DM8168 VIP capture without external decoder (OpenMAX)?
Other Parts Discussed in Thread: TVP7002
Hi all,
we have a custom DM8168 board with FPGAs as video sources on VIP0 and VIP1.
What steps are required to enable the capture ports in this configuration, using OpenMAX?  I've written an application for the EVM prior to this board, enabling the TVP7002 to decode incoming video for us but want to use FPGAs as direct inputs instead.
Just using VFCC doesn't seem enough as no frames are being detected (debug prints in loggerSM).
Any ideas would be appreciated.
Andreas
  • Andreas,
    You should be able to make your FPGA output a digital stream in the exact same format as the TVP7002 configuration you have used in the past. In this case all you should need to do is remove the TVP7002 specific configuration code from the drive and the DSP should not even know the difference.
    BR,
    Steve
  • Thanks Steve,
    I'll try that and keep you posted.
    -Andreas
  • Hi Steve,
    no luck. Nothing is being detected at all. I'm using LoggerSMDump and it doesn't see any incoming frames.
    Unfortunately, I cannot mimic the EVM setup exactly as I need to use 8-bit VIP1 instead of 16-bit VIP0 due to a hardware limitation on our current board. A new board will arrive mid December where VIP0 - 16bit should be available.
    Reading some other threads, it sounds like this should work though but would require creating a dummy/pass through decoder.
    This thread is doing exactly what I'm trying to achieve with our new board:
    http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/717/t/109357.aspx#546754
    Any ideas? I know Marc Pyne is trying to look into it as well.
    Thanks again,
    Andreas
  • Andreas,
    If you are not able to mimic the TVP7002 (i.e. an ITU1120 format) then yes, you will need to make changes to the configuration.
    additionally, I am not sure a 'dummy' decoder is necessary. As far as I know capture and display are separate entities hence can be configured as such.
    I will ask someone who is more familiar with the driver to try and help you.
    Just to clarify though, can you please say exactly what you are trying to achieve? e.g. 8 bit input in 422 format, 1024x768 image size, discrete syncs capture into a frame buffer for subsequent image processing.
    BR,
    Steve
  • Steve,
    we are pretty flexible in terms of the color space. Our main input will be a 1080p60 (1920x1080@60fps) connected via FPGA to VIN0. We have the entire 24bit bus connected so ideally 24bit RGB or 20bit YCbCr (embedded syncs), depending on color spaces supported by the DM8168 and its underlying software (OpenMAX).
    The secondary input port (VIN1) will do 1080p60, but only 16bit YCbCr as dictated by the DM8168.
    Thx,
    Andreas
    (aengberg at pc-medical dot com)
  • Andreas,
    The 816x supports capture of 2x8/16/24 bit on one port and 2x8/16 bit on the other port. The 24 bit port can capture in RGB or YUV and in 422 or 444 formats, so the choice is yours really.
    What is your current connectivity and we can work on matching the software to what you currently have.
    BR,
    Steve
  • Thanks Steve,
    we haven't really selected input format but I believe there are some software limitations that will impact our choice (on the OpenMAX side). Not really a worry at this point.
    Short term (e.g. right now), I'd like to connect a 480p@60 8-bit YUV to the secondary input port. This is just to demonstrate capture capability. In about two weeks, I"ll have a new board, which includes full 24bit access to the primary input port. Color format doesn't really matter as the FPGA can produce the various format combinations, but the FPGA's internal format is 24bit RGB so ideally, we keep it the same.
    I've attached a package list of our custom Arago distro so you know the versions of all TI components. I've based everything on the EZSDK 5.02
    Thx again,
    Andreas
    alsa-conf-base_1.0.24.1-r0.6_armv7a.ipk
    alsa-utils-alsamixer_1.0.24.2-r0.6_armv7a.ipk
    alsa-utils-amixer_1.0.24.2-r0.6_armv7a.ipk
    alsa-utils-aplay_1.0.24.2-r0.6_armv7a.ipk
    alsa-utils-speakertest_1.0.24.2-r0.6_armv7a.ipk
    angstrom-libc-fixup-hack_1.0-r0.6_all.ipk
    angstrom-version_1:2011.05-r7.6_dm816x-evm.ipk
    apm_3.2.2-r13.6_armv7a.ipk
    apmd_3.2.2-r13.6_armv7a.ipk
    arago-feed-configs_1.0-r11.6_armv7a.ipk
    avahi-autoipd_0.6.25-r13.0.6_armv7a.ipk
    avahi-daemon_0.6.25-r13.0.6_armv7a.ipk
    avahi-utils_0.6.25-r13.0.6_armv7a.ipk
    base-files_3.0.14-r100-arago1.6_dm816x-evm.ipk
    base-passwd_3.5.20-r1.6_armv7a.ipk
    bc-cube-fb_0.2.0-r2.6_armv7a.ipk
    blueprobe_0.18-r6.6_armv7a.ipk
    bluez4_4.89-r8.0-arago2.6_armv7a.ipk
    busybox_1.13.2-r42.4-arago3.6_armv7a.ipk
    busybox-mountall_1.13.2-r42.4-arago3.6_armv7a.ipk
    busybox-syslog_1.13.2-r42.4-arago3.6_armv7a.ipk
    coreutils_8.5-r6.0.6_armv7a.ipk
    cups_1.3.11-r7.2.6_armv7a.ipk
    cups-gs_8.71-r1.6_armv7a.ipk
    dbus_1.2.24-r20.1-arago2.6_armv7a.ipk
    devmem2_1.0-r7.6_armv7a.ipk
    directfb_1.4.11-r1.0.6_armv7a.ipk
    directfb-examples_1.2.0-r0.6_armv7a.ipk
    dropbear_0.51-r7.0.6_armv7a.ipk
    e2fsprogs_1.41.14-r30.6_armv7a.ipk
    e2fsprogs-badblocks_1.41.14-r30.6_armv7a.ipk
    e2fsprogs-e2fsck_1.41.14-r30.6_armv7a.ipk
    e2fsprogs-mke2fs_1.41.14-r30.6_armv7a.ipk
    ethtool_2.6.35-r1.6_armv7a.ipk
    fbset_2.1-r4.6_armv7a.ipk
    fbset-modes_0.1.0-r5.6_all.ipk
    flumotion_0.4.1-r11.6_armv7a.ipk
    font-update-common_0.1-r1.6_all.ipk
    gdbserver_6.8-r9.1.6_armv7a.ipk
    gdk-pixbuf-loader-gif_2.20.1-r10.4.6_armv7a.ipk
    gdk-pixbuf-loader-jpeg_2.20.1-r10.4.6_armv7a.ipk
    gdk-pixbuf-loader-png_2.20.1-r10.4.6_armv7a.ipk
    gdk-pixbuf-loader-xpm_2.20.1-r10.4.6_armv7a.ipk
    glibc-gconv_2.8-r11.6_armv7a.ipk
    glibc-gconv-iso8859-1_2.8-r11.6_armv7a.ipk
    gstreamer_0.10.30-r1.6_armv7a.ipk
    gtk+_2.20.1-r10.4.6_armv7a.ipk
    hdparm_9.35-r0.6_armv7a.ipk
    hicolor-icon-theme_0.11-r1.6_all.ipk
    hiredis_0.10.1-r2.6_armv7a.ipk
    i2c-tools_3.0.3-r0.6_armv7a.ipk
    initscripts_1.0-r126.6_armv7a.ipk
    joe_3.1-r3.6_armv7a.ipk
