how to compile new code and folder inside OMX demos in EZSDK
Hi all,
I am trying to compile a new code inside demos folder of OMX, but when I do make omx, the new code's executables are not in the bin folder.
I change the makefile in /ezsdk/component-sources/omx_05_02_00_48/examples
# CAPTURE->ENCODE->DECODE DISPLAY NT demo/app
capture_encode_decode_display: capture_encode_decode_displayhost
capture_encode_decode_displayhost:
ifeq ($(findstring make,$(BUILD_OPTIONS)),make)
    $(ECHO) \# Building $(subst host,,$@) executable for core: a8host
    $(MAKE) -C $($(subst host,,$@)_EXAMPLES_PATH) CORE=a8host
endif
but nothing happens.
What could I do? Any suggestion?
Inigo
    You should add it also in :
    <EZSDK>/component-sources/omx_05_02_00_48/src
    component.mk
    BR
    Margarita
  • Hello Margarita,
    1.  I write the next code in the component.mk file:
    # List of examples/demos under OMX
    omx_EXAMPLES_LIST = dm81xx
    omx_EXAMPLES_LIST_NONXDC = decode display decode_display capture_encode adec_snt c6xtest encode audio_encode decode_mosaicdisplay capture_encode_decode_display
    # OMX Demos/Examples
    decode_EXAMPLES_RELPATH = ti/omx/demos/decode
    decode_EXAMPLES_PATH = $(EXAMPLES_ROOT)/$(decode_EXAMPLES_RELPATH)
    display_EXAMPLES_RELPATH = ti/omx/demos/display
    display_EXAMPLES_PATH = $(EXAMPLES_ROOT)/$(display_EXAMPLES_RELPATH)
    decode_display_EXAMPLES_RELPATH = ti/omx/demos/decode_display
    decode_display_EXAMPLES_PATH = $(EXAMPLES_ROOT)/$(decode_display_EXAMPLES_RELPATH)
    capture_encode_EXAMPLES_RELPATH = ti/omx/demos/capture_encode
    capture_encode_EXAMPLES_PATH = $(EXAMPLES_ROOT)/$(capture_encode_EXAMPLES_RELPATH)
    c6xtest_EXAMPLES_RELPATH = ti/omx/demos/c6xtest
    c6xtest_EXAMPLES_PATH = $(EXAMPLES_ROOT)/$(c6xtest_EXAMPLES_RELPATH)
    adec_snt_EXAMPLES_RELPATH = ti/omx/demos/adec_snt
    adec_snt_EXAMPLES_PATH = $(EXAMPLES_ROOT)/$(adec_snt_EXAMPLES_RELPATH)
    encode_EXAMPLES_RELPATH = ti/omx/demos/encode
    encode_EXAMPLES_PATH = $(EXAMPLES_ROOT)/$(encode_EXAMPLES_RELPATH)
    audio_encode_EXAMPLES_RELPATH = ti/omx/demos/audio_encode
    audio_encode_EXAMPLES_PATH = $(EXAMPLES_ROOT)/$(audio_encode_EXAMPLES_RELPATH)
    decode_mosaicdisplay_EXAMPLES_RELPATH = ti/omx/demos/decode_mosaicdisplay
    decode_mosaicdisplay_EXAMPLES_PATH = $(EXAMPLES_ROOT)/$(decode_mosaicdisplay_EXAMPLES_RELPATH)
    omxobjs_EXAMPLES_RELPATH = ti/omx/demos/omxobjs
    omxobjs_EXAMPLES_PATH = $(EXAMPLES_ROOT)/$(omxobjs_EXAMPLES_RELPATH)
    dm81xx_EXAMPLES_RELPATH = ti/omx/demos/dm81xx
    dm81xx_EXAMPLES_PATH = $(EXAMPLES_ROOT)/$(dm81xx_EXAMPLES_RELPATH)
    capture_encode_decode_display_EXAMPLES_RELPATH = ti/omx/demos/capture_encode_decode_display
    capture_encode_decode_display_EXAMPLES_PATH = $(EXAMPLES_ROOT)/$(capture_encode_decode_display_EXAMPLES_RELPATH)
    2.  I add the code and the folder in the path:
    <EZSDK>/component-sources/omx_05_02_00_48/examples/ti/omx/demos$ ls
    adec_snt      c6xtest         capture_encode_decode_display         common  decode_display        display  encode
    audio_encode  capture_encode  Capture_encode_decode_display.tar.gz  decode  decode_mosaicdisplay  dm81xx   omxobjs
    3. I execute make omx in the <EZSDK> path, but in the <EZSDK>/component-sources/omx_05_02_00_48/bin a capture_encode_decode_display folder doesn't appear, despite the other demos appear and create the bin and obj folders.
    Why I can't create the bin and obj folder for the new demo?
    RB,
    Inigo
    The  mkdir is in the common.mk file.
    Here is example (decode_display_test), which you could follow:
    Path: /EZSDK/component-sources/omx_05_02_00_48/examples
    FIle: makefile
    Added:
    decode_display_test: decode_display_testhost
    decode_display_testhost:
    endif
    Path: /EZSDK/component-sources/omx_05_02_00_48/examples/ti/omx/demos/decode_display_test
    file: makefile
    added: APP_NAME = decode_display_test
    Path: /EZSDK/component-sources/omx_05_02_00_48/src
    file : component.mk
    add:
    omx_EXAMPLES_LIST_NONXDC = decode display decode_display capture_encode adec_snt c6xtest encode audio_encode decode_mosaicdisplay decode_display_test
    decode_display_test_EXAMPLES_RELPATH = ti/omx/demos/decode_display_test
    decode_display_test_EXAMPLES_PATH = $(EXAMPLES_ROOT)/$(decode_display_test_EXAMPLES_RELPATH)
    File: makefile
    endif
    Please let me know if you need further details.
