DVRRDK_03.50.00.05 problem
Other Parts Discussed in Thread: TVP5158
Dear all,
I am trying to upgrade from DVRRDK_03.00.01.03 to DVRRDK_03.50.00.05 on our customized DM8168 platform.
And I meet some problems:
I followed the instructions from DM81xx_DVR_RDK_Install_Guide.pdf released with DVRRDK_03.50.00.05
to build the whole system with 2GB DDR memory build and flashed u-boot, Linux kernel, ubifs rootfs into NAND flash.
When I tried to run DVR application, some error messages showed:
root@dm816x:/opt/dvr_rdk/ti816x# ./init.sh
*** Bootargs Validated for mem param ***
*** Bootargs Validated for notifyk.vpssm3 params ***
*** This RDK version requires LINUX_BASE_ADDRESS=0xc0000000.Recompile uImage ***
Cmd to rebuild uImage@0xc0000000:mkimage -A arm -O linux -T kernel -C none -a 0xc0008000 -e 0xc0008000 -n 'Linux-2.6.37' -d arch/arm/boot/zImage uImage
Refer http://processors.wiki.ti.com/index.php/DM816x_AM389x_PSP_User_Guide#Auto_detection_of_Kernel_Load_Address_and_Run_Time_RAM_Base_Determination
Kernel bootargs mismatch.!!!!ABORTING!!!
Then I followed the mentioned web page in error message: http://processors.wiki.ti.com/index.php/DM816x_AM389x_PSP_User_Guide#Auto_detection_of_Kernel_Load_Address_and_Run_Time_RAM_Base_Determination
to build Linux kernel with RAM base 0xc0000000 and retried to run DVR application again.
Other error messages showed:
*** Kernel Base address validated ***
Kernel bootargs validated
numid=101,iface=MIXER,name='Left DAC Mux'
; type=ENUMERATED,access=rw------,values=1,items=3
; Item #0 'DAC_L1'
; Item #1 'DAC_L3'
; Item #2 'DAC_L2'
: values=2
numid=99,iface=MIXER,name='Right DAC Mux'
; Item #0 'DAC_R1'
; Item #1 'DAC_R3'
; Item #2 'DAC_R2'
: values=2
[c6xdsp ] Remote Debug Shared Memory @ 0xbfd00000
[m3video] Remote Debug Shared Memory @ 0xbfd05020
[m3vpss ] Remote Debug Shared Memory @ 0xbfd0a040
SysLink version : 2.20.02.20
SysLink module created on Date:Dec 28 2012 Time:16:58:47
Trace enabled
Trace SetFailureReason enabled
Setting DMM priority for [DUCATI ] to [0] ( 0x4e000624 = 0x08000000 )
Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a )
Setting DMM priority for [HDVICP1 ] to [2] ( 0x4e000634 = 0x000a0000 )
Setting DMM priority for [HDVICP2 ] to [2] ( 0x4e000634 = 0x00a00000 )
*** TVP5158 probe : START ***
TI VS EVM : TVP5158 device address : 0x58, 0x5a, 0x5c, 0x5e
TI DVR : TVP5158 device address : 0x5c, 0x5d, 0x5e, 0x5f
Device found : I2C (0xXX): 0x08 = 0x51
I2C (0xXX): 0x09 = 0x58
Device NOT found : I2C (0xXX): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x58): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x5a): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x5c): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x5d): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x5e): Read ERROR !!! (reg[0x08], count = 2)
I2C (0x5f): Read ERROR !!! (reg[0x08], count = 2)
*** TVP5158 probe : END ***
/opt/dvr_rdk/ti816x
root@dm816x:/opt/dvr_rdk/ti816x# ./load.sh
Attached to slave procId 2.
Loaded file ../firmware/dvr_rdk_fw_m3vpss_2048M_512M.xem3 on slave procId 2.
Started slave procId 2.
After Ipc_loadcallback status [0x00000000]
[m3vpss ] ***** SYSTEM : Frequency <ORG> - 250000000, <NEW> - 274909088
[m3vpss ] notify_attach rtnVal 0
[m3vpss ] initProxyServer rtnVal 0
[m3vpss ]
[m3vpss ] *** UTILS: CPU KHz = 549818 Khz ***
[m3vpss ]
[m3vpss ] 35: SYSTEM : System Common Init in progress !!!