    kernel_2.6.37-psp04.00.00.12-r9.6_dm816x-evm.ipk
    kernel-2.6.37_2.6.37-psp04.00.00.12-r9.6_dm816x-evm.ipk
    kernel-image-2.6.37_2.6.37-psp04.00.00.12-r9.6_dm816x-evm.ipk
    kernel-module-ipv6_2.6.37-psp04.00.00.12-r9.6_dm816x-evm.ipk
    kernel-module-michael-mic_2.6.37-psp04.00.00.12-r9.6_dm816x-evm.ipk
    kernel-module-zd1211rw_2.6.37-psp04.00.00.12-r9.6_dm816x-evm.ipk
    layout_0.1+svnr76-r1.6_armv7a.ipk
    libapm1_3.2.2-r13.6_armv7a.ipk
    libasound2_1.0.24.1-r0.6_armv7a.ipk
    libatk-1.0-0_1.30.0-r1.6_armv7a.ipk
    libattr1_2.4.44-r4.6_armv7a.ipk
    libavahi-client3_0.6.25-r13.0.6_armv7a.ipk
    libavahi-common3_0.6.25-r13.0.6_armv7a.ipk
    libavahi-core6_0.6.25-r13.0.6_armv7a.ipk
    libblkid1_2.18-r36.0.6_armv7a.ipk
    libc6_2.8-r11.6_armv7a.ipk
    libcairo2_1.10.0-r2.6_armv7a.ipk
    libcap2_2.20-r0.6_armv7a.ipk
    libclutter-eglnative-1.0-0_1.4.2-r4.1.6_dm816x-evm.ipk
    libclutter-eglnative-1.0-cally-examples_1.4.2-r4.1.6_dm816x-evm.ipk
    libcom-err2_1.41.14-r30.6_armv7a.ipk
    libcrypto1.0.0_1.0.0d-r14.0.6_armv7a.ipk
    libcups2_1.3.11-r7.2.6_armv7a.ipk
    libcupsimage2_1.3.11-r7.2.6_armv7a.ipk
    libdaemon0_0.13-r0.6_armv7a.ipk
    libdbus-1-3_1.2.24-r20.1-arago2.6_armv7a.ipk
    libe2p2_1.41.14-r30.6_armv7a.ipk
    libevent_1.4.14b-stable-r1.6_armv7a.ipk
    libexpat1_2.0.1-r3.0.6_armv7a.ipk
    libext2fs2_1.41.14-r30.6_armv7a.ipk
    libffi5_3.0.9-r0.6_armv7a.ipk
    libfontconfig1_2.8.0-r0.6_armv7a.ipk
    libformw5_5.9-r0.6_armv7a.ipk
    libfreetype6_2.4.3-r1-arago1.6_armv7a.ipk
    libgcc1_4.3.3-r11.6_armv7a.ipk
    libgcrypt11_1.4.1-r0.6_armv7a.ipk
    libgio-2.0-0_2.24.1-r2.6_armv7a.ipk
    libgles-omap3_4.04.00.02-r11.6_armv7a.ipk
    libgles-omap3-blitwsegl_4.04.00.02-r11.6_armv7a.ipk
    libgles-omap3-flipwsegl_4.04.00.02-r11.6_armv7a.ipk
    libgles-omap3-frontwsegl_4.04.00.02-r11.6_armv7a.ipk
    libgles-omap3-linuxfbwsegl_4.04.00.02-r11.6_armv7a.ipk
    libgles-omap3-rawdemos_4.04.00.02-r11.6_armv7a.ipk
    libgles-omap3-rawtrainingcourses_4.04.00.02-r11.6_armv7a.ipk
    libglib-2.0-0_2.24.1-r2.6_armv7a.ipk
    libgmodule-2.0-0_2.24.1-r2.6_armv7a.ipk
    libgnutls26_2.10.4-r11.0.6_armv7a.ipk
    libgobject-2.0-0_2.24.1-r2.6_armv7a.ipk
    libgpg-error0_1.4-r7.1.6_armv7a.ipk
    libgstaudio-0.10-0_0.10.30-r11.0-arago4.6_armv7a.ipk
    libgstinterfaces-0.10-0_0.10.30-r11.0-arago4.6_armv7a.ipk
    libgstpbutils-0.10-0_0.10.30-r11.0-arago4.6_armv7a.ipk
    libgsttag-0.10-0_0.10.30-r11.0-arago4.6_armv7a.ipk
    libgstvideo-0.10-0_0.10.30-r11.0-arago4.6_armv7a.ipk
    libgthread-2.0-0_2.24.1-r2.6_armv7a.ipk
    libjpeg8_8b-r1.6_armv7a.ipk
    libjson-glib-1.0-0_0.10.4-r1.6_armv7a.ipk
    libjson0_0.9-r0.6_armv7a.ipk
    libmenuw5_5.9-r0.6_armv7a.ipk
    libmount1_2.18-r36.0.6_armv7a.ipk
    libncurses5_5.9-r0.6_armv7a.ipk
    libncursesw5_5.9-r0.6_armv7a.ipk
    libnl-genl2_1:2.0-r5.0.6_armv7a.ipk
    libnl2_1:2.0-r5.0.6_armv7a.ipk
    libnss-mdns_0.10-r0.6_armv7a.ipk
    libopkg0_0.1.8+svnr609-r5.6_armv7a.ipk
    libpam_1.1.1-r2.6_armv7a.ipk
    libpam-base-files_1.0-r7.6_armv7a.ipk
    libpam-meta_1.1.1-r2.6_armv7a.ipk
    libpanelw5_5.9-r0.6_armv7a.ipk
    libpcre0_7.6-r8.6_armv7a.ipk
    libpixman-1-0_0.21.6-r5.0.6_armv7a.ipk
    libpng12-0_1.2.44-r3.0.6_armv7a.ipk
    libpthread-stubs0_0.2-r2.0.6_armv7a.ipk
    libpyglib-2.0-python0_1:2.20.0-r3.6_armv7a.ipk
    libpython2.6-1.0_2.6.6-ml12.2.6_armv7a.ipk
    libreadline5_5.2-r8.6_armv7a.ipk
    libsqlite3-0_3.7.9-r4.0.6_armv7a.ipk
    libss2_1.41.14-r30.6_armv7a.ipk
    libssl1.0.0_1.0.0d-r14.0.6_armv7a.ipk
    libstdc++6_4.3.3-r11.6_armv7a.ipk
    libsysfs2_2.1.0-r3.6_armv7a.ipk
    libthread-db1_2.8-r11.6_armv7a.ipk
    libtiff5_3.9.4+4.0.0beta6-r1.6_armv7a.ipk
    libtinfo5_5.9-r0.6_armv7a.ipk
    libts-1.0-0_1.0+gitr0+5f48c7b878862b67ba61-r28.5.6_armv7a.ipk
    libusb-0.1-4_1:0.1.3-r0.6_armv7a.ipk
    libusb-1.0-0_1.0.8-r0.6_armv7a.ipk
    libuuid1_2.18-r36.0.6_armv7a.ipk
    libx11-6_1:1.4.1-r9.0.6_armv7a.ipk
    libxau6_1:1.0.6-r9.0.6_armv7a.ipk
    libxcb1_1.6-r4.1.6_armv7a.ipk
    libxcomposite1_1:0.4.3-r9.0.6_armv7a.ipk
    libxcursor1_1:1.1.11-r9.0.6_armv7a.ipk
    libxdamage1_1:1.1.3-r9.0.6_armv7a.ipk
    libxdmcp6_1:1.1.0-r9.0.6_armv7a.ipk
    libxext6_1:1.2.0-r9.1.6_armv7a.ipk
    libxfixes3_1:4.0.5-r9.0.6_armv7a.ipk
    libxft2_1:2.2.0-r9.0.6_armv7a.ipk
    libxml2_2.7.8-r9.1.6_armv7a.ipk
    libxrandr2_1:1.3.1-r9.0.6_armv7a.ipk
    libxrender1_1:0.9.6-r9.0.6_armv7a.ipk
    libz1_1.2.3-r7.0.6_armv7a.ipk
    lighttpd_1.4.26-r9.0.6_armv7a.ipk
    lighttpd-module-access_1.4.26-r9.0.6_armv7a.ipk
    lighttpd-module-accesslog_1.4.26-r9.0.6_armv7a.ipk
    lighttpd-module-cgi_1.4.26-r9.0.6_armv7a.ipk
    lighttpd-module-dirlisting_1.4.26-r9.0.6_armv7a.ipk
    lighttpd-module-indexfile_1.4.26-r9.0.6_armv7a.ipk
    lighttpd-module-scgi_1.4.26-r9.0.6_armv7a.ipk
    lighttpd-module-staticfile_1.4.26-r9.0.6_armv7a.ipk
    live555_20110813-r1.0.6_armv7a.ipk
    live555-mediaserver_20110813-r1.0.6_armv7a.ipk
    live555-openrtsp_20110813-r1.0.6_armv7a.ipk
    live555-playsip_20110813-r1.0.6_armv7a.ipk
    makedevs_1.0.0-r10.6_armv7a.ipk
    module-init-tools_3.12-r6.6_armv7a.ipk
    module-init-tools-depmod_3.12-r6.6_armv7a.ipk
    modutils-initscripts_1.0-r3.6_armv7a.ipk
    ncurses-terminfo_5.9-r0.6_armv7a.ipk
    ncurses-terminfo-base_5.9-r0.6_armv7a.ipk
    netbase_4.21-r50-arago2.6_armv7a.ipk
    omap3-sgx-modules_1.6.16.4117-r9i.6_dm816x-evm.ipk
    openssh-sftp-server_5.6p1-r9.0.6_armv7a.ipk
    openssl_1.0.0d-r14.0.6_armv7a.ipk
    openssl-conf_1.0.0d-r14.0.6_armv7a.ipk
    opkg_0.1.8+svnr609-r5.6_armv7a.ipk
    opkg-collateral_1.0-r3.6_all.ipk
    pam-plugin-access_1.1.1-r2.6_armv7a.ipk
    pam-plugin-debug_1.1.1-r2.6_armv7a.ipk
    pam-plugin-deny_1.1.1-r2.6_armv7a.ipk
    pam-plugin-echo_1.1.1-r2.6_armv7a.ipk
    pam-plugin-env_1.1.1-r2.6_armv7a.ipk
    pam-plugin-exec_1.1.1-r2.6_armv7a.ipk
    pam-plugin-faildelay_1.1.1-r2.6_armv7a.ipk
    pam-plugin-filter_1.1.1-r2.6_armv7a.ipk
    pam-plugin-ftp_1.1.1-r2.6_armv7a.ipk
    pam-plugin-group_1.1.1-r2.6_armv7a.ipk
    pam-plugin-issue_1.1.1-r2.6_armv7a.ipk
    pam-plugin-keyinit_1.1.1-r2.6_armv7a.ipk