    BR
    Margarita
    I followed step by step all you say, but when I do make omx, all the demos compile except the new one.
    here I paste the log:
    sudo make omx | more
    make -C /usr/local/ezsdk/component-sources/omx_05_02_00_48/src ROOTDIR=/usr/local/ezsdk/component-sources/omx_05_02_00_48 EXTERNAL_SW_ROOT=/
    usr/local/ezsdk/component-sources INTERNAL_SW_ROOT=/usr/local/ezsdk/component-sources/omx_05_02_00_48/src kernel_PATH=/usr/local/ezsdk/board
    -support/linux-2.6.37-psp04.04.00.01 bios_PATH=/usr/local/ezsdk/component-sources/bios_6_33_05_46 fc_PATH=/usr/local/ezsdk/component-sources
    /framework_components_3_22_01_07 osal_PATH=/usr/local/ezsdk/component-sources/osal_1_22_01_09 xdais_PATH=/usr/local/ezsdk/component-sources/
    xdais_7_22_00_03 linuxutils_PATH=/usr/local/ezsdk/component-sources/linuxutils_3_22_00_02 ce_PATH=/usr/local/ezsdk/component-sources/codec_e
    ngine_3_22_01_06 aaclcdec_PATH=/usr/local/ezsdk/component-sources/c674x-aaclcdec_01_41_00_00_elf ipc_PATH=/usr/local/ezsdk/component-sources
    /ipc_1_24_03_32 syslink_PATH=/usr/local/ezsdk/component-sources/syslink_2_20_02_20 xdc_PATH=/usr/local/ezsdk/component-sources/xdctools_3_23
    _03_53 uia_PATH=/usr/local/ezsdk/component-sources/uia_1_01_01_14 slog_PATH=/usr/local/ezsdk/component-sources/slog_04_00_00_02 lindevkit_PA
    TH=/usr/local/ezsdk/linux-devkit/arm-none-linux-gnueabi/usr PLATFORM=ti816x-evm EXAMPLES_ROOT=/usr/local/ezsdk/component-sources/omx_05_02_0
    0_48/examples CODEGEN_PATH_A8=/root/CodeSourcery/Sourcery_G++_Lite/ CROSS_COMPILE=arm-none-linux-gnueabi- TOOLCHAIN_LONGNAME=arm-none-linux-
    gnueabi CODEGEN_PATH_DSPELF=/usr/local/ezsdk/dsp-devkit/cgt6x_7_3_4 libs
    /bin/sh: line 0: cd: src: No such file or directory
    /bin/sh: line 0: cd: bin: No such file or directory
    /bin/sh: line 0: cd: lib: No such file or directory
    make[1]: Entering directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/src'
    # Building omxobjs executable for core: a8host
    make -C /usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/omxobjs CORE=a8host
    make[2]: Entering directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/omxobjs'
    # Making ti816x-evm:a8host:debug:domx...
    make -C /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/omx/domx
    make[3]: Entering directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/omx/domx'
    make[3]: Nothing to be done for `all'.
    make[3]: Leaving directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/omx/domx'
    # Making ti816x-evm:a8host:debug:domx_delegates_shmem...
    make -C /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/omx/domx/delegates/shmem
    make[3]: Entering directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/omx/domx/delegates/shmem'
    make[3]: Leaving directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/omx/domx/delegates/shmem'
    # Making ti816x-evm:a8host:debug:omxcore...
    make -C /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/omx/omxcore
    make[3]: Entering directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/omx/omxcore'
    make[3]: Leaving directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/omx/omxcore'
    # Making ti816x-evm:a8host:debug:memcfg...
    make -C /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/omx/memcfg
    make[3]: Entering directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/omx/memcfg'
    make[3]: Leaving directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/omx/memcfg'
    # Making ti816x-evm:a8host:debug:timmosal...
    make -C /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/timmosal
    make[3]: Entering directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/timmosal'
    --More--/bin/sh: line 0: cd: src: No such file or directory
    warning: entry-point symbol other than "_c_int00" specified:
       "ti_sysbios_family_c64p_Hwi0"
    make[3]: Leaving directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/timmosal'
    # Linking into /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/omxobjs/bin/ti816x-evm/omxobjs_a8host_debug.xv5T
    /root/CodeSourcery/Sourcery_G++_Lite//bin/arm-none-linux-gnueabi-gcc -Xlinker --start-group  /usr/local/ezsdk/component-sources/omx_05_02_00
    _48/src/../lib/omxobjs/obj/ti816x-evm/a8host/debug/main.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/omxobjs/obj/ti81
    6x-evm/a8host/debug/domx_cfg.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/omxobjs/obj/ti816x-evm/a8host/debug/domxPro
    xyWrappers.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/omxobjs/obj/ti816x-evm/a8host/debug/domx_delegates_shmem_cfg.
    ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/omxobjs/obj/ti816x-evm/a8host/debug/omxcore_cfg.ov5T  /usr/local/ezsdk/c
    omponent-sources/omx_05_02_00_48/src/../lib/omxobjs/obj/ti816x-evm/a8host/debug/memtbl_cfg.ov5T /usr/local/ezsdk/component-sources/omx_05_02
    _00_48/src/../lib/ti/omx/domx/lib/a8host/debug/domx.av5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/ti/omx/domx/delegates
    /shmem/lib/a8host/debug/domx_delegates_shmem.av5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/ti/omx/omxcore/lib/a8host/de
    bug/omxcore.av5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/ti/omx/memcfg/lib/a8host/debug/memcfg.av5T /usr/local/ezsdk/c
    omponent-sources/omx_05_02_00_48/src/../lib/ti/timmosal/lib/a8host/debug/timmosal.av5T  /usr/local/ezsdk/component-sources/osal_1_22_01_09/p
    ackages/linuxdist/build/lib/osal.a /usr/local/ezsdk/component-sources/osal_1_22_01_09/packages/linuxdist/cstubs/lib/cstubs.a /usr/local/ezsd
    k/component-sources/framework_components_3_22_01_07/packages/ti/sdo/rcm/lib/debug/rcm_syslink.av5T /usr/local/ezsdk/component-sources/framew
    ork_components_3_22_01_07/packages/ti/sdo/fc/memutils/lib/release/memutils.av5T /usr/local/ezsdk/component-sources/osal_1_22_01_09/packages/
    ti/sdo/xdcruntime/linux/lib/debug/osal_linux_470.av5T /usr/local/ezsdk/component-sources/framework_components_3_22_01_07/packages/ti/sdo/fc/
    global/lib/debug/fcsettings.av5T /usr/local/ezsdk/component-sources/syslink_2_20_02_20/packages/ti/syslink/lib/syslink.a_debug /usr/local/ez
    sdk/component-sources/linuxutils_3_22_00_02/packages/ti/sdo/linuxutils/cmem/lib/cmem.a470MV /usr/local/ezsdk/component-sources/uia_1_01_01_1
    4/packages/ti/uia/linux/lib/servicemgr.a -lpthread -lrt -L/root/CodeSourcery/Sourcery_G++_Lite//arm-none-linux-gnueabi/lib      -Xlinker --e
    nd-group -o /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/omxobjs/bin/ti816x-evm/omxobjs_a8host_debug.xv5T
    # /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/omxobjs/bin/ti816x-evm/omxobjs_a8host_debug.xv5T created.
    make[2]: Leaving directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/omxobjs'
    cp /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/omxobjs/obj/ti816x-evm/a8host/debug/*.ov5T /usr/local/ezsdk/component-sourc
    rm /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/main.ov5T
    make -C /usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/omxobjs archive_spl CORE=a8host AR_SPL_PATH=/usr/local/ezsd
    k/component-sources/omx_05_02_00_48/src/../lib AR_SPL_NAME=omxcfg.av5T
    # [SPL] Archiving /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/domx_cfg.ov5T /usr/local/ezsdk/component-sources/omx_05_02_0
    0_48/src/../lib/domx_delegates_shmem_cfg.ov5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/domxProxyWrappers.ov5T /usr/loca
    l/ezsdk/component-sources/omx_05_02_00_48/src/../lib/memtbl_cfg.ov5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/omxcore_c
    fg.ov5T into /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/omxcfg.av5T...
    /root/CodeSourcery/Sourcery_G++_Lite//bin/arm-none-linux-gnueabi-ar cr /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/omxcfg.
    av5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/*.ov5T
    rm /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/*.ov5T
    make[1]: Leaving directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/src'
    gnueabi CODEGEN_PATH_DSPELF=/usr/local/ezsdk/dsp-devkit/cgt6x_7_3_4 DEST_ROOT=/usr/local/ezsdk/component-sources/omx_05_02_00_48/bin example
    s
    # Making XDC dependent packages for dm81xx:c6x
    make -f xdcdepmakefile _APP=dm81xx CORE=c6xdsp
    make[2]: Entering directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/src'
    cd /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/xdc/dm81xx && /usr/local/ezsdk/component-sources/xdctools_3_23_03_53/xdc -PD .
    making all: Wed Aug 28 14:55:43 CEST 2013 ...
    s
    ======== .interfaces [/usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/timmosal] ========
    gmake[1]: `.interfaces' is up to date.
    ======== .interfaces [/usr/local/ezsdk/component-sources/syslink_2_20_02_20/packages/ti/syslink/ipc/rtos] ========
    ======== .interfaces [/usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/xdc/dm81xx] ========
    .interfaces files complete: Wed Aug 28 14:55:43 CEST 2013.
    ======== .libraries [/usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/timmosal] ========
    gmake[1]: `.libraries' is up to date.
    ======== .libraries [/usr/local/ezsdk/component-sources/syslink_2_20_02_20/packages/ti/syslink/ipc/rtos] ========
    ======== .libraries [/usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/xdc/dm81xx] ========
    .libraries files complete: Wed Aug 28 14:55:44 CEST 2013.
    ======== .dlls [/usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/timmosal] ========
    gmake[1]: `.dlls' is up to date.
    ======== .dlls [/usr/local/ezsdk/component-sources/syslink_2_20_02_20/packages/ti/syslink/ipc/rtos] ========
    ======== .dlls [/usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/xdc/dm81xx] ========
    .dlls files complete: Wed Aug 28 14:55:44 CEST 2013.
    ======== .executables [/usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/timmosal] ========
    gmake[1]: `.executables' is up to date.
    ======== .executables [/usr/local/ezsdk/component-sources/syslink_2_20_02_20/packages/ti/syslink/ipc/rtos] ========
    ======== .executables [/usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/xdc/dm81xx] ========
    .executables files complete: Wed Aug 28 14:55:44 CEST 2013.
    ======== all [/usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/timmosal] ========
    # all files complete.
    ======== all [/usr/local/ezsdk/component-sources/syslink_2_20_02_20/packages/ti/syslink/ipc/rtos] ========
    ======== all [/usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/xdc/dm81xx] ========
    all files complete: Wed Aug 28 14:55:44 CEST 2013.