[m3vpss ] 36: SYSTEM: IPC init in progress !!!
[m3vpss ] 36: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 1035: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 1037: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
After Ipc_startcallback status [0x00000000]
[m3vpss ] 1037: SYSTEM: Attaching to [DSP] ...
Attached to slave procId 1.
Loaded file ../firmware/dvr_rdk_fw_m3video_2048M_512M.xem3 on slave procId 1.
Started slave procId 1.
[m3video] ***** SYSTEM : Frequency <ORG> - 250000000, <NEW> - 274909088
[m3video]
[m3video] *** UTILS: CPU KHz = 549818 Khz ***
[m3video]
[m3video] 1439: SYSTEM : System Common Init in progress !!!
[m3video] 1439: SYSTEM: IPC init in progress !!!
[m3video] 1440: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 2037: SYSTEM: Attaching to [DSP] ...
[m3video] 2439: SYSTEM: Attaching to [HOST] ...
[m3video] 2441: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3video] 2441: SYSTEM: Attaching to [DSP] ...
Attached to slave procId 0.
Loaded file ../firmware/dvr_rdk_fw_c6xdsp_2048M_512M.xe674 on slave procId 0.
Started slave procId 0.
[c6xdsp ] ***** SYSTEM : Frequency <ORG> - 800000000, <NEW> - 1000000000
[c6xdsp ]
[c6xdsp ] *** UTILS: CPU KHz = 1000000 Khz ***
[c6xdsp ]
[c6xdsp ] 5: SYSTEM : System Common Init in progress !!!
[c6xdsp ] 5: SYSTEM: IPC init in progress !!!
[c6xdsp ] 5: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 3037: SYSTEM: Attaching to [DSP] ...
[m3video] 3441: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 1012: SYSTEM: Attaching to [HOST] ...
[c6xdsp ] 1015: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[c6xdsp ] 1015: SYSTEM: Attaching to [VIDEO-M3] ...
DMA: Module install successful, device major num = 250
DRV: Module install successful
DRV: Module built on Dec 28 2012 16:59:21
[m3vpss ] 4037: SYSTEM: Attaching to [DSP] ...
[m3video] 4441: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2021: SYSTEM: Attaching to [VIDEO-M3] ...
[m3vpss ] 5037: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2818: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3video] 5441: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 2818: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 5441: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[m3video] 5441: SYSTEM: Attaching to [VPSS-M3] ...
[m3vpss ] 6037: SYSTEM: Attaching to [DSP] ...
[m3video] 6441: SYSTEM: Attaching to [VPSS-M3] ...
[c6xdsp ] 3825: SYSTEM: Attaching to [VPSS-M3] ...
[m3vpss ] 7037: SYSTEM: Attaching to [DSP] ...
[c6xdsp ] 4414: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 7037: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[c6xdsp ] 4414: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_0] ...
[m3vpss ] 7037: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 4414: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
[c6xdsp ] 4414: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
[c6xdsp ] 4415: SYSTEM: Notify register to [HOST] line 0, event 15 ...
[c6xdsp ] 4415: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
[c6xdsp ] 4415: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
[c6xdsp ] 4415: SYSTEM: IPC init DONE !!!
[c6xdsp ] 4416: MEM: Shared Region 2: Base = 0x96000000, Length = 0x28000000 (640 MB)
[c6xdsp ] 4416: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4426: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4436: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4446: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4456: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4466: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4476: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4487: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4497: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4507: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4517: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4527: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4537: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4547: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4557: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4567: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4577: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4587: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4597: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4607: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4617: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4628: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4638: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4648: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4658: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4668: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4678: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4688: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4698: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4708: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4718: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4728: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4738: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4748: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4758: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4769: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4779: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4789: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4799: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4809: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4819: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[m3video] 7441: SYSTEM: Attaching to [VPSS-M3] ...
[c6xdsp ] 4829: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4839: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4849: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4859: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4869: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4879: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4889: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4899: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4910: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4920: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4930: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4940: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4950: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4960: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4970: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4980: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 4990: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5000: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5010: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5020: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5030: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5040: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5051: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5061: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5071: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5081: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5091: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5101: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5111: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5121: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5131: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5141: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5151: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5161: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5171: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5181: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5192: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5202: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5212: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5222: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5232: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5242: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5252: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5262: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5272: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5282: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5292: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5302: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5312: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5322: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5333: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5343: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5353: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5363: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5373: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5383: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5393: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5403: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5413: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)
[c6xdsp ] 5423: MEM: Shared Region 1: Base = 0x80000000, Length = 0x11600000 (278 MB)
[m3video] 8037: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 8037: SYSTEM: Attaching to [VIDEO-M3] ...
