• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » OMAP™ Processors » OMAP35x Processors Forum » TIImgenc1 problems after first frame
Share
OMAP™ Processors
  • Forums
  • Announcements
Options
  • Subscribe via RSS
Resources
  • OMAP-L1x DSP+ARM9™-based Processors Product Folder
  • OMAP3525/30 DSP+ARM Cortex™-A8-based SOCs Product Folder
  • Top OMAPL Wiki Links
  • OMAPL3x Schematic Review Checklist
  • OMAPL13x Boot resources
  • OMAPL Document Resources
  • OMAPL137 Technical reference manual
  • OMAPL138 Technical reference manual
  • OMAPL Boot loader App Notes
  • TIImgenc1 problems after first frame
    This question is not answered
    chrisw957
    Posted by chrisw957
    on Oct 04 2011 19:43 PM
    Intellectual430 points
    I'm having problems sending multiple frames thru TIImgenc1 element to jpeg encode them.  I've tried this on omap3530 and dm3730 (Overo gumstix and BB-xm), using the current dvsdk.
    Here is an example pipeline:
    gst-launch -v videotestsrc pattern=snow num-buffers=5 ! TIImgenc1 iColorSpace=UYVY  oColorSpace=YUV420P qValue=75 numOutputBufs=3 genTimeStamps=1 ! fakesink
    You will see from the output of fakesink, that the first frame from the jpeg encoder is correct, but all subsequent frames are around 570 bytes.
    I've tried turning on debug messages from gst and codec engine, but I can't figure out the cause.
    This was also reported here:
    https://gforge.ti.com/gf/project/gstreamer_ti/forum/?action=ForumBrowse&forum_id=187&thread_id=3754&_forum_action=ForumMessageBrowse
    Any help?
    /GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = "chain   ******* < (43468 bytes, timestamp: 0:00:00.000000000, duration: 0:00:00.033333333, offset: -1, offset_end: -1, flags: 0) 0x2a708"
    New clock: GstSystemClock
    /GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = "chain   ******* < (  575 bytes, timestamp: 0:00:00.033333333, duration: 0:00:00.033333333, offset: -1, offset_end: -1, flags: 0) 0x117020"
    /GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = "chain   ******* < (  573 bytes, timestamp: 0:00:00.066666666, duration: 0:00:00.033333333, offset: -1, offset_end: -1, flags: 0) 0x1170e0"
    /GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = "chain   ******* < (  573 bytes, timestamp: 0:00:00.099999999, duration: 0:00:00.033333333, offset: -1, offset_end: -1, flags: 0) 0x1171a0"
    /GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = "chain   ******* < (  573 bytes, timestamp: 0:00:00.133333332, duration: 0:00:00.033333333, offset: -1, offset_end: -1, flags: 0) 0x117260"
    omap3530 codec server codecs
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • chrisw957
      Posted by chrisw957
      on Oct 10 2011 20:39 PM
      Does anyone have any input on this issue?
      Thanks.
      Report Abuse
      • Reply
    • mike soso
      Posted by mike soso
      on Oct 11 2011 07:25 AM
      Intellectual810 points
      Hi Chris,
      I have the same problem as you.
      Take a look at : http://e2e.ti.com/support/embedded/f/354/p/134076/486099.aspx
      Maybe you will be more lllucky than i am. Let me know if you find a solution !
      Report Abuse
      • Reply
    • chrisw957
      Posted by chrisw957
      on Oct 11 2011 09:06 AM
      I noticed in your example pipeline from the other thread you didn't have numOutputBufs=3.  Without this, my pipeline stalls.  When it is added, the pipeline runs, but outputs garbage after the first frame.
      So the comment about buffers not being freed may relate to that, and be a totally different issue.  I would think a buffer allocation problem would result in nothing coming out of the pipeline rather than bad data?  I need to run again with more debug turned on and attach the output here.
      thanks.
      Report Abuse
      • Reply
    • mike soso
      Posted by mike soso
      on Oct 11 2011 09:43 AM
      Chris,
      I investigate our problem with this cmd line :
      CE_DEBUG=3 GST_DEBUG=5 gst-launch videotestsrc -v ! 'video/x
      -raw-yuv, width=320 , height=240, format=(fourcc)UYVY' ! TIImgenc1 engineName=co
      decServer codecName=jpegenc iColorSpace=UYVY oColorSpace=YUV420P qValue=75 numOu
      tputBufs=3 resolution=320x240 frameRate=30 displayBuffer=TRUE genTimeStamps=TRUE
       ! fakesink
      I noticed only this mistake :
      [ColorSpace] Unknown color space format (4) during Ienc1_process...
