5158> & Encode <AAC-LC, G711> demo
     6: Change Playback Channel <valid only if capture/playback is active>
     7: Audio encode demo <File In/Out>
     8: Audio decode demo <File In/Out>
     c: Change 8CH modes (8CH usecase ONLY!!!!)
     d: Change 16CH modes (16CH usecase ONLY!!!!)
     i: Print detailed system information
     s: Core Status: Active/In-active
     e: Stop Demo
     [m3vpss ] SWMS:HEAPID:1        USED:47296
     [m3vpss ] SWMS:HEAPID:3        USED:5087232
     [m3vpss ] SWMS:HEAPID:4        USED:1695744
     [m3vpss ]  71586: SWMS: Create Done !!!
     [m3vpss ]  71586: DISPLAY: Create in progress !!!
     [m3vpss ]  71587: DISPLAY: Create Done !!!
     [m3vpss ]  71588: DISPLAY: Create in progress !!!
     [m3vpss ]  71588: DISPLAY: 44: Field Separate Mode ENABLED for Que 0 !!!
     [m3vpss ]  71589: DISPLAY: Create Done !!!
     [m3vpss ]  71597: DISPLAY: Start in progress !!!
     [m3vpss ]  71662: DISPLAY: Start Done !!!
     [m3vpss ]  71662: DISPLAY: HDDAC(BP0) : 30 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
     Enter Choice:  [m3vpss ]  71662: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 1, HDDAC(BP0) 0, DVO2(BP1) 1, SDDAC(SEC1) 0
     [m3vpss ]  71663: SYSTEM  : FREE SPACE : System Heap      = 243136 B, Mbx = 10238 msgs)
     [m3vpss ]  71663: SYSTEM  : FREE SPACE : SR0 Heap         = 1426688 B (1 MB)
     [m3vpss ]  71663: SYSTEM  : FREE SPACE : Frame Buffer     = 417536 B (0 MB)
     [m3vpss ]  71663: SYSTEM  : FREE SPACE : Bitstream Buffer = 61621632 B (58 MB)
     [m3vpss ]  71663: DISPLAY: Start in progress !!!
     [m3vpss ]  71664: SYSTEM  : FREE SPACE : Tiler 8-bit      = 89128960 B (85 MB)  - TILER ON
     [m3vpss ]  71664: SYSTEM  : FREE SPACE : Tiler 16-bit     = 44040192 B (42 MB)  - TILER ON
     [m3vpss ]  71698: DISPLAY: Start Done !!!
     [m3vpss ]  71698: DISPLAY: SDDAC(SEC1): 28 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
     [m3vpss ]  71698: SWMS: Start in Progress !!!
     [m3vpss ]  71698: SWMS: Start Done !!!
     [m3vpss ]  71699: SWMS: Start in Progress !!!
     [m3vpss ]  71699: SWMS: Start Done !!!
     [m3vpss ]  71803: CAPTURE: Start in progress !!!
     [m3vpss ]  71804: CAPTURE: Start Done !!!
     [m3vpss ]  71903: CAPTURE: Enabled Time Stamping !!!
    This is the log,
    But I am getting only black data on my screen.
  • Do you have vs daughter card connected to the EVM ? Also is this the first demo you are running after board reboot ? The nameserver errors are not expected.
  • Hi Badri,
    Yes my daughter card is connected to EVM.
    And yes this is my first demo I am running after my board is reboot.
  • Share the logs from kernel boot onwards. I want to check if there were any i2c timeout errors. Also give the "I" cmd after running the demo as I previously mentioned and include it in the logs.
  • _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org dm814x ttyO0
    Arago 2010.11 dm814x ttyO0
    dm814x login: root
    root@dm814x:~#
    root@dm814x:~#
    root@dm814x:~#
    root@dm814x:~# cd /opt/dvr_rdk/ti814x
    root@dm814x:/opt/dvr_rdk/ti814x# ./init.sh
    *** Bootargs Validated for mem param ***
    *** Bootargs Validated for notifyk.vpssm3 params ***
    Kernel bootargs validated
    numid=1,iface=MIXER,name='PCM Playback Volume'
      ; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
      : values=127,127
      | dBscale-min=-63.50dB,step=0.50dB,mute=0
     [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
     [m3video] Remote Debug Shared Memory @ 0xbff05020
     [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
    SysLink version : 2.20.02.20
    SysLink module created on Date:Apr  9 2013 Time:16:10:22
    Trace enabled
    Trace SetFailureReason enabled
     Setting DMM priority for [DUCATI  ] to [0] ( 0x4e000624 = 0x08000000 )
     Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a )
     *** TVP5158 probe : START ***
     TI VS EVM : TVP5158 device address : 0x58, 0x5a, 0x5c, 0x5e
     TI DVR    : TVP5158 device address : 0x58, 0x59, 0x5a, 0x5b
     Device found     : I2C (0xXX): 0x08 = 0x51
                        I2C (0xXX): 0x09 = 0x58
     Device NOT found : I2C (0xXX): Read ERROR !!! (reg[0x08], count = 2)
     I2C (0x58): Read ERROR !!! (reg[0x08], count = 2)
     I2C (0x5a): Read ERROR !!! (reg[0x08], count = 2)
     I2C (0x5c): Read ERROR !!! (reg[0x08], count = 2)
     I2C (0x5e): Read ERROR !!! (reg[0x08], count = 2)
     I2C (0x59): Read ERROR !!! (reg[0x08], count = 2)
     I2C (0x5b): Read ERROR !!! (reg[0x08], count = 2)
     *** TVP5158 probe : END ***
    /opt/dvr_rdk/ti814x
    root@dm814x:/opt/dvr_rdk/ti814x# ./load.sh
    Attached to slave procId 2.
    Loaded file ../firmware/dvr_rdk_fw_m3vpss_512M_128M.xem3 on slave procId 2.
    Started slave procId 2.
    After Ipc_loadcallback status [0x00000000]
     [m3vpss ]      ISS Freq  : 480 MHz
     [m3vpss ] ***** SYSTEM  : Frequency <ORG> - 200000000, <NEW> - 240000000
     [m3vpss ] notify_attach  rtnVal  0
     [m3vpss ] initProxyServer  rtnVal  0
     [m3vpss ]
     [m3vpss ]  *** UTILS: CPU KHz = 480000 Khz ***
     [m3vpss ]
     [m3vpss ]  44: SYSTEM  : System Common Init in progress !!!
     [m3vpss ]  44: SYSTEM: IPC init in progress !!!
     [m3vpss ]  44: SYSTEM: Attaching to [HOST] ...
     [m3vpss ]  1044: SYSTEM: Attaching to [HOST] ...
     [m3vpss ]  1046: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
    After Ipc_startcallback status [0x00000000]
     [m3vpss ]  1046: SYSTEM: Attaching to [DSP] ...
    Attached to slave procId 1.
    Loaded file ../firmware/dvr_rdk_fw_m3video_512M_128M.xem3 on slave procId 1.
    Started slave procId 1.