    make[2]: Leaving directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/src'
    # Configuring XDC packages for dm81xx:c6x
    make -C /usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/dm81xx xdc_configuro CORE=c6xdsp
    make[2]: Entering directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/dm81xx'
    # Invoking configuro...
    chmod a+x /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/maketemp_configuro_cmd_c6xdsp.bat
    egrep -ivw dm81xx_configuro  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/dm81xx/obj/ti816x-evm/c6xdsp/debug/dm81xx_configuro/pack
    age/cfg/DspAppMain_pe674.xdl > /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/dm81xx/obj/ti816x-evm/c6xdsp/debug/dm81xx_configuro/li
    nker_mod.cmd
    # Configuro done!
    make[2]: Leaving directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/dm81xx'
    # Building dm81xx executable for core: c6xdsp
    make -C /usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/dm81xx CORE=c6xdsp
    # Making ti816x-evm:c6xdsp:debug:memcfg...
    # Making ti816x-evm:c6xdsp:debug:domx...
    # Making ti816x-evm:c6xdsp:debug:domx_delegates_shmem...
    # Making ti816x-evm:c6xdsp:debug:omxcore...
    # Making ti816x-evm:c6xdsp:debug:vlpb...
    make -C /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/omx/comp/vlpb
    make[3]: Entering directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/omx/comp/vlpb'
    make[3]: Leaving directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/omx/comp/vlpb'
    # Making ti816x-evm:c6xdsp:debug:adec...
    make -C /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/omx/comp/adec
    make[3]: Entering directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/omx/comp/adec'
    make[3]: Leaving directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/omx/comp/adec'
    # Making ti816x-evm:c6xdsp:debug:aenc...
    make -C /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/omx/comp/aenc
    make[3]: Entering directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/omx/comp/aenc'
    make[3]: Leaving directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/omx/comp/aenc'
    # Linking into /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/dm81xx/bin/ti816x-evm/dm81xx_c6xdsp_debug.xe674
    cd /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/dm81xx/obj/ti816x-evm/c6xdsp/debug && /usr/local/ezsdk/dsp-devkit/cgt6x_7_3_4/bin/
    lnk6x --warn_sections -q -e=_c_int00 --silicon_version=6740 -c  --dynamic  -x --zero_init=off --retain=_Ipc_ResetVector     /usr/local/ezsdk
    /component-sources/omx_05_02_00_48/bin/dm81xx/obj/ti816x-evm/c6xdsp/debug/main_c674.oe674  /usr/local/ezsdk/component-sources/omx_05_02_00_4
    8/bin/dm81xx/obj/ti816x-evm/c6xdsp/debug/platform_c674.oe674  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/dm81xx/obj/ti816x-evm/c
    6xdsp/debug/configureDspUiaLogger.oe674  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/dm81xx/obj/ti816x-evm/c6xdsp/debug/memtbl_cf
    g.oe674  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/dm81xx/obj/ti816x-evm/c6xdsp/debug/domx_cfg.oe674  /usr/local/ezsdk/componen
    t-sources/omx_05_02_00_48/bin/dm81xx/obj/ti816x-evm/c6xdsp/debug/domxProxyWrappers.oe674  /usr/local/ezsdk/component-sources/omx_05_02_00_48
    /bin/dm81xx/obj/ti816x-evm/c6xdsp/debug/domx_delegates_shmem_cfg.oe674  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/dm81xx/obj/ti
    816x-evm/c6xdsp/debug/omxcore_cfg.oe674 /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/dm81xx/obj/ti816x-evm/c6xdsp/debug/DspAppMain
    _pe674.oe674 /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/dm81xx/obj/ti816x-evm/c6xdsp/debug/dm81xx_configuro/linker_mod.cmd -o /u
    sr/local/ezsdk/component-sources/omx_05_02_00_48/bin/dm81xx/bin/ti816x-evm/dm81xx_c6xdsp_debug.xe674 -m /usr/local/ezsdk/component-sources/o
    mx_05_02_00_48/bin/dm81xx/bin/ti816x-evm/dm81xx_c6xdsp_debug.xe674.map -l/usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/ti/omx/memcf
    g/lib/c6xdsp/debug/memcfg.ae674 -l/usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/ti/omx/domx/lib/c6xdsp/debug/domx.ae674 -l/usr/loca
    l/ezsdk/component-sources/omx_05_02_00_48/bin/ti/omx/domx/delegates/shmem/lib/c6xdsp/debug/domx_delegates_shmem.ae674 -l/usr/local/ezsdk/com
    ponent-sources/omx_05_02_00_48/bin/ti/omx/omxcore/lib/c6xdsp/debug/omxcore.ae674 -l/usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/ti
    /omx/comp/vlpb/lib/c674/debug/vlpb.ae674 -l/usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/ti/omx/comp/adec/lib/c674/debug/adec.ae674
     -l/usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/ti/omx/comp/aenc/lib/c674/debug/aenc.ae674 -l/usr/local/ezsdk/dsp-devkit/cgt6x_7_3
    _4/lib/rts6740_elf.lib -l/usr/local/ezsdk/component-sources/omx_05_02_00_48/src/ti/omx/omxutils/lib/debug/omxutils.ae674 -l/usr/local/ezsdk/
    component-sources/omx_05_02_00_48/src/ti/omx/comp/omxbase/lib/c6xdsp/debug/omxbase.ae674 -l/usr/local/ezsdk/component-sources/omx_05_02_00_4