    pam-plugin-lastlog_1.1.1-r2.6_armv7a.ipk
    pam-plugin-limits_1.1.1-r2.6_armv7a.ipk
    pam-plugin-listfile_1.1.1-r2.6_armv7a.ipk
    pam-plugin-localuser_1.1.1-r2.6_armv7a.ipk
    pam-plugin-loginuid_1.1.1-r2.6_armv7a.ipk
    pam-plugin-mail_1.1.1-r2.6_armv7a.ipk
    pam-plugin-mkhomedir_1.1.1-r2.6_armv7a.ipk
    pam-plugin-motd_1.1.1-r2.6_armv7a.ipk
    pam-plugin-namespace_1.1.1-r2.6_armv7a.ipk
    pam-plugin-nologin_1.1.1-r2.6_armv7a.ipk
    pam-plugin-permit_1.1.1-r2.6_armv7a.ipk
    pam-plugin-pwhistory_1.1.1-r2.6_armv7a.ipk
    pam-plugin-rhosts_1.1.1-r2.6_armv7a.ipk
    pam-plugin-rootok_1.1.1-r2.6_armv7a.ipk
    pam-plugin-securetty_1.1.1-r2.6_armv7a.ipk
    pam-plugin-shells_1.1.1-r2.6_armv7a.ipk
    pam-plugin-stress_1.1.1-r2.6_armv7a.ipk
    pam-plugin-succeed-if_1.1.1-r2.6_armv7a.ipk
    pam-plugin-tally_1.1.1-r2.6_armv7a.ipk
    pam-plugin-tally2_1.1.1-r2.6_armv7a.ipk
    pam-plugin-time_1.1.1-r2.6_armv7a.ipk
    pam-plugin-timestamp_1.1.1-r2.6_armv7a.ipk
    pam-plugin-umask_1.1.1-r2.6_armv7a.ipk
    pam-plugin-unix_1.1.1-r2.6_armv7a.ipk
    pam-plugin-warn_1.1.1-r2.6_armv7a.ipk
    pam-plugin-wheel_1.1.1-r2.6_armv7a.ipk
    pam-plugin-xauth_1.1.1-r2.6_armv7a.ipk
    pango_1.24.4-r1.1.6_armv7a.ipk
    pango-module-basic-fc_1.24.4-r1.1.6_armv7a.ipk
    pango-module-basic-x_1.24.4-r1.1.6_armv7a.ipk
    pciutils_3.1.2-r7.6_armv7a.ipk
    poco_1.4.1p1-r2.6_armv7a.ipk
    pointercal_0.0-r22.6_dm816x-evm.ipk
    portmap_6.0-r5.6_armv7a.ipk
    ppp_2.4.3-r9.6_armv7a.ipk
    ppp-dialin_0.1-r7.6_all.ipk
    procps_3.2.8-r14.1.6_armv7a.ipk
    python-codecs_2.6.6-ml12.2.6_armv7a.ipk
    python-compression_2.6.6-ml12.2.6_armv7a.ipk
    python-core_2.6.6-ml12.2.6_armv7a.ipk
    python-crypt_2.6.6-ml12.2.6_armv7a.ipk
    python-curses_2.6.6-ml12.2.6_armv7a.ipk
    python-datetime_2.6.6-ml12.2.6_armv7a.ipk
    python-elementtree_2.6.6-ml12.2.6_armv7a.ipk
    python-fcntl_2.6.6-ml12.2.6_armv7a.ipk
    python-gst_0.10.17-r1.6_armv7a.ipk
    python-imaging_1.1.6-ml2.6_armv7a.ipk
    python-io_2.6.6-ml12.2.6_armv7a.ipk
    python-lang_2.6.6-ml12.2.6_armv7a.ipk
    python-logging_2.6.6-ml12.2.6_armv7a.ipk
    python-math_2.6.6-ml12.2.6_armv7a.ipk
    python-mime_2.6.6-ml12.2.6_armv7a.ipk
    python-misc_2.6.6-ml12.2.6_armv7a.ipk
    python-netclient_2.6.6-ml12.2.6_armv7a.ipk
    python-netserver_2.6.6-ml12.2.6_armv7a.ipk
    python-pickle_2.6.6-ml12.2.6_armv7a.ipk
    python-pprint_2.6.6-ml12.2.6_armv7a.ipk
    python-pygobject_1:2.20.0-r3.6_armv7a.ipk
    python-re_2.6.6-ml12.2.6_armv7a.ipk
    python-readline_2.6.6-ml12.2.6_armv7a.ipk
    python-resource_2.6.6-ml12.2.6_armv7a.ipk
    python-stringold_2.6.6-ml12.2.6_armv7a.ipk
    python-subprocess_2.6.6-ml12.2.6_armv7a.ipk
    python-textutils_2.6.6-ml12.2.6_armv7a.ipk
    python-threading_2.6.6-ml12.2.6_armv7a.ipk
    python-twisted-core_8.2.0-r3.6_armv7a.ipk
    python-twisted-web_8.2.0-r3.6_armv7a.ipk
    python-xml_2.6.6-ml12.2.6_armv7a.ipk
    python-zlib_2.6.6-ml12.2.6_armv7a.ipk
    python-zopeinterface_3.5.1-r2.6_armv7a.ipk
    rastertosony_1.2.0-r5.6_armv7a.ipk
    redis_2.4.1-r2.6_armv7a.ipk
    sqlite3_3.7.9-r4.0.6_armv7a.ipk
    strace_4.5.20-r1.6_armv7a.ipk
    sysfsutils_2.1.0-r3.6_armv7a.ipk
    sysvinit_2.86-r66-arago2.6_armv7a.ipk
    sysvinit-inittab_2.86-r66-arago2.6_dm816x-evm.ipk
    sysvinit-pidof_2.86-r66-arago2.6_armv7a.ipk
    sysvinit-utils_2.86-r66-arago2.6_armv7a.ipk
    task-base_1.0-r93.6_dm816x-evm.ipk
    task-base-apm_1.0-r93.6_dm816x-evm.ipk
    task-base-bluetooth_1.0-r93.6_dm816x-evm.ipk
    task-base-ext2_1.0-r93.6_dm816x-evm.ipk
    task-base-extended_1.0-r93.6_dm816x-evm.ipk
    task-base-ipv6_1.0-r93.6_dm816x-evm.ipk
    task-base-kernel26_1.0-r93.6_dm816x-evm.ipk
    task-base-nfs_1.0-r93.6_dm816x-evm.ipk
    task-base-ppp_1.0-r93.6_dm816x-evm.ipk
    task-base-smbfs_1.0-r93.6_dm816x-evm.ipk
    task-base-usbgadget_1.0-r93.6_dm816x-evm.ipk
    task-base-usbhost_1.0-r93.6_dm816x-evm.ipk
    task-base-vfat_1.0-r93.6_dm816x-evm.ipk
    task-base-wifi_1.0-r93.6_dm816x-evm.ipk
    task-boot_1.0-r53.6_dm816x-evm.ipk
    task-distro-base_1.0-r93.6_dm816x-evm.ipk
    task-machine-base_1.0-r93.6_dm816x-evm.ipk
    ti-firmware_05_02_00_15-r0.6_dm816x-evm.ipk
    ti-media-controller-hdvicp2-loader_2_02_00_09-r0.6_dm816x-evm.ipk
    ti-media-controller-hdvpss-loader_2_02_00_09-r0.6_dm816x-evm.ipk
    ti-media-controller-utils_2_02_00_09-r0.6_dm816x-evm.ipk
    ti-omtb_01_00_01_05-r1.6_dm816x-evm.ipk
    ti-omx_05_02_00_15-r1.6_dm816x-evm.ipk
    ti-syslink-module_2_00_02_80-r9i.6_dm816x-evm.ipk
    tinylogin_1.4-r7.6_armv7a.ipk
    tslib-conf_1.0+gitr0+5f48c7b878862b67ba61-r28.5.6_armv7a.ipk
    ttf-dejavu-common_2.23-r3.6_all.ipk
    ttf-dejavu-sans_2.23-r3.6_all.ipk
    u-boot_2010.06-psp04.00.00.12-r1.6.6_dm816x-evm.ipk
    u-boot-min-sd_2010.06-psp04.00.00.12-r1.4.6_dm816x-evm.ipk
    udev_141-r30.6-arago2.6_armv7a.ipk
    udev-utils_141-r30.6-arago2.6_armv7a.ipk
    update-modules_1.0-r10.6_all.ipk
    update-rc.d_0.7-r2.6_all.ipk
    usb-gadget-mode_0.0.2-r8.6_dm816x-evm.ipk
    usbutils_0.86-r1.6_armv7a.ipk
    util-linux-ng_2.18-r36.0.6_armv7a.ipk
    util-linux-ng-blkid_2.18-r36.0.6_armv7a.ipk
    util-linux-ng-cfdisk_2.18-r36.0.6_armv7a.ipk
    util-linux-ng-fdisk_2.18-r36.0.6_armv7a.ipk
    util-linux-ng-fsck_2.18-r36.0.6_armv7a.ipk
    util-linux-ng-losetup_2.18-r36.0.6_armv7a.ipk
    util-linux-ng-mount_2.18-r36.0.6_armv7a.ipk
    util-linux-ng-mountall_2.18-r36.0.6_armv7a.ipk
    util-linux-ng-readprofile_2.18-r36.0.6_armv7a.ipk
    util-linux-ng-sfdisk_2.18-r36.0.6_armv7a.ipk
    util-linux-ng-swaponoff_2.18-r36.0.6_armv7a.ipk
    util-linux-ng-umount_2.18-r36.0.6_armv7a.ipk
    web_0.1+svnr80-r1.6_armv7a.ipk
    wireless-tools_29-r5.6_armv7a.ipk
    wpa-supplicant_0.7.3+0.8.0-rc-r0+gitr0+b8fb017272ed4794339978c9fbc0e74571a44728.6_armv7a.ipk
    wpa-supplicant-cli_0.7.3+0.8.0-rc-r0+gitr0+b8fb017272ed4794339978c9fbc0e74571a44728.6_armv7a.ipk
    wpa-supplicant-passphrase_0.7.3+0.8.0-rc-r0+gitr0+b8fb017272ed4794339978c9fbc0e74571a44728.6_armv7a.ipk
    zeroconf_0.9-r2.6_armv7a.ipk
  • Steve,
    Thanks for your help. Will keep you posted on our progress.
