how to loard the rts67plus.lib correctly and the differences between rts67plus.lib and rts6740.lib
     I  am using tms3206747 ,now i have two questions.
1.in the cmd file,when i write '-l rts67plus.lib' and select -mv674x in build options.there will be a link error (undefined symbols , first reffered).but when i select -mv6700 in build options,there is no error at all.
2.i don't know the differences between  rts67plus.lib and rts6740.lib . what are the use of these two libs,and whether are they necessary for my program.
thanks for reply!
    Make sure that you have CGT 6.1.9 or later:
    http://tiexpressdsp.com/index.php/-mv_option_to_use_with_the_C6747
    If that does not solve, please send the error that you getting.
     67plus library is the one made for the C67x+ floating point core. 64plus library is the one made for the C64x+ fixed point core.
    C6747 has an hybrid core that will run all the instruction from the C67x+ core PLUS all the instructions for the C64x+ plus core. So for C674x you should use the rts6740 be cause it is more efficient, but the 67plus and 64plus will work as well.
    [/quote]
    thanks ror your answer ! i want to know whether the 6740.lib is loaded  when i select -mv6740 in build options.then it is unnecessary to write '-l rts67plus.lib' in my cmd file.
    [/quote]
  • Unless you are using DSP/BIOS in your project (DSP/BIOS does it for you), you need to load the rts in your project. For C674x core you can use the rts6740.lib .