     [m3video]      ISS Freq  : 480 MHz
     [m3video] ***** SYSTEM  : Frequency <ORG> - 200000000, <NEW> - 240000000
     [m3video]
     [m3video]  *** UTILS: CPU KHz = 480000 Khz ***
     [m3video]
     [m3video]  1330: SYSTEM  : System Common Init in progress !!!
     [m3video]  1330: SYSTEM: IPC init in progress !!!
     [m3video]  1330: SYSTEM: Attaching to [HOST] ...
     [m3vpss ]  2046: SYSTEM: Attaching to [DSP] ...
     [m3video]  2330: SYSTEM: Attaching to [HOST] ...
     [m3video]  2332: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
     [m3video]  2333: SYSTEM: Attaching to [DSP] ...
    Attached to slave procId 0.
    Loaded file ../firmware/dvr_rdk_fw_c6xdsp_512M_128M.xe674 on slave procId 0.
    Started slave procId 0.
     [c6xdsp ]      DSP Freq  : 750 MHz
     [c6xdsp ] ***** SYSTEM  : Frequency <ORG> - 500000000, <NEW> - 750000000
     [c6xdsp ]
     [c6xdsp ]  *** UTILS: CPU KHz = 750000 Khz ***
     [c6xdsp ]
     [c6xdsp ]  1: SYSTEM  : System Common Init in progress !!!
     [c6xdsp ]  1: SYSTEM: IPC init in progress !!!
     [c6xdsp ]  1: SYSTEM: Attaching to [HOST] ...
     [m3vpss ]  3046: SYSTEM: Attaching to [DSP] ...
     [m3video]  3332: SYSTEM: Attaching to [DSP] ...
     [c6xdsp ]  1000: SYSTEM: Attaching to [HOST] ...
     [c6xdsp ]  1003: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
     [c6xdsp ]  1003: SYSTEM: Attaching to [VIDEO-M3] ...
    DMA: Module install successful, device major num = 251
    DRV: Module install successful
    DRV: Module built on Apr  9 2013 16:10:45
     [m3vpss ]  4046: SYSTEM: Attaching to [DSP] ...
     [m3video]  4332: SYSTEM: Attaching to [DSP] ...
     [c6xdsp ]  2002: SYSTEM: Attaching to [VIDEO-M3] ...
     [m3vpss ]  5046: SYSTEM: Attaching to [DSP] ...
     [c6xdsp ]  2845: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
     [m3video]  5332: SYSTEM: Attaching to [DSP] ...
     [c6xdsp ]  2845: SYSTEM: Attaching to [VPSS-M3] ...
     [m3video]  5332: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
     [m3video]  5332: SYSTEM: Attaching to [VPSS-M3] ...
     [m3vpss ]  6046: SYSTEM: Attaching to [DSP] ...
     [c6xdsp ]  3845: SYSTEM: Attaching to [VPSS-M3] ...
     [m3video]  6332: SYSTEM: Attaching to [VPSS-M3] ...
     [c6xdsp ]  4559: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
     [m3vpss ]  7046: SYSTEM: Attaching to [DSP] ...
     [c6xdsp ]  4559: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_0] ...
     [m3vpss ]  7046: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
     [c6xdsp ]  4559: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
     [m3vpss ]  7046: SYSTEM: Attaching to [VIDEO-M3] ...
     [c6xdsp ]  4559: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
     [c6xdsp ]  4560: SYSTEM: Notify register to [HOST] line 0, event 15 ...
     [c6xdsp ]  4560: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
     [c6xdsp ]  4560: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
     [c6xdsp ]  4560: SYSTEM: IPC init DONE !!!
     [c6xdsp ]  4562: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x07000000 (112 MB)
     [c6xdsp ]  4562: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4571: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4581: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4591: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4601: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4611: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4621: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4631: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4641: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4651: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4661: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4671: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4681: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4691: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4701: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4711: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4721: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4731: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4741: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4751: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4761: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4771: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4781: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4791: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4801: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4811: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4821: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4831: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4841: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [m3video]  7332: SYSTEM: Attaching to [VPSS-M3] ...
     [c6xdsp ]  4851: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4861: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4871: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4881: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4891: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4901: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4911: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4921: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4931: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4941: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4951: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4961: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4971: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4981: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  4991: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5001: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5011: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5021: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5031: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5041: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5051: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5061: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5071: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5081: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5091: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5101: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5111: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5121: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5131: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5141: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5151: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5161: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5171: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5181: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5191: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5201: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5211: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5221: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5231: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5241: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5251: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5261: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5271: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5281: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5291: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5301: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5311: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5321: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5331: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5341: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5351: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5361: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5371: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5381: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5391: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5401: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5411: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5421: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5431: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5441: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5451: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5461: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5471: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5481: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5491: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5501: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5511: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5521: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5531: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5541: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5551: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [c6xdsp ]  5561: MEM: ERROR: SharedRegion_setEntry (2, 0x8fc85bfc) FAILED !!!  (status=-1)
     [m3video]  8046: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
     [m3vpss ]  8046: SYSTEM: Attaching to [VIDEO-M3] ...
     [m3video]  8046: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_1] ...
     [m3vpss ]  8046: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
     [m3video]  8047: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
     [m3vpss ]  8046: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_2] ...
     [m3video]  8047: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
     [m3vpss ]  8047: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
     [m3video]  8049: SYSTEM: Notify register to [HOST] line 0, event 15 ...
     [m3vpss ]  8047: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
     [m3video]  8049: SYSTEM: Notify register to [DSP] line 0, event 15 ...
     [m3vpss ]  8049: SYSTEM: Notify register to [HOST] line 0, event 15 ...
     [m3video]  8049: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
     [m3vpss ]  8049: SYSTEM: Notify register to [DSP] line 0, event 15 ...
     [m3video]  8049: SYSTEM: IPC init DONE !!!
     [m3vpss ]  8049: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
     [m3vpss ]  8049: SYSTEM: IPC init DONE !!!
     [c6xdsp ]  5571: MEM: Shared Region 1: Base = 0x88000000, Length = 0x04f00000 (79 MB)
     [m3video]  8057: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x07000000 (112 MB)
     [m3vpss ]  8057: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x07000000 (112 MB)
     [c6xdsp ]  5572: SYSTEM  : System Common Init Done !!!
     [m3video]  8057: MEM: Shared Region 1: Base = 0x88000000, Length = 0x04f00000 (79 MB)
     [m3vpss ]  8057: MEM: Shared Region 1: Base = 0x88000000, Length = 0x04f00000 (79 MB)
     [c6xdsp ]  5571: SYSTEM  : System DSP Init in progress !!!
     [m3video]  8059: SYSTEM  : System Common Init Done !!!
     [m3vpss ]  8059: SYSTEM  : System Common Init Done !!!
     [c6xdsp ]  5571: SYSTEM  : RpeServer_init() done... Ret Val 0!!!
     [m3video]  8059: SYSTEM  : System Video Init in progress !!!
     [m3vpss ]  8059: SYSTEM  : System VPSS Init in progress !!!
     [c6xdsp ]  5576: SYSTEM: Creating ListMP [DSP_IPC_OUT_19] in region 0 ...
     [m3video]  8059: SYSTEM  : System Video Init Done !!!