    Andreas
  • Hi Andreas,
      I have the same problem, I have a custom DM8168 board with FPGA.
      DM8168 get video source from FPGA.
      But before that when the custom board booting up I got some errors about VPSS
    FIRMWARE: 2 start Successful
    VPSS_FVID2: contrl event 0x3 timeout
    ti81xxfb ti81xxfb: failed to star.
    VPSS_FVID2: delete time out
    open /dev/fb0: Connection timed out
    VPSS_FVID2: contrl event 0x10040018 timeout
    VPSS_DCTRL: failed to get node input status
    VPSS_GRPX : failed to set grpx0 nodes
    ti81xxfb ti81xxfb: fvid2 create failed.
     Also omx sample not work on the new board,
    and when I using loggerSMDump to check the logs,
    I got an error in device init.
    N:VPSS P:2 #:00007 T:00000000|7a20409d S:Error in Vps_platformDeviceInit retVal: -1
    I wondered if this is an error about hardware, because there is no tvp7002 chip.
    Do you have the same problem?
  • Hi Lei,
    no didn't have that problem. Our problem was related to the video input not being detected.
    What version of everything are you using? Based of the EZSDK or are you compiling/building things on your own. It could be related to the address of the shared buffers for notify...
    Post your logfile (dmesg), commandline args, and all the various versions you use.
    Andreas
  • Steve,
    thanks for your help. We managed to get the video input to work fine our new motherboard.
    YCbCr 16bit, embedded syncs, 1080p60. We had to play around a little with the clocking but things are working solidly at the moment.
    Andreas
  • Excellent.
    Clocking can cause soooo many issues for a single signal !!!
    BR,
    Steve
  • Hi Andreas,
    I am using ezsdk_dm816x-evm_5_02_02_60, and I havn't changed any thing in it.
    When I booting my board (No TVP7002),
    the booting message like below.
    :,;;:;:;;;;;;;;r;;:,;;:;:;;;;;;;;:,;;:;:;;;;;;;;:,;;:;:;;;;;;;;:;;;;;;;;:,;;:;:
    ;,;:::;;;;r;;;rssiSiS552X5252525259GX2X9hX9X9XX2325S55252i5:,;;:;:;;;;;;;;:,;;:
    ;:;;;;;;;rrssSsS52S22h52299GGAAMHMM#BBH#B#HMM#HMBA&&XX2255S2S5Si:,;;:;:;;;;;;;;
    ;:;;r;;rsrrriiXS5S329&A&MH#BMB#A&9XXA252GXiSXX39AAMMMBB&G22S5i2SSiiiisi:,;;:;:;
    ;;;;;r;rr2iisiih393HB#B#AA99i22irrrX3X52AGsisss2Xii2299HBMA&X2S5S5iSiisSsi:,;;:
    r:r;rrsrsihXSi2&##MHB&Ahh3AGHGA9G9h&#H##@@@##MAMMXXX9SSS29&&HGGX2i5iisiiisisi:,
    ;;rrrrsSiiiA&ABH&A9GAGhAhBAMHA9HM@@@@@@@@@@@@@@@@@@@HHhAh2S2SX9&Gh22SSiisiiisii
    r:rrssisiS2XM##&h3AGAX&3GG3Ssr5H@M#HM2; ;2X&&&MHMB###GBB#B&XXSSs529XX55iSsisisi
    r;rsrisSi2XHAhX99A3XXG&&XS;:,rH#HGhAS   @@@@3rs2XBM@@A552&&AHA2XiisSS252SSsisSs
    r;issi5S22&&3iSSX292&hXsr;;:;h@&G339&S9@@@@2@MA&9&HB##Xris29ABMAAX2ir;rsSi5iss5
    rrsSi2XhG&9GXh399&X99i;;;;;;r#H&293H9X#@@@@@@@B&9GhAH@XrrsrsiXABHB&HG2rr;rrSiSi
    ;:rsisS599&AA9XG&3A35r;:::;,;BMh&&2iX5A@@@@@@@&392X5GB2;;;r;iSX393A##A&Xi:::rsi
    ;:rss552222X553&XHMhir;;::,:,h#HhGSXhG3#@@@@#AXXS2XAHA;::;;;;ss55XShBA3239r:,;;
    r;ii2S5SSi2i53hirsh2srr::,,,,;MMXX359&Ah3h&Si59SX99A#i:,::::;;sri2,.2r;:SGAr;,:
    ;:;rrrrssiriXGSi::shs;;;,,,:,,rBBA9h5s5h5iS5isi2SAHB5:,,,:::;rrs5&SrisSX5Srrr:,
    ;,r;;;;rsriSSrrrr;;5Xrr;;,:,,.,;9AA2SsisS5323XXXG9&i:.,,::;;r;;;srrrrrr;;:;::::
    :,;r;r;rrissrrr;:;::;s;;;;,:,,..,r293h222hXXAAGGGX;:,,,:,:,::;:;::,:,,,,...,,,,
    ;,;;;;rrrrrrrrirr;,.,,:::::::,,,,.,;SX&ABAB2hhXir:,,.,,.,,:,,,,..,,,..,..,,,..:
    :.:;:;;;:;;;;r;rrs;:.. ,,:::::,:,:,,.::rrsrr;;,,.......,..,....,,,,,,,...,.,,:,
    :.:::,::::::;;r;rrr;:.......,.,.,,:::,,...............,,::.,,,,:,::,,:,:,,,:,;:
    ,.::,:,,,,,;;;;;;;;r;;::,..............................;;;:;::::,:::::::,:,:,,,
    : ,,:,,,,,,,,,,,,,:;rrr;;:;,,,,,,,::,.,.:.,.,;s,:;;;;:;:;;;;;::::,:::,:::,:,:,:
    Net:   Detected MACID:90:d7:eb:2d:1e:ca
    Ethernet PHY: GENERIC @ 0x01
    DaVinci EMAC
    Hit any key to stop autoboot:  3  2  1  0
    BOOTP broadcast 1
    BOOTP broadcast 2
    DHCP client bound to address 172.16.1.49
    Using DaVinci EMAC device
    TFTP from server 172.16.1.62; our IP address is 172.16.1.49
    Filename 'uImage2.2'.
    Load address: 0x81000000
    Loading: *T #################################################################
    done
    Bytes transferred = 2410792 (24c928 hex)
    ## Booting kernel from Legacy Image at 81000000 ...
       Image Name:   Arago/2.6.37-psp04.00.00.12/dm81
       Image Type:   ARM Linux Kernel Image (uncompressed)
       Data Size:    2410728 Bytes = 2.3 MiB
       Load Address: 80008000
       Entry Point:  80008000
       Verifying Checksum ... OK
       Loading Kernel Image ... OK
    OK
    Starting kernel ...
    Uncompressing Linux... done, booting the kernel.
    Linux version 2.6.37 (x0029463@swubn01) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #1 Thu Sep 8 11:27:49 IST 2011
    CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
    CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
    Machine: ti8168evm
    vram size = 52428800 at 0
    reserved size = 52428800 at 0
    FB: Reserving 52428800 bytes SDRAM for VRAM
    Memory policy: ECC disabled, Data cache writeback
    OMAP chip is TI8168 1.1
    Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 52224
    Kernel command line: console=ttyO2,115200n8 rootwait rw mem=256M earlyprink notifyk.vpssm3_sva=0xBF900000 vram=50M ti816xfb.vram=0:16M,1:16M,2:6M root=/dev/nfs nfsroot=172.16.1.62:/home/xiaoxiao/targetfs ip=dhcp
    PID hash table entries: 1024 (order: 0, 4096 bytes)
    Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
    Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
    Memory: 206MB = 206MB total
    Memory: 203476k/203476k available, 58668k reserved, 0K highmem
    Virtual kernel memory layout:
        vector  : 0xffff0000 - 0xffff1000   (   4 kB)
        fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
        DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
        vmalloc : 0xd0800000 - 0xf8000000   ( 632 MB)
        lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
        modules : 0xbf000000 - 0xc0000000   (  16 MB)
          .init : 0xc0008000 - 0xc0038000   ( 192 kB)
          .text : 0xc0038000 - 0xc0492000   (4456 kB)
          .data : 0xc0492000 - 0xc04d89c0   ( 283 kB)
    SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    NR_IRQS:407
    IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
    Total of 128 interrupts on 1 active controller
    GPMC revision 6.0
    Trying to install interrupt handler for IRQ400
    Trying to install interrupt handler for IRQ401
    Trying to install interrupt handler for IRQ402
    Trying to install interrupt handler for IRQ403
    Trying to install interrupt handler for IRQ404
    Trying to install interrupt handler for IRQ405
    Trying to install interrupt handler for IRQ406
    Trying to install type control for IRQ407
    Trying to set irq flags for IRQ407
    OMAP clockevent source: GPTIMER1 at 27000000 Hz
    Console: colour dummy device 80x30
    Calibrating delay loop... 986.31 BogoMIPS (lpj=4931584)
    pid_max: default: 32768 minimum: 301
    Security Framework initialized
    Mount-cache hash table entries: 512
    CPU: Testing write buffer coherency: ok
    devtmpfs: initialized
    omap_voltage_early_init: voltage driver support not added
    regulator: core version 0.5
    regulator: dummy:
    NET: Registered protocol family 16
    OMAP GPIO hardware version 0.1
    omap_mux_init: Add partition: #1: core, flags: 0
    _omap_mux_get_by_name: Could not find signal i2c2_scl.i2c2_scl
    _omap_mux_get_by_name: Could not find signal i2c2_sda.i2c2_sda
    NOR: Can't request GPMC CS
    registered ti816x_vpss device
    registered ti816x_gpio_vr device
    registered TI816x on-chip HDMI device
    registered ti816x_sr device
    pm_dbg_init: only OMAP3 supported
    Registered ti81xx_fb device
    ti816x_pcie: Invoking PCI BIOS...
    ti816x_pcie: Setting up Host Controller...
    ti816x_pcie: Register base mapped @0xd0820000
    ti816x_pcie: Starting PCI scan...