      Report Abuse
      • Reply
    • mike soso
      Posted by mike soso
      on Oct 11 2011 11:31 AM
      This patch has corrected my format bug :
      https://gforge.ti.com/gf/project/gstreamer_ti/tracker/?action=TrackerItemEdit&tracker_item_id=1043
      gst-launch -v videotestsrc ! TIImgenc1 engineName=codecServe
      r codecName=jpegenc ! fakesink
      But i still have the same problem as above :
      Pipeline is PREROLLED ...
      Setting pipeline to PLAYING ...
      /GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = "chain   ******* < ( 8235 bytes, timestamp: none, duration: n
      one, offset: -1, offset_end: -1, flags: 0) 0x128ce8"
      /GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = "chain   ******* < (  575 bytes, timestamp: none, duration: n
      one, offset: -1, offset_end: -1, flags: 0) 0x128db8"
      /GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = "chain   ******* < (  573 bytes, timestamp: none, duration: n
      one, offset: -1, offset_end: -1, flags: 0) 0x128e88"
      Any advice ???
      Report Abuse
      • Reply
    • mike soso
      Posted by mike soso
      on Dec 16 2011 03:54 AM
      I needed to make Mjpeg encoding.
      I resolved this issue by modifing 3 files (I don't why we lost the params config but for now it's resolve our problem, already it's not an optimize solution...) :
      Modifing TIImgenc1 in encode_thread function :
              /*re-set of params because we lost them*/
              imgenc1->hIe = Ienc1_control(imgenc1->hIe,&imgenc1->dynParams);
              /* Invoke the image encoder */
              GST_LOG("invoking the image encoder\n");
              ret             = Ienc1_process(imgenc1->hIe, imgenc1->hInBuf, hDstBuf);
      Adding Ienc1_control function in Ienc1.c in DMAI to re-set params :
       * Ienc1_control
      Ienc1_Handle Ienc1_control(Ienc1_Handle hIe, IMGENC1_DynamicParams *dynParams)
          IMGENC1_Handle       hEncode;
          IMGENC1_Status       encStatus;
          XDAS_Int32           status;
          hEncode = Ienc1_getVisaHandle(hIe);
           /* Set dynamic parameters */
           encStatus.data.buf = NULL;
           encStatus.size = sizeof(IMGENC1_Status);
           status = IMGENC1_control(hEncode, XDM_SETPARAMS, dynParams, &encStatus);
              if (status != IMGENC1_EOK) {
                  Dmai_err1("XDM_SETPARAMS failed, status=%d\n", status);
                  IMGENC1_delete(hEncode);
                  free(hIe);
                  return NULL;
          return hIe;
      In Ienc1.h adding declaration:
      extern Ienc1_Handle Ienc1_control(Ienc1_Handle hIe,
                                      IMGENC1_DynamicParams *dynParams);
      I'm working on gstreamer_svn 962 on a DM6467T.
      If someone can give me return about my modification !
      gstreamer
      Report Abuse
      • Reply
    • mike soso
      Posted by mike soso
      on Dec 16 2011 04:03 AM
      I forgot to say what you need to recompile DMAI before recompile gstreamer_ti !
      I tried with success the TIImgenc1 with color input : UYVY and YUV420P.
      Report Abuse
      • Reply
    • JanR
      Posted by JanR
      on Dec 19 2011 10:33 AM
      Prodigy10 points
      I had the same problem on a DM6446 with the dmaienc_mjpeg element from the DDOMPE branch. The fix works there as well, with a slight modification:
      In gstimgenc1.c I added:
        dmaienc->hCodec = Ienc1_control(dmaienc->hCodec,(IMGENC1_DynamicParams*)dmaienc->dynParams);
       and modified Ienc1.c/h according to the post.
      Jan
      Report Abuse
      • Reply
    • ayhan kilinc
      Posted by ayhan kilinc
      on Dec 27 2011 07:13 AM
      Prodigy20 points
      I had the same problem. I changed dmai and gstreamer-ti code as shown above. It is working well. But when I use "TIImgenc1" in QT application, it stops after first frame. Any idea?