[c6xdsp ] 5424: SYSTEM : System Common Init Done !!!
[m3video] 8037: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_1] ...
[m3vpss ] 8037: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[c6xdsp ] 5380: SYSTEM : System DSP Init in progress !!!
[m3video] 8038: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[m3vpss ] 8037: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_2] ...
[m3video] 8038: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[m3vpss ] 8038: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[m3video] 8039: SYSTEM: Notify register to [HOST] line 0, event 15 ...
[m3vpss ] 8038: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[c6xdsp ] 5380: SYSTEM : RpeServer_init() done... Ret Val 0!!!
[m3video] 8040: SYSTEM: Notify register to [DSP] line 0, event 15 ...
[m3vpss ] 8039: SYSTEM: Notify register to [HOST] line 0, event 15 ...
[m3video] 8040: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
[m3vpss ] 8040: SYSTEM: Notify register to [DSP] line 0, event 15 ...
[m3video] 8040: SYSTEM: IPC init DONE !!!
[m3vpss ] 8040: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
[m3video] 8046: MEM: Shared Region 2: Base = 0x96000000, Length = 0x28000000 (640 MB)
[m3vpss ] 8040: SYSTEM: IPC init DONE !!!
[m3video] 8046: MEM: Shared Region 1: Base = 0x80000000, Length = 0x11600000 (278 MB)
[m3vpss ] 8045: MEM: Shared Region 2: Base = 0x96000000, Length = 0x28000000 (640 MB)
[m3vpss ] 8046: MEM: Shared Region 1: Base = 0x80000000, Length = 0x11600000 (278 MB)
[c6xdsp ] 5426: SYSTEM: Creating ListMP [DSP_IPC_OUT_19] in region 0 ...
[m3video] 8048: SYSTEM : System Common Init Done !!!
[m3vpss ] 8047: SYSTEM : System Common Init Done !!!
[c6xdsp ] 5426: SYSTEM: Creating ListMP [DSP_IPC_IN_19] in region 0 ...
[m3video] 8048: SYSTEM : System Video Init in progress !!!
[m3vpss ] 8048: SYSTEM : System VPSS Init in progress !!!
[c6xdsp ] 5426: SYSTEM: ListElem Shared Addr = 0xbe1b7300
[m3video] 8048: SYSTEM : System Video Init Done !!!
[m3vpss ] === HDVPSS Clocks are enabled ===
[c6xdsp ] 5427: SYSTEM: Creating ListMP [DSP_IPC_OUT_20] in region 0 ...
[m3video] 8048: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[m3vpss ] === HDVPSS is fully functional ===
[c6xdsp ] 5427: SYSTEM: Creating ListMP [DSP_IPC_IN_20] in region 0 ...
[m3video] 8049: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[m3vpss ] === HDVPSS module is not in standby ===
[c6xdsp ] 5427: SYSTEM: ListElem Shared Addr = 0xbe1dab80
[m3video] 8049: SYSTEM: ListElem Shared Addr = 0xbe1b3e00
[m3vpss ] === I2C1 Clk is active ===
[c6xdsp ] 5427: SYSTEM: Creating ListMP [DSP_IPC_OUT_21] in region 0 ...
[m3video] 8051: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to VPS_PLATFORM_CPU_REV_2_0
[c6xdsp ] 5427: SYSTEM: Creating ListMP [DSP_IPC_IN_21] in region 0 ...
[m3video] 8051: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[m3vpss ] 8053: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[c6xdsp ] 5428: SYSTEM: ListElem Shared Addr = 0xbe1fe400
[m3video] 8051: SYSTEM: ListElem Shared Addr = 0xbe222200
[m3vpss ] 8054: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[c6xdsp ] 5428: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
[m3video] 8057: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_19] in region 0 ...
[m3vpss ] 8054: SYSTEM: ListElem Shared Addr = 0xbe260780
[c6xdsp ] 5428: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
[m3video] 8057: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_19] in region 0 ...