     [c6xdsp ]  5576: SYSTEM: Creating ListMP [DSP_IPC_IN_19] in region 0 ...
     [m3video]  8060: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
     [c6xdsp ]  5576: SYSTEM: ListElem Shared Addr = 0xbf177300
     [m3video]  8060: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
     [m3video]  8061: SYSTEM: ListElem Shared Addr = 0xbf173e00
     [c6xdsp ]  5577: SYSTEM: Creating ListMP [DSP_IPC_OUT_20] in region 0 ...
     [m3video]  8063: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
     [c6xdsp ]  5577: SYSTEM: Creating ListMP [DSP_IPC_IN_20] in region 0 ...
     [m3video]  8063: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
     [c6xdsp ]  5577: SYSTEM: ListElem Shared Addr = 0xbf19e080
     [m3video]  8063: SYSTEM: ListElem Shared Addr = 0xbf19ab80
     [c6xdsp ]  5578: SYSTEM: Creating ListMP [DSP_IPC_OUT_21] in region 0 ...
     [m3video]  8071: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_19] in region 0 ...
     [c6xdsp ]  5578: SYSTEM: Creating ListMP [DSP_IPC_IN_21] in region 0 ...
     [m3video]  8071: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_19] in region 0 ...
     [c6xdsp ]  5578: SYSTEM: ListElem Shared Addr = 0xbf1c1900
     [m3video]  8071: SYSTEM: ListElem Shared Addr = 0xbf220780
     [c6xdsp ]  5579: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
     [c6xdsp ]  5579: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
     [c6xdsp ]  5579: SYSTEM: ListElem Shared Addr = 0xbf1e5180
     [c6xdsp ]  5579: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
     [c6xdsp ]  5580: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
     [c6xdsp ]  5580: SYSTEM: ListElem Shared Addr = 0xbf202c80
     [c6xdsp ] !!WARNING.Resource already registered:2
     [c6xdsp ]  5579: SYSTEM  : Initializing Links !!!
     [c6xdsp ]  5580: SYSTEM  : FREE SPACE : System Heap      = 6393472 B, Mbx = 10240 msgs)
     [m3video]  8074: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_20] in region 0 ...
     [m3vpss ] === I2C0/2 Clk is active ===
     [m3video]  8074: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_20] in region 0 ...
     [m3vpss ]  8077: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
     [c6xdsp ]  5591: SYSTEM  : Initializing Links ... DONE !!!
     [m3video]  8074: SYSTEM: ListElem Shared Addr = 0xbf244000
     [m3vpss ]  8078: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
     [m3video]  8077: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_21] in region 0 ...
     [m3vpss ]  8078: SYSTEM: ListElem Shared Addr = 0xbf267e00
     [c6xdsp ]  5591: SYSTEM  : System DSP Init Done !!!
     [m3video]  8078: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_21] in region 0 ...
     [m3vpss ]  8081: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
     [m3video]  8078: SYSTEM: ListElem Shared Addr = 0xbf26ad80
     [m3vpss ]  8081: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
     [m3video]  8095: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_24] in region 0 ...
     [m3vpss ]  8081: SYSTEM: ListElem Shared Addr = 0xbf28e600
     [m3video]  8095: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_24] in region 0 ...
     [m3vpss ]  8099: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_19] in region 0 ...
     [m3video]  8096: SYSTEM: ListElem Shared Addr = 0xbf291b00
     [m3vpss ]  8099: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_19] in region 0 ...
     [m3video]  8098: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_25] in region 0 ...
     [m3vpss ]  8099: SYSTEM: ListElem Shared Addr = 0xbf2cd100
     [m3video]  8099: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_25] in region 0 ...
     [m3vpss ]  8102: SYS[module] vpss probe done.
    TEM: Creating ListMP [VPSS-M3_IPC_OUT_20] in region 0 ...
     [m3video]  8099: SYSTEM: ListElem Shared Addr = 0xbf2af900
     [m3vpss ]  8103: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_20] in region 0 ...
     [m3video]  8101: HDVICP: Doing PRCM for  [FBDEV] IMPORTANT: Tied fb0+fb1 GRPX is ENABLED !!!
    IVAHD[0] ...
     [m3vpss ]  8103: SYSTEM: ListElem Shared Addr = 0xbf2f0980
     [m3video]  8101: HDVICP: PRCM for IVAHD[0] ... DONE.
     [m3vpss ]  8106: SYSTEM: Cre[module] ti81xxfb probe done.
    ating ListMP [VPSS-M3_IPC_OUT_21] in region 0 ...
     [m3video]  8102: UTILS: DMA: HWI Create for INT62 !!!
     [m3vpss ]  8106: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_21] in region 0 ...
     [m3video]  8103: SYSTEM  : ISS Init in progress !!!
     [m3vpss ]  8106: SYSTEM: ListElem Shared Addr = 0xbf314200
     [m3video]  8103: SYSTEM  : ISS Power-ON in progress !!!
     [m3vpss ]  8108: SYSTEM : HDVPSS Drivers Version: HDVPSSHDMI W1 rev 4.0
    _01_00_01_37
     [HDMI CEC Spec version 1.2
    m3video]  8113: SYSTEM  : ISS Power-ON in progress DONE !!!
     [m[module] ti81xx_hdmi probe done.
    3vpss ]  8108: SYSTEM  : FVID2 Init in progress !!!
     [m3video]  8113: SYSTEM  : ISS Init in progress DONE !!!
     [m3vpss ]  8190: SYSTEM  : FVID2 Init in progress DONE !!!
     [m3video]  8113: VCOP BOOST BIT is Set
     [m3vpss ]  8190: SYSTEM  : Device Init in progress !!!
     [m3video]  8113: SYSTEM  : VCOP Init in progress !!!
     [m3video]  8114: SYSTEM  : VCOP needs 172 B of memory !!!
     [m3vpss ] initPrms.isI2cInitReq = 0
     [m3video]  8115: SYSTEM  : VCOP Init in progress DONE !!!
     [m3video]  8115: SYSTEM  : Initializing Links !!!
     [m3vpss ]  8279: SYSTEM  : Device Init in progress DONE !!!
     [m3video]  8115: SYSTEM  : FREE SPACE : System Heap      = 6263296 B, Mbx = 10240 msgs)
     [m3vpss ]      HDVPSS Freq  : 220 MHz
     [m3video]  8115: SYSTEM  : FREE SPACE : SR0 Heap         = 5802880 B (5 MB)
     [m3vpss ]  8325: SYSTEM  : System VPSS Init Done !!!
     [m3video]  8116: SYSTEM  : FREE SPACE : Frame Buffer     = 117440384 B (111 MB)
     [m3vpss ]  8326: UTILS: DMA: HWI Create for INT63 !!!
     [m3vpss ]  8326: SYSTEM  : Initializing Links !!!