      Report Abuse
      • Reply
    • mike soso
      Posted by mike soso
      on Dec 27 2011 11:36 AM
      Personaly i have not expérience with gstreamer on Qt. If it s work with gstreamer maybe it is a multithread gestion problem or try to use Dmai_debug=2 in the beggining of your pipeline to have more debug info. Mika
      Report Abuse
      • Reply
    • chrisw957
      Posted by chrisw957
      on Jan 15 2012 15:33 PM
      I can confirm that this fixed the problem for me as well.  I'm using DDOMPE branch of the ti plugin.
      Thanks for posting this!
      Report Abuse
      • Reply
    • Vivek Jain
      Posted by Vivek Jain
      on Aug 07 2012 17:58 PM
      Prodigy90 points
      I am using DM3730 with DVSDK 4.02. I want to encode NTSC input into MJPEG using DSP. I tried the above changes as suggested but they did not work for me. I can only see first frame and no JPEG frame afterwards. Following is the output:
      gst-launch-0.10 v4l2src device=/dev/video0 -v !\
       video/x-raw-yuv,format=\(fourcc\)UYVY,framerate=\(fraction\)30000/1001,width=720,height=480 !\
       TIImgenc1 engineName=codecServer codecName=jpegenc iColorSpace=UYVY oColorSpace=YUV420P qValue=75 numOutputBufs=3 genTimeStamps=1 displayBuffer=true !\
       fakesink
      /GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw-yuv, format=(fourcc)UYVY, framerate=(fraction)30000/1001, width=(int)720, height=(int)480
      Pipeline is live and does not need PREROLL ...
      /GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw-yuv, format=(fourcc)UYVY, framerate=(fraction)30000/1001, width=(int)720, height=(int)480
      /GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw-yuv, format=(fourcc)UYVY, framerate=(fraction)30000/1001, width=(int)720, height=(int)480
      /GstPipeline:pipeline0/GstTIImgenc1:tiimgenc10.GstPad:sink: caps = video/x-raw-yuv, format=(fourcc)UYVY, framerate=(fraction)30000/1001, width=(int)720, height=(int)480
      [R=====================================W                                      ] [                                      B                                     |]
      /GstPipeline:pipeline0/GstTIImgenc1:tiimgenc10.GstPad:src: caps = video/x-jpeg, framerate=(fraction)30000/1001, width=(int)720, height=(int)480
      /GstPipeline:pipeline0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-jpeg, framerate=(fraction)30000/1001, width=(int)720, height=(int)480
      /GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = "preroll   ******* "
      /GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = "event   ******* E (type: 102, GstEventNewsegment, update=(boolean)false, rate=(double)1, applied-rate=(double)1, format=(GstFormat)GST_FORMAT_TIME, start=(gint64)0, stop=(gint64)-1, position=(gint64)0;) 0xf1920"
      /GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = "chain   ******* < (37187 bytes, timestamp: 0:00:00.067413330, duration: 0:00:00.033366666, offset: -1, offset_end: -1, flags: 0) 0x2ab08"
      [                                      R=====================================W] [        B]
      /GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = "chain   ******* < (  575 bytes, timestamp: 0:00:00.100779996, duration: 0:00:00.033366666, offset: -1, offset_end: -1, flags: 0) 0x104808"
      [--------------------------------------W                                     R] [                                      B                                     |]
      /GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = "chain   ******* < (  573 bytes, timestamp: 0:00:00.134146662, duration: 0:00:00.033366666, offset: -1, offset_end: -1, flags: 0) 0x1048c8"
      /GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = "chain   ******* < (  573 bytes, timestamp: 0:00:00.167513328, duration: 0:00:00.033366666, offset: -1, offset_end: -1, flags: 0) 0x104988"
      Applying all changes, compiling & installing dmai, compiling & installing gstreamer
      /GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = "chain   ******* < (36972 bytes, timestamp: 0:00:00.069549562, duration: 0:00:00.033366666, offset: -1, offset_end: -1, flags: 0) 0x2ab08"
      /GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = "chain   ******* < (  575 bytes, timestamp: 0:00:00.102916228, duration: 0:00:00.033366666, offset: -1, offset_end: -1, flags: 0) 0x104808"
      /GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = "chain   ******* < (  573 bytes, timestamp: 0:00:00.136282894, duration: 0:00:00.033366666, offset: -1, offset_end: -1, flags: 0) 0x1048c8"