[m3vpss ] 8056: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[c6xdsp ] 5428: SYSTEM: ListElem Shared Addr = 0xbe225180
[m3video] 8057: SYSTEM: ListElem Shared Addr = 0xbe267180
[m3vpss ] 8056: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[c6xdsp ] 5429: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
[m3video] 8060: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_20] in region 0 ...
[m3vpss ] 8057: SYSTEM: ListElem Shared Addr = 0xbe263c80
[c6xdsp ] 5429: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
[m3video] 8060: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_20] in region 0 ...
[m3vpss ] 8071: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_19] in region 0 ...
[c6xdsp ] 5429: SYSTEM: ListElem Shared Addr = 0xbe242c80
[m3video] 8060: SYSTEM: ListElem Shared Addr = 0xbe28aa00
[m3vpss ] 8071: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_19] in region 0 ...
[c6xdsp ] !!WARNING.Resource already registered:2
[c6xdsp ] 5385: SYSTEM : Initializing Links !!!
[m3video] 8063: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_21] in region 0 ...
[m3vpss ] 8071: SYSTEM: ListElem Shared Addr = 0xbe2d1b00
[m3video] 8063: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_21] in region 0 ...
[m3vpss ] 8074: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_20] in region 0 ...
[c6xdsp ] 5429: SYSTEM : FREE SPACE : System Heap = 10391168 B, Mbx = 10240 msgs)
[m3video] 8063: SYSTEM: ListElem Shared Addr = 0xbe2ae280
[m3vpss ] 8074: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_20] in region 0 ...
[m3video] 8077: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_24] in region 0 ...
[m3vpss ] 8074: SYSTEM: ListElem Shared Addr = 0xbe2f5380
[c6xdsp ] 5393: SYSTEM : Initializing Links ... DONE !!!
[m3video] 8077: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_24] in region 0 ...
[m3vpss ] 8076: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_21] in region 0 ...
[m3video] 8077: SYSTEM: ListElem Shared Addr = 0xbe33c480
[m3vpss ] 8077: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_21] in region 0 ...
[c6xdsp ] 5394: SYSTEM : System DSP Init Done !!!
[m3video] 8079: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_25] in region 0 ...
[m3vpss ] 8077: SYSTEM: ListElem Shared Addr = 0xbe319180
[m3video] 8080: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_25] in region 0 ...
[m3vpss ] 8079: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[m3video] 8080: SYSTEM: ListElem Shared Addr = 0xbe359f80
[m3vpss ] 8079: SYSTEM : FVID2 Init in progress !!!
[m3video] 8081: HDVICP: Doing PRCM for IVAHD[0] ...
[m3vpss ] 8152: SYSTEM : FVID2 Init in progress DONE !!!
[m3video] 8081: HDVICP: PRCM for IVAHD[0] ... DONE.
[m3vpss ] 8152: SYSTEM : Device Init in progress !!!
[m3video] 8082: HDVICP: Doing PRCM for IVAHD[1] ...
[m3video] 8082: HDVICP: PRCM for IVAHD[1] ... DONE.
[m3vpss ] initPrms.isI2cInitReq = 0
[m3video] 8082: HDVICP: Doing PRCM for IVAHD[2] ...
[m3video] 8082: HDVICP: PRCM for IVAHD[2] ... DONE.
[m3video] 8082: SYSTEM : Initializing Links !!!
[m3vpss ] 8155: SYSTEM : Device Init in progress DONE !!!
[m3vpss ] 8195: SYSTEM : System VPSS Init Done !!!
[m3video] 8082: SYSTEM : FREE SPACE : System Heap = 6279304 B, Mbx = 10240 msgs)
[m3vpss ] 8195: UTILS: DMA: HWI Create for INT63 !!!
[m3vpss ] 8196: SYSTEM : Initializing Links !!!
[m3video] 8082: SYSTEM : FREE SPACE : SR0 Heap = 20482944 B (19 MB)
[m3vpss ] 8196: SYSTEM : FREE SPACE : System Heap = 74024 B, Mbx = 10240 msgs)
[m3video] 8083: SYSTEM : FREE SPACE : Frame Buffer = 671088512 B (639 MB)
[m3vpss ] 8196: SYSTEM : FREE SPACE : SR0 Heap = 20482944 B (19 MB)
[m3video] 8083: SYSTEM : FREE SPACE : Bitstream Buffer = 291504000 B (277 MB)
[m3vpss ] 8196: SYSTEM : FREE SPACE : Frame Buffer = 666778496 B (635 MB)
[m3video] 8083: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[m3video] 8083: SYSTEM : FREE SPACE : Tiler 8-bit = 134217728 B (128 MB) - TILER ON
[m3vpss ] 8196: SYSTEM : FREE SPACE : Bitstream Buffer = 291504000 B (277 MB)
[m3vpss ] Received character 's'
[m3video] Received character 's'
[m3video] 8084: SYSTEM : FREE SPACE : Tiler 16-bit[module] vpss probe done.