    PCI: bus0: Fast back to back transfers enabled
    bio: create slab <bio-0> at 0
    regulator: VFB: 800 <--> 1025 mV at 800 mV
    vgaarb: loaded
    SCSI subsystem initialized
    usbcore: registered new interface driver usbfs
    usbcore: registered new interface driver hub
    usbcore: registered new device driver usb
    omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
    omap_i2c omap_i2c.2: bus 2 rev4.0 at 100 kHz
    Advanced Linux Sound Architecture Driver Version 1.0.23.
    Switching to clocksource gp timer
    musb-hdrc: version 6.0, host, debug=0
    musb-hdrc musb-hdrc.0: dma type: dma-cppi41
    registerd cppi-dma Intr @ IRQ 17
    Cppi41 Init Done
    musb-hdrc: kernel must blacklist external hubs
    musb-hdrc musb-hdrc.0: MUSB HDRC host driver
    musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
    usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    usb usb1: Product: MUSB HDRC host driver
    usb usb1: Manufacturer: Linux 2.6.37 musb-hcd
    usb usb1: SerialNumber: musb-hdrc.0
    hub 1-0:1.0: USB hub found
    hub 1-0:1.0: 1 port detected
    musb-hdrc musb-hdrc.0: USB Host mode controller at d080c000 using DMA, IRQ 18
    musb-hdrc musb-hdrc.1: dma type: dma-cppi41
    musb-hdrc musb-hdrc.1: MUSB HDRC host driver
    musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
    usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
    usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    usb usb2: Product: MUSB HDRC host driver
    usb usb2: Manufacturer: Linux 2.6.37 musb-hcd
    usb usb2: SerialNumber: musb-hdrc.1
    hub 2-0:1.0: USB hub found
    hub 2-0:1.0: 1 port detected
    musb-hdrc musb-hdrc.1: USB Host mode controller at d081e800 using DMA, IRQ 19
    NET: Registered protocol family 2
    IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
    TCP established hash table entries: 8192 (order: 4, 65536 bytes)
    TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
    TCP: Hash tables configured (established 8192 bind 8192)
    TCP reno registered
    UDP hash table entries: 256 (order: 0, 4096 bytes)
    UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
    RPC: Registered udp transport module.
    RPC: Registered tcp transport module.
    RPC: Registered tcp NFSv4.1 backchannel transport module.
    NetWinder Floating Point Emulator V0.97 (double precision)
    PMU: registered new PMU device of type 0
    omap-iommu omap-iommu.0: ducati registered
    omap-iommu omap-iommu.1: sys registered
    JFFS2 version 2.2. (NAND) c 2001-2006 Red Hat, Inc.
    msgmni has been set to 397
    io scheduler noop registered
    io scheduler deadline registered
    io scheduler cfq registered (default)
    Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
    omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
    omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
    console [ttyO2] enabled
    brd: module loaded
    loop: module loaded
    ahci ahci.0: forcing PORTS_IMPL to 0x3
    ahci ahci.0: AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl platform mode
    ahci ahci.0: flags: ncq sntf pm led clo only pmp pio slum part ccc
    scsi0 : ahci_platform
    scsi1 : ahci_platform
    ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x100 irq 16
    ata2: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x180 irq 16
    m25p80 spi1.0: found m25p32, expected w25x32
    m25p80 spi1.0: m25p32 (4096 Kbytes)
    Creating 4 MTD partitions on "spi_flash":
    0x000000000000-0x000000040000 : "U-Boot"
    0x000000040000-0x000000042000 : "U-Boot Env"
    mtd: partition "U-Boot Env" doesn't end on an erase block -- force read-only
    0x000000042000-0x0000002c2000 : "Kernel"
    mtd: partition "Kernel" doesn't start on an erase block boundary -- force read-only
    0x0000002c2000-0x000000400000 : "File System"
    mtd: partition "File System" doesn't start on an erase block boundary -- force read-only
    omap2-nand driver initializing
    NAND device: Manufacturer ID: 0x2c, Chip ID: 0xca (Micron )
    Creating 5 MTD partitions on "omap2-nand.0":
    0x000000000000-0x000000260000 : "U-Boot"
    0x000000260000-0x000000280000 : "U-Boot Env"
    0x000000280000-0x0000006c0000 : "Kernel"
    0x0000006c0000-0x00000cee0000 : "File System"
    0x00000cee0000-0x000010000000 : "Reserved"
    davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
    davinci_mdio davinci_mdio.0: detected phy mask fffffffd
    davinci_mdio.0: probed
    davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown
    usbcore: registered new interface driver cdc_ether
    usbcore: registered new interface driver dm9601
    Initializing USB Mass Storage driver...
    usbcore: registered new interface driver usb-storage
    USB Mass Storage support registered.
    mice: PS/2 mouse device common for all mice
    i2c /dev entries driver
    Linux video capture interface: v2.00
    usbcore: registered new interface driver uvcvideo
    USB Video Class driver (v1.0.0)
    OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
    usbcore: registered new interface driver usbhid
    usbhid: USB HID core driver
    notify_init : notify drivercreated  for  remote proc id 2 at physical Address 0xbf900000
    usbcore: registered new interface driver snd-usb-audio
    asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok
    ALSA device list:
      #0: TI81XX EVM
    TCP cubic registered
    NET: Registered protocol family 17
    VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
    omap_voltage_late_init: Voltage driver support not added
    smartreflex smartreflex: Driver initialized
    ata2: SATA link down (SStatus 0 SControl 300)
    ata1: SATA link down (SStatus 0 SControl 300)
    davinci_mdio davinci_mdio.0: resetting idled controller
    net eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, id=282f014)
    PHY 0:02 not found
    net eth1: could not connect to phy 0:02
    Sending DHCP requests ..
    PHY: 0:01 - Link is Up - 1000/Full
    ., OK
    IP-Config: Got DHCP answer from 0.0.0.0, my address is 172.16.1.49
    IP-Config: Complete:
         device=eth0, addr=172.16.1.49, mask=255.255.255.0, gw=172.16.1.1,
         host=172.16.1.49, domain=, nis-domain=(none),
         bootserver=0.0.0.0, rootserver=172.16.1.62, rootpath=
    VFS: Mounted root (nfs filesystem) on device 0:14.
    devtmpfs: mounted
    Freeing init memory: 192K
    INIT: version 2.86 booting
    Error opening /dev/fb0: No such file or directory
    Please wait: booting...
    Starting udev
    udevd (77): /proc/77/oom_adj is deprecated, please use /proc/77/oom_score_adj instead.
    udev: starting version 141
    udev: renamed network interface eth1 to eth2
    udevd-event[95]: error changing netif name eth0 to eth3: Device or resource busy
    Root filesystem already rw, not remounting
    Caching udev devnodes
    Populating dev cachemv: cannot rename '/tmp/devices': No such file or directory
    NET: Registered protocol family 10
    ALSA: Restoring mixer settings...
    NOT configuring network interfaces: / is an NFS mount
    hwclock: can't open '/dev/misc/rtc': No such file or directory
    Fri Sep  9 03:02:00 UTC 2011
    INIT: Entering runlevel: 5
    Starting system message bus: dbus.
    Loading HDVICP2 Firmware
    DM816X prcm_config_app version: 2.0.0.1
    Doing PRCM settings...
    PRCM for IVHD0 is in Progress, Please wait.....
    BW Phy Addr : 0x48180600 Data : 0x00000002
    AW Phy Addr : 0x48180600 Data : 0x00000002
    Phy Addr : 0x48180c04 Data : 0x00000037
    BW Phy Addr : 0x48180620 Data : 0x00070000
    AW Phy Addr : 0x48180620 Data : 0x00070002
    BW Phy Addr : 0x48180624 Data : 0x00030000
    AW Phy Addr : 0x48180624 Data : 0x00010002
    Phy Addr : 0x48180600 Data : 0x00000102
    BW Phy Addr : 0x48180c10 Data : 0x00000007
    AW Phy Addr : 0x48180c10 Data : 0x00000003
    Phy Addr : 0x48180c14 Data : 0x00000004
    BW Phy Addr : 0x58088000 Data : 0xeafffffe
    AW Phy Addr : 0x58088000 Data : 0xeafffffe
    BW Phy Addr : 0x58098000 Data : 0xeafffffe
    AW Phy Addr : 0x58098000 Data : 0xeafffffe
    BW Phy Addr : 0x48180c10 Data : 0x00000003
    AW Phy Addr : 0x48180c10 Data : 0x00000000
    Phy Addr : 0x48180c14 Data : 0x00000007
    PRCM for IVHD0 is Done Successfully
    PRCM for IVHD1 is in Progress, Please wait.....