    8/src/ti/omx/comp/omxbase/lib/c6xdsp/debug/omxbase_cfg.oe674
    # /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/dm81xx/bin/ti816x-evm/dm81xx_c6xdsp_debug.xe674 created.
    # Building decode executable for core: a8host
    make -C /usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/decode CORE=a8host
    make[2]: Entering directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/decode'
    # Linking into /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/decode/bin/ti816x-evm/decode_a8host_debug.xv5T
    _48/bin/decode/obj/ti816x-evm/a8host/debug/main.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/decode/obj/ti816x-evm/a8host/de
    bug/msgq.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/decode/obj/ti816x-evm/a8host/debug/decode_test.ov5T  /usr/local/ezsdk/
    component-sources/omx_05_02_00_48/bin/decode/obj/ti816x-evm/a8host/debug/decode_utils.ov5T   /usr/local/ezsdk/component-sources/omx_05_02_00
    _48/src/../lib/omxcore.av5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/memcfg.av5T /usr/local/ezsdk/component-sources/omx
    _05_02_00_48/src/../lib/domx.av5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/domx_delegates_shmem.av5T /usr/local/ezsdk/c
    omponent-sources/omx_05_02_00_48/src/../lib/timmosal.av5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/omxcfg.av5T /usr/loc
    al/ezsdk/component-sources/osal_1_22_01_09/packages/linuxdist/build/lib/osal.a /usr/local/ezsdk/component-sources/osal_1_22_01_09/packages/l
    inuxdist/cstubs/lib/cstubs.a /usr/local/ezsdk/component-sources/framework_components_3_22_01_07/packages/ti/sdo/rcm/lib/debug/rcm_syslink.av
    5T /usr/local/ezsdk/component-sources/framework_components_3_22_01_07/packages/ti/sdo/fc/memutils/lib/release/memutils.av5T /usr/local/ezsdk
    /component-sources/osal_1_22_01_09/packages/ti/sdo/xdcruntime/linux/lib/debug/osal_linux_470.av5T /usr/local/ezsdk/component-sources/framewo
    rk_components_3_22_01_07/packages/ti/sdo/fc/global/lib/debug/fcsettings.av5T /usr/local/ezsdk/component-sources/syslink_2_20_02_20/packages/
    ti/syslink/lib/syslink.a_debug /usr/local/ezsdk/component-sources/linuxutils_3_22_00_02/packages/ti/sdo/linuxutils/cmem/lib/cmem.a470MV /usr
    /local/ezsdk/component-sources/uia_1_01_01_14/packages/ti/uia/linux/lib/servicemgr.a -lpthread -lrt -L/root/CodeSourcery/Sourcery_G++_Lite//
    arm-none-linux-gnueabi/lib      -Xlinker --end-group -o /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/decode/bin/ti816x-evm/decode_
    a8host_debug.xv5T
    # /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/decode/bin/ti816x-evm/decode_a8host_debug.xv5T created.
    make[2]: Leaving directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/decode'
    # Building display executable for core: a8host
    make -C /usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/display CORE=a8host
    make[2]: Entering directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/display'
    # Linking into /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/display/bin/ti816x-evm/display_a8host_debug.xv5T
    _48/bin/display/obj/ti816x-evm/a8host/debug/main.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/display/obj/ti816x-evm/a8host/
    debug/msgq.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/display/obj/ti816x-evm/a8host/debug/ilclient.ov5T  /usr/local/ezsdk/
    component-sources/omx_05_02_00_48/bin/display/obj/ti816x-evm/a8host/debug/ilclient_utils.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_
    00_48/bin/display/obj/ti816x-evm/a8host/debug/semp.ov5T   /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/omxcore.av5T /usr/lo
    cal/ezsdk/component-sources/omx_05_02_00_48/src/../lib/memcfg.av5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/domx.av5T /
    usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/domx_delegates_shmem.av5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/sr
    c/../lib/timmosal.av5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/omxcfg.av5T /usr/local/ezsdk/component-sources/osal_1_2
    2_01_09/packages/linuxdist/build/lib/osal.a /usr/local/ezsdk/component-sources/osal_1_22_01_09/packages/linuxdist/cstubs/lib/cstubs.a /usr/l
    ocal/ezsdk/component-sources/framework_components_3_22_01_07/packages/ti/sdo/rcm/lib/debug/rcm_syslink.av5T /usr/local/ezsdk/component-sourc
    es/framework_components_3_22_01_07/packages/ti/sdo/fc/memutils/lib/release/memutils.av5T /usr/local/ezsdk/component-sources/osal_1_22_01_09/
    packages/ti/sdo/xdcruntime/linux/lib/debug/osal_linux_470.av5T /usr/local/ezsdk/component-sources/framework_components_3_22_01_07/packages/t
    i/sdo/fc/global/lib/debug/fcsettings.av5T /usr/local/ezsdk/component-sources/syslink_2_20_02_20/packages/ti/syslink/lib/syslink.a_debug /usr
    /local/ezsdk/component-sources/linuxutils_3_22_00_02/packages/ti/sdo/linuxutils/cmem/lib/cmem.a470MV /usr/local/ezsdk/component-sources/uia_
    1_01_01_14/packages/ti/uia/linux/lib/servicemgr.a -lpthread -lrt -L/root/CodeSourcery/Sourcery_G++_Lite//arm-none-linux-gnueabi/lib      -Xl
    inker --end-group -o /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/display/bin/ti816x-evm/display_a8host_debug.xv5T