     [m3video]  8116: SYSTEM  : FREE SPACE : Bitstream Buffer = 82837376 B (78 MB)
     [m3vpss ]  8326: SYSTEM  : FREE SPACE : System Heap      = 250312 B, Mbx = 10240 msgs)
     [m3video]  8116: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
     [m3video]  8117: SYSTEM  : FREE SPACE : Tiler 8-bit      = 89128960 B (85 MB)  - TILER ON
     [m3vpss ]  8327: SYSTEM  : FREE SPACE : SR0 Heap         = 5802880 B (5 MB)
     [m3video]  8117: SYSTEM  : FREE SPACE : Tiler 16-bit     = 44040192 B (42 MB)  - TILER ON
     [m3vpss ]  8327: SYSTEM  : FREE SPACE : Frame Buffer     = 113130368 B (107 MB)
     [m3video]  8175: SYSTEM  : Initializing Links ... DONE !!!
     [m3vpss ]  8327: SYSTEM  : FREE SPACE : Bitstream Buffer = 82837376 B (78 MB)
     [m3vpss ]  8327: SYSTEM  : FREE SPACE : Tiler 8-bit      = 89128960 B (85 MB)  - TILER ON
     [m3vpss ]  8327: SYSTEM  : FREE SPACE : Tiler 16-bit     = 44040192 B (42 MB)  - TILER ON
     [m3vpss ] Received character 's'
     [m3vpss ]  8475: SYSTEM  : Initializing Links ... DONE !!!
     [m3vpss ]  8475: SYSTEM  : Set Static L3 pressure for HDVPSS as High
     [m3video] Received character 's'
     [c6xdsp ] Received character 's'
    /opt/dvr_rdk/ti814x
    I2C No Ack
    HDMI failed to read E-EDID
     ## Interface is 1 [0:DVI, 1:HDMI]
     ORG 0x46c00524: 0
     NEW 0x46c00524: 2
     Main Menu
     e: Exit
     Enter Choice: 1
    Dec Channels => 4
    Disp Channels => 8
     10: SYSTEM: CPU [DSP] syslink proc ID is [0] !!!
     10: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [1] !!!
     10: SYSTEM: CPU [VPSS-M3] syslink proc ID is [2] !!!
     10: SYSTEM: CPU [HOST] syslink proc ID is [3] !!!
     10: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_3] ...
     13: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
     14: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
     16: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
     16: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
     17: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
     17: SYSTEM: Notify register to [DSP] line 0, event 15 ...
     18: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
     18: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
     19: SYSTEM: IPC init DONE !!!
     20: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
     22: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
     23: SYSTEM: ListElem Shared Addr = 0x408ddd00
     24: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
     26: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
     27: SYSTEM: ListElem Shared Addr = 0x408fb800
     28: SYSTEM: Creating ListMP [HOST_IPC_OUT_19] in region 0 ...
     30: SYSTEM: Creating ListMP [HOST_IPC_IN_19] in region 0 ...
     32: SYSTEM: ListElem Shared Addr = 0x40919300
     32: SYSTEM: Creating ListMP [HOST_IPC_OUT_20] in region 0 ...
     34: SYSTEM: Creating ListMP [HOST_IPC_IN_20] in region 0 ...
     35: SYSTEM: ListElem Shared Addr = 0x4093cb80
     36: SYSTEM: Creating ListMP [HOST_IPC_OUT_21] in region 0 ...
     38: SYSTEM: Creating ListMP [HOST_IPC_IN_21] in region 0 ...
     39: SYSTEM: ListElem Shared Addr = 0x40960400
     58: SYSTEM: System Common Init Done !!!
     Selected file write path [/home/vaibhav]
     [host] Partition Free Size for Path[/home/vaibhav/VBITS_HDR_0_LAYER_0.bin] = [0xA6939900]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV] Xres - 1280
     [FBDEV] Yres - 720
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV] Xres - 720
     [FBDEV] Yres - 480
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV] Xres - 1280
     [FBDEV] Yres - 720
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV] Xres - 1280
     [FBDEV] Yres - 720
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV] Xres - 1280
     [FBDEV] Yres - 720
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     [FBDEV]
     16704: MCFW  : CPU Revision [ES2.1] !!!
     16704: MCFW  : Detected [UNKNOWN] Board !!!
     16704: MCFW  : Base Board Revision [REV A] !!!
     [m3vpss ]  63994: CAPTURE: Create in progress !!!
     [m3vpss ]  64027: CAPTURE: VIP0 PortA capture mode is [ 8-bit, Pixel-mux Embedded Sync] !!!
     [m3vpss ]  64102: CAPTURE: Create Done !!!
     [m3vpss ]  64102: DEI    : Create in progress !!!
     [m3vpss ]  64224: DEI     : Loading Up-scaling Co-effs
     [m3vpss ]  64224: DEI     : Co-effs Loading ... DONE !!!
     [m3vpss ]  64225: DEI    : Create Done !!!
     [m3vpss ]  64230: DUP   : Create Done !!!
     [m3vpss ]  64231: NSF: Create in progress !!!
     [m3video]  64280: IPC_IN_M3   : Create in progress !!!
     [m3video]  64280: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
     [m3video]  64281: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
     [m3video]  64283: IPC_IN_M3   : Create Done !!!
     [m3video]  64284: ALG : Create in progress !!!
     [m3vpss ]  64276: NSF: Create Done !!!
     [m3vpss ]  64278: MERGE   : Create Done !!!
     [m3vpss ]  64278: IPC_OUT_M3   : Create in progress !!!
     [m3vpss ]  64280: IPC_OUT_M3   : Create Done !!!
     [m3video]  64295: ALG : Prev Link ID = 10000002 !!!
     [m3video]  64296: OSD: Opening algorithm ... !!!
     [m3video]  64309: OSD: Opening algorithm ... DONE !!!
     [m3video]  64327: SCD: Opening algorithm ... !!!
     [m3video]  64327: SCD: Opening algorithm ... DONE !!!
     [m3video]  64346: ALG : Create Done !!!
     [m3video]  64349: ENCODE: Create in progress ... !!!
     [m3video]  64382: ENCODE: Creating CH0 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED  ], bitrate = 2000 Kbps ...
     [m3video]  64396: ENCODE: Creating CH1 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED  ], bitrate = 2000 Kbps ...
     [m3video]  64406: ENCODE: Creating CH2 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED  ], bitrate = 2000 Kbps ...
     [host]  17161: IPC_BITS_IN   : Create in progress !!!
     [host]  17161: IPC_BITS_IN   : ListMPOpen start !!!
     [host]  17161: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_24] ...
     17163: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_24] ...
     [host]  17164: IPC_BITS_IN   : ListMPOpen done !!!
     [host]  17165: IPC_BITS_IN   : System_linkGetInfo done !!!
     [host]  17166: IPC_BITS_IN   : Create Done !!!
    numQ 1, numCh 12
     [host]  17166: IPC_BITS_OUT   : Create in progress !!!
     [host] IPCBITSOUTLINK:Translated Addr Virt:0x41378280 To Phy:0x88519280
     [host]  17167: IPC_BITS_OUT   : Create Done !!!
     [m3video]  64415: ENCODE: Creating CH3 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED  ], bitrate = 2000 Kbps ...
     [m3video]  64425: ENCODE: Creating CH4 of 352 x 240, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  64429: ENCODE: Creating CH5 of 352 x 240, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  64433: ENCODE: Creating CH6 of 352 x 240, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  64438: ENCODE: Creating CH7 of 352 x 240, pitch = (352, 352) [PROGRESSIVE] [NON-TILED  ], bitrate = 500 Kbps ...