      /GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = "chain   ******* < (  573 bytes, timestamp: 0:00:00.169649560, duration: 0:00:00.033366666, offset: -1, offset_end: -1, flags: 0) 0x104988"
      Following is the output when I encode using ARM:
       jpegenc quality=75 ! fakesink
      /GstPipeline:pipeline0/GstJpegEnc:jpegenc0.GstPad:src: caps = image/jpeg, width=(int)720, height=(int)480, framerate=(fraction)30000/1001, pixel-aspect-ratio=(fraction)1/1
      /GstPipeline:pipeline0/GstJpegEnc:jpegenc0.GstPad:sink: caps = video/x-raw-yuv, format=(fourcc)UYVY, framerate=(fraction)30000/1001, width=(int)720, height=(int)480
      /GstPipeline:pipeline0/GstFakeSink:fakesink0.GstPad:sink: caps = image/jpeg, width=(int)720, height=(int)480, framerate=(fraction)30000/1001, pixel-aspect-ratio=(fraction)1/1
      /GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = "event   ******* E (type: 102, GstEventNewsegment, update=(boolean)false, rate=(double)1, applied-rate=(double)1, format=(GstFormat)GST_FORMAT_TIME, start=(gint64)0, stop=(gint64)-1, position=(gint64)0;) 0xfa520"
      /GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = "chain   ******* < (43304 bytes, timestamp: 0:00:00.075195313, duration: 0:00:00.000000000, offset: 0, offset_end: 1, flags: 0) 0xf62d0"
      /GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = "chain   ******* < (40952 bytes, timestamp: 0:00:00.132659912, duration: 0:00:00.000000000, offset: 1, offset_end: 2, flags: 0) 0xf6380"
      /GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = "chain   ******* < (40836 bytes, timestamp: 0:00:00.183685304, duration: 0:00:00.000000000, offset: 2, offset_end: 3, flags: 0) 0xfe860"
      /GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = "chain   ******* < (41120 bytes, timestamp: 0:00:00.233337404, duration: 0:00:00.000000000, offset: 3, offset_end: 4, flags: 0) 0xfe910"
      However, for better speed I want to use DSP for encoding and not ARM processor. With ARM processor the output frame rate decreases as quality increases due to endcoding delays. Please let me know how to solve this issue.
      TIImgenc1
      Report Abuse
      • Reply
    • mike soso
      Posted by mike soso
      on Aug 08 2012 03:46 AM
      Hi Vivek Jain,
      Try to use DMAI_DEBUG=2 or CE_DEBUG=3 in the begginning of your pipeline (ex: DMAI_DEBUG=2 gst-launch ....) to check if call Ienc1_control and if the SETPARAMS is called to.
      I don't see other issue, only you are not re-setting the codec dynparams after the process call.
      Mika
      Report Abuse
      • Reply
    • Vivek Jain
      on Aug 08 2012 18:17 PM
      Prodigy90 points
      Hi Mike,
      Thank you for your prompt response. The solution worked for me as well. We are using gstreamer svn 962 version and not the one which came with the kit. So, when I compiled and installed gstreamer, all files were installed in gstreamer and gstreamer_demo folders in /opt directory, however, the executable were running from old installation. So, I set the path variables correctly and the only error left was 'cs.x64P not found' for which I created the symbolic link to the actual file and everything worked.
      Vivek
      Report Abuse
      • Reply
    • Vivek Jain
      on Aug 17 2012 19:36 PM
      Prodigy90 points
      Many times after stopping the gstreamer, when I start again, I get the following error:
      ERROR: Pipeline doesn't want to pause.
      ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not get bu ffers from device '/dev/video0'.
      Additional debug info: gstv4l2bufferpool.c(390): gst_v4l2_buffer_pool_new (): /GstPipeline:pipeline0/Gs tV4l2Src:v4l2src0:
      error requesting 2 buffers: Device or resource busy
      Setting pipeline to NULL ...
      Freeing pipeline ...
      Looks like buffers are not released properly when we stop the gstreamer by presssing crtl+c. (This problem does not arrises when I use ARM, jpegenc to do MJPEG encoding). Please let me know how to solve this issue. I am using the following pipeline:
      gst-launch-0.10 v4l2src device=/dev/video0 -v always-copy=false !\
       TIImgenc1 engineName=codecServer codecName=jpegenc iColorSpace=UYVY oColorSpace=YUV420P qValue=75 resolution=720x480 numOutputBufs=3 genTimeStamps=1 displayBuffer=true !\
       rtpjpegpay pt=26 ! udpsink host=192.168.1.101 port=5000
      Report Abuse
      • Reply
    12
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