    BW Phy Addr : 0x48180700 Data : 0x00000002
    AW Phy Addr : 0x48180700 Data : 0x00000002
    Phy Addr : 0x48180d04 Data : 0x00000037
    BW Phy Addr : 0x48180720 Data : 0x00070000
    AW Phy Addr : 0x48180720 Data : 0x00050002
    BW Phy Addr : 0x48180724 Data : 0x00030000
    AW Phy Addr : 0x48180724 Data : 0x00010002
    Phy Addr : 0x48180700 Data : 0x00000102
    BW Phy Addr : 0x48180d10 Data : 0x00000007
    AW Phy Addr : 0x48180d10 Data : 0x00000003
    Phy Addr : 0x48180d14 Data : 0x00000004
    BW Phy Addr : 0x5a088000 Data : 0xeafffffe
    AW Phy Addr : 0x5a088000 Data : 0xeafffffe
    BW Phy Addr : 0x5a098000 Data : 0xeafffffe
    AW Phy Addr : 0x5a098000 Data : 0xeafffffe
    BW Phy Addr : 0x48180d10 Data : 0x00000003
    AW Phy Addr : 0x48180d10 Data : 0x00000000
    Phy Addr : 0x48180d14 Data : 0x00000007
    PRCM for IVHD1 is Done Successfully
    PRCM for IVHD2 is in Progress, Please wait.....
    BW Phy Addr : 0x48180800 Data : 0x00000002
    AW Phy Addr : 0x48180800 Data : 0x00000002
    Phy Addr : 0x48180e04 Data : 0x00000037
    BW Phy Addr : 0x48180820 Data : 0x00070000
    AW Phy Addr : 0x48180820 Data : 0x00050002
    BW Phy Addr : 0x48180824 Data : 0x00030000
    AW Phy Addr : 0x48180824 Data : 0x00010002
    Phy Addr : 0x48180800 Data : 0x00000102
    BW Phy Addr : 0x48180e10 Data : 0x00000007
    AW Phy Addr : 0x48180e10 Data : 0x00000003
    Phy Addr : 0x48180e14 Data : 0x00000004
    BW Phy Addr : 0x53088000 Data : 0xeafffffe
    AW Phy Addr : 0x53088000 Data : 0xeafffffe
    BW Phy Addr : 0x53098000 Data : 0xeafffffe
    AW Phy Addr : 0x53098000 Data : 0xeafffffe
    BW Phy Addr : 0x48180e10 Data : 0x00000003
    AW Phy Addr : 0x48180e10 Data : 0x00000000
    Phy Addr : 0x48180e14 Data : 0x00000007
    PRCM for IVHD2 is Done Successfully
    PRCM Initialization completed
    SysLink version : 2.00.02.80
    SysLink module created on Date:Sep  8 2011 Time:12:18:39
    FIRMWARE: Memory map bin file not passed
    Usage : firmware_loader <Processor Id> <Location of Firmware> <start|stop> [Location of Mem map bin file]
    FIRMWARE: Default memory configuration is used
    MemCfg: DCMM (Dynamically Configurable Memory Map) Version :  2.1.1.1
    FIRMWARE: Memory Configuration status : In Progress
    FIRMWARE: 1 start Successful
    Starting telnet daemon.
    Loading HDVPSS Firmware
    cat: write error: No space left on device
    HDMI W1 rev 2.0
    Starting syslogd/klogd: done
    Starting thttpd.
    Starting PVR
    /dev/mem opened.
    Memory mapped at address 0x40304000.
    Read at address  0x48180F04 (0x40304f04): 0x00000001
    Write at address 0x48180F04 (0x40304f04): 0x00000000, readback 0x00000000
    /dev/mem opened.
    Memory mapped at address 0x40297000.
    Read at address  0x48180900 (0x40297900): 0x00000102
    Write at address 0x48180900 (0x40297900): 0x00000002, readback 0x00000002
    /dev/mem opened.
    Memory mapped at address 0x4024a000.
    Read at address  0x48180920 (0x4024a920): 0x00040002
    Write at address 0x48180920 (0x4024a920): 0x00000002, readback 0x00000002
    Starting Matrix GUI application.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org dm816x-evm ttyO2
    Arago 2011.05 dm816x-evm ttyO2
    dm816x-evm login: VPSS_FVID2: contrl event 0x10040018 timeout
    root
    I found there some errors about VPSS.
    dmesg log is this
    Machine: ti8168evm
    On node 0 totalpages: 52736
    free_area_init_node: node 0, pgdat c04d72ac, node_mem_map c0510000
      Normal zone: 512 pages used for memmap
      Normal zone: 0 pages reserved
      Normal zone: 52224 pages, LIFO batch:15
    pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
    pcpu-alloc: [0] 0
    NR_IRQS:407
    GPMC revision 6.0
    regulator: dummy:
    omap_gpio omap_gpio.0: rpm_resume flags 0x4
    omap_gpio omap_gpio.0: omap_pm_runtime_resume
    omap_gpio omap_gpio.0: rpm_resume returns 0
    omap_gpio omap_gpio.1: rpm_resume flags 0x4
    omap_gpio omap_gpio.1: omap_pm_runtime_resume
    omap_gpio omap_gpio.1: rpm_resume returns 0
    pci_bus 0000:00: resource 0 [mem 0x20000000-0x2fffffff]
    pci_bus 0000:00: resource 1 [io  0x40000000-0x402fffff]
    vgaarb: loaded
    libata version 3.00 loaded.
    omap_i2c omap_i2c.1: rpm_resume flags 0x4
    omap_i2c omap_i2c.1: omap_pm_runtime_resume
    omap_i2c omap_i2c.1: rpm_resume returns 0
    omap_i2c omap_i2c.1: rpm_suspend flags 0x0
    omap_i2c omap_i2c.1: omap_pm_runtime_suspend
    omap_i2c omap_i2c.1: rpm_suspend returns 0
    omap_i2c omap_i2c.2: rpm_resume flags 0x4
    omap_i2c omap_i2c.2: omap_pm_runtime_resume
    omap_i2c omap_i2c.2: rpm_resume returns 0
    omap_i2c omap_i2c.2: rpm_suspend flags 0x0
    omap_i2c omap_i2c.2: omap_pm_runtime_suspend
    omap_i2c omap_i2c.2: rpm_suspend returns 0
    Cppi41 Init Done
    musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
    musb-hdrc: HDRC RTL version 2.0
    musb-hdrc: setup fifo_mode 4
    musb-hdrc: 28/31 max ep, 16384/16384 memory
    usb usb1: rpm_resume flags 0x4
    usb usb1: rpm_resume returns 1
    usb usb1: rpm_resume flags 0x0
    Registered /proc/driver/musb_hdrc.0
    usb usb2: rpm_resume flags 0x4
    usb usb2: rpm_resume returns 1
    usb usb2: rpm_resume flags 0x0
    Registered /proc/driver/musb_hdrc.1
    TCP reno registered
    PCI: CLS 0 bytes, default 64
    hub 1-0:1.0: rpm_resume flags 0x4
    hub 1-0:1.0: rpm_resume returns 1
    hub 1-0:1.0: rpm_suspend flags 0x0
    hub 1-0:1.0: rpm_suspend returns 0
    brd: module loaded
    loop: module loaded
    hub 2-0:1.0: rpm_resume flags 0x4
    hub 2-0:1.0: rpm_resume returns 1
    hub 2-0:1.0: rpm_suspend flags 0x0
    hub 2-0:1.0: rpm_suspend returns 0
    scsi host0: rpm_resume flags 0x4
    scsi host0: rpm_resume returns 1
    scsi host1: rpm_resume flags 0x4
    scsi host1: rpm_resume returns 1
    omap_wdt omap_wdt: rpm_resume flags 0x4
    omap_wdt omap_wdt: omap_pm_runtime_resume
    omap_wdt omap_wdt: rpm_resume returns 0
    omap_wdt omap_wdt: rpm_suspend flags 0x0
    omap_wdt omap_wdt: omap_pm_runtime_suspend
    omap_wdt omap_wdt: rpm_suspend returns 0
    ALSA device list:
      #0: TI81XX EVM
    scsi host1: rpm_suspend flags 0x0
    scsi host1: rpm_suspend returns 0
    scsi host0: rpm_suspend flags 0x0
    scsi host0: rpm_suspend returns 0
    PHY 0:02 not found
    ., OK
    devtmpfs: mounted
    VPSS_CORE : core init
    VPSS_CORE : cpu version 1
    VPSS_SHRBUF: sbuf init
    VPSS_SHRBUF: map 0xbfb00000 to 0xd7000000 with size 2097152
    VPSS_FVID2: fvid2 init
    VPSS_SHRBUF: FOUND 0xbfb00000, end 0xbfd00000, map vir 0xd7000000 size 8192
    VPSS_FVID2: Handshake...
    VPSS_SHRBUF: FOUND 0xbfb02000, end 0xbfd00000, map vir 0xd7002000 size 4096
    VPSS_SHRBUF: free mem paddr 0xbfb02000 vaddr 0xd7002000 size 4096
    VPSS_FVID2: get firmware version 0x01000128.
    VPSS_SYSTEM: enter system init
    VPSS_FVID2: Fvid2 handle 0x9f296670 with notifyno 10 within 0 ms
    VPSS_FVID2: send control with cmd 0x10080002
    VPSS_FVID2: control event 0x10080002 return 0 within 0 ms.