    # /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/display/bin/ti816x-evm/display_a8host_debug.xv5T created.
    make[2]: Leaving directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/display'
    # Building decode_display executable for core: a8host
    make -C /usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/decode_display CORE=a8host
    make[2]: Entering directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/decode_display'
    # Linking into /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/decode_display/bin/ti816x-evm/decode_display_a8host_debug.xv5T
    _48/bin/decode_display/obj/ti816x-evm/a8host/debug/main.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/decode_display/obj/ti81
    6x-evm/a8host/debug/msgq.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/decode_display/obj/ti816x-evm/a8host/debug/platform_ut
    ils.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/decode_display/obj/ti816x-evm/a8host/debug/Fb_blending.ov5T  /usr/local/ezs
    dk/component-sources/omx_05_02_00_48/bin/decode_display/obj/ti816x-evm/a8host/debug/ilclient.ov5T  /usr/local/ezsdk/component-sources/omx_05
    _02_00_48/bin/decode_display/obj/ti816x-evm/a8host/debug/ilclient_utils.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/decode_
    display/obj/ti816x-evm/a8host/debug/es_parser.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/decode_display/obj/ti816x-evm/a8h
    ost/debug/semp.ov5T   /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/omxcore.av5T /usr/local/ezsdk/component-sources/omx_05_0
    2_00_48/src/../lib/memcfg.av5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/domx.av5T /usr/local/ezsdk/component-sources/om
    x_05_02_00_48/src/../lib/domx_delegates_shmem.av5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/timmosal.av5T /usr/local/ez
    sdk/component-sources/omx_05_02_00_48/src/../lib/omxcfg.av5T /usr/local/ezsdk/component-sources/osal_1_22_01_09/packages/linuxdist/build/lib
    /osal.a /usr/local/ezsdk/component-sources/osal_1_22_01_09/packages/linuxdist/cstubs/lib/cstubs.a /usr/local/ezsdk/component-sources/framewo
    rk_components_3_22_01_07/packages/ti/sdo/rcm/lib/debug/rcm_syslink.av5T /usr/local/ezsdk/component-sources/framework_components_3_22_01_07/p
    ackages/ti/sdo/fc/memutils/lib/release/memutils.av5T /usr/local/ezsdk/component-sources/osal_1_22_01_09/packages/ti/sdo/xdcruntime/linux/lib
    /debug/osal_linux_470.av5T /usr/local/ezsdk/component-sources/framework_components_3_22_01_07/packages/ti/sdo/fc/global/lib/debug/fcsettings
    .av5T /usr/local/ezsdk/component-sources/syslink_2_20_02_20/packages/ti/syslink/lib/syslink.a_debug /usr/local/ezsdk/component-sources/linux
    utils_3_22_00_02/packages/ti/sdo/linuxutils/cmem/lib/cmem.a470MV /usr/local/ezsdk/component-sources/uia_1_01_01_14/packages/ti/uia/linux/lib
    /servicemgr.a -lpthread -lrt -L/root/CodeSourcery/Sourcery_G++_Lite//arm-none-linux-gnueabi/lib      -Xlinker --end-group -o /usr/local/ezsd
    # /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/decode_display/bin/ti816x-evm/decode_display_a8host_debug.xv5T created.
    make[2]: Leaving directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/decode_display'
    # Building capture_encode executable for core: a8host
    make -C /usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/capture_encode CORE=a8host
    make[2]: Entering directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/capture_encode'
    # Linking into /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/capture_encode/bin/ti816x-evm/capture_encode_a8host_debug.xv5T
    _48/bin/capture_encode/obj/ti816x-evm/a8host/debug/main.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/capture_encode/obj/ti81
    6x-evm/a8host/debug/msgq.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/capture_encode/obj/ti816x-evm/a8host/debug/platform_ut
    ils.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/capture_encode/obj/ti816x-evm/a8host/debug/ilclient.ov5T  /usr/local/ezsdk/
    component-sources/omx_05_02_00_48/bin/capture_encode/obj/ti816x-evm/a8host/debug/ilclient_utils.ov5T  /usr/local/ezsdk/component-sources/omx
    _05_02_00_48/bin/capture_encode/obj/ti816x-evm/a8host/debug/semp.ov5T   /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/omxcor
    e.av5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/memcfg.av5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../l
    ib/domx.av5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/domx_delegates_shmem.av5T /usr/local/ezsdk/component-sources/omx_
    05_02_00_48/src/../lib/timmosal.av5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/omxcfg.av5T /usr/local/ezsdk/component-so
    urces/osal_1_22_01_09/packages/linuxdist/build/lib/osal.a /usr/local/ezsdk/component-sources/osal_1_22_01_09/packages/linuxdist/cstubs/lib/c
    stubs.a /usr/local/ezsdk/component-sources/framework_components_3_22_01_07/packages/ti/sdo/rcm/lib/debug/rcm_syslink.av5T /usr/local/ezsdk/c
    omponent-sources/framework_components_3_22_01_07/packages/ti/sdo/fc/memutils/lib/release/memutils.av5T /usr/local/ezsdk/component-sources/os
    al_1_22_01_09/packages/ti/sdo/xdcruntime/linux/lib/debug/osal_linux_470.av5T /usr/local/ezsdk/component-sources/framework_components_3_22_01
    _07/packages/ti/sdo/fc/global/lib/debug/fcsettings.av5T /usr/local/ezsdk/component-sources/syslink_2_20_02_20/packages/ti/syslink/lib/syslin
    k.a_release /usr/local/ezsdk/component-sources/linuxutils_3_22_00_02/packages/ti/sdo/linuxutils/cmem/lib/cmem.a470MV /usr/local/ezsdk/compon
    ent-sources/uia_1_01_01_14/packages/ti/uia/linux/lib/servicemgr.a -lpthread -lrt -L/root/CodeSourcery/Sourcery_G++_Lite//arm-none-linux-gnue
    abi/lib      -Xlinker --end-group -o /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/capture_encode/bin/ti816x-evm/capture_encode_a8h
    ost_debug.xv5T
    # /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/capture_encode/bin/ti816x-evm/capture_encode_a8host_debug.xv5T created.