     [m3video]  64442: ENCODE: Creating CH8 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED  ], bitrate = 100 Kbps ...
     [m3vpss ]  64579: IPC_IN_M3   : Create in progress !!!
     [m3video]  64443: ENCODE: Creating CH9 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED  ], bitrate = 100 Kbps ...
     [m3vpss ]  64579: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
     [m3vpss ]  64579: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
     [m3vpss ]  64580: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
     [m3vpss ]  64582: IPC_IN_M3   : Create Done !!!
     [m3video]  64444: ENCODE: Creating CH10 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED  ], bitrate = 100 Kbps ...
     [m3vpss ]  64584: MERGE   : Create Done !!!
     [m3vpss ]  64589: DUP   : Create Done !!!
     [m3vpss ]  64590: SWMS: Create in progress !!!
     [m3video]  64444: ENCODE: Creating CH11 of 704 x 480, pitch = (704, 704) [PROGRESSIVE] [NON-TILED  ], bitrate = 100 Kbps ...
     [m3video]  64445: ENCODE: All CH Create ... DONE !!!
     [m3video]  64446: ENCODE: Create ... DONE !!!
     [m3video]  64446: IPC_BITS_OUT   : Create in progress !!!
     [m3video]  64449: IPC_BITS_OUT   : Create Done !!!
     [m3video]  64456: IPC_BITS_IN   : Create in progress !!!
     [m3video]  64456: SYSTEM: Opening ListMP [HOST_IPC_OUT_24] ...
     [m3video]  64457: SYSTEM: Opening ListMP [HOST_IPC_IN_24] ...
     [m3video]  64458: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
     [m3video]  64460: IPC_BITS_IN   : Create Done !!!
     [m3video]  64460: DECODE: Create in progress ... !!!
     [m3video]  64489: DECODE: Creating CH0 of 704 x 480 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3video]  64517: DECODE: Creating CH1 of 704 x 480 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3video]  64545: DECODE: Creating CH2 of 704 x 480 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3video]  64572: DECODE: Creating CH3 of 704 x 480 [PROGRESSIVE] [NON-TILED  ],target bitrate = 2000 Kbps ...
     [m3video]  64574: DECODE: All CH Create ... DONE !!!
     [m3video]  64577: DECODE: Create ... DONE !!!
     [m3video]  64577: IPC_OUT_M3   : Create in progress !!!
     [m3video]  64578: IPC_OUT_M3   : Create Done !!!
     [m3vpss ]  64777: SWMS    : VipScReq is TRUE!!!
     [m3vpss ]  64783: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3vpss ]  64783: SWMS0    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3vpss ]  64783: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]  64783: SWMS    : OutFrames List -> 2 !!!!!!!
     [m3vpss ]  64784: SWMS    : ******* Configuring clock 15 secs...
     [m3vpss ]  64784: SWMS0    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3vpss ]  64784: SWMS0    : Loading Horizontal Co-effs (10/16)x ...
     [m3vpss ]  64784: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  64791: SWMS: Create Done !!!
     [m3vpss ]  64792: SWMS: Create in progress !!!
     [m3vpss ]  64841: SWMS1    : Loading Vertical Co-effs (UPSCALE)x ...
     [m3vpss ]  64841: SWMS1    : Loading Horizontal Co-effs (UPSCALE)x ...
     [m3vpss ]  64841: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]  64842: SWMS    : ******* Configuring clock 15 secs...
     [m3vpss ]  64842: SWMS1    : Loading Vertical Co-effs (7/16)x ...
     [m3vpss ]  64842: SWMS1    : Loading Horizontal Co-effs (3/16)x ...
     [m3vpss ]  64842: SWMS    : Co-effs Loading ... DONE !!!
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  64849: SWMS: Create Done !!!
     [m3vpss ]  64850: DISPLAY: Create in progress !!!
     [m3vpss ]  64851: DISPLAY: Create Done !!!
     [m3vpss ]  64851: DISPLAY: Create in progress !!!
     [m3vpss ]  64852: DISPLAY: 44: Field Separate Mode ENABLED for Que 0 !!!
     [m3vpss ]  64853: DISPLAY: Create Done !!!
     [m3vpss ]  64861: DISPLAY: Start in progress !!!
     [m3vpss ]  64920: DISPLAY: Start Done !!!
     [m3vpss ]  64920: DISPLAY: HDDAC(BP0) : 33 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
     Run-Time Menu
     1: Capture Settings
     2: Encode  Settings
     3: Decode  Settings
     4: Display Settings
     e: Stop Demo
     Enter Choice:  [m3vpss ]  64920: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 1, HDDAC(BP0) 0, DVO2(BP1) 1, SDDAC(SEC1) 1
     [m3vpss ]  64920: SYSTEM  : FREE SPACE : System Heap      = 243136 B, Mbx = 10238 msgs)
     [m3vpss ]  64921: SYSTEM  : FREE SPACE : SR0 Heap         = 2598656 B (2 MB)
     [m3vpss ]  64921: SYSTEM  : FREE SPACE : Frame Buffer     = 417536 B (0 MB)
     [m3vpss ]  64921: SYSTEM  : FREE SPACE : Bitstream Buffer = 61621632 B (58 MB)
     [m3vpss ]  64921: DISPLAY: Start in progress !!!
     [m3vpss ]  64922: SYSTEM  : FREE SPACE : Tiler 8-bit      = 89128960 B (85 MB)  - TILER ON
     [m3vpss ]  64922: SYSTEM  : FREE SPACE : Tiler 16-bit     = 44040192 B (42 MB)  - TILER ON
     [m3vpss ]  64960: DISPLAY: Start Done !!!
     [m3vpss ]  64961: DISPLAY: SDDAC(SEC1): 25 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
     [m3vpss ]  64961: SWMS: Start in Progress !!!
     [m3vpss ]  64961: SWMS: Start Done !!!
     [m3vpss ]  65351: CAPTURE: Start in progress !!!
     [m3vpss ]  65351: CAPTURE: Start Done !!!
     [m3vpss ]  65451: CAPTURE: Enabled Time Stamping !!!
     I
     Run-Time Menu
     1: Capture Settings
     2: Encode  Settings
     3: Decode  Settings
     4: Display Settings
     e: Stop Demo
     Enter Choice: i
     DEMO:  0: No video detected at CH [0,0] !!!
     DEMO:  1: No video detected at CH [0,1] !!!
     DEMO:  2: No video detected at CH [0,2] !!!
     DEMO:  3: No video detected at CH [0,3] !!!
