I'm trying to learn more about IPC. I want to build the demos and run them, in particular the notify example.
How am I meant to build the ARM application that talks to the DSP application?
Here is my config.bld that resides in <IPC>/packages.
* ======== config.bld ========
* Sample Build configuration script
//Use CCS4.0
var rootDirPre = "C:/Program Files/Texas Instruments/CCSv4/tools/compiler/";
var rootDirPost = "";
//Use CCS3.3
//var rootDirPre = "C:/CCStudio_v3.3/";
//var rootDirPost = "/cgtools";
//Setup for C64P target
/*var C64P = xdc.useModule('ti.targets.C64P');
C64P.rootDir = rootDirPre + "C6000" + rootDirPost;
C64P.ccOpts.suffix += " -mi10 -mo ";
//set default platform and list of all interested platforms for c64P
C64P.platforms = [
"ti.sdo.ipc.examples.platforms.evmDM6446.dsp",
"ti.sdo.ipc.examples.platforms.evm6472.core0",
"ti.sdo.ipc.examples.platforms.evm6474.core0",
C64P.platform = C64P.platforms[0];*/
//Setup for C674 target
var C674 = xdc.useModule('ti.targets.C674');
//C674.rootDir = rootDirPre + "C6000" + rootDirPost;
C674.rootDir = "/home/ralphc/ezsdk/ti-ezsdk_dm816x-evm_5_01_01_80/cgt6x_7_2_2"
C674.ccOpts.suffix += " -mi10 -mo ";
//set default platform and list of all interested platforms for c674
C674.platforms = [
"ti.sdo.ipc.examples.platforms.evmTI816X.dsp",
// "ti.sdo.ipc.examples.platforms.evmDA830.dsp",
// "ti.sdo.ipc.examples.platforms.evmOMAPL138.dsp",
C674.platform = C674.platforms[0];
//Setup for C66 target
/*var C66 = xdc.useModule('ti.targets.elf.C66');
C66.rootDir = rootDirPre + "C6000" + rootDirPost;
C66.ccOpts.suffix += " -mi10 -mo ";
C66.platforms = [
"ti.sdo.ipc.examples.platforms.evm6670.core0",
"ti.sdo.ipc.examples.platforms.evm6678.core0",
C66.platform = C66.platforms[0];*/
//Setup for C64T target
/*var C64T = xdc.useModule('ti.targets.elf.C64T');
C64T.rootDir = rootDirPre + "C6000" + rootDirPost;
C64T.ccOpts.suffix += " -mi10 -mo ";
//set default platform and list of all interested platforms for c64T
C64T.platforms = [
"ti.sdo.ipc.examples.platforms.omap4430.dsp",
C64T.platform = C64T.platforms[0];*/
//Setup for ARM target
/*var Arm9 = xdc.useModule('ti.targets.arm.elf.Arm9');
Arm9.rootDir = rootDirPre + "tms470" + rootDirPost;
Arm9.ccOpts.suffix += " -ms ";
//set default platform and list of all interested platforms for Arm9
Arm9.platforms = [
"ti.sdo.ipc.examples.platforms.evmDM6446.arm",
"ti.sdo.ipc.examples.platforms.evmDA830.arm",
"ti.sdo.ipc.examples.platforms.evmOMAPL138.arm",
Arm9.platform = Arm9.platforms[0];*/
//Setup for M3 target
/*var M3 = xdc.useModule('ti.targets.arm.elf.M3');
M3.rootDir = rootDirPre + "tms470" + rootDirPost;
M3.ccOpts.suffix += " -ms ";
//set default platform and list of all interested platforms for M3
M3.platforms = [
"ti.sdo.ipc.examples.platforms.evmTI816X.video",
"ti.sdo.ipc.examples.platforms.evmTI816X.vpss",
"ti.sdo.ipc.examples.platforms.evmDM8148.video",
"ti.sdo.ipc.examples.platforms.evmDM8148.vpss",
"ti.sdo.ipc.examples.platforms.omap4430.core0",
"ti.sdo.ipc.examples.platforms.omap4430.core1",
//Setup for A8F target
var A8F = xdc.useModule('ti.targets.arm.elf.A8F');
//A8F.rootDir = rootDirPre + "tms470" + rootDirPost;
A8F.rootDir = "/home/ralphc/arm-2009q1"
A8F.ccOpts.suffix += " -ms ";
//set default platform and list of all interested platforms for A8F
A8F.platforms = [
"ti.sdo.ipc.examples.platforms.evmTI816X.host",
// "ti.sdo.ipc.examples.platforms.evmDM8148.host",
A8F.platform = A8F.platforms[0];
//Uncomment the require targets
Build.targets = [
//C64P,
C674,
//C64T,
//C66,
//Arm9,
//M3,
A8F,
I run "xdc" as per the install guide to build the DSP application but how am I meant to build the ARM application? My efforts to edit the config.bld file above seem to have failed as xdc runs "cl470" on the ARM code (I assume that's what it's doing) and there is only GCC in the directory I specify above.
Ralph