    VPSS_DCTRL: dctrl init
    VPSS_SHRBUF: FOUND 0xbfb03000, end 0xbfd00000, map vir 0xd7003000 size 4096
    VPSS_FVID2: Fvid2 handle 0x9f296690 with notifyno 11 within 0 ms
    VPSS_DCTRL: mode hdmi:1080p-60,dvo2:1080p-60,hdcomp:1080p-60
    VPSS_FVID2: send control with cmd 0x10040003
    VPSS_FVID2: control event 0x10040003 return 0 within 0 ms.
    VPSS_FVID2: send control with cmd 0x1004001c
    VPSS_FVID2: control event 0x1004001c return 0 within 0 ms.
    VPSS_SYSTEM: enter set pll 148500KHz for VENC 1
    VPSS_FVID2: send control with cmd 0x10080000
    VPSS_FVID2: control event 0x10080000 return 0 within 0 ms.
    VPSS_SYSTEM: enter set pll 216000KHz for VENC 0
    VPSS_SYSTEM: enter set pll 148500KHz for VENC 2
    VPSS_FVID2: send control with cmd 0x1004001a
    VPSS_FVID2: control event 0x1004001a return 0 within 0 ms.
    VPSS_FVID2: send control with cmd 0x10040019
    VPSS_FVID2: control event 0x10040019 return 0 within 0 ms.
    VPSS_GRPX : grpx init
    VPSS_SHRBUF: FOUND 0xbfb04000, end 0xbfd00000, map vir 0xd7004000 size 4096
    VPSS_VIDEO: video init
    VPSS_SHRBUF: FOUND 0xbfb05000, end 0xbfd00000, map vir 0xd7005000 size 8192
    VPSS_SHRBUF: sharing buffer used 28672 byte, left 2068480 bytes
    VPSS_GRPX : (0)- get resolution.
    VPSS_DCTRL: enter get output format
    VPSS_GRPX : (0) - get timing
    VPSS_GRPX : (1)- get resolution.
    VPSS_GRPX : (1) - get timing
    VPSS_GRPX : (2)- get resolution.
    VPSS_GRPX : (2) - get timing
    VPSS_GRPX : (0)- apply changes into FVID2_FRAME.
    VPSS_GRPX : (0)- set format bpp 32 df 4104, pitch 7680.
    VPSS_GRPX : (0)- get region params.
    VPSS_GRPX : (0)- set region params.
    VPSS_GRPX : (0)- add buffer 0x8ce00000
    VPSS_GRPX : (1)- apply changes into FVID2_FRAME.
    VPSS_GRPX : (1)- set format bpp 32 df 4104, pitch 7680.
    VPSS_GRPX : (1)- get region params.
    VPSS_GRPX : (1)- set region params.
    VPSS_GRPX : (1)- add buffer 0x8e600000
    VPSS_GRPX : (2)- apply changes into FVID2_FRAME.
    VPSS_GRPX : (2)- set format bpp 32 df 4104, pitch 2880.
    VPSS_GRPX : (2)- get region params.
    VPSS_GRPX : (2)- set region params.
    VPSS_GRPX : (2)- add buffer 0x8f600000
    VPSS_GRPX : create grpx0
    VPSS_DCTRL: enter set node
    VPSS_FVID2: send control with cmd 0x10040018
    VPSS_FVID2: control event 0x10040018 return 0 within 0 ms.
    VPSS_FVID2: send control with cmd 0x10040017
    VPSS_FVID2: control event 0x10040017 return 0 within 0 ms.
    VPSS_FVID2: Fvid2 handle 0x9f2966b0 with notifyno 12 within 0 ms
    VPSS_GRPX : start grpx0
    VPSS_FVID2: send control with cmd 0x00000003
    VPSS_FVID2: control event 0x3 return 0 within 0 ms.
    VPSS_FVID2: send control with cmd 0x10000002
    VPSS_FVID2: control event 0x10000002 return 0 within 0 ms.
    VPSS_FVID2: queue event return 0 within 0 ms.
    VPSS_FVID2: send control with cmd 0x00000005
    VPSS_FVID2: control event 0x5 return 0 within 54 ms.
    VPSS_GRPX : (0)- set clut 0x8be47000
    VPSS_GRPX : stop grpx0
    VPSS_FVID2: send control with cmd 0x00000006
    VPSS_FVID2: control event 0x6 return 0 within 65 ms.
    VPSS_GRPX : delete GRPX0
    VPSS_FVID2: enter delete.
    VPSS_FVID2: delete event return 0 within 0 ms
    VPSS_FVID2: control event 0x5 return 0 within 62 ms.
    VPSS_FVID2: control event 0x6 return 0 within 38 ms.
    VPSS_GRPX : create grpx1
    VPSS_GRPX : start grpx1
    VPSS_FVID2: control event 0x5 return 0 within 60 ms.
    VPSS_GRPX : stop grpx1
    VPSS_FVID2: control event 0x6 return 0 within 57 ms.
    VPSS_GRPX : delete GRPX1
    HDMI W1 rev 2.0
    VPSS_FVID2: control event 0x1004001a return 0 within 2 ms.
    VPSS_FVID2: send control with cmd 0x10040004
    VPSS_FVID2: control event 0x10040004 return 0 within 0 ms.
    hdmi: Enter HDMI_W1_StopVideoFrame()
    hdmi: Enter HDMI_W1_GlobalInitVars()
    hdmi: Enter HDMI_Core_GlobalInitVars()
    hdmi: Enter HDMI_W1_ConfigVideoInterface()
    hdmi: HDMI_WP_AUDIO_CFG = 0x1030022
    hdmi: HDMI_WP_AUDIO_CFG2 = 0x20c0
    hdmi: HDMI_WP_AUDIO_CTRL = 0x20
    hdmi: Enter DSS_HDMI_CORE_SW_RESET_ASSERT ()
    hdmi: Enter DSS_HDMI_CORE_POWER_DOWN_DISABLE()
    hdmi: Enter DSS_HDMI_CORE_SW_RESET_RELEASE()
    hdmi: Enter HDMI_W1_StartVideoFrame  ()
    VPSS_FVID2: control event 0x5 return 0 within 59 ms.
    VPSS_FVID2: control event 0x6 return 0 within 66 ms.
    VPSS_FVID2: control event 0x10040018 return 0 within 1 ms.
    VPSS_FVID2: control event 0x5 return 0 within 50 ms.
    VPSS_FVID2: control event 0x5 return 0 within 37 ms.
    VPSS_FVID2: control event 0x5 return 0 within 51 ms.
    and my bootargs is
    bootdelay=3
    baudrate=115200
    autoload=no
    verify=yes
    ramdisk_file=ramdisk.gz
    loadaddr=0x81000000
    ethaddr=90:d7:eb:2d:1e:ca
    ethact=DaVinci EMAC
    bootcmd=dhcp;tftpboot;bootm
    serverip=172.16.1.62
    bootargs=console=ttyO2,115200n8 rootwait rw mem=256M earlyprink notifyk.vpssm3_
    bootfile=uImage2.2
    stdin=serial
    stdout=serial
    stderr=serial
    ver=U-Boot 2010.06 (Dec 16 2011 - 15:18:15)
    root@dm816x-evm:/usr/share/ti/ti-uia# ./loggerSMDump.out 0x9e400000 all
    Opened loggerSM.bin to store encoded records
    N:Video P:1 #:00000 T:00000000|019ded33 S:Enabling Status Logger
    N:VPSS  P:2 #:00000 T:00000000|2416529d S:Enabling Status Logger
    N:Video P:1 #:00001 T:00000000|019e23e1 S:Enabling User1 Logs
    N:VPSS  P:2 #:00001 T:00000000|241687bf S:Enabling User1 Logs
    N:Video P:1 #:00002 T:00000000|019e727f S:Disabling User1 Logs
    N:VPSS  P:2 #:00002 T:00000000|2416d7d7 S:Disabling User1 Logs
    N:Video P:1 #:00003 T:00000000|019eb57b S:Disabling User1 Logs
    N:VPSS  P:2 #:00003 T:00000000|24171ab1 S:Disabling User1 Logs
    N:Video P:1 #:00004 T:00000000|019ef711 S:Disabling User1 Logs
    N:VPSS  P:2 #:00004 T:00000000|24175c81 S:Disabling User1 Logs
    N:Video P:1 #:00005 T:00000000|019f3997 S:Disabling User1 Logs
    N:VPSS  P:2 #:00005 T:00000000|24179ea1 S:Disabling User1 Logs
    N:Video P:1 #:00006 T:00000000|019f7d61 S:Enabling Analysis Logs
    N:VPSS  P:2 #:00006 T:00000000|2417e22b S:Enabling Analysis Logs
    N:Video P:1 #:00007 T:00000000|01a50b95 S:Module<ti.omx> Entering<DomxCore_procInit> @line<116>
    N:VPSS  P:2 #:00007 T:00000000|7a2a534d S:Error in Vps_platformDeviceInit retVal: -1
    N:Video P:1 #:00008 T:00000000|01f67511 S:Module<ti.omx> @<DomxCore_procInit> @line<142> msg<Before Ipc_attach>
    N:Video P:1 #:00009 T:00000000|04fe645d S:Module<ti.omx> @<DomxCore_procInit> @line<149> msg<After Ipc_attach>
    N:VPSS  P:2 #:00008 T:00000000|7ae3af89 S:Module<ti.omx> Entering<DomxCore_procInit> @line<116>
    N:Video P:1 #:00010 T:00000000|04fec8c5 S:Module<ti.omx> @<DomxCore_procInit> @line<151> msg<Ipc_attach successful>
    N:VPSS  P:2 #:00009 T:00000000|7b3302f9 S:Module<ti.omx> @<DomxCore_procInit> @line<156> msg<Before Ipc_attach>
