hub 2-0:1.0: over-current change on port 1
Hi Pavel,
After booting,it outputs "hub 2-0:1.0: over-current change on port 1" without stop.
Here is the log below.I want to know what's wrong?
Thank you in advance.
B/R
Bob
ALSA device list:
  #0: TI81XX EVM
TCP cubic registered
NET: Registered protocol family 17
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
can: raw protocol (rev 20090105)
can: broadcast manager protocol (rev 20090105 t)
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
Detected MACID=84:7e:40:ea:5f:6c
omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
PHY 0:00 not found
CPSW phy found : id is : 0x1cc912
Sending DHCP requests .
PHY: 0:01 - Link is Up - 100/Full
  • Bob,
    Do you have USB1 port on your custom board?
    This one is known issue for DM811x device:
    http://processors.wiki.ti.com/index.php/TI811X_PSP_04.07.00.01_rc1_Release_Notes#TI811X_2
    Why do i contineously get error message "hub 2-0:1.0: over-current change on port 1"?
    This error message will be seen if the daughter board is not connected with the J5Eco EVM. In this absence of
    daughter board the USB1 port is hanging this produces the above error. In case you do not want to use
    daughter card you can disable the USB1 port by applying the patch provided in PSP release notes documents.
    TI811X: There is continuous overcurrent message on console from USB1 port when kernel loaded in usb host mode on TI811X EVM
    Known issue: Always connect the daughter board to use USB1 port other wise to disable the USB1 port use steps in this patch. Note that this patch will not apply directly, edit the specific changes manually as mentioned in the patch.
    http://arago-project.org/git/projects/?p=linux-omap3.git;a=commit;h=456b576bea9e5aab47d263c794f19cac977694f4
    Thus I suspect that something is wrong with your USB1 port.
    Pavel
  • Hi Pavel,
    Ok,I will try.
    Have a good weekend.
    B/R
    Bob
  • Bob,
    See also the below e2e threads:
    http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/717/t/149907.aspx
    http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/717/t/219479.aspx
    http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/717/p/253740/888152.aspx#888152
    http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/717/p/263564/924663.aspx#924663
    Pavel