[m3vpss ] 8197: SYSTEM : FREE SPACE : Tiler 8-bit = 134217728 B (128 MB) - TILER ON
[c6xdsp ] Received character 's'
/opt/dvr_rdk/ti816x
[m3video] 8119: S[module] ti81xxfb probe done.
[m3vpss ] 8197: SYSTEM : FREE SPACE : Tiler 16-bit = 134217728 B (128 MB) - TILER ON
[m3vpss ] 8314: SYSTEM : InitializiHDMI W1 rev 2.0
ng Links ... DONHDMI CEC Spec version 1.2
E !!!
[m3vpss[module] ti81xx_hdmi probe done.
] 8314: SYSTEM : Set Static L3 pressure for HDVPSS as High
## Interface is 1 [0:DVI, 1:HDMI]
ORG 0x46c00524: 0
NEW 0x46c00524: 2
However, I could run DEC + DIS test case successfully though these messages showed.
My questions are:
1. Is it correct to set Linux kernel RAM base to 0xc0000000 myself to successfully execute ./init.sh ?
2. Does the "[c6xdsp ] 5222: MEM: ERROR: SharedRegion_setEntry (2, 0x95555bfc) FAILED !!! (status=-1)" message matter?
Thanks a lot.
Phil
  • 1. Is it correct to set Linux kernel RAM base to 0xc0000000 myself to successfully execute ./init.sh ?
       - Yes you have to rebuild uImage to set base to 0xc000_0000.The init.sh script checks this.
       - The msg is not an issue.DSP is waiting for M3 VPSS to setup sharedRegion and will retry until it succeeds.Once M3VPSS sets up shared region it proceeds. THere is no problem due to this.
  • Thanks for your reply
  • I work with SDK4.0, when i run: ./load.sh
    i got it:
     ]  10: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
     [m3video]  30710: MEM: Shared Region i=0,2: Base = 0xae000000, Length = 0x10900000 (265 MB)
     [m3vpss ]  5483: MEM: Shared Region i=0,2: Base = 0xae000000, Length = 0x10900000 (265 MB)
     [c6xdsp ]  12: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
     [m3video]  30711: MEM: Shared Region i=1,1: Base = 0x90000000, Length = 0x0c600000 (198 MB)
     [m3vpss ]  5483: MEM: Shared Region i=1,1: Base = 0x90000000, Length = 0x0c600000 (198 MB)
     [c6xdsp ]  12: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP_0] ...
     [m3video]  30724: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
     [c6xdsp ]  12: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
     [m3video]  30725: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
     [c6xdsp ]  12: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
     [m3video]  30726: SYSTEM: ListElem Shared Addr = 0xbf273e00
     [c6xdsp ]  12: SYSTEM: Notify register to [HOST] line 0, event 15 ...
     [m3video]  30738: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
     [c6xdsp ]  12: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ...
     [m3video]  30739: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
     [m3vpss ]  5494: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
     [c6xdsp ]  13: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ...
     [m3video]  30740: SYSTEM: ListElem Shared Addr = 0xbf277300
     [m3vpss ]  5494: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
     [c6xdsp ]  13: SYSTEM: IPC init DONE !!!
     [m3video]  30774: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_19] in region 0 ...
     [m3vpss ]  5495: SYSTEM: ListElem Shared Addr = 0xbf27a800
     [c6xdsp ]  15: MEM: Shared Region i=0,2: Base = 0xae000000, Length = 0x10900000 (265 MB)
     [m3video]  30775: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_19] in region 0 ...
     [m3vpss ]  5497: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
     [c6xdsp ]  15: MEM: ERROR: SharedRegion_setEntry (2, 0x9ffa7bbc) FAILED !!!  (status=-1)
    Can you help me? Thanks.
  • There is no problem due to this error.What is the issue you are seeing ?