    make[2]: Leaving directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/capture_encode'
    # Building adec_snt executable for core: a8host
    make -C /usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/adec_snt CORE=a8host
    make[2]: Entering directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/adec_snt'
    # Linking into /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/adec_snt/bin/ti816x-evm/adec_snt_a8host_debug.xv5T
    _48/bin/adec_snt/obj/ti816x-evm/a8host/debug/main.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/adec_snt/obj/ti816x-evm/a8hos
    t/debug/msgq.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/adec_snt/obj/ti816x-evm/a8host/debug/ilclient_utils.ov5T  /usr/loc
    al/ezsdk/component-sources/omx_05_02_00_48/bin/adec_snt/obj/ti816x-evm/a8host/debug/ilclient.ov5T   /usr/local/ezsdk/component-sources/omx_0
    5_02_00_48/src/../lib/omxcore.av5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/memcfg.av5T /usr/local/ezsdk/component-sour
    ces/omx_05_02_00_48/src/../lib/domx.av5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/domx_delegates_shmem.av5T /usr/local/
    ezsdk/component-sources/omx_05_02_00_48/src/../lib/timmosal.av5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/omxcfg.av5T /
    usr/local/ezsdk/component-sources/osal_1_22_01_09/packages/linuxdist/build/lib/osal.a /usr/local/ezsdk/component-sources/osal_1_22_01_09/pac
    kages/linuxdist/cstubs/lib/cstubs.a /usr/local/ezsdk/component-sources/framework_components_3_22_01_07/packages/ti/sdo/rcm/lib/debug/rcm_sys
    link.av5T /usr/local/ezsdk/component-sources/framework_components_3_22_01_07/packages/ti/sdo/fc/memutils/lib/release/memutils.av5T /usr/loca
    l/ezsdk/component-sources/osal_1_22_01_09/packages/ti/sdo/xdcruntime/linux/lib/debug/osal_linux_470.av5T /usr/local/ezsdk/component-sources/
    framework_components_3_22_01_07/packages/ti/sdo/fc/global/lib/debug/fcsettings.av5T /usr/local/ezsdk/component-sources/syslink_2_20_02_20/pa
    ckages/ti/syslink/lib/syslink.a_debug /usr/local/ezsdk/component-sources/linuxutils_3_22_00_02/packages/ti/sdo/linuxutils/cmem/lib/cmem.a470
    MV /usr/local/ezsdk/component-sources/uia_1_01_01_14/packages/ti/uia/linux/lib/servicemgr.a /usr/local/ezsdk/linux-devkit/arm-none-linux-gnu
    eabi/usr/lib/libasound.so -lpthread -lrt -L/root/CodeSourcery/Sourcery_G++_Lite//arm-none-linux-gnueabi/lib      -Xlinker --end-group -o /us
    # /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/adec_snt/bin/ti816x-evm/adec_snt_a8host_debug.xv5T created.
    make[2]: Leaving directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/adec_snt'
    # Building c6xtest executable for core: a8host
    make -C /usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/c6xtest CORE=a8host
    make[2]: Entering directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/c6xtest'
    # Linking into /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/c6xtest/bin/ti816x-evm/c6xtest_a8host_debug.xv5T
    _48/bin/c6xtest/obj/ti816x-evm/a8host/debug/main.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/c6xtest/obj/ti816x-evm/a8host/
    debug/msgq.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/c6xtest/obj/ti816x-evm/a8host/debug/ilclient.ov5T  /usr/local/ezsdk/
    component-sources/omx_05_02_00_48/bin/c6xtest/obj/ti816x-evm/a8host/debug/ilclient_utils.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_
    00_48/bin/c6xtest/obj/ti816x-evm/a8host/debug/semp.ov5T   /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/omxcore.av5T /usr/lo
    inker --end-group -o /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/c6xtest/bin/ti816x-evm/c6xtest_a8host_debug.xv5T
    # /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/c6xtest/bin/ti816x-evm/c6xtest_a8host_debug.xv5T created.
    make[2]: Leaving directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/c6xtest'
    # Building encode executable for core: a8host
    make -C /usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/encode CORE=a8host
    make[2]: Entering directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/encode'
    # Linking into /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/encode/bin/ti816x-evm/encode_a8host_debug.xv5T
    _48/bin/encode/obj/ti816x-evm/a8host/debug/main.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/encode/obj/ti816x-evm/a8host/de
    bug/msgq.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/encode/obj/ti816x-evm/a8host/debug/ilclient.ov5T  /usr/local/ezsdk/com
    ponent-sources/omx_05_02_00_48/bin/encode/obj/ti816x-evm/a8host/debug/ilclient_utils.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_4
    8/bin/encode/obj/ti816x-evm/a8host/debug/semp.ov5T   /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/omxcore.av5T /usr/local/e
    zsdk/component-sources/omx_05_02_00_48/src/../lib/memcfg.av5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/domx.av5T /usr/l
    ocal/ezsdk/component-sources/omx_05_02_00_48/src/../lib/domx_delegates_shmem.av5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../
    lib/timmosal.av5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/omxcfg.av5T /usr/local/ezsdk/component-sources/osal_1_22_01_
    09/packages/linuxdist/build/lib/osal.a /usr/local/ezsdk/component-sources/osal_1_22_01_09/packages/linuxdist/cstubs/lib/cstubs.a /usr/local/
    ezsdk/component-sources/framework_components_3_22_01_07/packages/ti/sdo/rcm/lib/debug/rcm_syslink.av5T /usr/local/ezsdk/component-sources/fr
    amework_components_3_22_01_07/packages/ti/sdo/fc/memutils/lib/release/memutils.av5T /usr/local/ezsdk/component-sources/osal_1_22_01_09/packa
    ges/ti/sdo/xdcruntime/linux/lib/debug/osal_linux_470.av5T /usr/local/ezsdk/component-sources/framework_components_3_22_01_07/packages/ti/sdo
    /fc/global/lib/debug/fcsettings.av5T /usr/local/ezsdk/component-sources/syslink_2_20_02_20/packages/ti/syslink/lib/syslink.a_debug /usr/loca
    l/ezsdk/component-sources/linuxutils_3_22_00_02/packages/ti/sdo/linuxutils/cmem/lib/cmem.a470MV /usr/local/ezsdk/component-sources/uia_1_01_
    01_14/packages/ti/uia/linux/lib/servicemgr.a -lpthread -lrt -L/root/CodeSourcery/Sourcery_G++_Lite//arm-none-linux-gnueabi/lib      -Xlinker
     --end-group -o /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/encode/bin/ti816x-evm/encode_a8host_debug.xv5T
    # /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/encode/bin/ti816x-evm/encode_a8host_debug.xv5T created.
    make[2]: Leaving directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/encode'
    # Building audio_encode executable for core: a8host
    make -C /usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/audio_encode CORE=a8host
    make[2]: Entering directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/audio_encode'
    # Linking into /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/audio_encode/bin/ti816x-evm/audio_encode_a8host_debug.xv5T
    _48/bin/audio_encode/obj/ti816x-evm/a8host/debug/main.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/audio_encode/obj/ti816x-e
    vm/a8host/debug/msgq.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/audio_encode/obj/ti816x-evm/a8host/debug/ilclient_utils.ov
    5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/audio_encode/obj/ti816x-evm/a8host/debug/ilclient.ov5T  /usr/local/ezsdk/componen
    t-sources/omx_05_02_00_48/bin/audio_encode/obj/ti816x-evm/a8host/debug/semp.ov5T   /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/..