     [m3vpss ]
     [m3vpss ]  *** Capture Driver Advanced Statistics ***
     [m3vpss ]
     [m3vpss ]  *** [NSF0] NSF Statistics ***
     [m3vpss ]
     [m3vpss ]  Elasped Time           : 21 secs
     [m3vpss ]  Total Fields Processed : 0
     [m3vpss ]  Total Fields FPS       : 0 FPS
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  CH  | In Recv In Reject In Process Out User Out Out
     [m3vpss ]  Num | FPS     FPS       FPS        FPS Skip FPS Skip FPS
     [m3vpss ]    0 |       0         0          0   0        0        0
     [m3vpss ]    1 |       0         0          0   0        0        0
     [m3vpss ]    2 |       0         0          0   0        0        0
     [m3vpss ]    3 |       0         0          0   0        0        0
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  VIP Parser Reset Count : 0
     [m3vpss ]
     [m3vpss ]      |   Total    Even     Odd  Total  Even   Odd  Min /  Max  Min /  Max Dropped Fid Repeat Frame Error Y/C
     [m3vpss ]  CH  |  Fields  Fields  Fields    FPS   FPS   FPS       Width      Height  Fields      Count (Desc Error Y/C)
     [m3vpss ]  000 |       1       1       0      0     0     0 65535 /    0 65535 /    0       1          0 0/0 (0/0)
     [m3vpss ]  001 |       1       1       0      0     0     0 65535 /    0 65535 /    0       1          0 0/0 (0/0)
     [m3vpss ]  002 |       1       1       0      0     0     0 65535 /    0 65535 /    0       1          0 0/0 (0/0)
     [m3vpss ]  003 |       1       1       0      0     0     0 65535 /    0 65535 /    0       1          0 0/0 (0/0)
     [m3vpss ]
     [m3vpss ]  VIP Capture Port 0 | DescMissMatch1 = 0, DescMissMatch2 = 0 , DescMissMatch3 = 0
     [m3vpss ]
     [m3vpss ]  *** Capture List Manager Advanced Statistics ***
     [m3vpss ]
     [m3vpss ]  List Post Count        : 2498
     [m3vpss ]  List Stall Count       : 0
     [m3vpss ]  List Post Time (ms)    : Max = 0, Min = 0, Avg = 0, Total = 0
     [m3vpss ]  INTC Timeout Count     : (0, 0) (Min timeout value = 979, 996)
     [m3vpss ]  Descriptor miss found count : 0
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  VIP and VPDMA registers,
     [m3vpss ]  VIP0 : FIQ_STATUS  : 0x4810551c = 0x00000000
     [m3vpss ]  VIP1 : FIQ_STATUS  : 0x48105a1c = 0x00000000
     [m3vpss ]  VPDMA: LIST_BUSY   : 0x4810d00c = 0x00060000
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  51884: CAPTURE: Fields = 0 (fps = 0, CPU Load = 0)
     [m3vpss ]  51885: CAPTURE: Num Resets = 0 (Avg 0 ms per reset)
     [m3vpss ]  51885: SYSTEM  : FREE SPACE : System Heap      = 243136 B, Mbx = 10240 msgs)
     [m3vpss ]  51885: SYSTEM  : FREE SPACE : SR0 Heap         = 2598656 B (2 MB)
     [m3vpss ]  51885: SYSTEM  : FREE SPACE : Frame Buffer     = 417536 B (0 MB)
     [m3vpss ]  51885: SYSTEM  : FREE SPACE : Bitstream Buffer = 61621632 B (58 MB)
     [m3vpss ]  51886: SYSTEM  : FREE SPACE : Tiler 8-bit      = 89128960 B (85 MB)  - TILER ON
     [m3vpss ]  51886: SYSTEM  : FREE SPACE : Tiler 16-bit     = 44040192 B (42 MB)  - TILER ON
     [m3vpss ]
     [m3vpss ]  *** [DEI2    ] DEI Statistics ***
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  CH  | In Recv In Reject In Process Out[0] Out[1] Out[2] Out[3] Out[4] Skip Out[0] Skip Out[1] Skip Out[2] Skip Out[3] Skip Out[4] User Out[0] User Out[1] User Out[2] User Out[3] User Out[4] Latency
     [m3vpss ]  Num | FPS     FPS       FPS        FPS    FPS    FPS    FPS    FPS       FPS         FPS         FPS         FPS         FPS       Skip FPS    Skip FPS    Skip FPS    Skip FPS    Skip FPS   Min / Max
     [m3vpss ]  -------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
     [m3vpss ]    0 |       0         0          0      0      0      0      0      0           0           0           0           0           0           0           0           0           0           0 255 /   0
     [m3vpss ]    1 |       0         0          0      0      0      0      0      0           0           0           0           0           0           0           0           0           0           0 255 /   0
     [m3vpss ]    2 |       0         0          0      0      0      0      0      0           0           0           0           0           0           0           0           0           0           0 255 /   0
     [m3vpss ]    3 |       0         0          0      0      0      0      0      0           0           0           0           0           0           0           0           0           0           0 255 /   0
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  *** [SWMS0] Mosaic Statistics ***
     [m3vpss ]
     [m3vpss ]  Elasped Time: 20 secs
     [m3vpss ]
     [m3vpss ]  Output Request FPS   : 69 fps (1391 frames)
     [m3vpss ]  Output Actual  FPS   : 62 fps (1255 frames)
     [m3vpss ]  Output Drop    FPS   : 6 fps (136 frames)
     [m3vpss ]  Output Reject  FPS   : 0 fps (0 frames)
     [m3vpss ]  Scaling Internal     : 14 ms
     [m3vpss ]  Scaling Internal min : 15 ms
     [m3vpss ]  Scaling Internal max : 16 ms
     [m3vpss ]
     [m3vpss ]  Win | Window Repeat Drop Recv Que  FID Invlid Acc Event          Invalid   Que Reject Reject Latency   OutBufCopy InBufCopy
     [m3vpss ]  Num | FPS    FPS    FPS  FPS  FPS  FPS        Count (Max/Min)    CH Frames Frames     Frames Min / Max FPS        FPS
     [m3vpss ]    0 |      0     62    0    0    0          0        0 (  0/255)         0          0      0 65535 /   0         62         0
     [m3vpss ]    1 |      0     62    0    0    0          0        0 (  0/255)         0          0      0 65535 /   0         62         0
     [m3vpss ]    2 |      0     62    0    0    0          0        0 (  0/255)         0          0      0 65535 /   0         62         0
     [m3vpss ]    3 |      0     62    0    0    0          0        0 (  0/255)         0          0      0 65535 /   0         62         0
     [m3vpss ]    4 |      0     62    0    0    0          0        0 (  0/255)         0          0      0 65535 /   0         62         0
     [m3vpss ]    5 |      0     62    0    0    0          0        0 (  0/255)         0          0      0 65535 /   0         62         0
     [m3vpss ]    6 |      0     62    0    0    0          0        0 (  0/255)         0          0      0 65535 /   0         62         0
     [m3vpss ]    7 |      0     62    0    0    0          0        0 (  0/255)         0          0      0 65535 /   0         62         0
     [m3vpss ]    8 |      0      0    0    0    0          0        0 (  0/255)         0          0      0 65535 /   0         62         0
     [m3vpss ]    9 |      0      0    0    0    0          0        0 (  0/255)         0          0      0 65535 /   0         62         0
     [m3vpss ]   10 |      0      0    0    0    0          0        0 (  0/255)         0          0      0 65535 /   0         62         0
     [m3vpss ]   11 |      0      0    0    0    0          0        0 (  0/255)         0          0      0 65535 /   0         62         0
     [m3vpss ]   12 |      0      0    0    0    0          0        0 (  0/255)         0          0      0 65535 /   0         62         0
     [m3vpss ]   13 |      0      0    0    0    0          0        0 (  0/255)         0          0      0 65535 /   0         62         0
     [m3vpss ]   14 |      0      0    0    0    0          0        0 (  0/255)         0          0      0 65535 /   0         62         0
     [m3vpss ]   15 |      0      0    0    0    0          0        0 (  0/255)         0          0      0 65535 /   0         62         0
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]    0 |   0 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |    0,    0 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |    ON |
     [m3vpss ]    1 |   1 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |  480,    0 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |    ON |