    N:Video P:1 #:00011 T:00000000|04ff6ae9 S:Module<ti.omx> @<OmxRpc_moduleRegisterMsgqHeap> @line<921> msg<Before MessageQ_registerHeap>
    N:VPSS  P:2 #:00010 T:00000000|8132e5af S:Module<ti.omx> @<DomxCore_procInit> @line<163> msg<After Ipc_attach>
    N:Video P:1 #:00012 T:00000000|04ffcb49 S:Module<ti.omx> @<OmxRpc_moduleRegisterMsgqHeap> @line<926> msg<After MessageQ_registerHeap>
    N:VPSS  P:2 #:00011 T:00000000|81334bb9 S:Module<ti.omx> @<DomxCore_procInit> @line<165> msg<Ipc_attach successful>
    N:Video P:1 #:00013 T:00000000|050029ab S:Module<ti.omx> Leaving<DomxCore_procInit> @line<207> with error<0:ErrorNone>
    N:VPSS  P:2 #:00012 T:00000000|8133ed93 S:Module<ti.omx> @<OmxRpc_moduleRegisterMsgqHeap> @line<921> msg<Before MessageQ_registerHeap>
    N:Video P:1 #:00014 T:00000000|0500a0bf S:@ omxrpc_rcm_server_create: rcmServerName OmxRpcRcmServer_1, priority 14
    N:VPSS  P:2 #:00013 T:00000000|81344cf1 S:Module<ti.omx> @<OmxRpc_moduleRegisterMsgqHeap> @line<926> msg<After MessageQ_registerHeap>
    N:Video P:1 #:00015 T:00000000|0500efb9 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<225> msg<Before RcmServer_Params_init>
    N:VPSS  P:2 #:00014 T:00000000|8134aa09 S:Module<ti.omx> Leaving<DomxCore_procInit> @line<207> with error<0:ErrorNone>
    N:Video P:1 #:00016 T:00000000|05014d8d S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<229> msg<After RcmServer_Params_init>
    N:VPSS  P:2 #:00015 T:00000000|8135257b S:@ omxrpc_rcm_server_create: rcmServerName OmxRpcRcmServer_2, priority 14
    N:Video P:1 #:00017 T:00000000|0501a705 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<232> msg<Before RcmServer_create>
    N:VPSS  P:2 #:00016 T:00000000|81357389 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<225> msg<Before RcmServer_Params_init>
    N:Video P:1 #:00018 T:00000000|05070857 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<240> msg<After RcmServer_create>
    N:VPSS  P:2 #:00017 T:00000000|8135d449 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<229> msg<After RcmServer_Params_init>
    N:Video P:1 #:00019 T:00000000|050770df S:@ omxrpc_rcm_server_remote_fxn_register regFxnCategory 0
    N:VPSS  P:2 #:00018 T:00000000|81363213 S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<232> msg<Before RcmServer_create>
    N:Video P:1 #:00020 T:00000000|0507bb61 S:Calling RcmServer_addSymbol(OmxRpcGetHandle)
    N:VPSS  P:2 #:00019 T:00000000|813bfc4b S:Module<ti.omx> @<omxrpc_rcm_server_create> @line<240> msg<After RcmServer_create>
    N:Video P:1 #:00021 T:00000000|05082955 S:Calling RcmServer_addSymbol(OmxRpcFreeHandle)
    N:VPSS  P:2 #:00020 T:00000000|813c665f S:@ omxrpc_rcm_server_remote_fxn_register regFxnCategory 0
    N:Video P:1 #:00022 T:00000000|05087ed9 S:Calling RcmServer_addSymbol(OmxRpcCreateProxyLite)
    N:VPSS  P:2 #:00021 T:00000000|813caed3 S:Calling RcmServer_addSymbol(OmxRpcGetHandle)
    N:Video P:1 #:00023 T:00000000|0508d25f S:Calling RcmServer_addSymbol(OmxRpcGetHeapMemStats)
    N:VPSS  P:2 #:00022 T:00000000|813d2b81 S:Calling RcmServer_addSymbol(OmxRpcFreeHandle)
    N:Video P:1 #:00024 T:00000000|0509240f S:Calling RcmServer_addSymbol(OmxRpcDeleteProxyLite)
    N:VPSS  P:2 #:00023 T:00000000|813d8a1b S:Calling RcmServer_addSymbol(OmxRpcCreateProxyLite)
    N:Video P:1 #:00025 T:00000000|05097b87 S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<256> msg<Before RcmServer_start>
    N:VPSS  P:2 #:00024 T:00000000|813de4e1 S:Calling RcmServer_addSymbol(OmxRpcGetHeapMemStats)
    N:Video P:1 #:00026 T:00000000|050a009b S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<258> msg<After RcmServer_start>
    N:VPSS  P:2 #:00025 T:00000000|813e3bb5 S:Calling RcmServer_addSymbol(OmxRpcDeleteProxyLite)
    N:VPSS  P:2 #:00026 T:00000000|813e99c3 S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<256> msg<Before RcmServer_start>
    N:VPSS  P:2 #:00027 T:00000000|813f343d S:Module<ti.omx> @<omxrpc_rcm_server_start> @line<258> msg<After RcmServer_start>
    N:VPSS  P:2 #:00028 T:00000000|d8f2d3dd S:FATAL ERROR: ErrorCode:0x1. Unhandled Exception:
    N:VPSS  P:2 #:00029 T:00000000|d8f31da9 S:Exception occurred in ThreadType_SWI
    N:VPSS  P:2 #:00030 T:00000000|d8f35163 S:handle: 0x9f298af4.
    N:VPSS  P:2 #:00031 T:00000000|d8f3804b S:stack base: 0x9f36dcf4.
    N:VPSS  P:2 #:00032 T:00000000|d8f3afa7 S:stack size: 0x4000.
    N:VPSS  P:2 #:00033 T:00000000|d8f3e04d S:R0 = 0x68004808  R8  = 0x00000001
    N:VPSS  P:2 #:00034 T:00000000|d8f418d7 S:R1 = 0x00000000  R9  = 0x000017b4
    N:VPSS  P:2 #:00035 T:00000000|d8f45133 S:R2 = 0x9f29f248  R10 = 0x9f36d9b8
    N:VPSS  P:2 #:00036 T:00000000|d8f48929 S:R3 = 0xe0826001  R11 = 0x9f36dc88
    N:VPSS  P:2 #:00037 T:00000000|d8f4c417 S:R4 = 0x68004808  R12 = 0x9f5c15b0
    N:VPSS  P:2 #:00038 T:00000000|d8f4fd27 S:R5 = 0x9f35bb54  SP(R13) = 0x9f35db30
    N:VPSS  P:2 #:00039 T:00000000|d8f539cd S:R6 = 0x00000001  LR(R14) = 0x9f5d21e3
    N:VPSS  P:2 #:00040 T:00000000|d8f57295 S:R7 = 0x9f36d9a4  PC(R15) = 0x9f5c176e
    N:VPSS  P:2 #:00041 T:00000000|d8f5ae7d S:PSR = 0x61000200
    N:VPSS  P:2 #:00042 T:00000000|d8f5dbe3 S:ICSR = 0x00400803
    N:VPSS  P:2 #:00043 T:00000000|d8f60941 S:MMFSR = 0x00
    N:VPSS  P:2 #:00044 T:00000000|d8f63379 S:BFSR = 0x82
    N:VPSS  P:2 #:00045 T:00000000|d8f65df5 S:UFSR = 0x0000
    N:VPSS  P:2 #:00046 T:00000000|d8f6887b S:HFSR = 0x40000000
    N:VPSS  P:2 #:00047 T:00000000|d8f6b7a9 S:DFSR = 0x00000000
    N:VPSS  P:2 #:00048 T:00000000|d8f6e3d9 S:MMAR = 0xe0826005
    N:VPSS  P:2 #:00049 T:00000000|d8f7120c S:BFAR = 0xe0826005
    N:VPSS  P:2 #:00050 T:00000000|d8f73f1d S:AFSR = 0x00000000
    N:VPSS  P:2 #:00051 T:00000000|d8f76c33 S:FATAL ERROR: ErrorCode:0x1. Terminating Execution...
    I found there is an error
    N:VPSS  P:2 #:00007 T:00000000|9270e8a1 S:Error in Vps_platformDeviceInit retVal: -1
    and now there is no display from my hdmi and the omx capture demo stopped at
    configureUiaLoggerClient(2, &uiaCfg);
    configureUiaLoggerClient(1, &uiaCfg);
    Can you give me some advise about this?
    Thank you.
    Lei
  • Andreas,
          I have the same application problem as you, I want to capture external video source through FPGA to VIN0 without tvp7002.But know,I donnot how to change the program, which examples can I reference?
          I found Andreas have solve this problem, can you give me some advise on how to solve this problem.
    puyol.
  • Here is the best thread I have found that discusses how to capture video data without using the TVP7002:
    http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/716/t/160009.aspx?PageIndex=1
    If you want to get the second video input channel working as well then that's another question entirely (which I'm trying to solve at the moment......).