    /lib/omxcore.av5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/memcfg.av5T /usr/local/ezsdk/component-sources/omx_05_02_00_
    48/src/../lib/domx.av5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/domx_delegates_shmem.av5T /usr/local/ezsdk/component-s
    ources/omx_05_02_00_48/src/../lib/timmosal.av5T /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/omxcfg.av5T /usr/local/ezsdk/c
    omponent-sources/osal_1_22_01_09/packages/linuxdist/build/lib/osal.a /usr/local/ezsdk/component-sources/osal_1_22_01_09/packages/linuxdist/c
    stubs/lib/cstubs.a /usr/local/ezsdk/component-sources/framework_components_3_22_01_07/packages/ti/sdo/rcm/lib/debug/rcm_syslink.av5T /usr/lo
    cal/ezsdk/component-sources/framework_components_3_22_01_07/packages/ti/sdo/fc/memutils/lib/release/memutils.av5T /usr/local/ezsdk/component
    -sources/osal_1_22_01_09/packages/ti/sdo/xdcruntime/linux/lib/debug/osal_linux_470.av5T /usr/local/ezsdk/component-sources/framework_compone
    nts_3_22_01_07/packages/ti/sdo/fc/global/lib/debug/fcsettings.av5T /usr/local/ezsdk/component-sources/syslink_2_20_02_20/packages/ti/syslink
    /lib/syslink.a_debug /usr/local/ezsdk/component-sources/linuxutils_3_22_00_02/packages/ti/sdo/linuxutils/cmem/lib/cmem.a470MV /usr/local/ezs
    dk/component-sources/uia_1_01_01_14/packages/ti/uia/linux/lib/servicemgr.a /usr/local/ezsdk/linux-devkit/arm-none-linux-gnueabi/usr/lib/liba
    sound.so -lpthread -lrt -L/root/CodeSourcery/Sourcery_G++_Lite//arm-none-linux-gnueabi/lib      -Xlinker --end-group -o /usr/local/ezsdk/com
    # /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/audio_encode/bin/ti816x-evm/audio_encode_a8host_debug.xv5T created.
    make[2]: Leaving directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/audio_encode'
    # Building decode_mosaicdisplay executable for core: a8host
    make -C /usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/decode_mosaicdisplay CORE=a8host
    make[2]: Entering directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/decode_mosaicdisplay'
    # Linking into /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/decode_mosaicdisplay/bin/ti816x-evm/decode_mosaicdisplay_a8host_debug.
    xv5T
    _48/bin/decode_mosaicdisplay/obj/ti816x-evm/a8host/debug/main.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/decode_mosaicdisp
    lay/obj/ti816x-evm/a8host/debug/msgq.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/decode_mosaicdisplay/obj/ti816x-evm/a8host
    /debug/platform_utils.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/decode_mosaicdisplay/obj/ti816x-evm/a8host/debug/Fb_blend
    ing.ov5T  /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/decode_mosaicdisplay/obj/ti816x-evm/a8host/debug/ilclient.ov5T  /usr/local/
    ezsdk/component-sources/omx_05_02_00_48/bin/decode_mosaicdisplay/obj/ti816x-evm/a8host/debug/ilclient_utils.ov5T  /usr/local/ezsdk/component
    -sources/omx_05_02_00_48/bin/decode_mosaicdisplay/obj/ti816x-evm/a8host/debug/h264_parser.ov5T  /usr/local/ezsdk/component-sources/omx_05_02
    _00_48/bin/decode_mosaicdisplay/obj/ti816x-evm/a8host/debug/semp.ov5T   /usr/local/ezsdk/component-sources/omx_05_02_00_48/src/../lib/omxcor
    k.a_debug /usr/local/ezsdk/component-sources/linuxutils_3_22_00_02/packages/ti/sdo/linuxutils/cmem/lib/cmem.a470MV /usr/local/ezsdk/componen
    t-sources/uia_1_01_01_14/packages/ti/uia/linux/lib/servicemgr.a -lpthread -lrt -L/root/CodeSourcery/Sourcery_G++_Lite//arm-none-linux-gnueab
    i/lib      -Xlinker --end-group -o /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/decode_mosaicdisplay/bin/ti816x-evm/decode_mosaicd
    # /usr/local/ezsdk/component-sources/omx_05_02_00_48/bin/decode_mosaicdisplay/bin/ti816x-evm/decode_mosaicdisplay_a8host_debug.xv5T created.
    make[2]: Leaving directory `/usr/local/ezsdk/component-sources/omx_05_02_00_48/examples/ti/omx/demos/decode_mosaicdisplay'
      CCLD   lib/libtiomx.so
    The new example doesn't appear.
    BR,
    Inigo
    These changes is working for me.
    omx_src folder contained the make files which is adding decode_display_test1. The path is: <component-sources/omx_05_02_00_48/src>
    example folder contained the make files which is adding decode_display_test1. The path is </component-sources/omx_05_02_00_48/examples>
    display_decode_test1 folder contained the make file for the example which I want to make.
    2860.makefiles.tar.gz
    BR
    Margarita
    It doesn't work for me. Maybe it is because my versions are:
    Linux: ubuntu 11.10 LTS 32 bits
    EZSDK: 5_05_02_00_dm816x
    OMX: 05_02_00_48
    BR
    Inigo
    Could you tell me the name of the folder and the the APP_NAME?
    It wold be better if you attach me the makefile in the example's folder which you want to build and I will change the makefiles.
    BR
    Margarita
  • Thanks Margarita,
    Finally it works!!
    BR,
    Inigo
  • I am glad that this issue is solved.
    Margarita