     [m3vpss ]    2 |   2 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |  960,    0 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |    ON |
     [m3vpss ]    3 |   3 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   | 1440,    0 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |    ON |
     [m3vpss ]    4 |   4 |    0,    0 |   704 x    240 |  1792 /  1792 | NON-TILED   |    0,  270 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  420SP |    ON |
     [m3vpss ]    5 |   5 |    0,    0 |   704 x    240 |  1792 /  1792 | NON-TILED   |  480,  270 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  420SP |    ON |
     [m3vpss ]    6 |   6 |    0,    0 |   704 x    240 |  1792 /  1792 | NON-TILED   |  960,  270 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  420SP |    ON |
     [m3vpss ]    7 |   7 |    0,    0 |   704 x    240 |  1792 /  1792 | NON-TILED   | 1440,  270 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  420SP |    ON |
     [m3vpss ]    8 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |    0,  540 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |    ON |
     [m3vpss ]    9 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  480,  540 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |    ON |
     [m3vpss ]   10 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  960,  540 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |    ON |
     [m3vpss ]   11 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   | 1440,  540 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |    ON |
     [m3vpss ]   12 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |    0,  810 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |    ON |
     [m3vpss ]   13 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  480,  810 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |    ON |
     [m3vpss ]   14 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  960,  810 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |    ON |
     [m3vpss ]   15 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   | 1440,  810 |   480 x    270 |  3840 /      0 | NON-TILED   |       ON |    0 |  422I  |    ON |
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  *** [SWMS1] Mosaic Statistics ***
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]  Output Request FPS   : 69 fps (1392 frames)
     [m3vpss ]  Output Actual  FPS   : 62 fps (1252 frames)
     [m3vpss ]  Output Drop    FPS   : 7 fps (140 frames)
     [m3vpss ]  Scaling Internal max : 19 ms
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3vpss ]
     [m3video]
     [m3video]  *** (VCOP) OSD Statistics ***
     [m3video]
     [m3video]  Elasped Time           : 22 secs
     [m3video]  Total Fields Processed : 0
     [m3video]  Total Fields FPS       : 0 FPS
     [m3video]
     [m3video]  Detailed Internal Profile Log,
     [m3video]  - OSD ALG Total time   :          0 msecs (0 % of elasped time)
     [m3video]  - GATHER  Total time   :          0 msecs (0 % of elasped time)
     [m3video]  - BLEND   Total time   :          0 msecs (0 % of elasped time)
     [m3video]  - SCATTER Total time   :          0 msecs (0 % of elasped time)
     [m3video]  - EDMA    Total time   :          0 msecs (0 % of elasped time)
     [m3video]  - VCOP    Total time   :          0 msecs (0 % of elasped time)
     [m3video]  - SCAT/GATH CPU time   :          0 msecs (0 % of elasped time)
     [m3video]  - BLEND     CPU time   :          0 msecs (0 % of elasped time)
     [m3video]
     [m3video]
     [m3video]  CH  | In Recv In Que In Reject In Process
     [m3video]  Num | FPS     FPS    FPS       FPS
     [m3video]  ------------------------------------------
     [m3vpss ]    0 |   0 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |    0,    0 |   176 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  422I  |    ON |
     [m3video]    0 |       0      0         0          0
     [m3vpss ]    1 |   1 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |  176,    0 |   176 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  422I  |    ON |
     [m3video]    1 |       0      0         0          0
     [m3vpss ]    2 |   2 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |  352,    0 |   176 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  422I  |    ON |
     [m3video]    2 |       0      0         0          0
     [m3vpss ]    3 |   3 |    0,    0 |   704 x    240 |  2816 /  2816 | NON-TILED   |  528,    0 |   192 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  422I  |    ON |
     [m3video]    3 |       0      0         0          0
     [m3vpss ]    4 |   4 |    0,    0 |   704 x    240 |  1792 /  1792 | NON-TILED   |    0,  120 |   176 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  420SP |    ON |
     [m3video]    4 |       0      0         0          0
     [m3vpss ]    5 |   5 |    0,    0 |   704 x    240 |  1792 /  1792 | NON-TILED   |  176,  120 |   176 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  420SP |    ON |
     [m3video]    5 |       0      0         0          0
     [m3vpss ]    6 |   6 |    0,    0 |   704 x    240 |  1792 /  1792 | NON-TILED   |  352,  120 |   176 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  420SP |    ON |
     [m3video]    6 |       0      0         0          0
     [m3vpss ]    7 |   7 |    0,    0 |   704 x    240 |  1792 /  1792 | NON-TILED   |  528,  120 |   192 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  420SP |    ON |
     [m3video]    7 |       0      0         0          0
     [m3vpss ]    8 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |    0,  240 |   176 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  422I  |    ON |
     [m3video]    8 |       0      0         0          0
     [m3vpss ]    9 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  176,  240 |   176 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  422I  |    ON |
     [m3video]    9 |       0      0         0          0
     [m3vpss ]   10 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  352,  240 |   176 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  422I  |    ON |
     [m3video]   10 |       0      0         0          0
     [m3vpss ]   11 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  528,  240 |   192 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  422I  |    ON |
     [m3video]   11 |       0      0         0          0
     [m3vpss ]   12 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |    0,  360 |   176 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  422I  |    ON |
     [m3video]
     [m3vpss ]   13 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  176,  360 |   176 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  422I  |    ON |
     [m3video]
     [m3video]  *** (VCOP) SCD Statistics ***
     [m3video]
     [m3video]
     [m3video]  - SCD ALG Total time   :          0 msecs (0 % of elasped time)
     [m3video]  - SCD ALG   CPU time   :          0 msecs (0 % of elasped time)
     [m3video]
     [m3video]
     [m3video]  CH  | In Recv In Skip In Process
     [m3vpss ]   14 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  352,  360 |   176 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  422I  |    ON |
     [m3video]    0 |       0       0          0
     [m3vpss ]   15 | 255 |    0,    0 |   352 x    264 |   704 /   704 | NON-TILED   |  528,  360 |   192 x    120 |  1472 /      0 | NON-TILED   |       ON |    0 |  422I  |    ON |
     [m3video]    1 |       0       0          0
     [m3vpss ]
     [m3video]    2 |       0       0          0
     [m3vpss ]
     [m3video]    3 |       0       0          0
     [m3vpss ]  52060: DISPLAY: HDDAC(BP0) : 59 fps, Latency (Min / Max) = ( 79 / 152 ), Callback Interval (Min / Max) = ( 16 / 17 ) !!!
     [m3video]    4 |       0       0          0
     [m3video]    5 |       0       0          0
     [m3video]    6 |       0       0          0
     [m3vpss ]  52060: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 1259, HDDAC(BP0) 0, DVO2(BP1) 1259, SDDAC(SEC1) 1263
     [m3video]    7 |       0       0          0
     [m3vpss ]  52060: SYSTEM  : FREE SPACE : System Heap      = 243136 B, Mbx = 10237 msgs)
     [m3video]    8 |       0       0          0
     [m3video]    9 |       0       0          0
     [m3vpss ]  52061: SYSTEM  : FREE SPACE : SR0 Heap         = 2598656 B (2 MB)
     [m3vpss ]  52061: SYSTEM  : FREE SPACE : Frame Buffer     = 417536 B (0 MB)
     [m3video]
     [m3vpss ]  52061: SYSTEM  : FREE SPACE : Bitstream Buffer = 61621632 B (58 MB)
     [m3vpss ]  52061: SYSTEM  : FREE SPACE : Tiler 8-bit      = 89128960 B (85 MB)  - TILER ON
     [m3vpss ]  52061: SYSTEM  : FREE SPACE : Tiler 16-bit     = 44040192 B (42 MB)  - TILER ON
     [m3vpss ]  52062: DISPLAY: SDDAC(SEC1): 29 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 33 / 34 ) !!!
     [m3video]      54028: HDVICP-ID:0
     [m3video] All percentage figures are based off totalElapsedTime
     [m3video]               totalAcquire2wait :0 %
     [m3video]               totalWait2Isr :0 %
     [m3video]               totalIsr2Done :0 %
     [m3video]               totalWait2Done :0 %
     [m3video]               totalDone2Release :0 %
     [m3video]               totalAcquire2Release :0 %
     [m3video]               totalAcq2acqDelay :0 %
     [m3video]               totalElapsedTime in msec :       0
     [m3video]               numAccessCnt:       0
     [m3video]              IVA-FPS :       0
     [m3video]              Average time spent per frame in microsec:       0
     [m3video]      54029: HDVICP-ID:1
     [m3video]      54030: HDVICP-ID:2
     [m3video]
     [m3video]  *** ENCODE Statistics ***
     [m3video]
     [m3video]  Elasped Time           : 54 secs
     [m3video]
     [m3video]
     [m3video]  CH  | In Recv In Skip In User  Out Latency
     [m3video]  Num | FPS     FPS     Skip FPS FPS Min / Max
     [m3video]  --------------------------------------------
     [m3video]    0 |       0       0        0   0   0 /   0
     [m3video]    1 |       0       0        0   0   0 /   0
     [m3video]    2 |       0       0        0   0   0 /   0
     [m3video]    3 |       0       0        0   0   0 /   0
     [m3video]    4 |       0       0        0   0   0 /   0
     [m3video]    5 |       0       0        0   0   0 /   0
     [m3video]    6 |       0       0        0   0   0 /   0
     [m3video]    7 |       0       0        0   0   0 /   0
     [m3video]    8 |       0       0        0   0   0 /   0
     [m3video]    9 |       0       0        0   0   0 /   0
     [m3video]   10 |       0       0        0   0   0 /   0
     [m3video]   11 |       0       0        0   0   0 /   0
     [m3video]
     [m3video] Multi Channel Encode Average Submit Batch Size
     [m3video] Max Submit Batch Size : 24
     [m3video] IVAHD_0 Average Batch Size : 0
     [m3video] IVAHD_0 Max achieved Batch Size : 0
     [m3video]
     [m3video] Multi Channel Encode Batch break Stats
     [m3video] Total Number of Batches created: 0
     [m3video] All numbers are based off total number of Batches created
     [m3video]       Batch breaks due to batch sizeexceeding limit: 0 %
     [m3video]       Batch breaks due to ReqObj Que being empty: 0 %
     [m3video]       Batch breaks due to changed resolution class: 0 %
     [m3video]       Batch breaks due to interlace and progressivecontent mix: 0 %
     [m3video]       Batch breaks due to channel repeat: 0 %
     [m3video]       Batch breaks due to different codec: 0 %
     [m3video]
     [m3video]  *** DECODE Statistics ***
     [m3video]
     [m3video]  Elasped Time           : 23 secs
     [m3video]
     [m3video]
     [m3video]  CH  | In Recv In User  Out
     [m3video]  Num | FPS     Skip FPS FPS
     [m3video]    0 |       0        0   0
     [m3video]    1 |       0        0   0
     [m3video]    2 |       0        0   0
     [m3video]    3 |       0        0   0
     [m3video]
     [m3video] Multi Channel Decode Average Submit Batch Size
     [m3video]
     [m3video] Multi Channel Decode Batch break Stats
     [m3video]
     [m3vpss ]
     [m3vpss ]  55028: LOAD: CPU: 14.0% HWI: 3.9%, SWI:1.3%
     [m3vpss ]
     [m3vpss ]  55029: LOAD: TSK: CAPTURE             : 0.3%
     [m3vpss ]  55029: LOAD: TSK: DISPLAY0            : 0.6%
     [m3vpss ]  55029: LOAD: TSK: DISPLAY2            : 0.3%
     [m3vpss ]  55029: LOAD: TSK: SWMS0               : 3.1%
     [m3vpss ]  55030: LOAD: TSK: SWMS1               : 2.5%
     [m3vpss ]  55030: LOAD: TSK: MISC                : 2.0%
     [m3vpss ]
     [m3video]
     [m3video]  55531: LOAD: CPU: 3.5% HWI: 0.6%, SWI:1.2%
     [m3video]
     [m3video]  55531: LOAD: TSK: IPC_BITS_IN0        : 0.2%
     [m3video]  55531: LOAD: TSK: ENC0                : 0.5%
     [m3video]  55531: LOAD: TSK: DEC0                : 0.6%
     [m3video]  55531: LOAD: TSK: MISC                : 0.4%
     [m3video]
     [c6xdsp ]
     [c6xdsp ]  53545: LOAD: CPU: 0.2% HWI: 0.0%, SWI:0.0%
     [c6xdsp ]
     [c6xdsp ]  53545: LOAD: TSK: MISC                : 0.2%
     [c6xdsp ]
     *** Encode Bitstream Received Statistics ***
     Elased time =   39.0 secs
     CH | Bitrate (Kbps) | FPS | Key-frame FPS | Width (max/min) | Height (max/min) | Latency (max/min)
     *** SCD Frame Results Received Statistics ***
     Elased time =   41.8 secs
     CH | Bitrate (Kbps) | FPS | Width (max/min) | Height (max/min)
     Run-Time Menu
     1: Capture Settings
     2: Encode  Settings
     3: Decode  Settings
     4: Display Settings
     e: Stop Demo
  • This seems to be connectivity issue between EVM and daughter card causing i2c communication timeout. Are you seeing this behaviour on multiple boards ?
  • Thanks Badri,
    I fixed this issue, Yes it's connectivity issue.
    I want to run 8channel audio capture - encode application using DVRRDK.
    It works fine for 4channel & 16channel audio input. But not work for 8channel.
    Can you help me in this?
